[PATCH 4/4] score: PR2152: Use allocator mutex for objects
Thu Mar 27 13:20:24 UTC 2014
Use allocator mutex for objects allocate/free.  This prevents that the
thread dispatch latency depends on the workspace/heap fragmentation.
 cpukit/libcsupport/src/resource_snapshot.c       |   24 +++--------
 cpukit/posix/include/rtems/posix/pthreadimpl.h   |   21 ++-------
 cpukit/posix/include/rtems/posix/semaphoreimpl.h |   10 +----
 cpukit/posix/src/conddestroy.c                   |    8 +++-
 cpukit/posix/src/condinit.c                      |    6 +--
 cpukit/posix/src/keycreate.c                     |    6 +--
 cpukit/posix/src/keydelete.c                     |    4 ++
 cpukit/posix/src/mqueueclose.c                   |    4 ++
 cpukit/posix/src/mqueuecreatesupp.c              |   12 ++----
 cpukit/posix/src/mqueueopen.c                    |   14 +++----
 cpukit/posix/src/mqueueunlink.c                  |    3 +
 cpukit/posix/src/mutexdestroy.c                  |   10 +++-
 cpukit/posix/src/mutexinit.c                     |    9 +---
 cpukit/posix/src/pbarrierdestroy.c               |    7 ++-
 cpukit/posix/src/pbarrierinit.c                  |   12 +----
 cpukit/posix/src/prwlockdestroy.c                |    8 +++-
 cpukit/posix/src/prwlockinit.c                   |    9 +---
 cpukit/posix/src/pspindestroy.c                  |    7 ++-
 cpukit/posix/src/pspininit.c                     |    7 +--
 cpukit/posix/src/pthreadcreate.c                 |   13 ++----
 cpukit/posix/src/semaphorecreatesupp.c           |    5 --
 cpukit/posix/src/semclose.c                      |    4 ++
 cpukit/posix/src/semdestroy.c                    |    4 ++
 cpukit/posix/src/seminit.c                       |    2 +
 cpukit/posix/src/semopen.c                       |   11 ++---
 cpukit/posix/src/semunlink.c                     |   11 +++--
 cpukit/posix/src/timercreate.c                   |    8 +--
 cpukit/posix/src/timerdelete.c                   |    7 +++-
 cpukit/rtems/Makefile.am                         |    1 -
 cpukit/rtems/include/rtems/rtems/messageimpl.h   |   16 +++----
 cpukit/rtems/include/rtems/rtems/tasksimpl.h     |   13 ++----
 cpukit/rtems/src/barriercreate.c                 |    6 +--
 cpukit/rtems/src/barrierdelete.c                 |    8 ++-
 cpukit/rtems/src/dpmemcreate.c                   |    8 +--
 cpukit/rtems/src/dpmemdelete.c                   |    6 ++-
 cpukit/rtems/src/msgqallocate.c                  |   37 ----------------
 cpukit/rtems/src/msgqcreate.c                    |   10 ++---
 cpukit/rtems/src/msgqdelete.c                    |    9 +++-
 cpukit/rtems/src/partcreate.c                    |   10 ++---
 cpukit/rtems/src/partdelete.c                    |    9 +++-
 cpukit/rtems/src/ratemoncreate.c                 |    8 +--
 cpukit/rtems/src/ratemondelete.c                 |    6 ++-
 cpukit/rtems/src/regioncreate.c                  |    7 +--
 cpukit/rtems/src/regiondelete.c                  |    5 +-
 cpukit/rtems/src/regionextend.c                  |    3 +-
 cpukit/rtems/src/regiongetsegment.c              |    3 +-
 cpukit/rtems/src/regionresizesegment.c           |    3 +-
 cpukit/rtems/src/semcreate.c                     |   12 ++---
 cpukit/rtems/src/semdelete.c                     |   11 ++++-
 cpukit/rtems/src/taskcreate.c                    |   13 ++----
 cpukit/rtems/src/timercreate.c                   |    6 +--
 cpukit/rtems/src/timerdelete.c                   |    6 ++-
 cpukit/sapi/src/extensioncreate.c                |    8 ++--
 cpukit/sapi/src/extensiondelete.c                |    6 ++-
 cpukit/score/include/rtems/score/objectimpl.h    |   30 ++++++++++---
 cpukit/score/include/rtems/score/threadimpl.h    |    7 +--
 cpukit/score/src/apimutex.c                      |    3 +-
 cpukit/score/src/objectactivecount.c             |   10 ++++-
 cpukit/score/src/objectallocate.c                |   27 +++++++++++-
 cpukit/score/src/objectextendinformation.c       |   49 ++++++++++-----------
 cpukit/score/src/objectfree.c                    |    5 ++-
 cpukit/score/src/objectshrinkinformation.c       |    5 ++-
 testsuites/sptests/spobjgetnext/init.c           |    2 +
 63 files changed, 302 insertions(+), 312 deletions(-)
 delete mode 100644 cpukit/rtems/src/msgqallocate.c
diff --git a/cpukit/libcsupport/src/resource_snapshot.c b/cpukit/libcsupport/src/resource_snapshot.c
index 8c66f0f..6f5038d 100644
--- a/cpukit/libcsupport/src/resource_snapshot.c
+++ b/cpukit/libcsupport/src/resource_snapshot.c
@@ -98,38 +98,28 @@ static int open_files(void)
   return (int) rtems_libio_number_iops - free_count;
-static void free_all_delayed_blocks(void)
-  #ifdef HEAP_PROTECTION
-    _RTEMS_Lock_allocator();
-    _Thread_Disable_dispatch();
-    _Heap_Protection_free_all_delayed_blocks( RTEMS_Malloc_Heap );
-    _Heap_Protection_free_all_delayed_blocks( &_Workspace_Area );
-    _Thread_Enable_dispatch();
-    _RTEMS_Unlock_allocator();
-  #endif
 void rtems_resource_snapshot_take(rtems_resource_snapshot *snapshot)
   uint32_t *active = &snapshot->rtems_api.active_barriers;
   size_t i;
-  free_all_delayed_blocks();
+  _RTEMS_Lock_allocator();
   _Thread_Kill_zombies();
-  _Protected_heap_Get_information(RTEMS_Malloc_Heap, &snapshot->heap_info);
+  #ifdef HEAP_PROTECTION
+    _Heap_Protection_free_all_delayed_blocks(RTEMS_Malloc_Heap);
+    _Heap_Protection_free_all_delayed_blocks(&_Workspace_Area);
+  #endif
+  _Heap_Get_information(RTEMS_Malloc_Heap, &snapshot->heap_info);
   _Heap_Get_information(&_Workspace_Area, &snapshot->workspace_info);
   for (i = 0; i < RTEMS_ARRAY_SIZE(objects_info_table); ++i) {
     active [i] = _Objects_Active_count(objects_info_table[i]);
+  _RTEMS_Unlock_allocator();
   #ifndef RTEMS_POSIX_API
     memset(&snapshot->posix_api, 0, sizeof(snapshot->posix_api));
diff --git a/cpukit/posix/include/rtems/posix/pthreadimpl.h b/cpukit/posix/include/rtems/posix/pthreadimpl.h
index 02d8bca..d4a04e1 100644
--- a/cpukit/posix/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/posix/include/rtems/posix/pthreadimpl.h
@@ -68,16 +68,6 @@ extern void (*_POSIX_Threads_Initialize_user_threads_p)(void);
 void _POSIX_Threads_Manager_initialization(void);
- * @brief Allocate POSIX thread control block.
- * This function allocates a pthread control block from
- * the inactive chain of free pthread control blocks.
- * @return This method returns a newly allocated thread.
-RTEMS_INLINE_ROUTINE Thread_Control *_POSIX_Threads_Allocate( void );
  * @brief Copy POSIX Thread attribute structure.
