[PATCH 2/2] privateenv: Use POSIX keys instead of task variables.
Christian Mauderer Christian.Mauderer at embedded-brains.de
Wed Mar 26 15:43:18 UTC 2014
Am 26.03.2014 16:23, schrieb Gedare Bloom:
> On Wed, Mar 26, 2014 at 8:29 AM, Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
>>  cpukit/include/rtems/userenv.h                 | 20 +++++++++++---
>>  cpukit/libcsupport/include/rtems/libio_.h      |  2 ++
>>  cpukit/libcsupport/src/__usrenv.c              |  2 +-
>>  cpukit/libcsupport/src/libio_init.c            | 12 +++++++++
>>  cpukit/libcsupport/src/privateenv.c            | 37 +++++++++++++-------------
>>  cpukit/sapi/include/confdefs.h                 | 29 ++++++++++++--------
>>  doc/shell/file.t                               |  4 ++-
>>  testsuites/fstests/imfs_support/fs_support.c   |  1 +
>>  testsuites/fstests/jffs2_support/fs_support.c  |  2 ++
>>  testsuites/fstests/mdosfs_support/fs_support.c |  1 +
>>  testsuites/fstests/mimfs_support/fs_support.c  |  1 +
>>  testsuites/fstests/mrfs_support/fs_support.c   |  1 +
>>  testsuites/libtests/ftp01/init.c               |  2 ++
>>  testsuites/psxtests/psxchroot01/main.c         |  2 ++
>>  testsuites/psxtests/psxmount/main.c            |  2 ++
>>  testsuites/sptests/Makefile.am                 |  2 +-
>>  testsuites/sptests/configure.ac                |  1 +
>>  testsuites/sptests/spfatal27/Makefile.am       | 21 +++++++++++++++
>>  testsuites/sptests/spfatal27/spfatal27.doc     | 19 +++++++++++++
>>  testsuites/sptests/spfatal27/spfatal27.scn     |  4 +++
>>  testsuites/sptests/spfatal27/testcase.h        | 27 +++++++++++++++++++
>>  testsuites/sptests/spprivenv01/init.c          | 14 +++++++---
>>  22 files changed, 168 insertions(+), 38 deletions(-)
>>  create mode 100644 testsuites/sptests/spfatal27/Makefile.am
>>  create mode 100644 testsuites/sptests/spfatal27/spfatal27.doc
>>  create mode 100644 testsuites/sptests/spfatal27/spfatal27.scn
>>  create mode 100644 testsuites/sptests/spfatal27/testcase.h
>> diff --git a/cpukit/include/rtems/userenv.h b/cpukit/include/rtems/userenv.h
>> index 8a9a4fc..576636e 100644
>> --- a/cpukit/include/rtems/userenv.h
>> +++ b/cpukit/include/rtems/userenv.h
>> @@ -27,6 +27,8 @@
>>  #include <limits.h>
>> +#include <pthread.h>
>>  #include <rtems.h>
>>  #include <rtems/fs.h>
>> @@ -66,8 +68,18 @@ typedef struct {
>>    pid_t                            pgrp; /* process group id */
>>  } rtems_user_env_t;
>> -extern rtems_user_env_t * rtems_current_user_env;
>> -extern rtems_user_env_t   rtems_global_user_env;
>> +extern rtems_user_env_t rtems_global_user_env;
>> +extern pthread_key_t rtems_current_user_env_key;
>> + * @brief Fetch the pointer to the current user environment.
>> + * If the task has a private user environment the pointer to it will be
>> + * returned. Otherwise the pointer to rtems_global_user_env will be returned.
>> +rtems_user_env_t * rtems_current_user_env_get(void);
>> +#define rtems_current_user_env rtems_current_user_env_get()
>>  #define rtems_filesystem_current     (rtems_current_user_env->current_directory)
>>  #define rtems_filesystem_root        (rtems_current_user_env->root_directory)
>> @@ -84,7 +96,9 @@ extern rtems_user_env_t   rtems_global_user_env;
>>   * If the task has already a private environment nothing will be changed.  This
>>   * function must be called from normal thread context and may block on a mutex.
>> - * Thread dispatching is disabled to protect some critical sections.
>> + * Thread dispatching is disabled to protect some critical sections. Please note
>> + * that a POSIX key value pair has to be configured for each private
>> + * environment.
>>   * @retval RTEMS_SUCCESSFUL Successful operation.
