[PATCH 01/10] score: Add get/set affinity to Scheduler Framework.
Mon Mar 24 20:10:03 UTC 2014
On Mon, Mar 24, 2014 at 2:39 PM, Jennifer <jennifer.averett at oarcorp.com> wrote:
> From: Jennifer Averett <jennifer.averett at oarcorp.com>
>  cpukit/score/Makefile.am                           |  2 +
>  cpukit/score/include/rtems/score/scheduler.h       | 58 ++++++++++++++++++++++
>  cpukit/score/include/rtems/score/schedulerimpl.h   | 32 ++++++++++++
>  .../score/include/rtems/score/schedulerpriority.h  | 11 +++-
>  .../include/rtems/score/schedulerprioritysmp.h     |  6 ++-
>  .../score/include/rtems/score/schedulersimplesmp.h |  4 +-
>  cpukit/score/src/schedulerdefaultgetaffinity.c     | 41 +++++++++++++++
>  cpukit/score/src/schedulerdefaultsetaffinity.c     | 32 ++++++++++++
>  8 files changed, 182 insertions(+), 4 deletions(-)
>  create mode 100644 cpukit/score/src/schedulerdefaultgetaffinity.c
>  create mode 100644 cpukit/score/src/schedulerdefaultsetaffinity.c
> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> index aeee4b6..67cc802 100644
> --- a/cpukit/score/Makefile.am
> +++ b/cpukit/score/Makefile.am
> @@ -131,6 +131,8 @@ libscore_a_SOURCES += src/schedulersmpstartidle.c
>  libscore_a_SOURCES += src/smp.c
>  libscore_a_SOURCES += src/cpuset.c
>  libscore_a_SOURCES += src/cpusetprintsupport.c
> +libscore_a_SOURCES += src/schedulerdefaultgetaffinity.c
> +libscore_a_SOURCES += src/schedulerdefaultsetaffinity.c
>  endif
>  ## CORE_APIMUTEX_C_FILES
> diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
> index ced3c00..a0e36f3 100644
> --- a/cpukit/score/include/rtems/score/scheduler.h
> +++ b/cpukit/score/include/rtems/score/scheduler.h
> @@ -22,6 +22,9 @@
>  #include <rtems/score/percpu.h>
>  #include <rtems/score/chain.h>
>  #include <rtems/score/priority.h>
> +#if defined(__RTEMS_HAVE_SYS_CPUSET_H__) && defined(RTEMS_SMP)
> +  #include <sys/cpuset.h>
> +#endif
>  #ifdef __cplusplus
>  extern "C" {
> @@ -98,6 +101,24 @@ typedef struct {
>     * @see _Scheduler_Start_idle().
>    void ( *start_idle )( Thread_Control *thread, Per_CPU_Control *processor );
> +   * @brief Obtain the processor affinity for a thread.
> +   * @see _Scheduler_Get_affinity().
> +  int ( *get_affinity )( Thread_Control *thread, size_t cpusetsize, cpu_set_t *cpuset );
1 newline please
> +   * @brief Set the processor affinity for a thread.
> +   * @see _Scheduler_Set_affinity().
> +  int ( *set_affinity )( Thread_Control *thread, size_t cpusetsize, cpu_set_t *cpuset );
> +#endif
>  } Scheduler_Operations;
> @@ -184,6 +205,43 @@ void _Scheduler_default_Start_idle(
> +   * @brief Get affinity for the default scheduler.
> +   * @param[in] thread The associated thread.
> +   * @param[in] cpusetsize The size of the cpuset.
> +   * @param[out] cpuset Affinity set containing all CPUs.
> +   * @retval 0 Successfully got cpuset
> +   * @retval -1 The cpusetsize is invalid for the system
> +  int _Scheduler_default_Get_affinity(
> +    Thread_Control *thread,
> +    size_t          cpusetsize,
> +    cpu_set_t      *cpuset
> +   * @brief Set affinity for the default scheduler.
> +   * @param[in] cpuset Affinity new affinity set.
> +   *  This method always returns successful and does not save
> +   *  the cpuset.
> +  int _Scheduler_default_Set_affinity(
> +    cpu_set_t      *cpuset
> +#endif
>  #ifdef __cplusplus
> diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
> index 7fbaf54..021b50f 100644
> --- a/cpukit/score/include/rtems/score/schedulerimpl.h
> +++ b/cpukit/score/include/rtems/score/schedulerimpl.h
> @@ -240,6 +240,38 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Start_idle(
>    ( *_Scheduler.Operations.start_idle )( thread, processor );
> +   * @param[in,out] thread The idle thread for the processor.
idle?
> +   * @parma[out] cpuset The processor affinity for this thread
> +  RTEMS_INLINE_ROUTINE int _Scheduler_Get_affinity(
> +    cpu_set_t      *cpuset
> +    return (*_Scheduler.Operations.get_affinity)( thread, cpusetsize, cpuset );
idle?
