[PATCH 3/3] libcsupport: Use POSIX keys for gxx-wrapper-key-functions.
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Mar 21 11:07:29 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
With this patch C++ applications now eventually need additional POSIX-keys and
POSIX-key-value-pairs configured.
 cpukit/libcsupport/include/rtems/gxx_wrappers.h |   8 +-
 cpukit/libcsupport/src/gxx_wrappers.c           | 111 +++++++++++-------------
 testsuites/libtests/gxx01/gxx01.scn             |   8 +-
 testsuites/libtests/gxx01/init.c                |  29 ++++++-
 testsuites/sptests/spfatal24/spfatal24.doc      |   2 +-
 testsuites/sptests/spfatal24/testcase.h         |   6 +-
 testsuites/sptests/sptls02/init.cc              |   3 +
 7 files changed, 89 insertions(+), 78 deletions(-)
diff --git a/cpukit/libcsupport/include/rtems/gxx_wrappers.h b/cpukit/libcsupport/include/rtems/gxx_wrappers.h
index 801223e..94502b9 100644
--- a/cpukit/libcsupport/include/rtems/gxx_wrappers.h
+++ b/cpukit/libcsupport/include/rtems/gxx_wrappers.h
@@ -36,14 +36,8 @@ extern "C" {
  * These typedefs should match with the ones defined in the file
  * gcc/gthr-rtems.h in the gcc distribution.
- * FIXME: T.S, 2007/01/31: -> gcc/gthr-rtems.h still declares
- *                            void * __gthread_key_t;
-typedef struct __gthread_key_ {
-	void *val; 	           /* this is switched with the task      */
-	void (*dtor)(void*);   /* this remains in place for all tasks */
-} __gthread_key, *__gthread_key_t;
+typedef void *__gthread_key_t;
 typedef int   __gthread_once_t;
 typedef void *__gthread_mutex_t;
 typedef void *__gthread_recursive_mutex_t;
diff --git a/cpukit/libcsupport/src/gxx_wrappers.c b/cpukit/libcsupport/src/gxx_wrappers.c
index 0b9cad6..963b712 100644
--- a/cpukit/libcsupport/src/gxx_wrappers.c
+++ b/cpukit/libcsupport/src/gxx_wrappers.c
@@ -31,6 +31,7 @@
 #include <rtems/gxx_wrappers.h>
 #include <rtems/score/onceimpl.h>
+#include <errno.h>
@@ -49,82 +50,64 @@ int rtems_gxx_once(__gthread_once_t *once, void (*func) (void))
 int rtems_gxx_key_create (__gthread_key_t *key, void (*dtor) (void *))
-  rtems_status_code status;
-  /* Ok, this can be a bit tricky. We are going to return a "key" as a
-   * pointer to the buffer that will hold the value of the key itself.
-   * We have to to this, because the others functions on this interface
-   * deal with the value of the key, as used with the POSIX API.
