[PATCH 3/3] libcsupport: Use POSIX keys for gxx-wrapper-key-functions.
Fri Mar 21 12:30:06 UTC 2014
On Fri, Mar 21, 2014 at 5:26 AM, Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
> With this patch C++ applications now eventually need additional POSIX-keys and
> POSIX-key-value-pairs configured.
I'm not sure where, but this fact should be somewhere in user documentation.
>  cpukit/libcsupport/include/rtems/gxx_wrappers.h |  10 +--
>  cpukit/libcsupport/src/gxx_wrappers.c           | 111 +++++++++++-------------
>  testsuites/libtests/gxx01/gxx01.scn             |   8 +-
>  testsuites/libtests/gxx01/init.c                |  29 ++++++-
>  testsuites/sptests/spfatal24/spfatal24.doc      |   2 +-
>  testsuites/sptests/spfatal24/testcase.h         |   6 +-
>  testsuites/sptests/sptls02/init.cc              |   3 +
>  7 files changed, 91 insertions(+), 78 deletions(-)
> diff --git a/cpukit/libcsupport/include/rtems/gxx_wrappers.h b/cpukit/libcsupport/include/rtems/gxx_wrappers.h
> index 801223e..0efb341 100644
> --- a/cpukit/libcsupport/include/rtems/gxx_wrappers.h
> +++ b/cpukit/libcsupport/include/rtems/gxx_wrappers.h
> @@ -21,6 +21,8 @@
>  #ifndef __GCC_WRAPPERS_h
>  #define __GCC_WRAPPERS_h
> +#include <pthread.h>
>  #ifdef __cplusplus
>  extern "C" {
>  #endif /* __cplusplus */
> @@ -36,14 +38,8 @@ extern "C" {
>   * These typedefs should match with the ones defined in the file
>   * gcc/gthr-rtems.h in the gcc distribution.
> - * FIXME: T.S, 2007/01/31: -> gcc/gthr-rtems.h still declares
> - *                            void * __gthread_key_t;
> -typedef struct __gthread_key_ {
> -       void *val;                 /* this is switched with the task      */
> -       void (*dtor)(void*);   /* this remains in place for all tasks */
> -} __gthread_key, *__gthread_key_t;
> +typedef void *__gthread_key_t;
>  typedef int   __gthread_once_t;
>  typedef void *__gthread_mutex_t;
>  typedef void *__gthread_recursive_mutex_t;
> diff --git a/cpukit/libcsupport/src/gxx_wrappers.c b/cpukit/libcsupport/src/gxx_wrappers.c
> index 0b9cad6..963b712 100644
> --- a/cpukit/libcsupport/src/gxx_wrappers.c
> +++ b/cpukit/libcsupport/src/gxx_wrappers.c
> @@ -31,6 +31,7 @@
>  #include <rtems/gxx_wrappers.h>
>  #include <rtems/score/onceimpl.h>
> +#include <errno.h>
>  #include <stdlib.h>
>  #include <rtems.h>
> @@ -49,82 +50,64 @@ int rtems_gxx_once(__gthread_once_t *once, void (*func) (void))
>  int rtems_gxx_key_create (__gthread_key_t *key, void (*dtor) (void *))
> -  rtems_status_code status;
> -  /* Ok, this can be a bit tricky. We are going to return a "key" as a
> -   * pointer to the buffer that will hold the value of the key itself.
> -   * We have to to this, because the others functions on this interface
> -   * deal with the value of the key, as used with the POSIX API.
