[PATCH 14/17] score: Thread life cycle re-implementation
Wed Mar 26 17:43:08 UTC 2014
On Wed, Mar 26, 2014 at 12:45 PM, Sebastian Huber
> On 03/26/2014 03:56 PM, Gedare Bloom wrote:
>> On Tue, Mar 25, 2014 at 8:49 AM, Sebastian Huber
>>> >--- a/cpukit/score/include/rtems/score/thread.h
>>> >+++ b/cpukit/score/include/rtems/score/thread.h
>>> >@@ -11,6 +11,8 @@
>>> >   *  COPYRIGHT (c) 1989-2014.
>>> >   *  On-Line Applications Research Corporation (OAR).
>>> >+ *  Copyright (c) 2014 embedded brains GmbH.
>>> >   *  The license and distribution terms for this file may be
>>> >   *  found in the file LICENSE in this distribution or at
>>> >   *http://www.rtems.org/license/LICENSE.
>>> >@@ -412,8 +414,47 @@ typedef struct {
>>> >    Chain_Control Chain;
>>> >  } Thread_Action_control;
>>> >+ * @brief Thread life states.
>>> >+ * The thread life states are orthogonal to the thread states used for
>>> >+ * synchronization primitives and blocking operations.  They reflect
>>> > the state
>>> >+ * changes triggered with thread restart and delete requests.
>>> >+typedef enum {
>>> >+  THREAD_LIFE_NORMAL = 0x0,
>>> >+  THREAD_LIFE_PROTECTED = 0x1,
>>> >+  THREAD_LIFE_RESTARTED = 0x2,
>>> >+  THREAD_LIFE_PROTECTED_RESTARTED = 0x3,
>>> >+  THREAD_LIFE_TERMINATED = 0x4,
>>> >+  THREAD_LIFE_PROTECTED_TERMINATED = 0x5,
>>> >+  THREAD_LIFE_RESTARTED_TERMINATED = 0x6,
>>> >+  THREAD_LIFE_PROTECTED_RESTARTED_TERMINATED = 0x7
>>> >+} Thread_Life_state;
>> I would prefer the present tense (restarting, terminating) instead of
>> the past tense for restarted and terminated. I think it is easier to
>> follow then, because the life state flags are set while the
>> restart/terminate is happening. Protected is fine.
> Ok.
>>> >+ * @brief Thread life control.
>>> >  typedef struct {
>>> >+   * @brief Thread life action used to react upon thread restart and
>>> > delete
>>> >+   * requests.
>>> >    Thread_Action      Action;
>>> >+   * @brief The current thread life state.
>>> >+  Thread_Life_state  state;
>>> >+   * @brief The terminator thread of this thread.
>>> >+   * In case the thread is terminated and another thread (the
>>> > terminator) waits
>>> >+   * for the actual termination completion, then this field references
>>> > the
>>> >+   * terminator thread.
>>> >+  Thread_Control    *terminator;
>>> >  } Thread_Life_control;
>>> >@@ -486,9 +527,10 @@ struct Thread_Control_struct {
>>> >     * thread and thread dispatching is necessary.  On SMP a thread
>>> > dispatch on a
>>> >     * remote processor needs help from an inter-processor interrupt,
>>> > thus it
>>> >     * will take some time to complete the state change.  A lot of
>>> > things can
>>> >-   * happen in the meantime.
>>> >+   * happen in the meantime.  This field is volatile since it is polled
>>> > in
>>> >+   * _Thread_Kill_zombies().
>>> >-  bool                                  is_executing;
>>> >+  volatile bool                         is_executing;
>>> >  #if __RTEMS_HAVE_SYS_CPUSET_H__
>>> >diff --git a/cpukit/score/include/rtems/score/threadimpl.h
>>> > b/cpukit/score/include/rtems/score/threadimpl.h
>>> >index 2e31753..9166e9d 100644
>>> >--- a/cpukit/score/include/rtems/score/threadimpl.h
>>> >+++ b/cpukit/score/include/rtems/score/threadimpl.h
>>> >@@ -11,6 +11,8 @@
>>> >   *  COPYRIGHT (c) 1989-2008.
>>> >@@ -194,6 +196,8 @@ bool _Thread_Restart(
>>> >    Thread_Entry_numeric_type  numeric_argument
>>> >+bool _Thread_Set_life_protection( bool protect );
>>> >  void _Thread_Life_action_handler(
>>> >    Thread_Control  *executing,
>>> >    Thread_Action   *action,
>>> >@@ -201,17 +205,9 @@ void _Thread_Life_action_handler(
>>> >    ISR_Level        level
>>> >- *  @brief Frees all memory associated with the specified thread.
>>> >- *  This routine frees all memory associated with the specified
>>> >- *  thread and removes it from the local object table so no further
>>> >- *  operations on this thread are allowed.
>>> >-void _Thread_Close(
>>> >-  Objects_Information  *information,
>>> >-  Thread_Control       *the_thread
>>> >+void _Thread_Kill_zombies( void );
>>> >+void _Thread_Close( Thread_Control *the_thread, Thread_Control
>>> > *executing );
>> Add doxygen for these two functions. Can be done in separate patch.
> Ok.
>>> >   *  @brief Removes any set states for @a the_thread.
>>> >@@ -710,6 +706,34 @@ RTEMS_INLINE_ROUTINE void
>>> > _Thread_Add_post_switch_action(
>>> >    _Thread_Action_release_and_ISR_enable( cpu, level );
>>> >+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_restarted(
>>> >+  Thread_Life_state life_state
>>> >+  return ( life_state & THREAD_LIFE_RESTARTED ) != 0;
>>> >+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_terminated(
>>> >+  return ( life_state & THREAD_LIFE_TERMINATED ) != 0;
>>> >+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_protected(
>>> >+  return ( life_state & THREAD_LIFE_PROTECTED ) != 0;
>>> >+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_change_requested(
>>> >+  return ( life_state & THREAD_LIFE_RESTARTED_TERMINATED ) != 0;
>> And also doxygen for these functions, and consider using the present
>> tense for restarting, terminating
> Why would you document functions like this?
For the sake of completeness. However, the only one that really needs
it is the last one. It is not quite clear from the name what it
entails.