  * This routine copies the attr2 thread attribute structure
@@ -211,15 +201,14 @@ int rtems_pthread_attribute_compare(
   const pthread_attr_t *attr2
- *  _POSIX_Threads_Allocate
+RTEMS_INLINE_ROUTINE Thread_Control *_POSIX_Threads_Allocate(void)
+  _Objects_Allocator_lock();
-  return (Thread_Control *) _Objects_Allocate( &_POSIX_Threads_Information );
+  return (Thread_Control *)
+    _Objects_Allocate_unprotected( &_POSIX_Threads_Information );
diff --git a/cpukit/posix/include/rtems/posix/semaphoreimpl.h b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
index 7754ee9..26fca50 100644
--- a/cpukit/posix/include/rtems/posix/semaphoreimpl.h
+++ b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
@@ -48,20 +48,12 @@ extern const int
 void _POSIX_Semaphore_Manager_initialization(void);
- *  @brief POSIX Semaphore Allocate
- *  This function allocates a semaphore control block from
- *  the inactive chain of free semaphore control blocks.
 RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *_POSIX_Semaphore_Allocate( void )
   return (POSIX_Semaphore_Control *)
-    _Objects_Allocate( &_POSIX_Semaphore_Information );
+    _Objects_Allocate_unprotected( &_POSIX_Semaphore_Information );
  *  @brief POSIX Semaphore Free
diff --git a/cpukit/posix/src/conddestroy.c b/cpukit/posix/src/conddestroy.c
index 75bf4cd..cd437a9 100644
--- a/cpukit/posix/src/conddestroy.c
+++ b/cpukit/posix/src/conddestroy.c
@@ -38,6 +38,7 @@ int pthread_cond_destroy(
   POSIX_Condition_variables_Control *the_cond;
   Objects_Locations                  location;
   the_cond = _POSIX_Condition_variables_Get( cond, &location );
   switch ( location ) {
@@ -45,6 +46,7 @@ int pthread_cond_destroy(
       if ( _Thread_queue_First( &the_cond->Wait_queue ) ) {
         _Objects_Put( &the_cond->Object );
+        _Objects_Allocator_unlock();
         return EBUSY;
@@ -52,9 +54,9 @@ int pthread_cond_destroy(
         &_POSIX_Condition_variables_Information,
         &the_cond->Object
-      _POSIX_Condition_variables_Free( the_cond );
+      _POSIX_Condition_variables_Free( the_cond );
       return 0;
 #if defined(RTEMS_MULTIPROCESSING)
@@ -64,5 +66,7 @@ int pthread_cond_destroy(
       break;
   return EINVAL;
diff --git a/cpukit/posix/src/condinit.c b/cpukit/posix/src/condinit.c
index a69bc8c..81575f2 100644
--- a/cpukit/posix/src/condinit.c
+++ b/cpukit/posix/src/condinit.c
@@ -51,12 +51,10 @@ int pthread_cond_init(
   if ( !the_attr->is_initialized )
     return EINVAL;
   the_cond = _POSIX_Condition_variables_Allocate();
   if ( !the_cond ) {
     return ENOMEM;
@@ -79,7 +77,7 @@ int pthread_cond_init(
   *cond = the_cond->Object.id;
   return 0;
diff --git a/cpukit/posix/src/keycreate.c b/cpukit/posix/src/keycreate.c
index a7f6c91..245ac9e 100644
--- a/cpukit/posix/src/keycreate.c
+++ b/cpukit/posix/src/keycreate.c
@@ -38,18 +38,16 @@ int pthread_key_create(
   POSIX_Keys_Control  *the_key;
   the_key = _POSIX_Keys_Allocate();
   if ( !the_key ) {
     return EAGAIN;
   the_key->destructor = destructor;
   _Objects_Open_u32( &_POSIX_Keys_Information, &the_key->Object, 0 );
   *key = the_key->Object.id;
   return 0;
diff --git a/cpukit/posix/src/keydelete.c b/cpukit/posix/src/keydelete.c
index cd2b398..392558f 100644
--- a/cpukit/posix/src/keydelete.c
+++ b/cpukit/posix/src/keydelete.c
@@ -38,6 +38,7 @@ int pthread_key_delete(
   the_key = _POSIX_Keys_Get( key, &location );
@@ -50,6 +51,7 @@ int pthread_key_delete(
       _POSIX_Keys_Free( the_key );
       _Objects_Put(&the_key->Object);
       return 0;
@@ -59,5 +61,7 @@ int pthread_key_delete(
       break;
   return EINVAL;
diff --git a/cpukit/posix/src/mqueueclose.c b/cpukit/posix/src/mqueueclose.c
index 152fc7e..72a7cdc 100644
--- a/cpukit/posix/src/mqueueclose.c
+++ b/cpukit/posix/src/mqueueclose.c
@@ -57,6 +57,7 @@ int mq_close(
   POSIX_Message_queue_Control_fd *the_mq_fd;
   the_mq_fd = _POSIX_Message_queue_Get_fd( mqdes, &location );
   if ( location == OBJECTS_LOCAL ) {
       /* OBJECTS_LOCAL:
@@ -79,9 +80,12 @@ int mq_close(
       _POSIX_Message_queue_Free_fd( the_mq_fd );
       _Objects_Put( &the_mq_fd->Object );
       return 0;
     *  OBJECTS_REMOTE:
     *  OBJECTS_ERROR:
diff --git a/cpukit/posix/src/mqueuecreatesupp.c b/cpukit/posix/src/mqueuecreatesupp.c
index 056d35d..3be64b4 100644
--- a/cpukit/posix/src/mqueuecreatesupp.c
+++ b/cpukit/posix/src/mqueuecreatesupp.c
@@ -62,8 +62,6 @@ int _POSIX_Message_queue_Create_support(
   /* length of name has already been validated */
    *  There is no real basis for the default values.  They will work
    *  but were not compared against any existing implementation for
@@ -75,12 +73,10 @@ int _POSIX_Message_queue_Create_support(
     attr.mq_msgsize = 16;
   } else {
     if ( attr_ptr->mq_maxmsg <= 0 ){
       rtems_set_errno_and_return_minus_one( EINVAL );
     if ( attr_ptr->mq_msgsize <= 0 ){
@@ -89,7 +85,7 @@ int _POSIX_Message_queue_Create_support(
   the_mq = _POSIX_Message_queue_Allocate();
   if ( !the_mq ) {
     rtems_set_errno_and_return_minus_one( ENFILE );
@@ -100,7 +96,7 @@ int _POSIX_Message_queue_Create_support(
   name = _Workspace_String_duplicate( name_arg, name_len );
   if ( !name ) {
     _POSIX_Message_queue_Free( the_mq );
     rtems_set_errno_and_return_minus_one( ENOMEM );
@@ -128,7 +124,7 @@ int _POSIX_Message_queue_Create_support(
     _Workspace_Free(name);
     rtems_set_errno_and_return_minus_one( ENOSPC );
@@ -140,6 +136,6 @@ int _POSIX_Message_queue_Create_support(
   *message_queue = the_mq;
   return 0;
diff --git a/cpukit/posix/src/mqueueopen.c b/cpukit/posix/src/mqueueopen.c
index b33fc95..43e4082 100644
--- a/cpukit/posix/src/mqueueopen.c
+++ b/cpukit/posix/src/mqueueopen.c
@@ -72,8 +72,6 @@ mqd_t mq_open(
   size_t                          name_len;
   if ( oflag & O_CREAT ) {
     va_start(arg, oflag);
     mode = va_arg( arg, mode_t );
@@ -83,7 +81,7 @@ mqd_t mq_open(
   the_mq_fd = _POSIX_Message_queue_Allocate_fd();
   if ( !the_mq_fd ) {
   the_mq_fd->oflag = oflag;
@@ -103,7 +101,7 @@ mqd_t mq_open(
     if ( !( status == ENOENT && (oflag & O_CREAT) ) ) {
       rtems_set_errno_and_return_minus_one_cast( status, mqd_t );
@@ -113,7 +111,7 @@ mqd_t mq_open(
     if ( (oflag & (O_CREAT | O_EXCL)) == (O_CREAT | O_EXCL) ) {
       rtems_set_errno_and_return_minus_one_cast( EEXIST, mqd_t );
@@ -130,7 +128,7 @@ mqd_t mq_open(
       NULL
     return (mqd_t)the_mq_fd->Object.id;