> -   /* Do not pull your hair, trust me this works. :-) */
> -  __gthread_key_t new_key = (__gthread_key_t) malloc( sizeof( *new_key ) );
> -  *key = new_key;
> -  new_key->val  = NULL;
> -  new_key->dtor = dtor;
> +  int eno;
> +  pthread_key_t *pkey;
> +  pkey = malloc( sizeof( *pkey ) );
> +  *key = pkey;
> +  if ( pkey == NULL )
> +    return ENOMEM;
>    #ifdef DEBUG_GXX_WRAPPERS
>      printk(
> -      "gxx_wrappers: create key=%x, dtor=%x, new_key=%x\n", key, dtor, new_key
> +      "gxx_wrappers: create key=%x, dtor=%x, pkey=%x\n", key, dtor, pkey
>    #endif
> -  /* register with RTEMS the buffer that will hold the key values */
> -  status = rtems_task_variable_add( RTEMS_SELF, (void **)new_key, dtor );
> -  if ( status == RTEMS_SUCCESSFUL )
> -    return 0;
> +  eno = pthread_key_create(pkey, dtor);
> +  if ( eno != 0 ) {
> +    free( pkey );
> +    *key = NULL;
> -  free( new_key );
> -  return -1;
> +  return eno;
>  int rtems_gxx_key_delete (__gthread_key_t key)
> +  int eno = 0;
> +  pthread_key_t *pkey = key;
> -    printk( "gxx_wrappers: delete key=%x\n", key );
> +    printk( "gxx_wrappers: delete key=%x\n", pkey );
>    #endif
> -  status = rtems_task_variable_delete( RTEMS_SELF, (void **)key );
> -  if ( status == RTEMS_SUCCESSFUL ) {
> -    /* Hmm - hopefully all tasks using this key have gone away... */
> -    if ( key ) free( *(void **)key );
> -    return 0;
> +  if ( pkey == NULL ) {
> +    return EINVAL;
> -  key = NULL;
> -  return 0;
> +  eno = pthread_key_delete(*pkey);
> +  if ( eno == 0 ) {
> +    free( pkey );
> +  return eno;
>  void *rtems_gxx_getspecific(__gthread_key_t key)
> -  void              *p= 0;
> -  status = rtems_task_variable_get( RTEMS_SELF, (void **)key, &p );
> -    /* We do not have to do this, but what the heck ! */
> -     p= key->val;
> -  } else {
> -    /* fisrt time, always set to zero, it is unknown the value that the others
> -     * threads are using at the moment of this call
> -    status = rtems_task_variable_add( RTEMS_SELF, (void **)key, key->dtor );
> -    if ( status != RTEMS_SUCCESSFUL ) {
> -      _Terminate(
> -        INTERNAL_ERROR_CORE,
> -        true,
> -        INTERNAL_ERROR_GXX_KEY_ADD_FAILED
> -    key->val = (void *)0;
> +  void *p = NULL;
> +  if ( pkey != NULL ) {
> +    p = pthread_getspecific( *pkey );
>      printk(
>        "gxx_wrappers: getspecific key=%x, ptr=%x, id=%x\n",
> -       key,
> +       pkey,
>         p,
>         rtems_task_self()
> @@ -134,25 +117,33 @@ void *rtems_gxx_getspecific(__gthread_key_t key)
>  int rtems_gxx_setspecific(__gthread_key_t key, const void *ptr)
> +  int eno;
> +    return EINVAL;
> +  eno = pthread_setspecific( *pkey, ptr );
>      printk(
>        "gxx_wrappers: setspecific key=%x, ptr=%x, id=%x\n",
> -      key,
> +      pkey,
>        ptr,
>        rtems_task_self()
>    #endif
> -    /* now let's set the proper value */
> -    key->val =  (void *)ptr;
> -    return 0;
> +  if ( eno != 0 ) {
> +    _Terminate(
> +      INTERNAL_ERROR_CORE,
> +      true,
> +      INTERNAL_ERROR_GXX_KEY_ADD_FAILED
> -  return -1;
> +  return 0;
> diff --git a/testsuites/libtests/gxx01/gxx01.scn b/testsuites/libtests/gxx01/gxx01.scn
> index cb9f6b5..f831881 100644
> --- a/testsuites/libtests/gxx01/gxx01.scn
> +++ b/testsuites/libtests/gxx01/gxx01.scn
> @@ -22,10 +22,14 @@ Call once method the second time
>  rtems_gxx_key_create(&key, NULL) - OK
>  rtems_gxx_key_delete(key) - OK
>  rtems_gxx_key_create(&key, key_dtor) - OK
> -rtems_gxx_setspecific() - OK
> +rtems_gxx_getspecific(key) not set - OK
> +rtems_gxx_setspecific(key, 0x1234) - OK
