[PATCH] This patch contains the changes required to get the mrm332 bsp working again.
Wed Mar 26 15:35:08 UTC 2014
Thanks James,
I have checked-in with a slightly modified commit message and
regenerated the preinstall.am. (If you did that manually, note that
the correct way is to use bootstrap -p from the rtems.git root
directory).
http://git.rtems.org/rtems/commit/?id=89aa1ec87da68b8a6cff2233552a739173e676a4
It would be good to investigate how to condition optimization flags on
whether or not BSP_SMALL_MEMORY is defined.
-Gedare
On Mon, Mar 24, 2014 at 5:32 AM, James Fitzsimons
<james.fitzsimons at gmail.com> wrote:
> Changed console driver to use interrupts instead of polling.
> Change to avoid overwriting CPU32Bug interrupt vector when setting up the Sci interrupt handler.
> Fixed type for boolean flag in bsp.h.
> Changed mrm332.h to use 25Mhz clock.
> Fixes to mrm332.cfg to use correct mcpu32 value for RTEMS_CPU_MODEL instead of m68332 which is no longer supported.
> Added -mcpu=cpu32 to compiler options.
> Removed broken ROM linker script and replaced broken RAM linker script with working ROM linker script.
> Removed no longer required file except_vect_332_ROM.S.
> Enabled 0xbeefbeef magic string in start.S to allow MRM version of CPU32Bug to auto run RTEMS.
> Removed old code from start.S
> Changed compiler optimization flag to optimize for size.
>  c/src/lib/libbsp/m68k/mrm332/Makefile.am           |   5 +-
>  c/src/lib/libbsp/m68k/mrm332/console/console.c     |   2 +-
>  c/src/lib/libbsp/m68k/mrm332/console/sci.c         |  19 +-
>  c/src/lib/libbsp/m68k/mrm332/include/bsp.h         |   2 +-
>  c/src/lib/libbsp/m68k/mrm332/include/mrm332.h      |   7 +-
>  .../lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg  |  34 +--
>  c/src/lib/libbsp/m68k/mrm332/preinstall.am         |   3 -
>  c/src/lib/libbsp/m68k/mrm332/start/start.S         | 125 ++-------
>  .../m68k/mrm332/startup/except_vect_332_ROM.S      | 289 --------------------
>  c/src/lib/libbsp/m68k/mrm332/startup/linkcmds      | 302 +++++++++++----------
>  c/src/lib/libbsp/m68k/mrm332/startup/linkcmds_ROM  | 212 ---------------
>  c/src/lib/libbsp/m68k/mrm332/startup/start_c.c     | 185 ++++++-------
>  12 files changed, 296 insertions(+), 889 deletions(-)
>  delete mode 100644 c/src/lib/libbsp/m68k/mrm332/startup/except_vect_332_ROM.S
>  delete mode 100644 c/src/lib/libbsp/m68k/mrm332/startup/linkcmds_ROM
> diff --git a/c/src/lib/libbsp/m68k/mrm332/Makefile.am b/c/src/lib/libbsp/m68k/mrm332/Makefile.am
> index 29b9b4a..9de7cee 100644
> --- a/c/src/lib/libbsp/m68k/mrm332/Makefile.am
> +++ b/c/src/lib/libbsp/m68k/mrm332/Makefile.am
> @@ -22,7 +22,7 @@ noinst_LIBRARIES = libbspstart.a
>  libbspstart_a_SOURCES = start/start.S
>  project_lib_DATA = start.$(OBJEXT)
> -dist_project_lib_DATA += startup/linkcmds startup/linkcmds_ROM
> +dist_project_lib_DATA += startup/linkcmds
>  noinst_LIBRARIES += libbsp.a
>  libbsp_a_SOURCES =
> @@ -33,8 +33,7 @@ libbsp_a_SOURCES += startup/start_c.c ../../shared/bsplibc.c \
>      ../../shared/bootcard.c ../../shared/sbrk.c \
>      ../../shared/bspclean.c \
>      ../../shared/setvec.c ../../shared/bsppretaskinghook.c \
> -    ../../shared/bspgetworkarea.c ../../shared/gnatinstallhandler.c \
> -    startup/except_vect_332_ROM.S
> +    ../../shared/bspgetworkarea.c ../../shared/gnatinstallhandler.c
>  # clock
>  libbsp_a_SOURCES += clock/ckinit.c
>  # console
> diff --git a/c/src/lib/libbsp/m68k/mrm332/console/console.c b/c/src/lib/libbsp/m68k/mrm332/console/console.c
> index ce1547e..94fb803 100644
> --- a/c/src/lib/libbsp/m68k/mrm332/console/console.c
> +++ b/c/src/lib/libbsp/m68k/mrm332/console/console.c
> @@ -42,7 +42,7 @@ rtems_device_driver console_open(
>      /* SCI internal uart */
> -    status = rtems_termios_open( major, minor, arg, SciGetTermiosHandlers( TRUE ) );
> +    status = rtems_termios_open( major, minor, arg, SciGetTermiosHandlers( FALSE ) );
>      return status;
> diff --git a/c/src/lib/libbsp/m68k/mrm332/console/sci.c b/c/src/lib/libbsp/m68k/mrm332/console/sci.c
> index 4b67c33..a671fb0 100644
> --- a/c/src/lib/libbsp/m68k/mrm332/console/sci.c
> +++ b/c/src/lib/libbsp/m68k/mrm332/console/sci.c
> @@ -351,8 +351,8 @@ rtems_isr SciIsr( rtems_vector_number vector )
>      if ( (*SCSR) & SCI_ERROR_OVERRUN )   SciErrorsOverrun ++;
>      /* see if it was a transmit interrupt */
> -    if ( (*SCSR) & SCI_XMTR_AVAILABLE )         /* data reg empty, xmt complete */
> +    /* data reg empty, xmt complete */
> +    if ( ( *SCCR1 & SCI_ENABLE_INT_TX ) && ( (*SCSR) & SCI_XMTR_AVAILABLE ) )
>          SciDisableTransmitInterrupts();
> @@ -554,12 +554,17 @@ int   SciInterruptOpen(
>      SciSetDataBits(SCI_8_DATA_BITS);            /* set data bits to 8 */
> -    /* Install our interrupt handler into RTEMS, where does 66 come from? */
> +    /* Install our interrupt handler into RTEMS. */
> +    /* 68 is an unused user-defined vector.  Note that the vector must be */
> +    /* even - it sets the low bit for SPI interrupts, and clears it for */
> +    /* SCI interrupts.  Also note that vector 66 is used by CPU32bug on */
> +    /* the mrm332. */
> -    rtems_interrupt_catch( SciIsr, 66, &old_vector );
> +    rtems_interrupt_catch( SciIsr, 68, &old_vector );
> -    *QIVR  = 66;
> -    *QIVR &= 0xf8;
> +    *QSMCR = (*QSMCR & ~IARB) | 1; // Is 1 a good value for qsm iarb?