@@ -152,7 +150,7 @@ mqd_t mq_open(
   if ( status == -1 ) {
     return (mqd_t) -1;
@@ -163,7 +161,7 @@ mqd_t mq_open(
     NULL
   return (mqd_t) the_mq_fd->Object.id;
diff --git a/cpukit/posix/src/mqueueunlink.c b/cpukit/posix/src/mqueueunlink.c
index 47a0f5a..92b1976 100644
--- a/cpukit/posix/src/mqueueunlink.c
+++ b/cpukit/posix/src/mqueueunlink.c
@@ -46,11 +46,13 @@ int mq_unlink(
   Objects_Id                            the_mq_id;
   size_t                                name_len;
   status = _POSIX_Message_queue_Name_to_id( name, &the_mq_id, &name_len );
    if ( status != 0 ) {
     rtems_set_errno_and_return_minus_one( status );
@@ -64,5 +66,6 @@ int mq_unlink(
   _POSIX_Message_queue_Delete( the_mq );
   return 0;
diff --git a/cpukit/posix/src/mutexdestroy.c b/cpukit/posix/src/mutexdestroy.c
index 0fad9a9..fce78af 100644
--- a/cpukit/posix/src/mutexdestroy.c
+++ b/cpukit/posix/src/mutexdestroy.c
@@ -39,6 +39,7 @@ int pthread_mutex_destroy(
   register POSIX_Mutex_Control *the_mutex;
   the_mutex = _POSIX_Mutex_Get( mutex, &location );
@@ -50,15 +51,16 @@ int pthread_mutex_destroy(
       if ( _CORE_mutex_Is_locked( &the_mutex->Mutex ) ) {
         _Objects_Put( &the_mutex->Object );
         return EBUSY;
       _Objects_Close( &_POSIX_Mutex_Information, &the_mutex->Object );
       _CORE_mutex_Flush( &the_mutex->Mutex, NULL, EINVAL );
-      _POSIX_Mutex_Free( the_mutex );
+      _POSIX_Mutex_Free( the_mutex );
       return 0;
@@ -68,5 +70,7 @@ int pthread_mutex_destroy(
       break;
   return EINVAL;
diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
index d41b4c7..73d3101 100644
--- a/cpukit/posix/src/mutexinit.c
+++ b/cpukit/posix/src/mutexinit.c
@@ -149,15 +149,10 @@ int pthread_mutex_init(
 #endif
-   *  Enter a dispatching critical section and begin to do the real work.
   the_mutex = _POSIX_Mutex_Allocate();
   if ( !the_mutex ) {
     return EAGAIN;
@@ -188,6 +183,6 @@ int pthread_mutex_init(
   *mutex = the_mutex->Object.id;
   return 0;
diff --git a/cpukit/posix/src/pbarrierdestroy.c b/cpukit/posix/src/pbarrierdestroy.c
index d2eb505..4b9a0fd 100644
--- a/cpukit/posix/src/pbarrierdestroy.c
+++ b/cpukit/posix/src/pbarrierdestroy.c
@@ -45,6 +45,7 @@ int pthread_barrier_destroy(
   if ( !barrier )
     return EINVAL;
   the_barrier = _POSIX_Barrier_Get( barrier, &location );
@@ -55,10 +56,10 @@ int pthread_barrier_destroy(
       _Objects_Close( &_POSIX_Barrier_Information, &the_barrier->Object );
+      _Objects_Put( &the_barrier->Object );
       _POSIX_Barrier_Free( the_barrier );
-      _Objects_Put( &the_barrier->Object );
       return 0;
@@ -68,5 +69,7 @@ int pthread_barrier_destroy(
       break;
   return EINVAL;
diff --git a/cpukit/posix/src/pbarrierinit.c b/cpukit/posix/src/pbarrierinit.c
index f2dda78..9560856 100644
--- a/cpukit/posix/src/pbarrierinit.c
+++ b/cpukit/posix/src/pbarrierinit.c
@@ -92,15 +92,10 @@ int pthread_barrier_init(
   the_attributes.discipline    = CORE_BARRIER_AUTOMATIC_RELEASE;
   the_attributes.maximum_count = count;
-   * Enter dispatching critical section to allocate and initialize barrier
-  _Thread_Disable_dispatch();             /* prevents deletion */
   the_barrier = _POSIX_Barrier_Allocate();
   if ( !the_barrier ) {
     return EAGAIN;
@@ -112,10 +107,7 @@ int pthread_barrier_init(
     0
-   * Exit the critical section and return the user an operational barrier
   *barrier = the_barrier->Object.id;
   return 0;
diff --git a/cpukit/posix/src/prwlockdestroy.c b/cpukit/posix/src/prwlockdestroy.c
index 9054e92..d1261ca 100644
--- a/cpukit/posix/src/prwlockdestroy.c
+++ b/cpukit/posix/src/prwlockdestroy.c
@@ -44,6 +44,7 @@ int pthread_rwlock_destroy(
   if ( !rwlock )
     return EINVAL;
   the_rwlock = _POSIX_RWLock_Get( rwlock, &location );
@@ -53,6 +54,7 @@ int pthread_rwlock_destroy(
       if ( _Thread_queue_First( &the_rwlock->RWLock.Wait_queue ) != NULL ) {
         _Objects_Put( &the_rwlock->Object );
         return EBUSY;
@@ -61,10 +63,10 @@ int pthread_rwlock_destroy(
       _Objects_Close( &_POSIX_RWLock_Information, &the_rwlock->Object );
+      _Objects_Put( &the_rwlock->Object );
       _POSIX_RWLock_Free( the_rwlock );
-      _Objects_Put( &the_rwlock->Object );
       return 0;
@@ -74,5 +76,7 @@ int pthread_rwlock_destroy(
       break;
   return EINVAL;
diff --git a/cpukit/posix/src/prwlockinit.c b/cpukit/posix/src/prwlockinit.c
index 488b46b..94973f6 100644
--- a/cpukit/posix/src/prwlockinit.c
+++ b/cpukit/posix/src/prwlockinit.c
@@ -88,15 +88,10 @@ int pthread_rwlock_init(
   _CORE_RWLock_Initialize_attributes( &the_attributes );
-   * Enter dispatching critical section to allocate and initialize RWLock
   the_rwlock = _POSIX_RWLock_Allocate();
   if ( !the_rwlock ) {
     return EAGAIN;
@@ -110,6 +105,6 @@ int pthread_rwlock_init(
   *rwlock = the_rwlock->Object.id;
   return 0;
diff --git a/cpukit/posix/src/pspindestroy.c b/cpukit/posix/src/pspindestroy.c
index 7795a33..ab45ad1 100644
--- a/cpukit/posix/src/pspindestroy.c
+++ b/cpukit/posix/src/pspindestroy.c
@@ -45,6 +45,7 @@ int pthread_spin_destroy(
   if ( !spinlock )
     return EINVAL;
   the_spinlock = _POSIX_Spinlock_Get( spinlock, &location );
@@ -55,10 +56,10 @@ int pthread_spin_destroy(
       _Objects_Close( &_POSIX_Spinlock_Information, &the_spinlock->Object );
+      _Objects_Put( &the_spinlock->Object );
       _POSIX_Spinlock_Free( the_spinlock );
-      _Objects_Put( &the_spinlock->Object );
       return 0;
@@ -68,5 +69,7 @@ int pthread_spin_destroy(
       break;
   return EINVAL;
diff --git a/cpukit/posix/src/pspininit.c b/cpukit/posix/src/pspininit.c
index 6030ed0..02b07c8 100644
--- a/cpukit/posix/src/pspininit.c
+++ b/cpukit/posix/src/pspininit.c
@@ -49,7 +49,6 @@ int pthread_spin_init(
   POSIX_Spinlock_Control   *the_spinlock;
   CORE_spinlock_Attributes  attributes;
   if ( !spinlock )
     return EINVAL;
@@ -61,12 +60,10 @@ int pthread_spin_init(
       return EINVAL;
   the_spinlock = _POSIX_Spinlock_Allocate();
   if ( !the_spinlock ) {
     return EAGAIN;
@@ -78,6 +75,6 @@ int pthread_spin_init(
   *spinlock = the_spinlock->Object.id;
   return 0;
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index 5a6d929..8d03133 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -156,18 +156,13 @@ int pthread_create(
   #endif
-   *  Lock the allocator mutex for protection
    *  Allocate the thread control block.
