EDF Scheduler and Priority Queues
Fri Mar 21 13:46:55 UTC 2014
On Fri, Mar 21, 2014 at 9:43 AM, Sebastian Huber
> On 2014-03-21 14:32, Sebastian Huber wrote:
>> Hello,
>> I changed the objects allocate/free to use the allocator mutex.  This
>> change is
>> very important since otherwise the thread dispatch latency depends on the
>> heap
>> fragmentation.  I noticed now a problem with the thread priority queues
>> and the
>> EDF scheduler.  The EDF scheduler uses priority values greater than 255.
>> Now
>> we have a problem in _Thread_queue_Enqueue_priority():
>> Thread_blocking_operation_States _Thread_queue_Enqueue_priority (
>>    Thread_queue_Control *the_thread_queue,
>>    Thread_Control       *the_thread,
>>    ISR_Level            *level_p
>>    _Chain_Initialize_empty( &the_thread->Wait.Block2n );
>>    priority     = the_thread->current_priority;
>>    header_index = _Thread_queue_Header_number( priority );
>>    header       = &the_thread_queue->Queues.Priority[ header_index ];
>> The header_index is now out of range.
>> Should the EDF scheduler work with thread priority queues?
> I have another question regarding the EDF scheduler.  Does this work in case
> _Watchdog_Ticks_since_boot overflows?
No. For this, I think we need to use "deadline folding" which is just
modulo arithmetic.
> void _Scheduler_EDF_Release_job(
>   uint32_t           deadline
>   Priority_Control new_priority;
>   if (deadline) {
>     /* Initializing or shifting deadline. */
>     new_priority = (_Watchdog_Ticks_since_boot + deadline)
>                    & ~SCHEDULER_EDF_PRIO_MSB;
>   else {
>     /* Switch back to background priority. */
>     new_priority = the_thread->Start.initial_priority;
>   the_thread->real_priority = new_priority;
>   _Thread_Change_priority(the_thread, new_priority, true);
> rtems-devel mailing list
> rtems-devel at rtems.org