> +    *QIVR  = 68;
> +    *QILR &= 0xf8;
>      *QILR |= 0x06 & 0x07;
>      SciEnableTransmitter();                     /* enable the transmitter */
> @@ -1382,7 +1387,7 @@ void SciWriteCharWait(uint8_t   c)
>      /* poll the fifo, waiting for room for another character */
> -    while ( ( *SCSR & SCI_XMTR_AVAILABLE ) == 0 )
> +    while ( ( *SCSR & SCI_XMTR_AVAILABLE ) != SCI_XMTR_AVAILABLE )
>          /* Either we are writing to the fifo faster than
>           * the uart can clock bytes out onto the cable,
> diff --git a/c/src/lib/libbsp/m68k/mrm332/include/bsp.h b/c/src/lib/libbsp/m68k/mrm332/include/bsp.h
> index 456b315..8f2c7cf 100644
> --- a/c/src/lib/libbsp/m68k/mrm332/include/bsp.h
> +++ b/c/src/lib/libbsp/m68k/mrm332/include/bsp.h
> @@ -42,7 +42,7 @@ extern char _copy_start[];
>  extern char _edata[];
>  extern char _clear_start[];
>  extern char end[];
> -extern char _copy_data_from_rom[];
> +extern bool _copy_data_from_rom;
>  /* constants */
> diff --git a/c/src/lib/libbsp/m68k/mrm332/include/mrm332.h b/c/src/lib/libbsp/m68k/mrm332/include/mrm332.h
> index 58e5b20..1b86727 100644
> --- a/c/src/lib/libbsp/m68k/mrm332/include/mrm332.h
> +++ b/c/src/lib/libbsp/m68k/mrm332/include/mrm332.h
> @@ -27,6 +27,8 @@
>  /* System Clock definitions */
>  #define XTAL 32768.0           /* crystal frequency in Hz */
> +/* Specify the CPU frequency. Do not specify a faster clock than your */
> +/* CPU is rated for! */
>  #if 0
>  /* Default MRM clock rate (8.388688 MHz) set by CPU32: */
>  #define MRM_W 0                        /* system clock parameters */
> @@ -34,18 +36,19 @@
>  #define MRM_Y 0x3f
>  #endif
> -#if 1
> +#if 0
>  /* 16.77722 MHz: */
>  #define MRM_W 1                        /* system clock parameters */
>  #define MRM_X 1
>  #define MRM_Y 0x0f
>  #endif
> -#if 0
> +#if 1
>  /* 25.16582 MHz: */
>  #define MRM_X 1
>  #define MRM_Y 0x17
> +#define SET_EDIV
>  #endif
>  #define SYS_CLOCK (XTAL*4.0*(MRM_Y+1)*(1 << (2*MRM_W+MRM_X)))
> diff --git a/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg b/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg
> index bf55e4f..de07e73 100644
> --- a/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg
> +++ b/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg
> @@ -5,41 +5,15 @@
>  include $(RTEMS_ROOT)/make/custom/default.cfg
>  RTEMS_CPU=m68k
> -RTEMS_CPU_MODEL=m68332
> +RTEMS_CPU_MODEL=mcpu32
>  #  This contains the compiler options necessary to select the CPU model
>  #  and (hopefully) optimize for it.
>  CPU_CFLAGS = -mcpu=cpu32
> -# optimize flag: typically -O2
> -CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
> +# using optimise for size due to small memory on target board.
> +CFLAGS_OPTIMIZE_V = -Os -g -fomit-frame-pointer
> -ifeq ($(MRM_IN_ROM),yes)
> -# Build a rommable image - move the .data section after the .text section
> -# in the image.
> -CPU_CFLAGS += -qnolinkcmds -T $(exec_prefix)/mrm332/lib/linkcmds_ROM
> -endif
> -define bsp-post-link
> -       $(OBJCOPY) --adjust-section-vma \
> -         .data=`m68k-rtems-objdump --section-headers $(basename $@).pxe | \
> -         awk 'function h2d(x) { x=toupper(x); digits=length(x); s=0 ; \
> -              for (p=digits; p>0; p--) \
> -              s += (16^(p-1)) * ( index("0123456789ABCDEF",\
> -               substr(x,1+digits-p,1)) -1 );\
> -               return s } ;\
> -               /\.text/ { base = $$4 ; size = $$3 };\
> -               END { printf("0x%x", h2d(base) + h2d(size)) }'\
> -              ` $(basename $@).pxe $(basename $@)$(EXEEXT)
> -       $(OBJCOPY) -O srec $(basename $@)$(EXEEXT) $(basename $@).srec
> -       sed -e 's/.$$//' -e '/^S0/d' $(basename $@).srec | \
> -           $(PACKHEX) > $(basename $@)$(DOWNEXT)
> -       $(NM) -g -n $(basename $@).pxe > $(basename $@).pnum
> -       rm -f $(basename $@).srec $(basename $@).srec
> -       $(default-bsp-post-link)
> -endef
> -else
> @@ -47,4 +21,4 @@ define bsp-post-link
>  endef
> -endif
> diff --git a/c/src/lib/libbsp/m68k/mrm332/preinstall.am b/c/src/lib/libbsp/m68k/mrm332/preinstall.am
> index 4a71e7d..19e184f 100644
> --- a/c/src/lib/libbsp/m68k/mrm332/preinstall.am
> +++ b/c/src/lib/libbsp/m68k/mrm332/preinstall.am
> @@ -69,7 +69,4 @@ $(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
>  PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds
> -$(PROJECT_LIB)/linkcmds_ROM: startup/linkcmds_ROM $(PROJECT_LIB)/$(dirstamp)
> -       $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds_ROM
> -PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds_ROM
> diff --git a/c/src/lib/libbsp/m68k/mrm332/start/start.S b/c/src/lib/libbsp/m68k/mrm332/start/start.S