    *  NOTE:  Global threads are not currently supported.
   the_thread = _POSIX_Threads_Allocate();
   if ( !the_thread ) {
     return EAGAIN;
@@ -190,7 +185,7 @@ int pthread_create(
   if ( !status ) {
     _POSIX_Threads_Free( the_thread );
     return EAGAIN;
@@ -235,7 +230,7 @@ int pthread_create(
     if ( !status ) {
       return EINVAL;
   #endif
@@ -254,6 +249,6 @@ int pthread_create(
   *thread = the_thread->Object.id;
   return 0;
diff --git a/cpukit/posix/src/semaphorecreatesupp.c b/cpukit/posix/src/semaphorecreatesupp.c
index 54b5b46..df3dde6 100644
--- a/cpukit/posix/src/semaphorecreatesupp.c
+++ b/cpukit/posix/src/semaphorecreatesupp.c
@@ -56,11 +56,8 @@ int _POSIX_Semaphore_Create_support(
   if (pshared != 0)
     rtems_set_errno_and_return_minus_one( ENOSYS );
   the_semaphore = _POSIX_Semaphore_Allocate();
   if ( !the_semaphore ) {
@@ -72,7 +69,6 @@ int _POSIX_Semaphore_Create_support(
     if ( !name ) {
       _POSIX_Semaphore_Free( the_semaphore );
   } else {
@@ -120,6 +116,5 @@ int _POSIX_Semaphore_Create_support(
   *the_sem = the_semaphore;
   return 0;
diff --git a/cpukit/posix/src/semclose.c b/cpukit/posix/src/semclose.c
index 1c205bf..9dedc34 100644
--- a/cpukit/posix/src/semclose.c
+++ b/cpukit/posix/src/semclose.c
@@ -38,6 +38,7 @@ int sem_close(
   POSIX_Semaphore_Control          *the_semaphore;
   the_semaphore = _POSIX_Semaphore_Get( sem, &location );
@@ -45,6 +46,7 @@ int sem_close(
       the_semaphore->open_count -= 1;
       _POSIX_Semaphore_Delete( the_semaphore );
       _Objects_Put( &the_semaphore->Object );
       return 0;
@@ -54,5 +56,7 @@ int sem_close(
       break;
diff --git a/cpukit/posix/src/semdestroy.c b/cpukit/posix/src/semdestroy.c
index 8c3f079..1c695bb 100644
--- a/cpukit/posix/src/semdestroy.c
+++ b/cpukit/posix/src/semdestroy.c
@@ -38,6 +38,7 @@ int sem_destroy(
@@ -53,6 +54,7 @@ int sem_destroy(
       return 0;
@@ -62,5 +64,7 @@ int sem_destroy(
       break;
diff --git a/cpukit/posix/src/seminit.c b/cpukit/posix/src/seminit.c
index 466b2d0..a55a1c4 100644
--- a/cpukit/posix/src/seminit.c
+++ b/cpukit/posix/src/seminit.c
@@ -47,6 +47,7 @@ int sem_init(
   if ( !sem )
   status = _POSIX_Semaphore_Create_support(
     NULL,
     0,
@@ -54,6 +55,7 @@ int sem_init(
     value,
     &the_semaphore
   if ( status != -1 )
     *sem = the_semaphore->Object.id;
diff --git a/cpukit/posix/src/semopen.c b/cpukit/posix/src/semopen.c
index 20e2e92..0b98ca6 100644
--- a/cpukit/posix/src/semopen.c
+++ b/cpukit/posix/src/semopen.c
@@ -66,8 +66,6 @@ sem_t *sem_open(
   size_t                     name_len;
@@ -75,6 +73,7 @@ sem_t *sem_open(
     va_end(arg);
   status = _POSIX_Semaphore_Name_to_id( name, &the_semaphore_id, &name_len );
@@ -92,7 +91,7 @@ sem_t *sem_open(
       rtems_set_errno_and_return_minus_one_cast( status, sem_t * );
   } else {
@@ -102,14 +101,14 @@ sem_t *sem_open(
       rtems_set_errno_and_return_minus_one_cast( EEXIST, sem_t * );
     the_semaphore = _POSIX_Semaphore_Get( (sem_t *) &the_semaphore_id, &location );
     the_semaphore->open_count += 1;
     goto return_id;
@@ -130,7 +129,7 @@ sem_t *sem_open(
    * errno was set by Create_support, so don't set it again.
   if ( status == -1 )
     return SEM_FAILED;
diff --git a/cpukit/posix/src/semunlink.c b/cpukit/posix/src/semunlink.c
index 180facc..40d5660 100644
--- a/cpukit/posix/src/semunlink.c
+++ b/cpukit/posix/src/semunlink.c
@@ -35,11 +35,12 @@ int sem_unlink(
   const char *name
-  int  status;
-  POSIX_Semaphore_Control          *the_semaphore;
-  Objects_Id the_semaphore_id;
-  size_t name_len;
+  int                      status;
+  POSIX_Semaphore_Control *the_semaphore;
+  Objects_Id               the_semaphore_id;
+  size_t                   name_len;
@@ -58,5 +59,7 @@ int sem_unlink(
   return 0;
diff --git a/cpukit/posix/src/timercreate.c b/cpukit/posix/src/timercreate.c
index f55e2db..6d822b3 100644
--- a/cpukit/posix/src/timercreate.c
+++ b/cpukit/posix/src/timercreate.c
@@ -66,21 +66,19 @@ int timer_create(
-  _Thread_Disable_dispatch();         /* to prevent deletion */
    *  Allocate a timer
   ptimer = _POSIX_Timer_Allocate();
   if ( !ptimer ) {
-    _Objects_Put( &ptimer->Object );
     rtems_set_errno_and_return_minus_one( EAGAIN );
   /* The data of the created timer are stored to use them later */
   ptimer->state     = POSIX_TIMER_STATE_CREATE_NEW;
-  ptimer->thread_id = _Thread_Executing->Object.id;
+  ptimer->thread_id = _Thread_Get_executing()->Object.id;
   if ( evp != NULL ) {
     ptimer->inf.sigev_notify = evp->sigev_notify;
@@ -98,6 +96,6 @@ int timer_create(
   _Objects_Open_u32(&_POSIX_Timer_Information, &ptimer->Object, 0);
   *timerid  = ptimer->Object.id;
   return 0;
diff --git a/cpukit/posix/src/timerdelete.c b/cpukit/posix/src/timerdelete.c
index 5ebf8f8..71b25fa 100644
--- a/cpukit/posix/src/timerdelete.c
+++ b/cpukit/posix/src/timerdelete.c
@@ -47,6 +47,7 @@ int timer_delete(
   POSIX_Timer_Control *ptimer;
   ptimer = _POSIX_Timer_Get( timerid, &location );
@@ -54,8 +55,10 @@ int timer_delete(
       _Objects_Close( &_POSIX_Timer_Information, &ptimer->Object );
       ptimer->state = POSIX_TIMER_STATE_FREE;
       (void) _Watchdog_Remove( &ptimer->Timer );
-      _POSIX_Timer_Free( ptimer );
+      _POSIX_Timer_Free( ptimer );
       return 0;
@@ -65,5 +68,7 @@ int timer_delete(
       break;
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index f89a896..cf8ca3b 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -175,7 +175,6 @@ librtems_a_SOURCES += src/rtemstimerdata.c
 ## MESSAGE_QUEUE_C_FILES
 librtems_a_SOURCES += src/msg.c
-librtems_a_SOURCES += src/msgqallocate.c
 librtems_a_SOURCES += src/msgqbroadcast.c
 librtems_a_SOURCES += src/msgqcreate.c
 librtems_a_SOURCES += src/msgqdelete.c
diff --git a/cpukit/rtems/include/rtems/rtems/messageimpl.h b/cpukit/rtems/include/rtems/rtems/messageimpl.h
index da87fd1..714fb61 100644
--- a/cpukit/rtems/include/rtems/rtems/messageimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/messageimpl.h
@@ -90,16 +90,6 @@ rtems_status_code _Message_queue_Submit(
- * @brief Message Queue Allocate
- * This function allocates a message queue control block from
- * the inactive chain of free message queue control blocks.
