[PATCH 04/10] sapi: Add priority affinity smp scheduler.
Jennifer jennifer.averett at oarcorp.com
Mon Mar 24 18:39:35 UTC 2014
From: Jennifer Averett <jennifer.averett at oarcorp.com>
 cpukit/sapi/include/confdefs.h | 22 ++++++++++++++++++++++
 1 file changed, 22 insertions(+)
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index aca99f0..e784a40 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -624,6 +624,7 @@ const rtems_libio_helper rtems_fs_init_helper =
  *  CONFIGURE_SCHEDULER_USER       - user provided scheduler
  *  CONFIGURE_SCHEDULER_PRIORITY   - Deterministic Priority Scheduler
  *  CONFIGURE_SCHEDULER_PRIORITY_SMP - Deterministic Priority SMP Scheduler
+ *  CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP - Deterministic Priority SMP Affinity Scheduler
  *  CONFIGURE_SCHEDULER_SIMPLE     - Light-weight Priority Scheduler
  *  CONFIGURE_SCHEDULER_SIMPLE_SMP - Simple SMP Priority Scheduler
  *  CONFIGURE_SCHEDULER_EDF        - EDF Scheduler
@@ -648,6 +649,7 @@ const rtems_libio_helper rtems_fs_init_helper =
 #if !defined(CONFIGURE_SCHEDULER_USER) && \
     !defined(CONFIGURE_SCHEDULER_PRIORITY) && \
     !defined(CONFIGURE_SCHEDULER_PRIORITY_SMP) && \
+    !defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP) && \
     !defined(CONFIGURE_SCHEDULER_SIMPLE) && \
     !defined(CONFIGURE_SCHEDULER_SIMPLE_SMP) && \
     !defined(CONFIGURE_SCHEDULER_EDF) && \
@@ -698,6 +700,26 @@ const rtems_libio_helper rtems_fs_init_helper =
 #endif
+ * If the Deterministic Priority Affinity SMP Scheduler is selected, then configure for
+ * it.
+#if defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP)
+  #include <rtems/score/schedulerpriorityaffinitysmp.h>
+  #define CONFIGURE_SCHEDULER_ENTRY_POINTS SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS
+   * This defines the memory used by the priority scheduler.
+  #define CONFIGURE_MEMORY_FOR_SCHEDULER ( \
+    _Configure_From_workspace( \
+      sizeof(Scheduler_SMP_Control) +  \
+      ((CONFIGURE_MAXIMUM_PRIORITY) * sizeof(Chain_Control)) ) \
+  #define CONFIGURE_MEMORY_PER_TASK_FOR_SCHEDULER ( \
+    _Configure_From_workspace(sizeof(Scheduler_priority_Per_thread)) )
+#endif
  * If the Simple Priority Scheduler is selected, then configure for it.
 #if defined(CONFIGURE_SCHEDULER_SIMPLE)
1.8.1.4