> index e8f7514..5e2bbeb 100644
> --- a/c/src/lib/libbsp/m68k/mrm332/start/start.S
> +++ b/c/src/lib/libbsp/m68k/mrm332/start/start.S
> @@ -22,7 +22,7 @@ BEGIN_CODE
>    /* Put the header necessary for the modified CPU32bug to automatically
>       start up rtems: */
> -#if 0
> +#if 1
>  .long 0xbeefbeef ;
>  #endif
>  .long 0 ;
> @@ -31,11 +31,16 @@ BEGIN_CODE
>  .global start
>         start:
> -       oriw   #0x0700,sr
> -       movel  #end, d0
> -       addl   #_StackSize,d0
> +       oriw   #0x0700,sr                       /* Mask off interupts */
> +       // Set VBR to CPU32Bug vector table address
> +       movel   #0x0,d0                         /* Use the initial vectors until we get going */
> +       movecl  d0,vbr
> +       movel  #end, d0                         /* Next 3 instructions set stack pointer    */
> +       addl   #_StackSize,d0       /* sp = end + _StackSize from linker script */
>         movel  d0,sp
> -       movel  d0,a6
> +       movel  d0,a6
>    /* include in ram_init.S */
> @@ -46,6 +51,13 @@ BEGIN_CODE
>    /* Module Configuration Register */
>    /*    see section(s) 3.1.3-3.1.6 of the SIM Reference Manual */
> +  /* SIMCR etc and SAM macro all defined in sim.h found at     */
> +  /* /cpukit/score/cpu/m68k/rtems/m68k/sim.h                              */
> +  /* The code below does the following:                                                   */
> +  /*   - Sets Freeze Software Enable                                              */
> +  /*   - Turns off Show Cycle Enable                                              */
> +  /*   - Sets the location of SIM module mapping                          */
> +  /*   - Sets the SIM Interrupt Arbitration Field                         */
>         lea     SIMCR, a0
>         movew   #FRZSW,d0
>         oriw    #SAM(0,8,SHEN),d0
> @@ -57,106 +69,3 @@ BEGIN_CODE
>  END_CODE
> -#if 0
> -  /* Synthesizer Control Register */
> -  /*    see section(s) 4.8 */
> -  /* end include in ram_init.S */
> -  *SYNCR = (unsigned short int)
> -    ( SAM(MRM_W,15,VCO) | SAM(0x0,14,PRESCALE) | SAM(MRM_Y,8,COUNTER) );
> -  while (! (*SYNCR & SLOCK));  /* protect from clock overshoot */
> -  /* include in ram_init.S */
> -    ( SAM(MRM_W,15,VCO) | SAM(MRM_X,14,PRESCALE) | SAM(MRM_Y,8,COUNTER) );
> -  /* System Protection Control Register */
> -  /*    !!! can only write to once after reset !!! */
> -  /*    see section 3.8.4 of the SIM Reference Manual */
> -  *SYPCR = (unsigned char)( HME | BME );
> -  /* Periodic Interrupr Control Register */
> -  /*    see section 3.8.2 of the SIM Reference Manual */
> -  *PICR = (unsigned short int)
> -    ( SAM(0,8,PIRQL) | SAM(MRM_PIV,0,PIV) );
> -  /*     ^^^ zero disables interrupt, don't enable here or ram_init will
> -        be wrong. It's enabled below. */
> -  /* Periodic Interrupt Timer Register */
> -  /*    see section 3.8.3 of the SIM Reference Manual */
> -  *PITR = (unsigned short int)( SAM(0x09,0,PITM) );
> -  /*    1.098mS interrupt, assuming 32.768 KHz input clock */
> -  /* Port C Data */
> -  /*    load values before enabled */
> -  *PORTC = (unsigned char) 0x0;
> -  /* Port E and F Data Register */
> -  /*    see section 9 of the SIM Reference Manual */
> -  *PORTE0 = (unsigned char) 0;
> -  *PORTF0 = (unsigned char) 0;
> -  /* Port E and F Data Direction Register */
> -  *DDRE = (unsigned char) 0xff;
> -  *DDRF = (unsigned char) 0xfd;
> -  /* Port E and F Pin Assignment Register */
> -  *PEPAR = (unsigned char) 0;
> -  *PFPAR = (unsigned char) 0;
> -  /* end of SIM initalization code */
> -   * Initialize RAM by copying the .data section out of ROM (if
> -   * needed) and "zero-ing" the .bss section.
> -    register char *src = _etext;
> -    register char *dst = _copy_start;
> -    if (_copy_data_from_rom)
> -      /* ROM has data at end of text; copy it. */
> -      while (dst < _edata)
> -       *dst++ = *src++;
> -    /* Zero bss */
> -    for (dst = _clear_start; dst< end; dst++)
> -       *dst = 0;
> -   * Initialize vector table.
> -    rtems_isr_entry *monitors_vector_table;
> -    m68k_get_vbr(monitors_vector_table);
> -    M68Kvec[  4 ] = monitors_vector_table[  4 ];   /* breakpoints vector */
> -    M68Kvec[  9 ] = monitors_vector_table[  9 ];   /* trace vector */
> -    M68Kvec[ 31 ] = monitors_vector_table[ 31 ];   /* level 7 interrupt */
> -    M68Kvec[ 47 ] = monitors_vector_table[ 47 ];   /* system call vector */
> -    M68Kvec[ 66 ] = monitors_vector_table[ 66 ];   /* user defined */
> -    m68k_set_vbr(&M68Kvec);
> -   * Initalize the board.
> -  Spurious_Initialize();
> -  console_init();
> -   * Execute main with arguments argc and agrv.
