[PATCH 14/17] score: Thread life cycle re-implementation
    Gedare Bloom
    gedare at rtems.org
    Thu Mar 27 12:18:51 UTC 2014
On Thu, Mar 27, 2014 at 3:14 AM, Sebastian Huber
> On 2014-03-26 18:43, Gedare Bloom wrote:
>>>>>> +RTEMS_INLINE_ROUTINE bool _Thread_Is_life_restarted(
>>>>>> >>> >+  Thread_Life_state life_state
>>>>>> >>> >+  return ( life_state & THREAD_LIFE_RESTARTED ) != 0;
>>>>>> >>> >+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_terminated(
>>>>>> >>> >+  return ( life_state & THREAD_LIFE_TERMINATED ) != 0;
>>>>>> >>> >+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_protected(
>>>>>> >>> >+  return ( life_state & THREAD_LIFE_PROTECTED ) != 0;
>>>>>> >>> >+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_change_requested(
>>>>>> >>> >+  return ( life_state & THREAD_LIFE_RESTARTED_TERMINATED ) != 0;
>>>> >>And also doxygen for these functions, and consider using the present
>>>> >>tense for restarting, terminating
>>> >Why would you document functions like this?
>> For the sake of completeness.
> To do something for completeness is a bad argument.
Yeah.
>> However, the only one that really needs
>> it is the last one. It is not quite clear from the name what it
>> entails.
> I see really no sense in adding documentation for functions that test two
> bits and are not part of the application API.
Perhaps not, but there is a difference between documenting something
for end users, and documenting something for the next person to come
along to maintain the kernel code. If a function/macro use is not
obvious from its name, then there needs to be some documentation on
it.
> What about the name _Thread_Is_life_changing()?
Yes this is clearer.
Thanks,
Gedare