- * @retval the_message_queue filled in if successful, NULL otherwise
-Message_queue_Control *_Message_queue_Allocate (void);
  * @brief Message queue Translate Core Message Queue Return Code
  * This function returns a RTEMS status code based on
@@ -162,6 +152,12 @@ RTEMS_INLINE_ROUTINE Message_queue_Control *_Message_queue_Get (
      _Objects_Get( &_Message_queue_Information, id, location );
+RTEMS_INLINE_ROUTINE Message_queue_Control *_Message_queue_Allocate( void )
+  return (Message_queue_Control *)
+    _Objects_Allocate( &_Message_queue_Information );
 #ifdef __cplusplus
diff --git a/cpukit/rtems/include/rtems/rtems/tasksimpl.h b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
index 2a99812..c86d591 100644
--- a/cpukit/rtems/include/rtems/rtems/tasksimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
@@ -77,17 +77,14 @@ void _RTEMS_Tasks_Invoke_task_variable_dtor(
   rtems_task_variable_t *tvp
- *  @brief Allocates a task control block.
- *  This function allocates a task control block from
- *  the inactive chain of free task control blocks.
-RTEMS_INLINE_ROUTINE Thread_Control *_RTEMS_tasks_Allocate( void )
+RTEMS_INLINE_ROUTINE Thread_Control *_RTEMS_tasks_Allocate(void)
-  return (Thread_Control *) _Objects_Allocate( &_RTEMS_tasks_Information );
+    _Objects_Allocate_unprotected( &_RTEMS_tasks_Information );
diff --git a/cpukit/rtems/src/barriercreate.c b/cpukit/rtems/src/barriercreate.c
index e865774..12a917f 100644
--- a/cpukit/rtems/src/barriercreate.c
+++ b/cpukit/rtems/src/barriercreate.c
@@ -68,12 +68,10 @@ rtems_status_code rtems_barrier_create(
     the_attributes.discipline = CORE_BARRIER_MANUAL_RELEASE;
   the_attributes.maximum_count = maximum_waiters;
   the_barrier = _Barrier_Allocate();
     return RTEMS_TOO_MANY;
@@ -89,6 +87,6 @@ rtems_status_code rtems_barrier_create(
   *id = the_barrier->Object.id;
   return RTEMS_SUCCESSFUL;
diff --git a/cpukit/rtems/src/barrierdelete.c b/cpukit/rtems/src/barrierdelete.c
index 90fff5e..2ea1550 100644
--- a/cpukit/rtems/src/barrierdelete.c
+++ b/cpukit/rtems/src/barrierdelete.c
@@ -28,6 +28,7 @@ rtems_status_code rtems_barrier_delete(
   Barrier_Control   *the_barrier;
   the_barrier = _Barrier_Get( id, &location );
@@ -39,10 +40,9 @@ rtems_status_code rtems_barrier_delete(
       _Objects_Close( &_Barrier_Information, &the_barrier->Object );
-      _Barrier_Free( the_barrier );
+      _Barrier_Free( the_barrier );
@@ -52,5 +52,7 @@ rtems_status_code rtems_barrier_delete(
       break;
   return RTEMS_INVALID_ID;
diff --git a/cpukit/rtems/src/dpmemcreate.c b/cpukit/rtems/src/dpmemcreate.c
index 9ad1588..206a199 100644
--- a/cpukit/rtems/src/dpmemcreate.c
+++ b/cpukit/rtems/src/dpmemcreate.c
@@ -33,7 +33,7 @@ rtems_status_code rtems_port_create(
   rtems_id     *id
-  Dual_ported_memory_Control          *the_port;
+  Dual_ported_memory_Control *the_port;
   if ( !rtems_is_name_valid( name ) )
     return RTEMS_INVALID_NAME;
@@ -45,12 +45,10 @@ rtems_status_code rtems_port_create(
        !_Addresses_Is_aligned( external_start ) )
     return RTEMS_INVALID_ADDRESS;
   the_port = _Dual_ported_memory_Allocate();
   if ( !the_port ) {
@@ -65,6 +63,6 @@ rtems_status_code rtems_port_create(
   *id = the_port->Object.id;
diff --git a/cpukit/rtems/src/dpmemdelete.c b/cpukit/rtems/src/dpmemdelete.c
index d6b42ff..6f11a53 100644
--- a/cpukit/rtems/src/dpmemdelete.c
+++ b/cpukit/rtems/src/dpmemdelete.c
@@ -32,13 +32,15 @@ rtems_status_code rtems_port_delete(
   the_port = _Dual_ported_memory_Get( id, &location );
     case OBJECTS_LOCAL:
       _Objects_Close( &_Dual_ported_memory_Information, &the_port->Object );
-      _Dual_ported_memory_Free( the_port );
       _Objects_Put( &the_port->Object );
+      _Dual_ported_memory_Free( the_port );
@@ -48,5 +50,7 @@ rtems_status_code rtems_port_delete(
       break;
diff --git a/cpukit/rtems/src/msgqallocate.c b/cpukit/rtems/src/msgqallocate.c
deleted file mode 100644
index f5776f1..0000000
--- a/cpukit/rtems/src/msgqallocate.c
+++ /dev/null
@@ -1,37 +0,0 @@
- *  @file
- *  @ingroup ClassicMessageQueue
- *  COPYRIGHT (c) 1989-1999.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/system.h>
-#include <rtems/score/chain.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/coremsgimpl.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/wkspace.h>
-#include <rtems/rtems/status.h>
-#include <rtems/rtems/attrimpl.h>
-#include <rtems/rtems/messageimpl.h>
-#include <rtems/rtems/options.h>
-#include <rtems/rtems/support.h>
-Message_queue_Control *_Message_queue_Allocate(void)
-  return (Message_queue_Control *)
-    _Objects_Allocate(&_Message_queue_Information);
diff --git a/cpukit/rtems/src/msgqcreate.c b/cpukit/rtems/src/msgqcreate.c
index 6f60773..b18f3b2 100644
--- a/cpukit/rtems/src/msgqcreate.c
+++ b/cpukit/rtems/src/msgqcreate.c
@@ -81,12 +81,10 @@ rtems_status_code rtems_message_queue_create(
 #endif
 #endif
-  _Thread_Disable_dispatch();              /* protects object pointer */
   the_message_queue = _Message_queue_Allocate();
   if ( !the_message_queue ) {
@@ -95,7 +93,7 @@ rtems_status_code rtems_message_queue_create(
     !( _Objects_MP_Allocate_and_open( &_Message_queue_Information,
                               name, the_message_queue->Object.id, false ) ) ) {
     _Message_queue_Free( the_message_queue );
 #endif
@@ -120,7 +118,7 @@ rtems_status_code rtems_message_queue_create(
 #endif
     return RTEMS_UNSATISFIED;
@@ -142,6 +140,6 @@ rtems_status_code rtems_message_queue_create(
 #endif
diff --git a/cpukit/rtems/src/msgqdelete.c b/cpukit/rtems/src/msgqdelete.c
index d3c0767..e2df2b9 100644
--- a/cpukit/rtems/src/msgqdelete.c
+++ b/cpukit/rtems/src/msgqdelete.c
@@ -37,6 +37,7 @@ rtems_status_code rtems_message_queue_delete(
   Message_queue_Control          *the_message_queue;
   the_message_queue = _Message_queue_Get( id, &location );
@@ -54,8 +55,6 @@ rtems_status_code rtems_message_queue_delete(
         CORE_MESSAGE_QUEUE_STATUS_WAS_DELETED
-      _Message_queue_Free( the_message_queue );
       if ( _Attributes_Is_global( the_message_queue->attribute_set ) ) {
         _Objects_MP_Close(
@@ -72,11 +71,13 @@ rtems_status_code rtems_message_queue_delete(
 #endif
       _Objects_Put( &the_message_queue->Object );
