[PATCH 02/10] score: Add priority affinity smp scheduler.
Mon Mar 24 20:22:34 UTC 2014
On Mon, Mar 24, 2014 at 2:39 PM, Jennifer <jennifer.averett at oarcorp.com> wrote:
> From: Jennifer Averett <jennifer.averett at oarcorp.com>
>  cpukit/score/Makefile.am                           |   2 +
>  .../rtems/score/schedulerpriorityaffinitysmp.h     | 144 +++++++++++++++++++++
>  cpukit/score/preinstall.am                         |   4 +
>  cpukit/score/src/schedulerpriorityaffinitysmp.c    |  95 ++++++++++++++
>  4 files changed, 245 insertions(+)
>  create mode 100644 cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
>  create mode 100644 cpukit/score/src/schedulerpriorityaffinitysmp.c
> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> index 67cc802..95406d9 100644
> --- a/cpukit/score/Makefile.am
> +++ b/cpukit/score/Makefile.am
> @@ -109,6 +109,7 @@ endif
>  if HAS_SMP
>  include_rtems_score_HEADERS += include/rtems/score/atomic.h
>  include_rtems_score_HEADERS += include/rtems/score/cpustdatomic.h
> +include_rtems_score_HEADERS += include/rtems/score/schedulerpriorityaffinitysmp.h
>  include_rtems_score_HEADERS += include/rtems/score/schedulersimplesmp.h
>  endif
> @@ -125,6 +126,7 @@ endif
>  if HAS_SMP
>  libscore_a_SOURCES += src/profilingsmplock.c
> +libscore_a_SOURCES += src/schedulerpriorityaffinitysmp.c
>  libscore_a_SOURCES += src/schedulerprioritysmp.c
>  libscore_a_SOURCES += src/schedulersimplesmp.c
>  libscore_a_SOURCES += src/schedulersmpstartidle.c
> diff --git a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
> new file mode 100644
> index 0000000..b64f54d
> --- /dev/null
> +++ b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
> @@ -0,0 +1,144 @@
> + * @file
> + * @ingroup ScoreSchedulerPriorityAffinitySMP
> + * @brief Deterministic Priority Affinity SMP Scheduler API
> + *  COPYRIGHT (c) 2014.
> + *  On-Line Applications Research Corporation (OAR).
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#ifndef _RTEMS_SCORE_SCHEDULERPRIORITYAFFINITYSMP_H
> +#define _RTEMS_SCORE_SCHEDULERPRIORITYAFFINITYSMP_H
> +#include <rtems/score/scheduler.h>
> +#include <rtems/score/schedulerpriority.h>
> +#include <rtems/score/schedulersmp.h>
> +#include <rtems/score/schedulerprioritysmp.h>
> +#include <rtems/score/cpuset.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> + * @defgroup ScoreSchedulerPriorityAffinitySMP Deterministic Priority Affinity SMP Scheduler
> + * This is an extension of the Deterministic Priority SMP Scheduler. which
> + * is an implementation of the global fixed priority scheduler (G-FP).
> + * It adds thread to core affinity support.
> + * @note This is the first iteration of this scheduler. It currently tracks
> + *       the requested affinity to exercise the Scheduler Framework but it
> + *       does not honor that affinity in assigning threads to cores. This
> + *       will be added in a subsequent revision.
> + * @brief Entry points for the Simple SMP Scheduler w/ Affinity.
Keep the name consistent:
delete the w/ Affinity and s/Simple/Deterministic Priority Affinity/
> +#define SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS \
> +    _Scheduler_priority_SMP_Initialize, \
> +    _Scheduler_priority_SMP_Schedule, \
> +    _Scheduler_priority_SMP_Yield, \
> +    _Scheduler_priority_SMP_Block, \
> +    _Scheduler_priority_SMP_Enqueue_fifo, \
> +    _Scheduler_priority_affinity_SMP_Allocate, \
> +    _Scheduler_priority_Free, \
> +    _Scheduler_priority_SMP_Update, \
> +    _Scheduler_priority_SMP_Enqueue_lifo, \
> +    _Scheduler_priority_SMP_Extract, \
> +    _Scheduler_priority_Priority_compare, \
> +    _Scheduler_default_Release_job, \
> +    _Scheduler_default_Tick, \
> +    _Scheduler_SMP_Start_idle, \
> +    _Scheduler_priority_affinity_SMP_Get_affinity, \
> +    _Scheduler_priority_affinity_SMP_Set_affinity \
> + *  @brief Allocates @a the_thread->scheduler.
> + *  This routine allocates @a the_thread->scheduler.
> + *  @param[in] the_thread is the thread the scheduler is allocating
> + *             management memory for
> +void * _Scheduler_priority_affinity_SMP_Allocate( Thread_Control *the_thread );
> + * @brief Get affinity for the priority affinity smp scheduler.
> + * @param[in] thread The associated thread.