>>   * @retval RTEMS_NO_MEMORY Not enough memory.
>> diff --git a/cpukit/libcsupport/include/rtems/libio_.h b/cpukit/libcsupport/include/rtems/libio_.h
>> index 9960288..0347c5b 100644
>> --- a/cpukit/libcsupport/include/rtems/libio_.h
>> +++ b/cpukit/libcsupport/include/rtems/libio_.h
>> @@ -238,6 +238,8 @@ void rtems_filesystem_location_free( rtems_filesystem_location_info_t *loc );
>>  #include <rtems/userenv.h>
>> +void rtems_libio_free_user_env( void *env );
>>  static inline void rtems_libio_lock( void )
>>    rtems_semaphore_obtain( rtems_libio_semaphore, RTEMS_WAIT, RTEMS_NO_TIMEOUT );
>> diff --git a/cpukit/libcsupport/src/__usrenv.c b/cpukit/libcsupport/src/__usrenv.c
>> index 3ce6a2d..71efda9 100644
>> --- a/cpukit/libcsupport/src/__usrenv.c
>> +++ b/cpukit/libcsupport/src/__usrenv.c
>> @@ -257,4 +257,4 @@ rtems_user_env_t rtems_global_user_env = {
>>    .umask = S_IWGRP | S_IWOTH
>> -rtems_user_env_t *rtems_current_user_env = &rtems_global_user_env;
>> +pthread_key_t rtems_current_user_env_key;
>> diff --git a/cpukit/libcsupport/src/libio_init.c b/cpukit/libcsupport/src/libio_init.c
>> index 4d705fb..e64ddd6 100644
>> --- a/cpukit/libcsupport/src/libio_init.c
>> +++ b/cpukit/libcsupport/src/libio_init.c
>> @@ -46,6 +46,7 @@ void rtems_libio_init( void )
>>      rtems_status_code rc;
>>      uint32_t i;
>>      rtems_libio_t *iop;
>> +    int eno;
>>      if (rtems_libio_number_iops > 0)
>> @@ -61,6 +62,17 @@ void rtems_libio_init( void )
>> +   *  Create the posix key for user environment.
>> +  eno = pthread_key_create(
>> +    &rtems_current_user_env_key,
>> +    rtems_libio_free_user_env
>> +  if (eno != 0) {
>> +    rtems_fatal_error_occurred( RTEMS_UNSATISFIED );
>>     *  Create the binary semaphore used to provide mutual exclusion
>>     *  on the IOP Table.
>> diff --git a/cpukit/libcsupport/src/privateenv.c b/cpukit/libcsupport/src/privateenv.c
>> index bee94c1..60207b0 100644
>> --- a/cpukit/libcsupport/src/privateenv.c
>> +++ b/cpukit/libcsupport/src/privateenv.c
>> @@ -29,7 +29,16 @@
>>   *  Instantiate a private user environment for the calling thread.
>> -static void free_user_env(void *arg)
>> +  void *ptr = pthread_getspecific(rtems_current_user_env_key);
>> +  if (ptr == NULL) {
>> +    ptr = &rtems_global_user_env;
>> +  return (rtems_user_env_t *) ptr;
>> +void rtems_libio_free_user_env(void *arg)
>>    rtems_user_env_t *env = arg;
>>    bool uses_global_env = env == &rtems_global_user_env;
>> @@ -44,7 +53,7 @@ static void free_user_env(void *arg)
>>  static void free_user_env_protected(rtems_user_env_t *env)
>>    _Thread_Disable_dispatch();
>> -  free_user_env(env);
>> +  rtems_libio_free_user_env(env);
>>    _Thread_Enable_dispatch();
>> @@ -68,14 +77,13 @@ rtems_status_code rtems_libio_set_private_env(void)
>>          !rtems_filesystem_global_location_is_null(new_env->root_directory)
>>            && !rtems_filesystem_global_location_is_null(new_env->current_directory)
>> -        sc = rtems_task_variable_add(
>> -          RTEMS_SELF,
>> -          (void **) &rtems_current_user_env,
>> -          free_user_env
>> +        int eno = pthread_setspecific(
>> +          rtems_current_user_env_key,
>> +          new_env
>> -        if (sc == RTEMS_SUCCESSFUL) {
>> +        if (eno == 0) {
>>            free_user_env_protected(old_env);
>> -          rtems_current_user_env = new_env;