+      _Message_queue_Free( the_message_queue );
     case OBJECTS_REMOTE:
-      _Thread_Dispatch();
       return RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
 #endif
@@ -84,5 +85,7 @@ rtems_status_code rtems_message_queue_delete(
       break;
diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
index 32758f8..e3544e7 100644
--- a/cpukit/rtems/src/partcreate.c
+++ b/cpukit/rtems/src/partcreate.c
@@ -53,7 +53,7 @@ rtems_status_code rtems_partition_create(
   rtems_id        *id
-   Partition_Control           *the_partition;
+  Partition_Control *the_partition;
@@ -77,12 +77,10 @@ rtems_status_code rtems_partition_create(
     return RTEMS_MP_NOT_CONFIGURED;
 #endif
   the_partition = _Partition_Allocate();
   if ( !the_partition ) {
@@ -91,7 +89,7 @@ rtems_status_code rtems_partition_create(
        !( _Objects_MP_Allocate_and_open( &_Partition_Information, name,
                             the_partition->Object.id, false ) ) ) {
     _Partition_Free( the_partition );
 #endif
@@ -122,6 +120,6 @@ rtems_status_code rtems_partition_create(
 #endif
diff --git a/cpukit/rtems/src/partdelete.c b/cpukit/rtems/src/partdelete.c
index cc10abc..032f73d 100644
--- a/cpukit/rtems/src/partdelete.c
+++ b/cpukit/rtems/src/partdelete.c
@@ -29,13 +29,13 @@ rtems_status_code rtems_partition_delete(
   the_partition = _Partition_Get( id, &location );
     case OBJECTS_LOCAL:
       if ( the_partition->number_of_used_blocks == 0 ) {
         _Objects_Close( &_Partition_Information, &the_partition->Object );
-        _Partition_Free( the_partition );
         if ( _Attributes_Is_global( the_partition->attribute_set ) ) {
@@ -54,14 +54,17 @@ rtems_status_code rtems_partition_delete(
 #endif
         _Objects_Put( &the_partition->Object );
+        _Partition_Free( the_partition );
       return RTEMS_RESOURCE_IN_USE;
 #endif
@@ -69,5 +72,7 @@ rtems_status_code rtems_partition_delete(
       break;
diff --git a/cpukit/rtems/src/ratemoncreate.c b/cpukit/rtems/src/ratemoncreate.c
index ce0e1de..1f597ec 100644
--- a/cpukit/rtems/src/ratemoncreate.c
+++ b/cpukit/rtems/src/ratemoncreate.c
@@ -55,16 +55,14 @@ rtems_status_code rtems_rate_monotonic_create(
   if ( !id )
   the_period = _Rate_monotonic_Allocate();
   if ( !the_period ) {
-  the_period->owner = _Thread_Executing;
+  the_period->owner = _Thread_Get_executing();
   the_period->state = RATE_MONOTONIC_INACTIVE;
   _Watchdog_Initialize( &the_period->Timer, NULL, 0, NULL );
@@ -78,6 +76,6 @@ rtems_status_code rtems_rate_monotonic_create(
   *id = the_period->Object.id;
diff --git a/cpukit/rtems/src/ratemondelete.c b/cpukit/rtems/src/ratemondelete.c
index 0a9e6a49..36480be 100644
--- a/cpukit/rtems/src/ratemondelete.c
+++ b/cpukit/rtems/src/ratemondelete.c
@@ -30,6 +30,7 @@ rtems_status_code rtems_rate_monotonic_delete(
   Rate_monotonic_Control *the_period;
   the_period = _Rate_monotonic_Get( id, &location );
@@ -38,8 +39,9 @@ rtems_status_code rtems_rate_monotonic_delete(
       _Objects_Close( &_Rate_monotonic_Information, &the_period->Object );
       (void) _Watchdog_Remove( &the_period->Timer );
-      _Rate_monotonic_Free( the_period );
       _Objects_Put( &the_period->Object );
+      _Rate_monotonic_Free( the_period );
@@ -49,5 +51,7 @@ rtems_status_code rtems_rate_monotonic_delete(
       break;
diff --git a/cpukit/rtems/src/regioncreate.c b/cpukit/rtems/src/regioncreate.c
index 3b4325e..6c623c8 100644
--- a/cpukit/rtems/src/regioncreate.c
+++ b/cpukit/rtems/src/regioncreate.c
@@ -66,9 +66,7 @@ rtems_status_code rtems_region_create(
   if ( !id )
-  _RTEMS_Lock_allocator();                      /* to prevent deletion */
-    the_region = _Region_Allocate();
+  the_region = _Region_Allocate();
     if ( !the_region )
       return_status = RTEMS_TOO_MANY;
@@ -111,6 +109,7 @@ rtems_status_code rtems_region_create(
   return return_status;
diff --git a/cpukit/rtems/src/regiondelete.c b/cpukit/rtems/src/regiondelete.c
index 5144db0..5a2df7c 100644
--- a/cpukit/rtems/src/regiondelete.c
+++ b/cpukit/rtems/src/regiondelete.c
@@ -34,7 +34,7 @@ rtems_status_code rtems_region_delete(
   rtems_status_code   return_status;
   Region_Control     *the_region;
     the_region = _Region_Get( id, &location );
@@ -61,6 +61,7 @@ rtems_status_code rtems_region_delete(
         break;
diff --git a/cpukit/rtems/src/regionextend.c b/cpukit/rtems/src/regionextend.c
index 289377d..65b68cd 100644
--- a/cpukit/rtems/src/regionextend.c
+++ b/cpukit/rtems/src/regionextend.c
@@ -40,7 +40,7 @@ rtems_status_code rtems_region_extend(
   if ( !starting_address )
+  _RTEMS_Lock_allocator(); /* to prevent deletion */
@@ -75,5 +75,6 @@ rtems_status_code rtems_region_extend(
diff --git a/cpukit/rtems/src/regiongetsegment.c b/cpukit/rtems/src/regiongetsegment.c
index 92b3a94..4bd2445 100644
--- a/cpukit/rtems/src/regiongetsegment.c
+++ b/cpukit/rtems/src/regiongetsegment.c
@@ -47,7 +47,7 @@ rtems_status_code rtems_region_get_segment(
-    executing  = _Thread_Executing;
+    executing  = _Thread_Get_executing();
@@ -110,5 +110,6 @@ rtems_status_code rtems_region_get_segment(
diff --git a/cpukit/rtems/src/regionresizesegment.c b/cpukit/rtems/src/regionresizesegment.c
index ff45215..ee3499a 100644
--- a/cpukit/rtems/src/regionresizesegment.c
+++ b/cpukit/rtems/src/regionresizesegment.c
@@ -64,7 +64,8 @@ rtems_status_code rtems_region_resize_segment(
         _Region_Debug_Walk( the_region, 8 );
         if ( status == HEAP_RESIZE_SUCCESSFUL )
-          _Region_Process_queue( the_region );    /* unlocks allocator */
+          /* unlocks allocator */
+          _Region_Process_queue( the_region );
         else
diff --git a/cpukit/rtems/src/semcreate.c b/cpukit/rtems/src/semcreate.c
index bf9229e..5cd9568 100644
--- a/cpukit/rtems/src/semcreate.c
+++ b/cpukit/rtems/src/semcreate.c
@@ -100,12 +100,10 @@ rtems_status_code rtems_semaphore_create(
   if ( !_Attributes_Is_counting_semaphore( attribute_set ) && ( count > 1 ) )
     return RTEMS_INVALID_NUMBER;
   the_semaphore = _Semaphore_Allocate();
@@ -114,7 +112,7 @@ rtems_status_code rtems_semaphore_create(
        ! ( _Objects_MP_Allocate_and_open( &_Semaphore_Information, name,
                             the_semaphore->Object.id, false ) ) ) {
 #endif
