[rtems commit] librpc: Use POSIX key instead of task variables
Mon Mar 24 17:56:56 UTC 2014
On 03/24/2014 06:39 PM, Joel Sherrill wrote:
> On 3/24/2014 12:34 PM, Sebastian Huber wrote:
>> >Hello Joel,
>> >On 03/24/2014 05:59 PM, Joel Sherrill wrote:
>>> >>Grep'ing to see what was left, I see two things:
>>> >>+ privateenv.c
>> >what is your opinion on removing rtems_libio_share_private_env()?
> Not sure.
>> >http://www.rtems.org/pipermail/rtems-devel/2014-March/006134.html
>> >This would dramatically simplify the implementation.  What was the use
>> >case for this function?
> It allows a group of threads to share per-process information.  You can
> share a single
> copy across all threads, one unique instance per thread, or share
> between a subset of
> threads.
> I think one user of this feature is the ftp server. That may be the only
> one.
No, the FTP sever uses chroot() which uses rtems_libio_set_private_env().
The rtems_libio_share_private_env() is not used in the RTEMS tree.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