-   /* Do not pull your hair, trust me this works. :-) */
-  __gthread_key_t new_key = (__gthread_key_t) malloc( sizeof( *new_key ) );
-  *key = new_key;
-  new_key->val  = NULL;
-  new_key->dtor = dtor;
+  int eno;
+  pthread_key_t *pkey;
+  pkey = malloc( sizeof( *pkey ) );
+  *key = pkey;
+  if ( pkey == NULL )
+    return ENOMEM;
   #ifdef DEBUG_GXX_WRAPPERS
     printk(
-      "gxx_wrappers: create key=%x, dtor=%x, new_key=%x\n", key, dtor, new_key
+      "gxx_wrappers: create key=%x, dtor=%x, pkey=%x\n", key, dtor, pkey
   #endif
-  /* register with RTEMS the buffer that will hold the key values */
-  status = rtems_task_variable_add( RTEMS_SELF, (void **)new_key, dtor );
-  if ( status == RTEMS_SUCCESSFUL )
-    return 0;
+  eno = pthread_key_create(pkey, dtor);
+  if ( eno != 0 ) {
+    free( pkey );
+    *key = NULL;
-  free( new_key );
-  return -1;
+  return eno;
 int rtems_gxx_key_delete (__gthread_key_t key)
+  int eno = 0;
+  pthread_key_t *pkey = key;
-    printk( "gxx_wrappers: delete key=%x\n", key );
+    printk( "gxx_wrappers: delete key=%x\n", pkey );
   #endif
-  status = rtems_task_variable_delete( RTEMS_SELF, (void **)key );
-  if ( status == RTEMS_SUCCESSFUL ) {
-    /* Hmm - hopefully all tasks using this key have gone away... */
-    if ( key ) free( *(void **)key );
-    return 0;
+  if ( pkey == NULL ) {
+    return EINVAL;
-  key = NULL;
-  return 0;
+  eno = pthread_key_delete(*pkey);
+  if ( eno == 0 ) {
+    free( pkey );
+  return eno;
 void *rtems_gxx_getspecific(__gthread_key_t key)
-  void              *p= 0;
-  status = rtems_task_variable_get( RTEMS_SELF, (void **)key, &p );
-    /* We do not have to do this, but what the heck ! */
-     p= key->val;
-  } else {
-    /* fisrt time, always set to zero, it is unknown the value that the others
-     * threads are using at the moment of this call
-    status = rtems_task_variable_add( RTEMS_SELF, (void **)key, key->dtor );
-    if ( status != RTEMS_SUCCESSFUL ) {
-      _Terminate(
-        INTERNAL_ERROR_CORE,
-        true,
-        INTERNAL_ERROR_GXX_KEY_ADD_FAILED
-    key->val = (void *)0;
+  void *p = NULL;
+  if ( pkey != NULL ) {
+    p = pthread_getspecific( *pkey );
     printk(
       "gxx_wrappers: getspecific key=%x, ptr=%x, id=%x\n",
-       key,
+       pkey,
        p,
        rtems_task_self()
@@ -134,25 +117,33 @@ void *rtems_gxx_getspecific(__gthread_key_t key)
 int rtems_gxx_setspecific(__gthread_key_t key, const void *ptr)
+  int eno;
+    return EINVAL;
+  eno = pthread_setspecific( *pkey, ptr );
     printk(
       "gxx_wrappers: setspecific key=%x, ptr=%x, id=%x\n",
-      key,
+      pkey,
       ptr,
       rtems_task_self()
   #endif
-    /* now let's set the proper value */
-    key->val =  (void *)ptr;
-    return 0;
+  if ( eno != 0 ) {
+    _Terminate(
+      INTERNAL_ERROR_CORE,
+      true,
+      INTERNAL_ERROR_GXX_KEY_ADD_FAILED
-  return -1;
+  return 0;
diff --git a/testsuites/libtests/gxx01/gxx01.scn b/testsuites/libtests/gxx01/gxx01.scn
index cb9f6b5..f831881 100644
--- a/testsuites/libtests/gxx01/gxx01.scn
+++ b/testsuites/libtests/gxx01/gxx01.scn
@@ -22,10 +22,14 @@ Call once method the second time
 rtems_gxx_key_create(&key, NULL) - OK
 rtems_gxx_key_delete(key) - OK
 rtems_gxx_key_create(&key, key_dtor) - OK
-rtems_gxx_setspecific() - OK
+rtems_gxx_getspecific(key) not set - OK
+rtems_gxx_setspecific(key, 0x1234) - OK