@@ -179,14 +177,14 @@ rtems_status_code rtems_semaphore_create(
     mutex_status = _CORE_mutex_Initialize(
       &the_semaphore->Core_control.mutex,
-      _Thread_Executing,
+      _Thread_Get_executing(),
       &the_mutex_attr,
       (count == 1) ? CORE_MUTEX_UNLOCKED : CORE_MUTEX_LOCKED
     if ( mutex_status == CORE_MUTEX_STATUS_CEILING_VIOLATED ) {
       return RTEMS_INVALID_PRIORITY;
@@ -212,6 +210,6 @@ rtems_status_code rtems_semaphore_create(
       0                          /* Not used */
 #endif
diff --git a/cpukit/rtems/src/semdelete.c b/cpukit/rtems/src/semdelete.c
index ea82b77..6e7c5ea 100644
--- a/cpukit/rtems/src/semdelete.c
+++ b/cpukit/rtems/src/semdelete.c
@@ -44,6 +44,8 @@ rtems_status_code rtems_semaphore_delete(
   the_semaphore = _Semaphore_Get( id, &location );
@@ -53,6 +55,7 @@ rtems_status_code rtems_semaphore_delete(
              !_Attributes_Is_simple_binary_semaphore(
                  the_semaphore->attribute_set ) ) {
         _CORE_mutex_Flush(
@@ -70,8 +73,6 @@ rtems_status_code rtems_semaphore_delete(
       _Objects_Close( &_Semaphore_Information, &the_semaphore->Object );
-      _Semaphore_Free( the_semaphore );
       if ( _Attributes_Is_global( the_semaphore->attribute_set ) ) {
@@ -85,12 +86,15 @@ rtems_status_code rtems_semaphore_delete(
 #endif
+      _Semaphore_Free( the_semaphore );
 #endif
@@ -98,5 +102,6 @@ rtems_status_code rtems_semaphore_delete(
       break;
diff --git a/cpukit/rtems/src/taskcreate.c b/cpukit/rtems/src/taskcreate.c
index ae4e188..35dd37c 100644
--- a/cpukit/rtems/src/taskcreate.c
+++ b/cpukit/rtems/src/taskcreate.c
@@ -105,11 +105,6 @@ rtems_status_code rtems_task_create(
    *  Allocate the thread control block and -- if the task is global --
    *  allocate a global object control block.
@@ -122,7 +117,7 @@ rtems_status_code rtems_task_create(
   the_thread = _RTEMS_tasks_Allocate();
@@ -132,7 +127,7 @@ rtems_status_code rtems_task_create(
     if ( _Objects_MP_Is_null_global_object( the_global_object ) ) {
       _RTEMS_tasks_Free( the_thread );
@@ -164,7 +159,7 @@ rtems_status_code rtems_task_create(
       _Objects_MP_Free_global_object( the_global_object );
 #endif
@@ -195,6 +190,6 @@ rtems_status_code rtems_task_create(
 #endif
diff --git a/cpukit/rtems/src/timercreate.c b/cpukit/rtems/src/timercreate.c
index 35cdfab..0b1c44b 100644
--- a/cpukit/rtems/src/timercreate.c
+++ b/cpukit/rtems/src/timercreate.c
@@ -38,12 +38,10 @@ rtems_status_code rtems_timer_create(
   if ( !id )
   the_timer = _Timer_Allocate();
   if ( !the_timer ) {
@@ -57,6 +55,6 @@ rtems_status_code rtems_timer_create(
   *id = the_timer->Object.id;
diff --git a/cpukit/rtems/src/timerdelete.c b/cpukit/rtems/src/timerdelete.c
index a3cf52a..19232c8 100644
--- a/cpukit/rtems/src/timerdelete.c
+++ b/cpukit/rtems/src/timerdelete.c
@@ -32,14 +32,16 @@ rtems_status_code rtems_timer_delete(
   Timer_Control     *the_timer;
   the_timer = _Timer_Get( id, &location );
     case OBJECTS_LOCAL:
       _Objects_Close( &_Timer_Information, &the_timer->Object );
       (void) _Watchdog_Remove( &the_timer->Ticker );
-      _Timer_Free( the_timer );
       _Objects_Put( &the_timer->Object );
+      _Timer_Free( the_timer );
@@ -49,5 +51,7 @@ rtems_status_code rtems_timer_delete(
       break;
diff --git a/cpukit/sapi/src/extensioncreate.c b/cpukit/sapi/src/extensioncreate.c
index 1d7232f..8442096 100644
--- a/cpukit/sapi/src/extensioncreate.c
+++ b/cpukit/sapi/src/extensioncreate.c
@@ -39,16 +39,16 @@ rtems_status_code rtems_extension_create(
   the_extension = _Extension_Allocate();
   if ( !the_extension ) {
+  _Thread_Disable_dispatch();
   _User_extensions_Add_set_with_table( &the_extension->Extension, extension_table );
+  _Thread_Enable_dispatch();
   _Objects_Open(
     &_Extension_Information,
@@ -57,6 +57,6 @@ rtems_status_code rtems_extension_create(
   *id = the_extension->Object.id;
diff --git a/cpukit/sapi/src/extensiondelete.c b/cpukit/sapi/src/extensiondelete.c
index 0eaaffd..f851ea0 100644
--- a/cpukit/sapi/src/extensiondelete.c
+++ b/cpukit/sapi/src/extensiondelete.c
@@ -30,13 +30,15 @@ rtems_status_code rtems_extension_delete(
   Extension_Control   *the_extension;
   the_extension = _Extension_Get( id, &location );
     case OBJECTS_LOCAL:
       _User_extensions_Remove_set( &the_extension->Extension );
       _Objects_Close( &_Extension_Information, &the_extension->Object );
-      _Extension_Free( the_extension );
       _Objects_Put( &the_extension->Object );
+      _Extension_Free( the_extension );
@@ -46,5 +48,7 @@ rtems_status_code rtems_extension_delete(
       break;
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index 119f11d..424252a 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -20,6 +20,7 @@
 #define _RTEMS_SCORE_OBJECTIMPL_H
+#include <rtems/score/apimutex.h>
 #include <rtems/score/isrlevel.h>
@@ -263,17 +264,22 @@ unsigned int _Objects_API_maximum_class(
   uint32_t api
+Objects_Control *_Objects_Allocate_unprotected(
+  Objects_Information *information
- *  @brief Allocate an object.
+ * @brief Allocates an object.
- *  This function allocates an object control block from
- *  the inactive chain of free object control blocks.
+ * This function locks the object allocator mutex.  The caller must later
+ * unlock the object allocator mutex via _Objects_Allocator_unlock().
- *  @param[in] information points to an object class information block.
+ * @param[in] information The object information block.
+ * @retval NULL No object available.
+ * @retval object The allocated object.
-Objects_Control *_Objects_Allocate(
-  Objects_Information *information
+Objects_Control *_Objects_Allocate( Objects_Information *information );
  *  @brief Free an object.
@@ -892,6 +898,16 @@ RTEMS_INLINE_ROUTINE void _Objects_Put_for_get_isr_disable(
 #endif
+RTEMS_INLINE_ROUTINE void _Objects_Allocator_lock( void )
+RTEMS_INLINE_ROUTINE void _Objects_Allocator_unlock( void )
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index d0c7933..2ac8344 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -590,13 +590,10 @@ RTEMS_INLINE_ROUTINE uint32_t _Thread_Get_maximum_internal_threads(void)
   return maximum_internal_threads;
- * This routine allocates an internal thread.