>>          } else {
>>            sc = RTEMS_TOO_MANY;
>> @@ -84,7 +92,7 @@ rtems_status_code rtems_libio_set_private_env(void)
>>        if (sc != RTEMS_SUCCESSFUL) {
>> -        free_user_env(new_env);
>> +        rtems_libio_free_user_env(new_env);
>>      } else {
>>        sc = RTEMS_NO_MEMORY;
>> @@ -101,14 +109,7 @@ void rtems_libio_use_global_env(void)
>>    bool uses_private_env = env != &rtems_global_user_env;
>>    if (uses_private_env) {
>> -    sc = rtems_task_variable_delete(
>> -      RTEMS_SELF,
>> -    if (sc != RTEMS_SUCCESSFUL) {
>> -      rtems_fatal_error_occurred(0xdeadbeef);
>> -    rtems_current_user_env = &rtems_global_user_env;
>> +    free_user_env_protected(env);
>> +    pthread_setspecific(rtems_current_user_env_key, NULL);
>> diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
>> index aca99f0..5da3c2e 100644
>> --- a/cpukit/sapi/include/confdefs.h
>> +++ b/cpukit/sapi/include/confdefs.h
>> @@ -148,6 +148,11 @@ const rtems_libio_helper rtems_fs_init_helper =
>>  #define CONFIGURE_LIBIO_SEMAPHORES 1
>> + * POSIX key count used by the IO library.
>> +#define CONFIGURE_LIBIO_POSIX_KEYS 1
>>  #ifdef CONFIGURE_INIT
>>     * When instantiating the configuration tables, this variable is
>> @@ -1728,16 +1733,18 @@ const rtems_libio_helper rtems_fs_init_helper =
>>  #include <rtems/posix/key.h>
>>  #ifndef CONFIGURE_MAXIMUM_POSIX_KEYS
>> -  #define CONFIGURE_MAXIMUM_POSIX_KEYS            0
>> -  #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 0
>> -#else
>> -  #ifndef CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
>> -    #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS \
>> -      (CONFIGURE_MAXIMUM_POSIX_KEYS * \
>> -       (CONFIGURE_MAXIMUM_POSIX_THREADS + CONFIGURE_MAXIMUM_TASKS))
>> -  #endif
>> +  #define CONFIGURE_MAXIMUM_POSIX_KEYS 0
>> +#endif
>> +#ifndef CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
>> +  #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS \
>> +    (CONFIGURE_MAXIMUM_POSIX_KEYS * \
>> +     (CONFIGURE_MAXIMUM_POSIX_THREADS + CONFIGURE_MAXIMUM_TASKS))
>>  #endif
>> +#define CONFIGURE_POSIX_KEYS \
>> +  (CONFIGURE_MAXIMUM_POSIX_KEYS + CONFIGURE_LIBIO_POSIX_KEYS)
> If you add another macro here like...
> #define CONFIGURE_POSIX_KEY_VALUE_PAIRS
> (CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS + (1 *
> CONFIGURE_LIBIO_POSIX_KEYS))
> and change the below to use the new macro, then the user does not need
> to do any configuring of the posix keys for the private environment.
Thanks for the hint. I have thought about that and decided against it
with the following reason:
One key value pair would most likely not be the correct number of key
value pairs. We can distinguish between three cases:
One case would be that no private environment is used. In that case we
would need no key and only waste resources.
The second case would be that one thread uses a private environment. In
that case the number would be correct.
The last case is that multiple threads are using private environments.
Then we would need multiple key value pairs (one per thread).
At the moment the main use for a private environment seems to be the
chroot function. If a program never uses this function it will most
likely never use a private environment. Therefore I would prefer not to
add this key value pair in default configuration.