>  rtems_gxx_getspecific(key) already existing - OK
>  rtems_gxx_getspecific(key) non-existent - OK
> -rtems_gxx_key_delete(key) - OK
> +rtems_gxx_key_delete(key) - NOT OK
> +rtems_gxx_setspecific(NULL, 0x1234) - NOT OK
> +rtems_gxx_getspecific(NULL) - OK
> +rtems_gxx_key_delete(NULL) - NOT OK
>  *** END OF TEST GXX 01 ***
> diff --git a/testsuites/libtests/gxx01/init.c b/testsuites/libtests/gxx01/init.c
> index cc704ef..5c7a3c1 100644
> --- a/testsuites/libtests/gxx01/init.c
> +++ b/testsuites/libtests/gxx01/init.c
> @@ -11,6 +11,7 @@
>  #include "config.h"
>  #endif
> +#include <errno.h>
>  #include <tmacros.h>
>  #include "test_support.h"
> @@ -140,7 +141,11 @@ void test_key(void)
>    sc = rtems_gxx_key_create(&key, key_dtor);
>    rtems_test_assert( sc == 0 );
> -  puts( "rtems_gxx_setspecific() - OK" );
> +  puts( "rtems_gxx_getspecific(key) not set - OK" );
> +  p = rtems_gxx_getspecific(key);
> +  rtems_test_assert( p == NULL );
> +  puts( "rtems_gxx_setspecific(key, 0x1234) - OK" );
>    sc = rtems_gxx_setspecific(key, (void *)0x1234);
> @@ -151,7 +156,8 @@ void test_key(void)
>    puts( "rtems_gxx_key_delete(key) - OK" );
>    sc = rtems_gxx_key_delete(key);
> -  rtems_test_assert( key_dtor_ran == true );
> +  /* pthread_key man-page: the dtor should _not_ be called */
> +  rtems_test_assert( key_dtor_ran != true );
>    key = calloc( 1, sizeof( *key ) );
>    rtems_test_assert( key != NULL );
> @@ -160,9 +166,21 @@ void test_key(void)
>    p = rtems_gxx_getspecific( key );
> -  puts( "rtems_gxx_key_delete(key) - OK" );
> +  puts( "rtems_gxx_key_delete(key) - NOT OK" );
>    sc = rtems_gxx_key_delete( key );
> -  rtems_test_assert( sc == 0 );
> +  rtems_test_assert( sc != 0 );
> +  puts( "rtems_gxx_setspecific(NULL, 0x1234) - NOT OK" );
> +  sc = rtems_gxx_setspecific( NULL, (void *)0x1234 );
> +  rtems_test_assert( sc == EINVAL );
> +  puts( "rtems_gxx_getspecific(NULL) - OK" );
> +  p = rtems_gxx_getspecific( NULL );
> +  puts( "rtems_gxx_key_delete(NULL) - NOT OK" );
> +  sc = rtems_gxx_key_delete( NULL );
>  rtems_task Init(
> @@ -197,6 +215,9 @@ rtems_task Init(
>  #define CONFIGURE_MAXIMUM_SEMAPHORES   2
>  #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_MAXIMUM_POSIX_KEYS            1
> +#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 1
>  #define CONFIGURE_INIT
>  #include <rtems/confdefs.h>
> diff --git a/testsuites/sptests/spfatal24/spfatal24.doc b/testsuites/sptests/spfatal24/spfatal24.doc
> index ad6eda5..0ff898d 100644
> --- a/testsuites/sptests/spfatal24/spfatal24.doc
> +++ b/testsuites/sptests/spfatal24/spfatal24.doc
> @@ -12,7 +12,7 @@ test set name:  spfatal24
>  directives:
> -  rtems_gxx_getspecific();
> +  rtems_gxx_setspecific();
>  concepts:
> diff --git a/testsuites/sptests/spfatal24/testcase.h b/testsuites/sptests/spfatal24/testcase.h
> index 6ac8906..226ccc9 100644
> --- a/testsuites/sptests/spfatal24/testcase.h
> +++ b/testsuites/sptests/spfatal24/testcase.h
> @@ -18,9 +18,7 @@
>  void force_error()
> -  __gthread_key key;
> +  pthread_key_t key = -1;
> -  rtems_workspace_greedy_allocate( NULL, 0 );
> -  rtems_gxx_getspecific( &key );
> +  rtems_gxx_setspecific( &key, NULL );
> diff --git a/testsuites/sptests/sptls02/init.cc b/testsuites/sptests/sptls02/init.cc
> index d704190..2c9e283 100644
> --- a/testsuites/sptests/sptls02/init.cc
> +++ b/testsuites/sptests/sptls02/init.cc
> @@ -251,6 +251,9 @@ extern "C" void Init(rtems_task_argument arg)
> +#define CONFIGURE_MAXIMUM_POSIX_KEYS 2
> +#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 2
> 1.8.4.5
> rtems-devel mailing list
> rtems-devel at rtems.org