> -  boot_card((void*)0);
> -  reboot();
> -#endif
> diff --git a/c/src/lib/libbsp/m68k/mrm332/startup/except_vect_332_ROM.S b/c/src/lib/libbsp/m68k/mrm332/startup/except_vect_332_ROM.S
> deleted file mode 100644
> index 6a2e679..0000000
> --- a/c/src/lib/libbsp/m68k/mrm332/startup/except_vect_332_ROM.S
> +++ /dev/null
> @@ -1,289 +0,0 @@
> -/* Exception Vector definitions follow */
> -       /* !!! Warning !!! This table is not tested, and
> -          the user must make sure it is complete. */
> -       /* If we use TRAP #15 for reboot, note that group 0 and 1 exceptions
> -          will have priority. */
> -       /* This is the "magic word" that CPU32bug uses to indicate that
> -          there is a bootable image here. */
> -       .long   0xBEEFBEEF
> -       /* Vector 0:    RESET:  Initial SSP */
> -       .long   _RamEnd
> -       /* Vector 1:    RESET:  Initial PC */
> -       .long   start
> -       /* default action for undefined vectors is to re-boot */
> -       /* Note group 0 and 1 exception (like trace) have priority
> -          over other exceptions (like trap #15) that may call this. */
> -       /* Vectors 2-255 */
> -       .long reboot   /* exception vector:   2 */
> -       .long reboot   /* exception vector:   3 */
> -       .long reboot   /* exception vector:   4 */
> -       .long reboot   /* exception vector:   5 */
> -       .long reboot   /* exception vector:   6 */
> -       .long reboot   /* exception vector:   7 */
> -       .long reboot   /* exception vector:   8 */
> -       .long reboot   /* exception vector:   9 */
> -       .long reboot   /* exception vector:  10 */
> -       .long reboot   /* exception vector:  11 */
> -       .long reboot   /* exception vector:  12 */
> -       .long reboot   /* exception vector:  13 */
> -       .long reboot   /* exception vector:  14 */
> -       .long reboot   /* exception vector:  15 */
> -       .long reboot   /* exception vector:  16 */
> -       .long reboot   /* exception vector:  17 */
> -       .long reboot   /* exception vector:  18 */
> -       .long reboot   /* exception vector:  19 */
> -       .long reboot   /* exception vector:  20 */
> -       .long reboot   /* exception vector:  21 */
> -       .long reboot   /* exception vector:  22 */
> -       .long reboot   /* exception vector:  23 */
> -       .long reboot   /* exception vector:  24 */
> -       .long reboot   /* exception vector:  25 */
> -       .long reboot   /* exception vector:  26 */
> -       .long reboot   /* exception vector:  27 */
> -       .long reboot   /* exception vector:  28 */
> -       .long reboot   /* exception vector:  29 */
> -       .long reboot   /* exception vector:  30 */
> -       .long reboot   /* exception vector:  31 */
> -       .long reboot   /* exception vector:  32 */
> -       .long reboot   /* exception vector:  33 */
> -       .long reboot   /* exception vector:  34 */
> -       .long reboot   /* exception vector:  35 */
> -       .long reboot   /* exception vector:  36 */
> -       .long reboot   /* exception vector:  37 */
> -       .long reboot   /* exception vector:  38 */
> -       .long reboot   /* exception vector:  39 */
> -       .long reboot   /* exception vector:  40 */
> -       .long reboot   /* exception vector:  41 */
> -       .long reboot   /* exception vector:  42 */
> -       .long reboot   /* exception vector:  43 */
> -       .long reboot   /* exception vector:  44 */
> -       .long reboot   /* exception vector:  45 */
> -       .long reboot   /* exception vector:  46 */
> -       .long _reboot  /* the reboot trap:   47 */
> -       .long reboot   /* exception vector:  48 */
> -       .long reboot   /* exception vector:  49 */
> -       .long reboot   /* exception vector:  50 */
> -       .long reboot   /* exception vector:  51 */
> -       .long reboot   /* exception vector:  52 */
> -       .long reboot   /* exception vector:  53 */
> -       .long reboot   /* exception vector:  54 */
> -       .long reboot   /* exception vector:  55 */
> -       .long reboot   /* exception vector:  56 */
> -       .long reboot   /* exception vector:  57 */
> -       .long reboot   /* exception vector:  58 */
> -       .long reboot   /* exception vector:  59 */
> -       .long reboot   /* exception vector:  60 */
> -       .long reboot   /* exception vector:  61 */
> -       .long reboot   /* exception vector:  62 */
> -       .long reboot   /* exception vector:  63 */
> -       .long reboot   /* exception vector:  64 */
> -       .long reboot   /* exception vector:  65 */
> -       .long reboot   /* exception vector:  66 */
> -       .long reboot   /* exception vector:  67 */
> -       .long reboot   /* exception vector:  68 */
> -       .long reboot   /* exception vector:  69 */
> -       .long reboot   /* exception vector:  70 */
> -       .long reboot   /* exception vector:  71 */
> -       .long reboot   /* exception vector:  72 */
> -       .long reboot   /* exception vector:  73 */
> -       .long reboot   /* exception vector:  74 */
> -       .long reboot   /* exception vector:  75 */
> -       .long reboot   /* exception vector:  76 */
> -       .long reboot   /* exception vector:  77 */
> -       .long reboot   /* exception vector:  78 */
> -       .long reboot   /* exception vector:  79 */
> -       .long reboot   /* exception vector:  80 */
> -       .long reboot   /* exception vector:  81 */
> -       .long reboot   /* exception vector:  82 */
> -       .long reboot   /* exception vector:  83 */
> -       .long reboot   /* exception vector:  84 */
> -       .long reboot   /* exception vector:  85 */
> -       .long reboot   /* exception vector:  86 */
> -       .long reboot   /* exception vector:  87 */
> -       .long reboot   /* exception vector:  88 */
> -       .long reboot   /* exception vector:  89 */
> -       .long reboot   /* exception vector:  90 */
> -       .long reboot   /* exception vector:  91 */
> -       .long reboot   /* exception vector:  92 */
> -       .long reboot   /* exception vector:  93 */
> -       .long reboot   /* exception vector:  94 */
> -       .long reboot   /* exception vector:  95 */
> -       .long reboot   /* exception vector:  96 */
> -       .long reboot   /* exception vector:  97 */
> -       .long reboot   /* exception vector:  98 */
> -       .long reboot   /* exception vector:  99 */
> -       .long reboot   /* exception vector: 100 */
> -       .long reboot   /* exception vector: 101 */
> -       .long reboot   /* exception vector: 102 */
> -       .long reboot   /* exception vector: 103 */
> -       .long reboot   /* exception vector: 104 */
> -       .long reboot   /* exception vector: 105 */
> -       .long reboot   /* exception vector: 106 */
> -       .long reboot   /* exception vector: 107 */
> -       .long reboot   /* exception vector: 108 */
> -       .long reboot   /* exception vector: 109 */
> -       .long reboot   /* exception vector: 110 */
> -       .long reboot   /* exception vector: 111 */
> -       .long reboot   /* exception vector: 112 */
> -       .long reboot   /* exception vector: 113 */
> -       .long reboot   /* exception vector: 114 */
> -       .long reboot   /* exception vector: 115 */
> -       .long reboot   /* exception vector: 116 */
> -       .long reboot   /* exception vector: 117 */
> -       .long reboot   /* exception vector: 118 */
> -       .long reboot   /* exception vector: 119 */
> -       .long reboot   /* exception vector: 120 */
> -       .long reboot   /* exception vector: 121 */
> -       .long reboot   /* exception vector: 122 */
> -       .long reboot   /* exception vector: 123 */
> -       .long reboot   /* exception vector: 124 */
> -       .long reboot   /* exception vector: 125 */
> -       .long reboot   /* exception vector: 126 */
> -       .long reboot   /* exception vector: 127 */
> -       .long reboot   /* exception vector: 128 */
> -       .long reboot   /* exception vector: 129 */
> -       .long reboot   /* exception vector: 130 */
> -       .long reboot   /* exception vector: 131 */
> -       .long reboot   /* exception vector: 132 */
> -       .long reboot   /* exception vector: 133 */
> -       .long reboot   /* exception vector: 134 */