>>  #define CONFIGURE_MEMORY_FOR_POSIX_KEYS(_keys, _key_value_pairs) \
>>     (_Configure_Object_RAM(_keys, sizeof(POSIX_Keys_Control) ) \
>>      + _Configure_From_workspace( \
>> @@ -2216,7 +2223,7 @@ const rtems_libio_helper rtems_fs_init_helper =
>>       CONFIGURE_TOTAL_TASKS_AND_THREADS, CONFIGURE_TOTAL_TASKS_AND_THREADS) + \
>>     CONFIGURE_MEMORY_FOR_CLASSIC + \
>>     CONFIGURE_MEMORY_FOR_POSIX_KEYS( \
>> -      CONFIGURE_MAXIMUM_POSIX_KEYS, \
>> +      CONFIGURE_POSIX_KEYS, \
>>        CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS ) + \
>>     CONFIGURE_MEMORY_FOR_POSIX + \
>>     CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS + \
>> @@ -2391,7 +2398,7 @@ const rtems_libio_helper rtems_fs_init_helper =
>>      CONFIGURE_EXECUTIVE_RAM_SIZE,             /* required RTEMS workspace */
>>      CONFIGURE_STACK_SPACE_SIZE,               /* required stack space */
>>      CONFIGURE_MAXIMUM_USER_EXTENSIONS,        /* maximum dynamic extensions */
>> -    CONFIGURE_MAXIMUM_POSIX_KEYS,             /* POSIX keys are always */
>> +    CONFIGURE_POSIX_KEYS,                     /* POSIX keys are always */
>>      CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS,  /*   enabled */
>>      CONFIGURE_MICROSECONDS_PER_TICK,          /* microseconds per clock tick */
>>      1000 * CONFIGURE_MICROSECONDS_PER_TICK,   /* nanoseconds per clock tick */
>> @@ -2586,7 +2593,7 @@ const rtems_libio_helper rtems_fs_init_helper =
>>      CONFIGURE_MEMORY_FOR_PERIODS(CONFIGURE_MAXIMUM_PERIODS),
>>      CONFIGURE_MEMORY_FOR_BARRIERS(CONFIGURE_BARRIERS),
>>      CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(CONFIGURE_MAXIMUM_USER_EXTENSIONS),
>> -    CONFIGURE_MEMORY_FOR_POSIX_KEYS( CONFIGURE_MAXIMUM_POSIX_KEYS, \
>> +    CONFIGURE_MEMORY_FOR_POSIX_KEYS( CONFIGURE_POSIX_KEYS, \
>>                                       CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS ),
>>  #ifdef RTEMS_POSIX_API
>> diff --git a/doc/shell/file.t b/doc/shell/file.t
>> index 01a3b28..eb38fe3 100644
>> --- a/doc/shell/file.t
>> +++ b/doc/shell/file.t
>> @@ -1148,7 +1148,9 @@ cat: /etc/passwd: No such file or directory
>>  This command is included in the default shell command set.
>>  When building a custom command set, define
>>  @code{CONFIGURE_SHELL_COMMAND_CHROOT} to have this
>> -command included.
>> +command included. Additional to that you have to add one
>> +POSIX key value pair for each thread where you want to use
>> +the command.
>>  This command can be excluded from the shell command set by
>>  defining @code{CONFIGURE_SHELL_NO_COMMAND_CHROOT} when all
>> diff --git a/testsuites/fstests/imfs_support/fs_support.c b/testsuites/fstests/imfs_support/fs_support.c
>> index 8eb9cca..e853690 100644
>> --- a/testsuites/fstests/imfs_support/fs_support.c
>> +++ b/testsuites/fstests/imfs_support/fs_support.c
>> @@ -41,6 +41,7 @@ test_shutdown_filesystem (void)
>>  #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>>  #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 40
>>  #define CONFIGURE_INIT_TASK_STACK_SIZE (16 * 1024)
>> +#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS  1
>>  #include <rtems/confdefs.h>
>> diff --git a/testsuites/fstests/jffs2_support/fs_support.c b/testsuites/fstests/jffs2_support/fs_support.c
>> index 2df6da3..1ff010d 100644
>> --- a/testsuites/fstests/jffs2_support/fs_support.c
>> +++ b/testsuites/fstests/jffs2_support/fs_support.c
>> @@ -157,6 +157,8 @@ void test_shutdown_filesystem(void)
>>  #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>>  #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> diff --git a/testsuites/fstests/mdosfs_support/fs_support.c b/testsuites/fstests/mdosfs_support/fs_support.c
>> index 8c5fef4..8d01e9c 100644
>> --- a/testsuites/fstests/mdosfs_support/fs_support.c
>> +++ b/testsuites/fstests/mdosfs_support/fs_support.c
>> @@ -91,6 +91,7 @@ void test_shutdown_filesystem(void)
