[PATCH 04/17] score: Add thread actions
Tue Mar 25 12:49:08 UTC 2014
Thread actions are the building block for efficient implementation of
  - Classic signals delivery,
  - POSIX signals delivery,
  - thread restart notification,
  - thread delete notification,
  - forced thread migration on SMP configurations, and
  - the Multiprocessor Resource Sharing Protocol (MrsP).
 cpukit/score/include/rtems/score/thread.h     |   59 ++++++++++++++++++++++
 cpukit/score/include/rtems/score/threadimpl.h |   67 +++++++++++++++++++++++++
 cpukit/score/src/threaddispatch.c             |   33 ++++++++++++
 cpukit/score/src/threadinitialize.c           |    2 +
 4 files changed, 161 insertions(+), 0 deletions(-)
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index 7147110..153537a 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -356,6 +356,62 @@ typedef enum {
 /** This macro defines the last API which has threads. */
 #define THREAD_API_LAST  THREAD_API_POSIX
+typedef struct Thread_Action Thread_Action;
+ * @brief Thread action handler.
+ * The thread action handler will be called with interrupts disabled and the
+ * thread action lock acquired.  The handler must release the thread action
+ * lock with _Thread_Action_release_and_ISR_enable().  So the thread action
+ * lock can be used to protect private data fields of the particular action.
+ * Since the action is passed to the handler private data fields can be added
+ * below the common thread action fields.
+ * @param[in] thread The thread performing the action.
+ * @param[in] action The thread action.
+ * @param[in] cpu The processor of the thread.
+ * @param[in] level The ISR level for _Thread_Action_release_and_ISR_enable().
+typedef void ( *Thread_Action_handler )(
+  Thread_Control  *thread,
+  Thread_Action   *action,
+  Per_CPU_Control *cpu,
+  ISR_Level        level
+ * @brief Thread action.
+ * Thread actions can be chained together to trigger a set of actions on
+ * particular events like for example a thread post-switch.  Use
+ * _Thread_Action_initialize() to initialize this structure.
+ * Thread actions are the building block for efficient implementation of
+ * - Classic signals delivery,
+ * - POSIX signals delivery,
+ * - thread restart notification,
+ * - thread delete notification,
+ * - forced thread migration on SMP configurations, and
+ * - the Multiprocessor Resource Sharing Protocol (MrsP).
+ * @see _Thread_Run_post_switch_actions().
+struct Thread_Action {
+  Chain_Node            Node;
+  Thread_Action_handler handler;
+ * @brief Control block to manage thread actions.
+ * Use _Thread_Action_control_initialize() to initialize this structure.
+typedef struct {
+  Chain_Control Chain;
+} Thread_Action_control;
  *  This structure defines the Thread Control Block (TCB).
@@ -473,6 +529,9 @@ struct Thread_Control_struct {
    *  this thread.
   Thread_Start_information              Start;
+  Thread_Action_control                 Post_switch_actions;
   /** This field contains the context of this thread. */
   Context_Control                       Registers;
 #if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index cc0d818..bbaa10a 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -20,6 +20,7 @@
 #define _RTEMS_SCORE_THREADIMPL_H
+#include <rtems/score/chainimpl.h>
 #include <rtems/score/interr.h>
 #include <rtems/score/isr.h>
@@ -639,6 +640,72 @@ RTEMS_INLINE_ROUTINE void _Thread_Update_cpu_time_used(
   _Timestamp_Add_to( &executing->cpu_time_used, &ran );
+RTEMS_INLINE_ROUTINE void _Thread_Action_control_initialize(
+  Thread_Action_control *action_control
+  _Chain_Initialize_empty( &action_control->Chain );
+RTEMS_INLINE_ROUTINE void _Thread_Action_initialize(
+  action->handler = handler;
+  _Chain_Set_off_chain( &action->Node );
+RTEMS_INLINE_ROUTINE Per_CPU_Control *
+  _Thread_Action_ISR_disable_and_acquire_for_executing( ISR_Level *level )
+  Per_CPU_Control *cpu;
+  _ISR_Disable_without_giant( *level );
+  cpu = _Per_CPU_Get();
+  _Per_CPU_Acquire( cpu );
+  return cpu;
+RTEMS_INLINE_ROUTINE Per_CPU_Control *_Thread_Action_ISR_disable_and_acquire(
+  ISR_Level      *level
+  cpu = _Thread_Get_CPU( thread );
+  return cpu;
+RTEMS_INLINE_ROUTINE void _Thread_Action_release_and_ISR_enable(
+  ISR_Level level
+  _Per_CPU_Release_and_ISR_enable( cpu, level );
+RTEMS_INLINE_ROUTINE void _Thread_Add_post_switch_action(
+  ISR_Level        level;
+  cpu = _Thread_Action_ISR_disable_and_acquire( thread, &level );
+  _Chain_Append_if_is_off_chain_unprotected(
+    &thread->Post_switch_actions.Chain,
+    &action->Node
+  _Thread_Action_release_and_ISR_enable( cpu, level );
 #if !defined(__DYNAMIC_REENT__)
  * This routine returns the C library re-enterant pointer.
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index 22a4f88..ae30c0c 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -9,6 +9,8 @@
  *  COPYRIGHT (c) 1989-2009.
  *  On-Line Applications Research Corporation (OAR).
+ *  Copyright (c) 2014 embedded brains GmbH.
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
  *  http://www.rtems.org/license/LICENSE.
@@ -27,6 +29,36 @@
 #include <rtems/score/userextimpl.h>
+static Thread_Action *_Thread_Get_post_switch_action(
+  Thread_Control *executing
+  Chain_Control *chain = &executing->Post_switch_actions.Chain;
+  return (Thread_Action *) _Chain_Get_unprotected( chain );
+static void _Thread_Run_post_switch_actions( Thread_Control *executing )
+  ISR_Level        level;
+  Thread_Action   *action;
+  cpu = _Thread_Action_ISR_disable_and_acquire( executing, &level );
+  action = _Thread_Get_post_switch_action( executing );
+  while ( action != NULL ) {
+    ( *action->handler )( executing, action, cpu, level );
 void _Thread_Dispatch( void )
   Per_CPU_Control  *per_cpu;
@@ -176,4 +208,5 @@ post_switch:
   _Per_CPU_Release_and_ISR_enable( per_cpu, level );
   _API_extensions_Run_post_switch( executing );
+  _Thread_Run_post_switch_actions( executing );
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index df49184..315156e 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -238,6 +238,8 @@ bool _Thread_Initialize(
   _Chain_Initialize_empty( &the_thread->Key_Chain );
+  _Thread_Action_control_initialize( &the_thread->Post_switch_actions );
    *  Open the object
1.7.7