> -       .long reboot   /* exception vector: 135 */
> -       .long reboot   /* exception vector: 136 */
> -       .long reboot   /* exception vector: 137 */
> -       .long reboot   /* exception vector: 138 */
> -       .long reboot   /* exception vector: 139 */
> -       .long reboot   /* exception vector: 140 */
> -       .long reboot   /* exception vector: 141 */
> -       .long reboot   /* exception vector: 142 */
> -       .long reboot   /* exception vector: 143 */
> -       .long reboot   /* exception vector: 144 */
> -       .long reboot   /* exception vector: 145 */
> -       .long reboot   /* exception vector: 146 */
> -       .long reboot   /* exception vector: 147 */
> -       .long reboot   /* exception vector: 148 */
> -       .long reboot   /* exception vector: 149 */
> -       .long reboot   /* exception vector: 150 */
> -       .long reboot   /* exception vector: 151 */
> -       .long reboot   /* exception vector: 152 */
> -       .long reboot   /* exception vector: 153 */
> -       .long reboot   /* exception vector: 154 */
> -       .long reboot   /* exception vector: 155 */
> -       .long reboot   /* exception vector: 156 */
> -       .long reboot   /* exception vector: 157 */
> -       .long reboot   /* exception vector: 158 */
> -       .long reboot   /* exception vector: 159 */
> -       .long reboot   /* exception vector: 160 */
> -       .long reboot   /* exception vector: 161 */
> -       .long reboot   /* exception vector: 162 */
> -       .long reboot   /* exception vector: 163 */
> -       .long reboot   /* exception vector: 164 */
> -       .long reboot   /* exception vector: 165 */
> -       .long reboot   /* exception vector: 166 */
> -       .long reboot   /* exception vector: 167 */
> -       .long reboot   /* exception vector: 168 */
> -       .long reboot   /* exception vector: 169 */
> -       .long reboot   /* exception vector: 170 */
> -       .long reboot   /* exception vector: 171 */
> -       .long reboot   /* exception vector: 172 */
> -       .long reboot   /* exception vector: 173 */
> -       .long reboot   /* exception vector: 174 */
> -       .long reboot   /* exception vector: 175 */
> -       .long reboot   /* exception vector: 176 */
> -       .long reboot   /* exception vector: 177 */
> -       .long reboot   /* exception vector: 178 */
> -       .long reboot   /* exception vector: 179 */
> -       .long reboot   /* exception vector: 180 */
> -       .long reboot   /* exception vector: 181 */
> -       .long reboot   /* exception vector: 182 */
> -       .long reboot   /* exception vector: 183 */
> -       .long reboot   /* exception vector: 184 */
> -       .long reboot   /* exception vector: 185 */
> -       .long reboot   /* exception vector: 186 */
> -       .long reboot   /* exception vector: 187 */
> -       .long reboot   /* exception vector: 188 */
> -       .long reboot   /* exception vector: 189 */
> -       .long reboot   /* exception vector: 190 */
> -       .long reboot   /* exception vector: 191 */
> -       .long reboot   /* exception vector: 192 */
> -       .long reboot   /* exception vector: 193 */
> -       .long reboot   /* exception vector: 194 */
> -       .long reboot   /* exception vector: 195 */
> -       .long reboot   /* exception vector: 196 */
> -       .long reboot   /* exception vector: 197 */
> -       .long reboot   /* exception vector: 198 */
> -       .long reboot   /* exception vector: 199 */
> -       .long reboot   /* exception vector: 200 */
> -       .long reboot   /* exception vector: 201 */
> -       .long reboot   /* exception vector: 202 */
> -       .long reboot   /* exception vector: 203 */
> -       .long reboot   /* exception vector: 204 */
> -       .long reboot   /* exception vector: 205 */
> -       .long reboot   /* exception vector: 206 */
> -       .long reboot   /* exception vector: 207 */
> -       .long reboot   /* exception vector: 208 */
> -       .long reboot   /* exception vector: 209 */
> -       .long reboot   /* exception vector: 210 */
> -       .long reboot   /* exception vector: 211 */
> -       .long reboot   /* exception vector: 212 */
> -       .long reboot   /* exception vector: 213 */
> -       .long reboot   /* exception vector: 214 */
> -       .long reboot   /* exception vector: 215 */
> -       .long reboot   /* exception vector: 216 */
> -       .long reboot   /* exception vector: 217 */
> -       .long reboot   /* exception vector: 218 */
> -       .long reboot   /* exception vector: 219 */
> -       .long reboot   /* exception vector: 220 */
> -       .long reboot   /* exception vector: 221 */
> -       .long reboot   /* exception vector: 222 */
> -       .long reboot   /* exception vector: 223 */
> -       .long reboot   /* exception vector: 224 */
> -       .long reboot   /* exception vector: 225 */
> -       .long reboot   /* exception vector: 226 */
> -       .long reboot   /* exception vector: 227 */
> -       .long reboot   /* exception vector: 228 */
> -       .long reboot   /* exception vector: 229 */
> -       .long reboot   /* exception vector: 230 */
> -       .long reboot   /* exception vector: 231 */
> -       .long reboot   /* exception vector: 232 */
> -       .long reboot   /* exception vector: 233 */
> -       .long reboot   /* exception vector: 234 */
> -       .long reboot   /* exception vector: 235 */
> -       .long reboot   /* exception vector: 236 */
> -       .long reboot   /* exception vector: 237 */
> -       .long reboot   /* exception vector: 238 */
> -       .long reboot   /* exception vector: 239 */
> -       .long reboot   /* exception vector: 240 */
> -       .long reboot   /* exception vector: 241 */
> -       .long reboot   /* exception vector: 242 */
> -       .long reboot   /* exception vector: 243 */
> -       .long reboot   /* exception vector: 244 */
> -       .long reboot   /* exception vector: 245 */
> -       .long reboot   /* exception vector: 246 */
> -       .long reboot   /* exception vector: 247 */
> -       .long reboot   /* exception vector: 248 */
> -       .long reboot   /* exception vector: 249 */
> -       .long reboot   /* exception vector: 250 */
> -       .long reboot   /* exception vector: 251 */
> -       .long reboot   /* exception vector: 252 */
> -       .long reboot   /* exception vector: 253 */
> -       .long reboot   /* exception vector: 254 */
> -       .long reboot   /* exception vector: 255 */
> -_reboot:
> -       move    #0x2700,%sr     /* mask interrupts */
> -       movea.l (0x0).w,%a7     /* load stack */
> -       movea.l (0x4).w,%a0     /* jmp to location of reset vector */
> -       jmp     (%a0)
> -reboot:
> -       trap    #15             /* use trap exception to enter supervisor
> -                                  state. Trace mode ( and other group 0
> -                                  and 1 exceptions) *could* screw this up if
> -                                  not vectored to reboot or did not return. */
> diff --git a/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds b/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds
> index 651fc9f..378559c 100644
> --- a/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds
> +++ b/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds
> @@ -5,20 +5,26 @@ OUTPUT_ARCH(m68k)
>  __DYNAMIC  =  0;
> - * The memory map looks like this:
> + * ROM:
>   * +--------------------+ <- low memory
>   * | .text              |
>   * |        etext       |
>   * |        ctor list   | the ctor and dtor lists are for
>   * |        dtor list   | C++ support
>   * |        _endtext    |
> + * | temporary .data    | .data is moved to RAM by crt0
> + * +--------------------+ <- high memory
> + * RAM:
> + * +--------------------+ <- low memory
>   * | .data              | initialized data goes here
>   * |        _sdata      |
>   * |        _edata      |
>   * | .bss               |
> - * |        _clear_start| start of bss, cleared by crt0
> + * |        __bss_start | start of bss, cleared by crt0
>   * |        _end        | start of heap, used by sbrk()
>   * |    heap space      |
> @@ -31,150 +37,170 @@ __DYNAMIC  =  0;
>   * Declare some sizes.
