[PATCH 1/2] privateenv: Remove sharing of user environment between threads.
Christian Mauderer
christian.mauderer at embedded-brains.de
Wed Mar 26 12:29:58 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
cpukit/include/rtems/userenv.h | 20 ---------
cpukit/libcsupport/src/privateenv.c | 60 ++------------------------
testsuites/fstests/fsnofs01/fsnofs01.doc | 1 -
testsuites/fstests/fsnofs01/init.c | 12 ------
testsuites/sptests/spprivenv01/init.c | 40 +++++++----------
testsuites/sptests/spprivenv01/spprivenv01.doc | 5 +--
testsuites/sptests/spprivenv01/spprivenv01.scn | 15 +++----
7 files changed, 27 insertions(+), 126 deletions(-)
diff --git a/cpukit/include/rtems/userenv.h b/cpukit/include/rtems/userenv.h
index 7d874d3..8a9a4fc 100644
--- a/cpukit/include/rtems/userenv.h
+++ b/cpukit/include/rtems/userenv.h
@@ -64,9 +64,6 @@ typedef struct {
gid_t egid;
char login_buffer[LOGIN_NAME_MAX];
pid_t pgrp; /* process group id */
- /* User environment maintenance */
- rtems_id task_id;
- int reference_count;
} rtems_user_env_t;
extern rtems_user_env_t * rtems_current_user_env;
@@ -97,23 +94,6 @@ extern rtems_user_env_t rtems_global_user_env;
rtems_status_code rtems_libio_set_private_env(void);
- * @brief Creates a private environment shared with another task.
- * An attempt to share the environment with itself has no effect. This
- * function must be called from normal thread context and may block on a mutex.
- * Thread dispatching is disabled to protect some critical sections.
- * @param[in] task_id The private environment is shared with the task specified
- * by this identifier.
- * @retval RTEMS_SUCCESSFUL Successful operation.
- * @retval RTEMS_UNSATISFIED No shared environment is available for this task
- * @retval RTEMS_TOO_MANY Cannot register the shared environment.
- * identifier.
-rtems_status_code rtems_libio_share_private_env(rtems_id task_id) ;
* @brief Use the global environment.
* A private environment will be released. This function may be called from
diff --git a/cpukit/libcsupport/src/privateenv.c b/cpukit/libcsupport/src/privateenv.c
index c7a65a5..bee94c1 100644
--- a/cpukit/libcsupport/src/privateenv.c
+++ b/cpukit/libcsupport/src/privateenv.c
@@ -35,13 +35,9 @@ static void free_user_env(void *arg)
bool uses_global_env = env == &rtems_global_user_env;
if (!uses_global_env) {
- if (env->reference_count == 1) {
- rtems_filesystem_global_location_release(env->current_directory);
- rtems_filesystem_global_location_release(env->root_directory);
- free(env);
- } else {
- --env->reference_count;
+ rtems_filesystem_global_location_release(env->current_directory);
+ rtems_filesystem_global_location_release(env->root_directory);
+ free(env);
@@ -55,18 +51,14 @@ static void free_user_env_protected(rtems_user_env_t *env)
rtems_status_code sc = RTEMS_SUCCESSFUL;
- rtems_id self_task_id = rtems_task_self();
rtems_user_env_t *old_env = rtems_current_user_env;
bool uses_global_env = old_env == &rtems_global_user_env;
- bool uses_shared_env = old_env->task_id != self_task_id;
- if (uses_global_env || uses_shared_env) {
+ if (uses_global_env) {
rtems_user_env_t *new_env = calloc(1, sizeof(*new_env));
if (new_env != NULL) {
*new_env = *old_env;
- new_env->reference_count = 1;
- new_env->task_id = self_task_id;
new_env->root_directory =
rtems_filesystem_global_location_obtain(&old_env->root_directory);
new_env->current_directory =
@@ -102,50 +94,6 @@ rtems_status_code rtems_libio_set_private_env(void)
return sc;
- rtems_status_code sc = RTEMS_SUCCESSFUL;
- if (task_id != RTEMS_SELF && self_task_id != task_id) {
- rtems_user_env_t *env;
- * We have to disable the thread dispatching to prevent deletion of the
- * environment in the meantime.