 RTEMS_INLINE_ROUTINE Thread_Control *_Thread_Internal_allocate( void )
-  return (Thread_Control *) _Objects_Allocate( &_Thread_Internal_information );
+    _Objects_Allocate_unprotected( &_Thread_Internal_information );
 RTEMS_INLINE_ROUTINE void _Thread_Request_dispatch_if_executing(
diff --git a/cpukit/score/src/apimutex.c b/cpukit/score/src/apimutex.c
index 18ac2db8..7899934 100644
--- a/cpukit/score/src/apimutex.c
+++ b/cpukit/score/src/apimutex.c
@@ -58,7 +58,8 @@ void _API_Mutex_Allocate(
     0
-  mutex = (API_Mutex_Control *) _Objects_Allocate( &_API_Mutex_Information );
+  mutex = (API_Mutex_Control *)
+    _Objects_Allocate_unprotected( &_API_Mutex_Information );
   _CORE_mutex_Initialize( &mutex->Mutex, NULL, &attr, CORE_MUTEX_UNLOCKED );
diff --git a/cpukit/score/src/objectactivecount.c b/cpukit/score/src/objectactivecount.c
index de34212..de3243a 100644
--- a/cpukit/score/src/objectactivecount.c
+++ b/cpukit/score/src/objectactivecount.c
@@ -17,14 +17,20 @@
 #endif
+#include <rtems/score/assert.h>
 Objects_Maximum _Objects_Active_count(
   const Objects_Information *information
-  size_t inactive = _Chain_Node_count_unprotected( &information->Inactive );
-  size_t maximum  = information->maximum;
+  size_t inactive;
+  size_t maximum;
+  _Assert( _Debug_Is_owner_of_allocator() );
+  inactive = _Chain_Node_count_unprotected( &information->Inactive );
+  maximum  = information->maximum;
   return (Objects_Maximum) ( maximum - inactive );
diff --git a/cpukit/score/src/objectallocate.c b/cpukit/score/src/objectallocate.c
index 842c49d..40a7cae 100644
--- a/cpukit/score/src/objectallocate.c
+++ b/cpukit/score/src/objectallocate.c
@@ -19,7 +19,9 @@
 #endif
+#include <rtems/score/sysstate.h>
 /* #define RTEMS_DEBUG_OBJECT_ALLOCATION */
@@ -27,12 +29,24 @@
 #include <rtems/bspIo.h>
 #endif
+static Objects_Control *_Objects_Get_inactive(
+  return (Objects_Control *) _Chain_Get_unprotected( &information->Inactive );
   Objects_Control *the_object;
+  _Assert(
+    _Debug_Is_owner_of_allocator()
+      || !_System_state_Is_up( _System_state_Get() )
    *  If the application is using the optional manager stubs and
    *  still attempts to create the object, the information block
@@ -46,7 +60,7 @@ Objects_Control *_Objects_Allocate(
    *  OK.  The manager should be initialized and configured to have objects.
    *  With any luck, it is safe to attempt to allocate an object.
-  the_object = (Objects_Control *) _Chain_Get( &information->Inactive );
+  the_object = _Objects_Get_inactive( information );
   if ( information->auto_extend ) {
@@ -56,7 +70,7 @@ Objects_Control *_Objects_Allocate(
     if ( !the_object ) {
       _Objects_Extend_information( information );
     if ( the_object ) {
@@ -83,3 +97,10 @@ Objects_Control *_Objects_Allocate(
   return the_object;
+  return _Objects_Allocate_unprotected( information );
diff --git a/cpukit/score/src/objectextendinformation.c b/cpukit/score/src/objectextendinformation.c
index d11f927..b1fcec7 100644
--- a/cpukit/score/src/objectextendinformation.c
+++ b/cpukit/score/src/objectextendinformation.c
@@ -20,8 +20,10 @@
 #include <rtems/score/address.h>
 #include <string.h>  /* for memcpy() */
@@ -42,10 +44,10 @@ void _Objects_Extend_information(
-  Chain_Control     Inactive;
   uint32_t          block_count;
   uint32_t          block;
   uint32_t          index_base;
+  uint32_t          index_end;
   uint32_t          minimum_index;
   uint32_t          index;
   uint32_t          maximum;
@@ -53,6 +55,11 @@ void _Objects_Extend_information(
   void             *new_object_block;
   bool              do_extend;
+  _Assert(
    *  Search for a free block of indexes. If we do NOT need to allocate or
    *  extend the block table, then we will change do_extend.
@@ -76,6 +83,7 @@ void _Objects_Extend_information(
         index_base += information->allocation_size;
+  index_end = index_base + information->allocation_size;
   maximum = (uint32_t) information->maximum + information->allocation_size;
@@ -213,12 +221,11 @@ void _Objects_Extend_information(
     object_blocks[block_count] = NULL;
     inactive_per_block[block_count] = 0;
-    for ( index=index_base ;
-          index < ( information->allocation_size + index_base );
-          index++ ) {
+    for ( index = index_base ; index < index_end ; ++index ) {
       local_table[ index ] = NULL;
     _ISR_Disable( level );
     old_tables = information->object_blocks;
@@ -235,6 +242,7 @@ void _Objects_Extend_information(
     _ISR_Enable( level );
     _Workspace_Free( old_tables );
@@ -247,32 +255,21 @@ void _Objects_Extend_information(
   information->object_blocks[ block ] = new_object_block;
-   *  Initialize objects .. add to a local chain first.
+   *  Append to inactive chain.
-  _Chain_Initialize(
-    &Inactive,
-    information->object_blocks[ block ],
-    information->allocation_size,
-    information->size
-   *  Move from the local chain, initialise, then append to the inactive chain
-  index = index_base;
-  while ((the_object = (Objects_Control *) _Chain_Get( &Inactive )) != NULL ) {
+  the_object = information->object_blocks[ block ];
     the_object->id = _Objects_Build_id(
-        information->the_api,
-        information->the_class,
-        _Objects_Local_node,
-        index
+      information->the_api,
+      information->the_class,
+      _Objects_Local_node,
+      index
-    _Chain_Append( &information->Inactive, &the_object->Node );
+    _Chain_Append_unprotected( &information->Inactive, &the_object->Node );
-    index++;
+    the_object = (Objects_Control *)
+      ( (char *) the_object + information->size );
   information->inactive_per_block[ block ] = information->allocation_size;
diff --git a/cpukit/score/src/objectfree.c b/cpukit/score/src/objectfree.c
index cc2fbac..f1c0ee4 100644
--- a/cpukit/score/src/objectfree.c
+++ b/cpukit/score/src/objectfree.c
@@ -19,6 +19,7 @@
 #endif
 void _Objects_Free(
@@ -28,7 +29,9 @@ void _Objects_Free(
   uint32_t    allocation_size = information->allocation_size;
     uint32_t    block;
diff --git a/cpukit/score/src/objectshrinkinformation.c b/cpukit/score/src/objectshrinkinformation.c
index 9731c21..2f64cd2 100644
--- a/cpukit/score/src/objectshrinkinformation.c
+++ b/cpukit/score/src/objectshrinkinformation.c
@@ -19,6 +19,7 @@
 #endif
@@ -30,6 +31,8 @@ void _Objects_Shrink_information(
   uint32_t          block;
    * Search the list to find block or chunk with all objects inactive.
@@ -55,7 +58,7 @@ void _Objects_Shrink_information(
         node = _Chain_Next( node );
         if ( index >= index_base && index < index_end ) {
-          _Chain_Extract( &object->Node );
+          _Chain_Extract_unprotected( &object->Node );
diff --git a/testsuites/sptests/spobjgetnext/init.c b/testsuites/sptests/spobjgetnext/init.c
index 9682c34..2695190 100644
--- a/testsuites/sptests/spobjgetnext/init.c
+++ b/testsuites/sptests/spobjgetnext/init.c
@@ -108,7 +108,9 @@ rtems_task Init(
   /* XXX try with a manager with no objects created */
   puts( "Init - _Objects_Active_count" );
   active_count = _Objects_Active_count( info );
   rtems_test_assert( active_count == 1 );
   TEST_END();
1.7.7
