Running the Hello World example on POK.
Youren Shen
shenyouren at gmail.com
Mon Mar 24 05:01:33 UTC 2014
Hi,Gedare:
I have run the hello world example successfully and update the blog with
screenshot[1]. The Philipp supplied me a patch. In that patch we replace
the i386_disable_interrupts by _CPU_Virtual_Interrupts_disable.
I also post a blog about the POK startup flow which is important to
paravirtualization design. The blog is too long so I did not mention the
changes in POK that Philipp did last year. I will discuss the changes in
POK next weekend.
Thank you very much.
[1]. http://huaiyusched.github.io/rtems/2014/03/15/how-to-run-rtems-on-pok/
[2].
https://github.com/HuaiYuSched/rtems_GSoC/blob/master/rtems_paravirt_cpu_i386.patch
Best Regards.
Youren Shen.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140324/9f63abee/attachment.html>
