[PATCH 07/17] score: Delete post-switch API extensions
Tue Mar 25 15:45:25 UTC 2014
OK to these patches. I like this consolidation very nice.
On Tue, Mar 25, 2014 at 8:49 AM, Sebastian Huber
> Use thread post-switch actions instead.
>  cpukit/score/include/rtems/score/apiext.h |   64 -----------------------------
>  cpukit/score/src/apiext.c                 |   11 -----
>  cpukit/score/src/threaddispatch.c         |    1 -
>  3 files changed, 0 insertions(+), 76 deletions(-)
> diff --git a/cpukit/score/include/rtems/score/apiext.h b/cpukit/score/include/rtems/score/apiext.h
> index f281ab8..8382673 100644
> --- a/cpukit/score/include/rtems/score/apiext.h
> +++ b/cpukit/score/include/rtems/score/apiext.h
> @@ -52,13 +52,6 @@ extern "C" {
>  typedef void (*API_extensions_Postdriver_hook)(void);
> - *  This type defines the prototype of the Post Switch Hook.
> -typedef void (*API_extensions_Post_switch_hook)(
> -                 Thread_Control *
>   *  The control structure which defines the points at which an API
>   *  can add an extension to the system initialization thread.
> @@ -86,31 +79,10 @@ typedef struct {
>  }  API_extensions_Control;
> - * @brief Control structure for post switch hooks.
> -typedef struct {
> -  Chain_Node Node;
> -   * @brief The hook invoked during each context switch in the context of the
> -   * heir thread.
> -   * This hook must not be NULL.
> -  API_extensions_Post_switch_hook hook;
> -} API_extensions_Post_switch_control;
>   *  This is the list of API extensions to the system initialization.
>  SCORE_EXTERN Chain_Control _API_extensions_List;
> - * @brief The API extensions post switch list.
> -SCORE_EXTERN Chain_Control _API_extensions_Post_switch_list;
>   *  @brief Initialize the API extensions handler.
> @@ -129,23 +101,6 @@ void _API_extensions_Add(
>    API_extensions_Control *the_extension
> - * @brief Adds the API extension post switch control to the post switch list.
> - * The post switch control is only added to the list if it is in the off chain
> - * state.  Thus this function can be called multiple times with the same
> - * post switch control and only the first invocation will actually add it to the
> - * list.
> - * There is no protection against concurrent access.  This function must be
> - * called within a _Thread_Disable_dispatch() critical section.
> - * @param [in, out] post_switch The post switch control.
> -void _API_extensions_Add_post_switch(
> -  API_extensions_Post_switch_control *post_switch
>  #if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API)
>   *  @brief Execute all pre-driver extensions.
> @@ -162,25 +117,6 @@ void _API_extensions_Add_post_switch(
>  void _API_extensions_Run_postdriver( void );
> - * @brief Runs all API extension post switch hooks.
> -static inline void _API_extensions_Run_post_switch( Thread_Control *executing )
> -  const Chain_Control *chain = &_API_extensions_Post_switch_list;
> -  const Chain_Node    *tail = _Chain_Immutable_tail( chain );
> -  const Chain_Node    *node = _Chain_Immutable_first( chain );
> -  while ( node != tail ) {
> -    const API_extensions_Post_switch_control *post_switch =
> -      (const API_extensions_Post_switch_control *) node;
> -    (*post_switch->hook)( executing );
> -    node = _Chain_Immutable_next( node );
>  #ifdef __cplusplus
> diff --git a/cpukit/score/src/apiext.c b/cpukit/score/src/apiext.c
> index d4e67bf..3d9121d 100644
> --- a/cpukit/score/src/apiext.c
> +++ b/cpukit/score/src/apiext.c
> @@ -25,7 +25,6 @@
>  void _API_extensions_Initialization( void )
>   _Chain_Initialize_empty( &_API_extensions_List );
> - _Chain_Initialize_empty( &_API_extensions_Post_switch_list );
> @@ -35,16 +34,6 @@ void _API_extensions_Add(
>    _Chain_Append( &_API_extensions_List, &the_extension->Node );
> -  _Chain_Append_if_is_off_chain_unprotected(
> -    &_API_extensions_Post_switch_list,
> -    &post_switch->Node
>    void _API_extensions_Run_predriver( void )
> diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
> index ae30c0c..ae69a5c 100644
> --- a/cpukit/score/src/threaddispatch.c
> +++ b/cpukit/score/src/threaddispatch.c
> @@ -207,6 +207,5 @@ post_switch:
>    _Per_CPU_Release_and_ISR_enable( per_cpu, level );
> -  _API_extensions_Run_post_switch( executing );
>    _Thread_Run_post_switch_actions( executing );
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