> + * @param[in] cpusetsize The size of the cpuset.
> + * @param[in,out] cpuset The associated affinity set.
> + * @retval 0 Successfully got cpuset
> + * @retval -1 The cpusetsize is invalid for the system
> +int _Scheduler_priority_affinity_SMP_Get_affinity(
> +  Thread_Control *thread,
> +  size_t          cpusetsize,
> +  cpu_set_t      *cpuset
> + * @brief Set affinity for the priority affinity smp scheduler.
> + * @param[in] cpuset Affinity new affinity set.
> +int _Scheduler_priority_affinity_SMP_Set_affinity(
> +  cpu_set_t      *cpuset
> + * This structure handles affinity specific data of a thread.
> + * @note The attribute priority_sched_info must remain
> + *       the first element in the structure so that the
> + *       Scheduler_priority_XXX methods will continue to
> + *       function.
> +typedef struct {
> +   * Data for the Priority Scheduler.
> +  Scheduler_priority_Per_thread  priority_sched_info;
An included structure gets the first letter caps, e.g. Priority_sched_info.
> +   * Pointer to corresponding Thread Control Block.
> +  Thread_Control *thread;
> +   * Structure containing affinity set data and size
> +  CPU_set_Control affinity;
ditto.
> +} Scheduler_priority_affinity_SMP_Per_thread;
> +#ifdef __cplusplus
> +#endif /* _RTEMS_SCORE_SCHEDULERPRIORITYSMP_H */
> diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
> index 68ded43..efbe37d 100644
> --- a/cpukit/score/preinstall.am
> +++ b/cpukit/score/preinstall.am
> @@ -386,6 +386,10 @@ $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h: include/rtems/score/cpustdatomic.
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h
> +$(PROJECT_INCLUDE)/rtems/score/schedulerpriorityaffinitysmp.h: include/rtems/score/schedulerpriorityaffinitysmp.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulerpriorityaffinitysmp.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulerpriorityaffinitysmp.h
>  $(PROJECT_INCLUDE)/rtems/score/schedulersimplesmp.h: include/rtems/score/schedulersimplesmp.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulersimplesmp.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulersimplesmp.h
> diff --git a/cpukit/score/src/schedulerpriorityaffinitysmp.c b/cpukit/score/src/schedulerpriorityaffinitysmp.c
> index 0000000..aa77d8d
> --- /dev/null
> +++ b/cpukit/score/src/schedulerpriorityaffinitysmp.c
> @@ -0,0 +1,95 @@
> + * @file
> + * @brief Deterministic Priority Affinity SMP Scheduler Implementation
> +#if HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <rtems/score/schedulerpriorityaffinitysmp.h>
> +#include <rtems/score/schedulerpriorityimpl.h>
> +#include <rtems/score/schedulersmpimpl.h>
> +#include <rtems/score/wkspace.h>
> +#include <rtems/score/cpusetimpl.h>
> +RTEMS_INLINE_ROUTINE Scheduler_priority_affinity_SMP_Per_thread *
> +_Scheduler_priority_affinity_Get_scheduler_info( Thread_Control *thread )
> +  return ( Scheduler_priority_affinity_SMP_Per_thread * ) thread->scheduler_info;
Why is this here, not in an impl.h file? if file-local, then make static please.
> +void _Scheduler_priority_affinity_SMP_Initialize( void )
> +  Scheduler_SMP_Control *self = _Workspace_Allocate_or_fatal_error(
> +    sizeof( *self ) + PRIORITY_MAXIMUM * sizeof( Chain_Control )
> +  _Chain_Initialize_empty( &self->scheduled );
> +  _Scheduler_priority_Ready_queue_initialize( &self->ready[ 0 ] );
> +  _Scheduler.information = self;
> +  Scheduler_priority_affinity_SMP_Per_thread *sched_info_of_thread =
> +    _Workspace_Allocate( sizeof( *sched_info_of_thread ) );
1 newline
> +  sched_info_of_thread->affinity = *_CPU_set_Default();
> +  sched_info_of_thread->affinity.set =
> +    &sched_info_of_thread->affinity.preallocated;
ditto, and use a shorter variable name you can squeeze the lines better.
> +  the_thread->scheduler_info = sched_info_of_thread;
> +  return sched_info_of_thread;
> +  cpu_set_t      *cpuset
> +    _Scheduler_priority_affinity_Get_scheduler_info(thread);
> +  if ( sched_info_of_thread->affinity.setsize != cpusetsize ) {
> +    return -1;
> +  CPU_COPY( cpuset, sched_info_of_thread->affinity.set );
> +  return 0;
> +  cpu_set_t      *cpuset
> +    return -1;
> +  CPU_COPY( sched_info_of_thread->affinity.set, cpuset );
> +  return 0;
> 1.8.1.4
> rtems-devel mailing list
> rtems-devel at rtems.org