- _Thread_Disable_dispatch();
- sc = rtems_task_variable_get(
- task_id,
- (void *) &rtems_current_user_env,
- (void *) &env
- if (sc == RTEMS_SUCCESSFUL) {
- ++env->reference_count;
- } else {
- sc = RTEMS_UNSATISFIED;
- _Thread_Enable_dispatch();
- sc = rtems_task_variable_add(
- RTEMS_SELF,
- (void **) &rtems_current_user_env,
- free_user_env
- free_user_env_protected(rtems_current_user_env);
- rtems_current_user_env = env;
- } else {
- free_user_env_protected(env);
- sc = RTEMS_TOO_MANY;
- return sc;
void rtems_libio_use_global_env(void)
diff --git a/testsuites/fstests/fsnofs01/fsnofs01.doc b/testsuites/fstests/fsnofs01/fsnofs01.doc
index 5980be8..3a47c46 100644
--- a/testsuites/fstests/fsnofs01/fsnofs01.doc
+++ b/testsuites/fstests/fsnofs01/fsnofs01.doc
@@ -35,7 +35,6 @@ directives:
+ rtems_filesystem_location_free
+ rtems_filesystem_global_location_obtain_null
+ rtems_libio_set_private_env
- + rtems_libio_share_private_env
+ rtems_libio_use_global_env
+ rmdir
+ stat
diff --git a/testsuites/fstests/fsnofs01/init.c b/testsuites/fstests/fsnofs01/init.c
index fdcf959..13cd709 100644
--- a/testsuites/fstests/fsnofs01/init.c
+++ b/testsuites/fstests/fsnofs01/init.c
@@ -315,18 +315,6 @@ static void test_user_env(void)
rtems_test_assert(node_count(loc_chain) == 1);
rtems_test_assert(null_loc->reference_count == 4);
- sc = rtems_libio_share_private_env(RTEMS_SELF);
- rtems_test_assert(sc == RTEMS_SUCCESSFUL);
- rtems_test_assert(node_count(loc_chain) == 1);
- rtems_test_assert(null_loc->reference_count == 4);
- sc = rtems_libio_share_private_env(rtems_task_self());
rtems_libio_use_global_env();
diff --git a/testsuites/sptests/spprivenv01/init.c b/testsuites/sptests/spprivenv01/init.c
index f60bcef..a670085 100644
--- a/testsuites/sptests/spprivenv01/init.c
+++ b/testsuites/sptests/spprivenv01/init.c
@@ -31,6 +31,9 @@ rtems_task task_routine(rtems_task_argument not_used)
sc = rtems_libio_set_private_env();
directive_failed( sc, "set private env" );
+ rtems_test_assert( sc == RTEMS_SUCCESSFUL );
+ rtems_test_assert( rtems_current_user_env != &rtems_global_user_env );
sleep( 1 );
rtems_task_delete( RTEMS_SELF );
@@ -42,9 +45,9 @@ rtems_task Init(
rtems_status_code sc;
void *opaque;
- rtems_id current_task_id;
rtems_id task_id;
rtems_name another_task_name;
+ rtems_user_env_t *current_env;
TEST_BEGIN();
@@ -68,6 +71,12 @@ rtems_task Init(
puts( "Init - freeing the workspace memory" );
rtems_workspace_greedy_free( opaque );
+ puts( "Init - Attempt to get a private environment" );
+ sc = rtems_libio_set_private_env();
+ current_env = rtems_current_user_env;
+ rtems_test_assert( current_env != &rtems_global_user_env );
puts( "Init - creating a task name and a task -- OK" );
another_task_name =
@@ -85,33 +94,14 @@ rtems_task Init(
sc = rtems_task_start( task_id, task_routine, 0);
- puts( "Init - attempt to share the env with another task -- Expect error" );
- sc = rtems_libio_share_private_env( task_id );
- rtems_test_assert( sc == RTEMS_UNSATISFIED );
sleep( 1 );
- puts( "Init - attempt to share the env with another task -- OK" );
- rtems_test_assert( sc == RTEMS_SUCCESSFUL );
- rtems_test_assert( rtems_current_user_env->task_id == task_id );
- puts( "Init - Get current task id" );
- current_task_id = rtems_task_self();
+ puts( "Init - Check current private environment. Should be same as before." );
+ rtems_test_assert( rtems_current_user_env == current_env );
- puts( "Init - Attempt to reset current task's environment" );
- sc = rtems_libio_set_private_env();
- rtems_test_assert( rtems_current_user_env->task_id == current_task_id );
- puts( "Init - attempt to share with self -- OK" );
+ puts( "Init - Reset to global environment" );
+ rtems_libio_use_global_env();
+ rtems_test_assert( rtems_current_user_env == &rtems_global_user_env );
TEST_END();
diff --git a/testsuites/sptests/spprivenv01/spprivenv01.doc b/testsuites/sptests/spprivenv01/spprivenv01.doc
index cb5c1bc..71ed426 100644
--- a/testsuites/sptests/spprivenv01/spprivenv01.doc
+++ b/testsuites/sptests/spprivenv01/spprivenv01.doc
@@ -13,10 +13,9 @@ test set name: spprivenv01
directives:
concepts:
-+ Exercise the routines at privateenv.c, which reset/share a task's
-private environment
++ Exercise the routines at privateenv.c, which reset a task's private
+environment
diff --git a/testsuites/sptests/spprivenv01/spprivenv01.scn b/testsuites/sptests/spprivenv01/spprivenv01.scn
index b95832c..1b71be1 100644
--- a/testsuites/sptests/spprivenv01/spprivenv01.scn
+++ b/testsuites/sptests/spprivenv01/spprivenv01.scn
@@ -1,17 +1,14 @@
-*** TEST USER ENVIRONMENT ROUTINE - 01 ***
+*** BEGIN OF TEST SPPRIVENV 1 ***
Init - allocating most of heap -- OK
Init - attempt to reset env - expect RTEMS_NO_MEMORY
Init - freeing the allocated memory
Init - allocating most of workspace memory
-Init - attempt to reset env - expect RTEMS_NO_MEMORY
+Init - attempt to reset env - expect RTEMS_TOO_MANY
+Init - Attempt to get a private environment
Init - starting the task_routine, to set its private environment
-Init - attempt to share the env with another task -- Expect error
task_routine - setting up a private environment
-Init - attempt to share the env with another task -- OK
-Init - Get current task id
-Init - Attempt to reset current task's environment
-Init - attempt to share with self -- OK
-*** END OF TEST USER ENVIRONMENT ROUTINE - 01 ***
+Init - Check current private environment. Should be same as before.
+Init - Reset to global environment
+*** END OF TEST SPPRIVENV 1 ***
1.8.4.5