>>  #define CONFIGURE_MAXIMUM_DRIVERS                   10
>>  #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
>> diff --git a/testsuites/fstests/mimfs_support/fs_support.c b/testsuites/fstests/mimfs_support/fs_support.c
>> index 4b3c701..894d8f8 100644
>> --- a/testsuites/fstests/mimfs_support/fs_support.c
>> +++ b/testsuites/fstests/mimfs_support/fs_support.c
>> @@ -56,6 +56,7 @@ test_shutdown_filesystem (void)
>> diff --git a/testsuites/fstests/mrfs_support/fs_support.c b/testsuites/fstests/mrfs_support/fs_support.c
>> index 8c9989e..a1b9a87 100644
>> --- a/testsuites/fstests/mrfs_support/fs_support.c
>> +++ b/testsuites/fstests/mrfs_support/fs_support.c
>> @@ -70,6 +70,7 @@ test_shutdown_filesystem (void)
>>  #define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
>> diff --git a/testsuites/libtests/ftp01/init.c b/testsuites/libtests/ftp01/init.c
>> index dcae4b1..b0c20a2 100644
>> --- a/testsuites/libtests/ftp01/init.c
>> +++ b/testsuites/libtests/ftp01/init.c
>> @@ -246,6 +246,8 @@ static rtems_task Init(rtems_task_argument argument)
>> +#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 2
>> diff --git a/testsuites/psxtests/psxchroot01/main.c b/testsuites/psxtests/psxchroot01/main.c
>> index 0255724..5eeeebc 100644
>> --- a/testsuites/psxtests/psxchroot01/main.c
>> +++ b/testsuites/psxtests/psxchroot01/main.c
>> @@ -34,6 +34,8 @@ rtems_task Init(
>>  #define CONFIGURE_MAXIMUM_TASKS 1
>> diff --git a/testsuites/psxtests/psxmount/main.c b/testsuites/psxtests/psxmount/main.c
>> index 92ddb3e..c6479cb 100644
>> --- a/testsuites/psxtests/psxmount/main.c
>> +++ b/testsuites/psxtests/psxmount/main.c
>> @@ -36,6 +36,8 @@ rtems_task Init(
>> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
>> index d57ae69..3150694 100644
>> --- a/testsuites/sptests/Makefile.am
>> +++ b/testsuites/sptests/Makefile.am
>> @@ -18,7 +18,7 @@ SUBDIRS = \
>>      spfatal01 spfatal02 spfatal03 spfatal04 spfatal05 spfatal06 spfatal07 \
>>      spfatal08 spfatal09 spfatal10 spfatal11 spfatal12 spfatal13 spfatal14 \
>>      spfatal15 spfatal16 spfatal17 spfatal18 spfatal19 spfatal20 \
>> -    spfatal22 spfatal24 spfatal25 \
>> +    spfatal22 spfatal24 spfatal25 spfatal27\
>>      spfifo01 spfifo02 spfifo03 spfifo04 spfifo05 \
>>      spfreechain01 \
>>      spintrcritical01 spintrcritical02 spintrcritical03 spintrcritical04 \
>> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
>> index 5f98ba7..71f0c8d 100644
>> --- a/testsuites/sptests/configure.ac
>> +++ b/testsuites/sptests/configure.ac
>> @@ -166,6 +166,7 @@ spfatal20/Makefile
>>  spfatal22/Makefile
>>  spfatal24/Makefile
>>  spfatal25/Makefile
>> +spfatal27/Makefile
>>  spfifo01/Makefile
>>  spfifo02/Makefile
>>  spfifo03/Makefile
>> diff --git a/testsuites/sptests/spfatal27/Makefile.am b/testsuites/sptests/spfatal27/Makefile.am
>> new file mode 100644
>> index 0000000..744cef7
>> --- /dev/null
>> +++ b/testsuites/sptests/spfatal27/Makefile.am
>> @@ -0,0 +1,21 @@
>> +rtems_tests_PROGRAMS = spfatal27
>> +spfatal27_SOURCES = ../spfatal_support/init.c \
>> +    ../spfatal_support/system.h testcase.h
>> +dist_rtems_tests_DATA = spfatal27.scn
>> +dist_rtems_tests_DATA += spfatal27.doc
>> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
>> +include $(top_srcdir)/../automake/compile.am
>> +include $(top_srcdir)/../automake/leaf.am
>> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
>> +LINK_OBJS = $(spfatal27_OBJECTS)
>> +LINK_LIBS = $(spfatal27_LDLIBS)
>> +spfatal27$(EXEEXT): $(spfatal27_OBJECTS) $(spfatal27_DEPENDENCIES)
>> +       @rm -f spfatal27$(EXEEXT)
>> +       $(make-exe)
>> +include $(top_srcdir)/../automake/local.am
>> diff --git a/testsuites/sptests/spfatal27/spfatal27.doc b/testsuites/sptests/spfatal27/spfatal27.doc
>> index 0000000..02abfef
>> --- /dev/null
>> +++ b/testsuites/sptests/spfatal27/spfatal27.doc
>> @@ -0,0 +1,19 @@
>> +#  COPYRIGHT (c) 1989-2010.