> -RamBase = DEFINED(RamBase) ? RamBase : 0x10000;
> -RamSize = DEFINED(RamSize) ? RamSize : 0x70000;
> +RomBase = DEFINED(RomBase) ? RomBase : 0x90000;
> +RamBase = DEFINED(RamBase) ? RamBase : 0x03000;
> +RamSize = DEFINED(RamSize) ? RamSize : 0x7d000;
>  _RamEnd = RamBase + RamSize;
> -HeapSize = DEFINED(HeapSize) ? HeapSize : 0x0;
> -_StackSize = DEFINED(_StackSize) ? _StackSize : 0x2000;
>  MEMORY
> -  ram     : ORIGIN = 0x10000, LENGTH = 0x70000
> +  rom     : ORIGIN = 0x90000, LENGTH = 0x70000
> +  ram     : ORIGIN = 0x03000, LENGTH = 0x7d000
> -_copy_data_from_rom = 0;
> +_copy_data_from_rom = 1;
> +HeapSize = DEFINED(HeapSize) ? HeapSize : 0x0;
> +_StackSize = DEFINED(_StackSize) ? _StackSize : 0x2000;
> - * stick everything in ram (of course)
>  SECTIONS
> -       ram : {
> -       } >ram
> -         * Text, data and bss segments
> -        .text : {
> -                *(.text*)
> -                * C++ constructors/destructors
> -               *(.gnu.linkonce.t.*)
> -                * Initialization and finalization code.
> -                * Various files can provide initialization and finalization
> -                * functions.  crtbegin.o and crtend.o are two instances. The
> -                * body of these functions are in .init and .fini sections. We
> -                * accumulate the bodies here, and prepend function prologues
> -                * from crti.o and function epilogues from crtn.o. crti.o must
> -                * be linked first; crtn.o must be linked last.  Because these
> -                * are wildcards, it doesn't matter if the user does not
> -                * actually link against crti.o and crtn.o; the linker won't
> -                * look for a file to match a wildcard.  The wildcard also
> -                * means that it doesn't matter which directory crti.o and
> -                * crtn.o are in.
> -               PROVIDE (_init = .);
> -               *crti.o(.init)
> -               *(.init)
> -               *crtn.o(.init)
> -               PROVIDE (_fini = .);
> -               *crti.o(.fini)
> -               *(.fini)
> -               *crtn.o(.fini)
> -                * Special FreeBSD sysctl sections.
> -               . = ALIGN (16);
> -               __start_set_sysctl_set = .;
> -               *(set_sysctl_*);
> -               __stop_set_sysctl_set = ABSOLUTE(.);
> -               *(set_domain_*);
> -               *(set_pseudo_*);
> -                * gcc uses crtbegin.o to find the start of the constructors
> -                * and destructors so we make sure it is first.  Because this
> -                * is a wildcard, it doesn't matter if the user does not
> -                * actually link against crtbegin.o; the linker won't look for
> -                * a file to match a wildcard.  The wildcard also means that
> -                * it doesn't matter which directory crtbegin.o is in. The
> -                * constructor and destructor list are terminated in
> -                * crtend.o.  The same comments apply to it.
> -               . = ALIGN (16);
> -               *crtbegin.o(.ctors)
> -               *(.ctors)
> -               *crtend.o(.ctors)
> -               *crtbegin.o(.dtors)
> -               *(.dtors)
> -               *crtend.o(.dtors)
> -                * Exception frame info
> -               . = ALIGN (16);
> -               *(.eh_frame)
> -                * Read-only data
> -               . = ALIGN (16);
> -               _rodata_start = .;
> -               *(.rodata*)
> -               *(.gnu.linkonce.r*)
> -                 . = ALIGN (16);
> -                PROVIDE (_etext = .);
> -        } >ram
> -       .tdata : {
> -               _TLS_Data_begin = .;
> -               *(.tdata .tdata.* .gnu.linkonce.td.*)
> -               _TLS_Data_end = .;
> -       } >ram
> -       .tbss : {
> -               _TLS_BSS_begin = .;
> -               *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
> -               _TLS_BSS_end = .;
> -       } >ram
> -       _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
> -       _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
> -       _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
> -       _TLS_Alignment = ALIGNOF (.tdata);
> -        .data : {
> -                PROVIDE (_copy_start = .);
> -                *(.data*)
> -               *(.gnu.linkonce.d*)
> -               *(.gcc_except_table*)
> -               *(.jcr)
> -                . = ALIGN (16);
> -                PROVIDE (_edata = .);
> -                PROVIDE (_copy_end = .);
> -        } >ram
> -        .bss : {
> -                _clear_start = .;
> -                *(.dynbss)
> -                *(.bss* .gnu.linkonce.b.*)
> -                *(COMMON)
> -                . = ALIGN (16);
> -                PROVIDE (end = .);
> -                . += _StackSize;
> -                . = ALIGN (16);
> -                _stack_init = .;
> -                _clear_end = .;
> -                WorkAreaBase = .;
> -        } >ram
> +  .text :
> +    text_start = .;
> +    _text_start = .;
> +    *(.text*)
> +    . = ALIGN (16);
> +        * C++ constructors/destructors
> +       *(.gnu.linkonce.t.*)
> +     * Initialization and finalization code.