> +   * @parma[in] cpuset The processor affinity for this thread
> +  RTEMS_INLINE_ROUTINE int _Scheduler_Set_affinity(
> +    cpu_set_t      *cpuset
> +    return (*_Scheduler.Operations.set_affinity)( thread, cpusetsize, cpuset );
> +#endif
>  RTEMS_INLINE_ROUTINE void _Scheduler_Update_heir(
>    Thread_Control *heir,
>    bool force_dispatch
> diff --git a/cpukit/score/include/rtems/score/schedulerpriority.h b/cpukit/score/include/rtems/score/schedulerpriority.h
> index 605ab39..a9a46e9 100644
> --- a/cpukit/score/include/rtems/score/schedulerpriority.h
> +++ b/cpukit/score/include/rtems/score/schedulerpriority.h
> @@ -34,6 +34,14 @@ extern "C" {
> +  #define SCHEDULER_PRIORITY_ADDITIONAL_SMP_ENTRY_POINTS \
> +    _Scheduler_default_Get_affinity,     /* get affinity entry point */ \
> +    _Scheduler_default_Set_affinity      /* set affinity entry point */
> +#else
> +#endif
>   *  Entry points for the Deterministic Priority Based Scheduler.
> @@ -53,7 +61,8 @@ extern "C" {
>      _Scheduler_priority_Priority_compare, /* compares two priorities */ \
>      _Scheduler_default_Release_job,       /* new period of task */ \
>      _Scheduler_default_Tick,              /* tick entry point */ \
> -    _Scheduler_default_Start_idle         /* start idle entry point */ \
> +    _Scheduler_default_Start_idle,        /* start idle entry point */ \
> +    SCHEDULER_PRIORITY_ADDITIONAL_SMP_ENTRY_POINTS \
Do we support configuring an SMP system with this scheduler?
> diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmp.h b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
> index b0e5fad..bee4232 100644
> --- a/cpukit/score/include/rtems/score/schedulerprioritysmp.h
> +++ b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
> @@ -48,7 +48,7 @@ extern "C" {
> - * @brief Entry points for the Simple SMP Scheduler.
> + * @brief Entry points for the Priority SMP Scheduler.
>  #define SCHEDULER_PRIORITY_SMP_ENTRY_POINTS \
> @@ -66,7 +66,9 @@ extern "C" {
>      _Scheduler_priority_Priority_compare, \
>      _Scheduler_default_Release_job, \
>      _Scheduler_default_Tick, \
> -    _Scheduler_SMP_Start_idle \
> +    _Scheduler_SMP_Start_idle, \
> +    _Scheduler_default_Get_affinity, \
> +    _Scheduler_default_Set_affinity \
>  void _Scheduler_priority_SMP_Initialize( void );
> diff --git a/cpukit/score/include/rtems/score/schedulersimplesmp.h b/cpukit/score/include/rtems/score/schedulersimplesmp.h
> index 1a69358..e8cd54b 100644
> --- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
> +++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
> @@ -68,7 +68,9 @@ extern "C" {
>  void _Scheduler_simple_smp_Initialize( void );
> diff --git a/cpukit/score/src/schedulerdefaultgetaffinity.c b/cpukit/score/src/schedulerdefaultgetaffinity.c
> new file mode 100644
> index 0000000..fde9b01
> --- /dev/null
> +++ b/cpukit/score/src/schedulerdefaultgetaffinity.c
> @@ -0,0 +1,41 @@
> + * @file
> + * @brief Scheduler Default Get Affinity Operation
> + * @ingroup ScoreScheduler
> + *  COPYRIGHT (c) 2014.
> + *  On-Line Applications Research Corporation (OAR).
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#if HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <rtems/score/schedulerimpl.h>
> +#include <rtems/score/cpusetimpl.h>
> +int _Scheduler_default_Get_affinity(
> +  cpu_set_t      *cpuset
> +  const CPU_set_Control *ctl;
> +  ctl = _CPU_set_Default();
> +  if ( cpusetsize == ctl->setsize ) {
shouldn't this be !=
> +    return -1;
> +  CPU_COPY( cpuset, ctl->set );
> +  return 0;
> diff --git a/cpukit/score/src/schedulerdefaultsetaffinity.c b/cpukit/score/src/schedulerdefaultsetaffinity.c
> index 0000000..9c1eef0
> --- /dev/null
> +++ b/cpukit/score/src/schedulerdefaultsetaffinity.c
> @@ -0,0 +1,32 @@
> + * @file
> + * @brief Scheduler Default Set Affinity Operation
> +#if HAVE_CONFIG_H
> +#endif
> +int _Scheduler_default_Set_affinity(
> +  cpu_set_t      *cpuset
> +  return 0;
> 1.8.1.4
> rtems-devel mailing list
> rtems-devel at rtems.org