>> +#  On-Line Applications Research Corporation (OAR).
>> +#  The license and distribution terms for this file may be
>> +#  found in the file LICENSE in this distribution or at
>> +#  http://www.rtems.org/license/LICENSE.
>> +This file describes the directives and concepts tested by this test set.
>> +test set name:  spfatal22
>> +directives:
>> +  rtems_libio_init
>> +concepts:
>> ++ Exercise path when unable to allocate memory.
>> diff --git a/testsuites/sptests/spfatal27/spfatal27.scn b/testsuites/sptests/spfatal27/spfatal27.scn
>> index 0000000..b4239e6
>> --- /dev/null
>> +++ b/testsuites/sptests/spfatal27/spfatal27.scn
>> @@ -0,0 +1,4 @@
>> +*** TEST FATAL FATAL 22 ***
>> +Allocate_majority_of_heap:
>> +Fatal error (libio init out of memory) hit
>> +*** END OF TEST FATAL 22 ***
>> diff --git a/testsuites/sptests/spfatal27/testcase.h b/testsuites/sptests/spfatal27/testcase.h
>> index 0000000..4dc4f9d
>> --- /dev/null
>> +++ b/testsuites/sptests/spfatal27/testcase.h
>> @@ -0,0 +1,27 @@
>> + * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
>> + *  embedded brains GmbH
>> + *  Dornierstrasse 4
>> + *  82178 Puchheim
>> + *  Germany
>> + *  <rtems at embedded-brains.de>
>> + * The license and distribution terms for this file may be
>> + * found in the file LICENSE in this distribution or at
>> + * http://www.rtems.org/license/LICENSE.
>> +#define FATAL_ERROR_TEST_NAME            "FATAL 27"
>> +#define FATAL_ERROR_DESCRIPTION          "libio init no posix key left"
>> +#define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_RTEMS_API
>> +#define FATAL_ERROR_EXPECTED_IS_INTERNAL FALSE
>> +#define FATAL_ERROR_EXPECTED_ERROR       RTEMS_UNSATISFIED
>> +#define CONFIGURE_MAXIMUM_POSIX_KEYS (-1)
>> +#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS (0)
>> +void force_error()
>> +  /* we should not reach this */
>> diff --git a/testsuites/sptests/spprivenv01/init.c b/testsuites/sptests/spprivenv01/init.c
>> index a670085..4f0660d 100644
>> --- a/testsuites/sptests/spprivenv01/init.c
>> +++ b/testsuites/sptests/spprivenv01/init.c
>> @@ -63,14 +63,19 @@ rtems_task Init(
>>    puts( "Init - allocating most of workspace memory" );
>>    opaque = rtems_workspace_greedy_allocate( NULL, 0 );
>> -  puts( "Init - attempt to reset env - expect RTEMS_TOO_MANY" );
>> +  puts( "Init - attempt to reset env - expect RTEMS_SUCCESSFUL" );
>>    sc = rtems_libio_set_private_env();
>> -  rtems_test_assert( sc == RTEMS_TOO_MANY );
>> +  rtems_test_assert( sc == RTEMS_SUCCESSFUL );
>> +  rtems_test_assert( rtems_current_user_env != &rtems_global_user_env );
>>    puts( "Init - freeing the workspace memory" );
>>    rtems_workspace_greedy_free( opaque );
>> +  puts( "Init - Reset to global environment" );
>> +  rtems_libio_use_global_env();
>> +  rtems_test_assert( rtems_current_user_env == &rtems_global_user_env );
>>    puts( "Init - Attempt to get a private environment" );
>> @@ -118,6 +123,9 @@ rtems_task Init(
>> +#define CONFIGURE_MAXIMUM_POSIX_KEYS 1
>> 1.8.4.5
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
Christian Mauderer     Dornierstr. 4
D-82178 Puchheim       Germany
email: Christian.Mauderer at embedded-brains.de
Phone: +49-89-18 94 741-18
Fax:   +49-89-18 94 741-08
