[PATCH] cpukit/librpc: Replace rpc task variables with POSIX keys.
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Mar 21 13:17:19 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 cpukit/librpc/include/rpc/rpc.h   |  4 ++-
 cpukit/librpc/src/rpc/rtems_rpc.c | 65 +++++++++++++++++++++++++++++----------
 2 files changed, 51 insertions(+), 18 deletions(-)
diff --git a/cpukit/librpc/include/rpc/rpc.h b/cpukit/librpc/include/rpc/rpc.h
index 95df085..20065ef 100644
--- a/cpukit/librpc/include/rpc/rpc.h
+++ b/cpukit/librpc/include/rpc/rpc.h
@@ -104,7 +104,9 @@ struct _rtems_rpc_task_variables {
 	struct authsvc *svc_auths_Auths;
-extern struct _rtems_rpc_task_variables *rtems_rpc_task_variables;
+struct _rtems_rpc_task_variables *rtems_rpc_task_variables_get(void);
+#define rtems_rpc_task_variables rtems_rpc_task_variables_get()
 #define svc_maxfd (rtems_rpc_task_variables->svc_svc_maxfd)
 #define svc_fdset (rtems_rpc_task_variables->svc_svc_fdset)
diff --git a/cpukit/librpc/src/rpc/rtems_rpc.c b/cpukit/librpc/src/rpc/rtems_rpc.c
index 5d31f12..69d6c65 100644
--- a/cpukit/librpc/src/rpc/rtems_rpc.c
+++ b/cpukit/librpc/src/rpc/rtems_rpc.c
@@ -9,6 +9,8 @@
 #include <rpc/rpc.h>
+#include <pthread.h>
+#include <assert.h>
  * RPC variables for single-thread
@@ -61,35 +63,64 @@ static const struct _rtems_rpc_task_variables rpc_init = {
  * Per-task pointer to RPC data
-struct _rtems_rpc_task_variables *rtems_rpc_task_variables = &rpc_default;
+static pthread_once_t rtems_rpc_task_variable_once = PTHREAD_ONCE_INIT;
+static pthread_key_t rtems_rpc_task_variable_key;
+ * Return the current task variable pointer.
+struct _rtems_rpc_task_variables *rtems_rpc_task_variables_get (void)
+  void *ptr = pthread_getspecific(rtems_rpc_task_variable_key);
+  if (ptr == NULL) {
+    ptr = &rpc_default;
+  return (struct _rtems_rpc_task_variables *) ptr;
+ * Key create function for task_variable_key.
+static void rtems_rpc_task_variable_make_key (void)
+	int eno = pthread_key_create(&rtems_rpc_task_variable_key, NULL);
+	assert (eno == 0);
+	 * FIXME: Should have destructor which cleans up
+	 * all RPC stuff:
+	 *  - Close all files
+	 *  - Go through and free linked list elements
+	 *  - Free other allocated memory (e.g. clnt_perror_buf)
  * Set up per-task RPC variables
 int rtems_rpc_task_init (void)
-	rtems_status_code sc;
 	struct _rtems_rpc_task_variables *tvp;
+	int eno = 0;
+	eno = pthread_once(
+		&rtems_rpc_task_variable_once,
+		rtems_rpc_task_variable_make_key
-	if (rtems_rpc_task_variables == &rpc_default) {
+	tvp = pthread_getspecific (rtems_rpc_task_variable_key);
+	if (tvp == NULL) {
 		tvp = malloc (sizeof *tvp);
-		if (tvp == NULL)
 			return RTEMS_NO_MEMORY;
-		 * FIXME: Should have destructor which cleans up
-		 * all RPC stuff:
-		 *	- Close all files
-		 *	- Go through and free linked list elements
-		 *	- Free other allocated memory (e.g. clnt_perror_buf)
-		sc = rtems_task_variable_add (
-			RTEMS_SELF, (void *)&rtems_rpc_task_variables, NULL);
-		if (sc != RTEMS_SUCCESSFUL) {
-			free (tvp);
-			return sc;
 		*tvp = rpc_init;
-		rtems_rpc_task_variables = tvp;
+		eno = pthread_setspecific (rtems_rpc_task_variable_key, (void *) tvp);
+		if (eno != 0) {
+			free (tvp);
+			return RTEMS_INTERNAL_ERROR;
 	return RTEMS_SUCCESSFUL;
1.8.4.5