> +     * Various files can provide initialization and finalization
> +     * functions.  crtbegin.o and crtend.o are two instances. The
> +     * body of these functions are in .init and .fini sections. We
> +     * accumulate the bodies here, and prepend function prologues
> +     * from crti.o and function epilogues from crtn.o. crti.o must
> +     * be linked first; crtn.o must be linked last.  Because these
> +     * are wildcards, it doesn't matter if the user does not
> +     * actually link against crti.o and crtn.o; the linker won't
> +     * look for a file to match a wildcard.  The wildcard also
> +     * means that it doesn't matter which directory crti.o and
> +     * crtn.o are in.
> +    PROVIDE (_init = .);
> +    *crti.o(.init)
> +    *(.init)
> +    *crtn.o(.init)
> +    PROVIDE (_fini = .);
> +    *crti.o(.fini)
> +    *(.fini)
> +    *crtn.o(.fini)
> +     * Special FreeBSD sysctl sections.
> +    . = ALIGN (16);
> +    __start_set_sysctl_set = .;
> +    *(set_sysctl_*);
> +    __stop_set_sysctl_set = ABSOLUTE(.);
> +    *(set_domain_*);
> +    *(set_pseudo_*);
> +     * gcc uses crtbegin.o to find the start of the constructors
> +     * and destructors so we make sure it is first.  Because this
> +     * is a wildcard, it doesn't matter if the user does not
> +     * actually link against crtbegin.o; the linker won't look for
> +     * a file to match a wildcard.  The wildcard also means that
> +     * it doesn't matter which directory crtbegin.o is in. The
> +     * constructor and destructor list are terminated in
> +     * crtend.o.  The same comments apply to it.
> +    . = ALIGN (16);
> +    *crtbegin.o(.ctors)
> +    *(.ctors)
> +    *crtend.o(.ctors)
> +    *crtbegin.o(.dtors)
> +    *(.dtors)
> +    *crtend.o(.dtors)
> +        * Exception frame info
> +       . = ALIGN (16);
> +       *(.eh_frame)
> +     * Read-only data
> +    . = ALIGN (16);
> +    _rodata_start = . ;
> +    *(.rodata*)
> +    *(.gnu.linkonce.r*)
> +    . = ALIGN (16);
> +    PROVIDE (_etext = .);
> +    _endtext = .;
> +    __data_start_rom = .;
> +  } > rom
> +  .tdata : {
> +    _TLS_Data_begin = .;
> +    *(.tdata .tdata.* .gnu.linkonce.td.*)
> +    _TLS_Data_end = .;
> +  } > rom
> +  .tbss : {
> +    _TLS_BSS_begin = .;
> +    *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
> +    _TLS_BSS_end = .;
> +  } > rom
> +  _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
> +  _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
> +  _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
> +  _TLS_Alignment = ALIGNOF (.tdata);
> +  .gcc_exc :
> +  AT ( ADDR(.tdata) + SIZEOF( .tdata ) )
> +    *(.gcc_exc)
> +  } > ram
> +  .data : AT(__data_start_rom)
> +       PROVIDE (_copy_start = .);
> +    *(.data*)
> +       *(.gnu.linkonce.d*)
> +       *(.gcc_except_table*)
> +       *(.jcr)
> +    . = ALIGN (16);
> +    PROVIDE (_edata = .);
> +    PROVIDE (_copy_end = .);
> +  } > ram
> +  .shbss :
> +    *(.shbss)
> +  } > ram
> +  .bss :
> +    M68Kvec = .;
> +    . += (256 * 4);
> +    _clear_start = .;
> +    *(.dynbss)
> +    *(.bss* .gnu.linkonce.b.*)
> +    *(COMMON)
> +    . = ALIGN (16);
> +    PROVIDE (end = .);
> +    . += _StackSize;
> +    . = ALIGN (16);
> +    _stack_init = .;
> +    _clear_end = .;
> +    WorkAreaBase = .;
> +  } > ram
> +  .stab . (NOLOAD) :
> +    [ .stab ]
> +  .stabstr . (NOLOAD) :
> +    [ .stabstr ]
> diff --git a/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds_ROM b/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds_ROM
> index 48b2f3f..0000000
> --- a/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds_ROM
> +++ /dev/null
> @@ -1,212 +0,0 @@
> -/*  linkcmds
> -OUTPUT_ARCH(m68k)
> -STARTUP(except_vect_332_ROM.o)
> -__DYNAMIC  =  0;
> - * ROM:
> - * +--------------------+ <- low memory
> - * | .text              |
> - * |        etext       |
> - * |        ctor list   | the ctor and dtor lists are for
> - * |        dtor list   | C++ support
> - * |        _endtext    |
> - * | temporary .data    | .data is moved to RAM by crt0
> - * +--------------------+ <- high memory
> - * RAM:
> - * | .data              | initialized data goes here
> - * |        _sdata      |
> - * |        _edata      |
> - * | .bss               |
> - * |        __bss_start | start of bss, cleared by crt0
> - * |        _end        | start of heap, used by sbrk()
> - * |    heap space      |
> - * |        _ENDHEAP    |
> - * |    stack space     |
> - * |        __stack     | top of stack
> -MEMORY
> -  rom     : ORIGIN = 0x90000, LENGTH = 0x70000
> -  ram     : ORIGIN = 0x03000, LENGTH = 0x7d000
> -RamBase = DEFINED(RamBase) ? RamBase : 0x003000;
> -RamSize = DEFINED(RamSize) ? RamSize : 0x7d000;
> -_RamEnd = RamBase + RamSize;
> -__end_of_ram = 0x080000;
> -_copy_data_from_rom = 1;
> -SECTIONS
> -  .text :
> -    CREATE_OBJECT_SYMBOLS
> -    text_start = .;
> -    _text_start = .;
> -    *(.text*)
> -    . = ALIGN (16);
> -     * crtn.o are in.