 rtems_gxx_getspecific(key) already existing - OK
 rtems_gxx_getspecific(key) non-existent - OK
-rtems_gxx_key_delete(key) - OK
+rtems_gxx_key_delete(key) - NOT OK
+rtems_gxx_setspecific(NULL, 0x1234) - NOT OK
+rtems_gxx_getspecific(NULL) - OK
+rtems_gxx_key_delete(NULL) - NOT OK
 *** END OF TEST GXX 01 ***
diff --git a/testsuites/libtests/gxx01/init.c b/testsuites/libtests/gxx01/init.c
index cc704ef..5c7a3c1 100644
--- a/testsuites/libtests/gxx01/init.c
+++ b/testsuites/libtests/gxx01/init.c
@@ -11,6 +11,7 @@
 #include "config.h"
 #endif
+#include <errno.h>
 #include <tmacros.h>
 #include "test_support.h"
@@ -140,7 +141,11 @@ void test_key(void)
   sc = rtems_gxx_key_create(&key, key_dtor);
   rtems_test_assert( sc == 0 );
-  puts( "rtems_gxx_setspecific() - OK" );
+  puts( "rtems_gxx_getspecific(key) not set - OK" );
+  p = rtems_gxx_getspecific(key);
+  rtems_test_assert( p == NULL );
+  puts( "rtems_gxx_setspecific(key, 0x1234) - OK" );
   sc = rtems_gxx_setspecific(key, (void *)0x1234);
@@ -151,7 +156,8 @@ void test_key(void)
   puts( "rtems_gxx_key_delete(key) - OK" );
   sc = rtems_gxx_key_delete(key);
-  rtems_test_assert( key_dtor_ran == true );
+  /* pthread_key man-page: the dtor should _not_ be called */
+  rtems_test_assert( key_dtor_ran != true );
   key = calloc( 1, sizeof( *key ) );
   rtems_test_assert( key != NULL );
@@ -160,9 +166,21 @@ void test_key(void)
   p = rtems_gxx_getspecific( key );
-  puts( "rtems_gxx_key_delete(key) - OK" );
+  puts( "rtems_gxx_key_delete(key) - NOT OK" );
   sc = rtems_gxx_key_delete( key );
-  rtems_test_assert( sc == 0 );
+  rtems_test_assert( sc != 0 );
+  puts( "rtems_gxx_setspecific(NULL, 0x1234) - NOT OK" );
+  sc = rtems_gxx_setspecific( NULL, (void *)0x1234 );
+  rtems_test_assert( sc == EINVAL );
+  puts( "rtems_gxx_getspecific(NULL) - OK" );
+  p = rtems_gxx_getspecific( NULL );
+  puts( "rtems_gxx_key_delete(NULL) - NOT OK" );
+  sc = rtems_gxx_key_delete( NULL );
 rtems_task Init(
@@ -197,6 +215,9 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_SEMAPHORES   2
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_MAXIMUM_POSIX_KEYS            1
+#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 1
 #define CONFIGURE_INIT
 #include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spfatal24/spfatal24.doc b/testsuites/sptests/spfatal24/spfatal24.doc
index ad6eda5..0ff898d 100644
--- a/testsuites/sptests/spfatal24/spfatal24.doc
+++ b/testsuites/sptests/spfatal24/spfatal24.doc
@@ -12,7 +12,7 @@ test set name:  spfatal24
 directives:
-  rtems_gxx_getspecific();
+  rtems_gxx_setspecific();
 concepts:
diff --git a/testsuites/sptests/spfatal24/testcase.h b/testsuites/sptests/spfatal24/testcase.h
index 6ac8906..226ccc9 100644
--- a/testsuites/sptests/spfatal24/testcase.h
+++ b/testsuites/sptests/spfatal24/testcase.h
@@ -18,9 +18,7 @@
 void force_error()
-  __gthread_key key;
+  pthread_key_t key = -1;
-  rtems_workspace_greedy_allocate( NULL, 0 );
-  rtems_gxx_getspecific( &key );
+  rtems_gxx_setspecific( &key, NULL );
diff --git a/testsuites/sptests/sptls02/init.cc b/testsuites/sptests/sptls02/init.cc
index d704190..2c9e283 100644
--- a/testsuites/sptests/sptls02/init.cc
+++ b/testsuites/sptests/sptls02/init.cc
@@ -251,6 +251,9 @@ extern "C" void Init(rtems_task_argument arg)
+#define CONFIGURE_MAXIMUM_POSIX_KEYS 2
+#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 2
1.8.4.5