> -    *crti.o(.init)
> -    *(.init)
> -    *crtn.o(.init)
> -    *crti.o(.fini)
> -    *(.fini)
> -    *crtn.o(.fini)
> -    . = ALIGN (16);
> -    *(set_sysctl_*);
> -    *(set_domain_*);
> -    *(set_pseudo_*);
> -    . = ALIGN (16);
> -    *(.ctors)
> -    *crtend.o(.ctors)
> -    *(.dtors)
> -    *crtend.o(.dtors)
> -    *(.eh_frame)
> -    . = ALIGN (16);
> -     * Read-only data
> -    . = ALIGN (16);
> -    _rodata_start = . ;
> -    *(.rodata*)
> -    etext = ALIGN(0x10);
> -    __CTOR_LIST__ = .;
> -    LONG((__CTOR_END__ - __CTOR_LIST__) / 4 - 2)
> -    *(.ctors)
> -    LONG(0)
> -    __CTOR_END__ = .;
> -    __DTOR_LIST__ = .;
> -    LONG((__DTOR_END__ - __DTOR_LIST__) / 4 - 2)
> -    *(.dtors)
> -    LONG(0)
> -    __DTOR_END__ = .;
> -    *(.lit)
> -    *(.shdata)
> -    _etext = .;
> -    _endtext = .;
> -  } > rom
> -  .tdata : {
> -  } > rom
> -  .tbss : {
> -    _TLS_BSS_end = .;
> -  } > rom
> -  .gcc_exc :
> -  AT ( ADDR(.tdata) + SIZEOF( .tdata ) )
> -    *(.gcc_exc)
> -  } > ram
> -  .data :
> -    data_start = .;
> -    _data_start = .;
> -    _copy_start = .;
> -    _sdata = . ;
> -    *(.data)
> -    *(.jcr)
> -    CONSTRUCTORS
> -    edata = ALIGN(0x10);
> -    _edata = .;
> -  } > ram
> -  .shbss :
> -    *(.shbss)
> -  } > ram
> -  .bss :
> -    __bss_start = ALIGN(0x8);
> -    bss_start = .;
> -    _bss_start = .;
> -    _clear_start = .;
> -    *(.shbss)
> -    *(.dynbss)
> -    *(COMMON)
> -    . = ALIGN (16);
> -    end = .;
> -    _end = ALIGN(0x8);
> -    __end = ALIGN(0x8);
> -    WorkAreaBase = . + _StackSize;
> -  } > ram
> -  .stab . (NOLOAD) :
> -    [ .stab ]
> -  .stabstr . (NOLOAD) :
> -    [ .stabstr ]
> diff --git a/c/src/lib/libbsp/m68k/mrm332/startup/start_c.c b/c/src/lib/libbsp/m68k/mrm332/startup/start_c.c
> index 5c3c38c..060c96b 100644
> --- a/c/src/lib/libbsp/m68k/mrm332/startup/start_c.c
> +++ b/c/src/lib/libbsp/m68k/mrm332/startup/start_c.c
> @@ -14,14 +14,11 @@
> +#include <bsp.h>
> +#include <bsp/bootcard.h>
>  #include <mrm332.h>
>  #include <rtems/m68k/sim.h>
>  #define __START_C__
> -#include "bsp.h"
> -#include <bsp/bootcard.h>
> -rtems_isr_entry M68Kvec[256];
> -rtems_isr_entry vectors[256];
>   *  This prototype really should have the noreturn attribute but
> @@ -32,99 +29,97 @@ void start_c(void);
>  void start_c(void) {
> +#ifdef SET_EDIV
> +#define OPTIONAL_EDIV EDIV
> +#else
> +#define OPTIONAL_EDIV 0
> +#endif
> +       /* Synthesizer Control Register */
> +       /*    see section(s) 4.8 */
> +       /* end include in ram_init.S */
> +       *SYNCR = (unsigned short int) (SAM(MRM_W, 15, VCO) | SAM(0x0, 14, PRESCALE)
> +                       | SAM(MRM_Y, 8, COUNTER) | OPTIONAL_EDIV);
> +       while (!(*SYNCR & SLOCK))
> +               ; /* protect from clock overshoot */
> +       /* include in ram_init.S */
> +       *SYNCR = (unsigned short int) (SAM(MRM_W, 15, VCO) | SAM(MRM_X, 14,
> +                       PRESCALE) | SAM(MRM_Y, 8, COUNTER) | OPTIONAL_EDIV);
> +       /* System Protection Control Register */
> +       /*    !!! can only write to once after reset !!! */
> +       /*    see section 3.8.4 of the SIM Reference Manual */
> +       *SYPCR = (unsigned char) (HME | BME);
> +       /* Periodic Interrupr Control Register */
> +       /*    see section 3.8.2 of the SIM Reference Manual */
> +       *PICR = (unsigned short int) (SAM(0, 8, PIRQL) | SAM(MRM_PIV, 0, PIV));
> +       /*     ^^^ zero disables interrupt, don't enable here or ram_init will
> -  /* Port C Data */
> -       *dst++ = *src++;
> -    /* Zero bss */
> -       *dst = 0;
> +       /* Periodic Interrupt Timer Register */
> +       /*    see section 3.8.3 of the SIM Reference Manual */
> +       *PITR = (unsigned short int) (SAM(0x09, 0, PITM));
> +       /*    1.098mS interrupt, assuming 32.768 KHz input clock */
> +       /* Port C Data */
> +       /*    load values before enabled */
> +       *PORTC = (unsigned char) 0x0;
> +       /* Port E and F Data Register */
> +       /*    see section 9 of the SIM Reference Manual */
> +       *PORTE0 = (unsigned char) 0;
> +       *PORTF0 = (unsigned char) 0;
> +       /* Port E and F Data Direction Register */
> +       *DDRE = (unsigned char) 0xff;
> +       *DDRF = (unsigned char) 0xfd;
> +       /* Port E and F Pin Assignment Register. Set up Port E and F as I/O */
> +       *PEPAR = (unsigned char) 0;
> +       *PFPAR = (unsigned char) 0;
> +       /* end of SIM initalization code */
> +        * Initialize RAM by copying the .data section out of ROM (if
> +        * needed) and "zero-ing" the .bss section.
> +               register char *src = _etext;
> +               register char *dst = _copy_start;
> +               if (_copy_data_from_rom) {
> +                       /* ROM has data at end of text; copy it. */
> +                       while (dst < _edata)
> +                               *dst++ = *src++;
> +               /* Zero bss */
> +               for (dst = _clear_start; dst < end; dst++) {
> +                       *dst = 0;
> +        * Initialize vector table.
> +               rtems_isr_entry *monitors_vector_table;
> +               m68k_get_vbr(monitors_vector_table);
> +               M68Kvec[4] = monitors_vector_table[4]; /* breakpoints vector */
> +               M68Kvec[9] = monitors_vector_table[9]; /* trace vector */
> +               M68Kvec[31] = monitors_vector_table[31]; /* level 7 interrupt */
> +               M68Kvec[47] = monitors_vector_table[47]; /* system call vector */
> +               M68Kvec[66] = monitors_vector_table[66]; /* user defined */
> +               m68k_set_vbr(&M68Kvec);
> -  /* Spurious should be called in the predriver hook */
> -  /* Spurious_Initialize(); */
> -  /*console_init(); */
> 1.8.3.2
> rtems-devel mailing list
> rtems-devel at rtems.org
