[PATCH 1/9] spratemon_err01: New test split from sp09.
Jennifer Averett jennifer.averett at oarcorp.com
Thu Mar 27 15:29:58 UTC 2014
This test splits sp09 screen10 into a unique
rate monotonic error test.
 testsuites/sptests/Makefile.am                     |   2 +-
 testsuites/sptests/configure.ac                    |   1 +
 testsuites/sptests/sp09/Makefile.am                |   4 +-
 testsuites/sptests/sp09/screen03.c                 |  11 -
 testsuites/sptests/sp09/screen10.c                 | 222 ---------------------
 testsuites/sptests/sp09/sp09.scn                   |  27 ---
 testsuites/sptests/sp09/system.h                   |   8 +-
 testsuites/sptests/sp09/task1.c                    |   5 +-
 testsuites/sptests/sp09/task4.c                    |  51 -----
 testsuites/sptests/spratemon_err01/Makefile.am     |  23 +++
 testsuites/sptests/spratemon_err01/init.c          |  40 ++++
 testsuites/sptests/spratemon_err01/screen10.c      | 222 +++++++++++++++++++++
 .../sptests/spratemon_err01/spratemon_err01.doc    |  25 +++
 .../sptests/spratemon_err01/spratemon_err01.scn    |  28 +++
 testsuites/sptests/spratemon_err01/system.h        |  75 +++++++
 testsuites/sptests/spratemon_err01/task4.c         |  51 +++++
 16 files changed, 470 insertions(+), 325 deletions(-)
 delete mode 100644 testsuites/sptests/sp09/screen10.c
 delete mode 100644 testsuites/sptests/sp09/task4.c
 create mode 100644 testsuites/sptests/spratemon_err01/Makefile.am
 create mode 100644 testsuites/sptests/spratemon_err01/init.c
 create mode 100644 testsuites/sptests/spratemon_err01/screen10.c
 create mode 100644 testsuites/sptests/spratemon_err01/spratemon_err01.doc
 create mode 100644 testsuites/sptests/spratemon_err01/spratemon_err01.scn
 create mode 100644 testsuites/sptests/spratemon_err01/system.h
 create mode 100644 testsuites/sptests/spratemon_err01/task4.c
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index d57ae69..f6831ce 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -29,7 +29,7 @@ SUBDIRS = \
     sppagesize spsem01 spsem02 spsimplesched01 spsimplesched02 \
     spsimplesched03 spnsext01 spedfsched01 spedfsched02 spedfsched03 \
     spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
-    spregion_err01 sppartition_err01
+    spregion_err01 sppartition_err01 spratemon_err01
 SUBDIRS += spprofiling01
 SUBDIRS += spcache01
 SUBDIRS += sptls03
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 5f98ba7..b980b2d 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -199,6 +199,7 @@ sppagesize/Makefile
 spprintk/Makefile
 spprivenv01/Makefile
 spqreslib/Makefile
+spratemon_err01/Makefile
 sprbtree01/Makefile
 spsem01/Makefile
 spsem02/Makefile
diff --git a/testsuites/sptests/sp09/Makefile.am b/testsuites/sptests/sp09/Makefile.am
index 67e97ce..f486853 100644
--- a/testsuites/sptests/sp09/Makefile.am
+++ b/testsuites/sptests/sp09/Makefile.am
@@ -1,8 +1,8 @@
 rtems_tests_PROGRAMS = sp09
 sp09_SOURCES = init.c delay.c isr.c screen01.c screen02.c screen03.c screen04.c \
-    screen05.c screen06.c screen07.c screen08.c screen09.c screen10.c \
-    task1.c task2.c task3.c task4.c \
+    screen05.c screen06.c screen07.c screen08.c screen09.c \
+    task1.c task2.c task3.c \
     system.h
 dist_rtems_tests_DATA = sp09.scn
diff --git a/testsuites/sptests/sp09/screen03.c b/testsuites/sptests/sp09/screen03.c
index 3fd3fc9..7debabc 100644
--- a/testsuites/sptests/sp09/screen03.c
+++ b/testsuites/sptests/sp09/screen03.c
@@ -134,17 +134,6 @@ void Screen3()
   puts( "TA1 - rtems_task_create - TA3 created - RTEMS_SUCCESSFUL" );
   status = rtems_task_create(
-    Task_name[ 4 ],
-    4,
-    RTEMS_MINIMUM_STACK_SIZE,
-    RTEMS_DEFAULT_MODES,
-    RTEMS_DEFAULT_ATTRIBUTES,
-    &Task_id[ 4 ]
-  directive_failed( status, "rtems_task_create of TA4" );
-  puts( "TA1 - rtems_task_create - 4 created - RTEMS_SUCCESSFUL" );
-  status = rtems_task_create(
     Task_name[ 5 ],
     4,
diff --git a/testsuites/sptests/sp09/screen10.c b/testsuites/sptests/sp09/screen10.c
deleted file mode 100644
index e7a883a..0000000
--- a/testsuites/sptests/sp09/screen10.c
+++ /dev/null
@@ -1,222 +0,0 @@
-/*  Screen10
- *  This routine generates error screen 10 for test 9.
- *  Input parameters:  NONE
- *  Output parameters:  NONE
- *  COPYRIGHT (c) 1989-2009.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include "system.h"
-void Screen10()
-  rtems_rate_monotonic_period_status period_status;
-  rtems_status_code                  status;
-   * Check create error cases.
-  status = rtems_rate_monotonic_create( Period_name[ 1 ], NULL );
-  fatal_directive_status(
-    status,
-    RTEMS_INVALID_ADDRESS,
-    "rtems_rate_monotonic_create with NULL param"
-  puts( "TA1 - rtems_rate_monotonic_create - RTEMS_INVALID_ADDRESS" );
-  status = rtems_rate_monotonic_create( 0, &Junk_id );
-    status,
-    RTEMS_INVALID_NAME,
-    "rtems_rate_monotonic_create with illegal name"
-  puts( "TA1 - rtems_rate_monotonic_create - RTEMS_INVALID_NAME" );
-  status = rtems_rate_monotonic_create( Period_name[ 1 ], &Period_id[ 1 ] );
-  directive_failed( status, "rtems_rate_monotonic_create successful" );
-  puts( "TA1 - rtems_rate_monotonic_create - RTEMS_SUCCESSFUL" );
-  status = rtems_rate_monotonic_create( Period_name[ 1 ], &Junk_id );
-    status,
-    RTEMS_TOO_MANY,
-    "rtems_rate_monotonic_create of too many"
-  puts( "TA1 - rtems_rate_monotonic_create - RTEMS_TOO_MANY" );
-   * Check ident error cases.
-  status = rtems_rate_monotonic_ident( 0, &Junk_id );
-    status,
-    "rtems_rate_monotonic_ident with illegal name"
-  puts( "TA1 - rtems_rate_monotonic_ident - RTEMS_INVALID_NAME" );
-   * Check period error cases.
-  status = rtems_rate_monotonic_period( 100, 5 );
-    status,
-    RTEMS_INVALID_ID,
-    "rtems_rate_monotonic_period with illegal id"
-  puts( "TA1 - rtems_rate_monotonic_period - RTEMS_INVALID_ID" );
-  status = rtems_rate_monotonic_period( rtems_build_id( 1, 1, 1, 256 ), 5 );
-    status,
-    RTEMS_INVALID_ID,
-  puts( "TA1 - rtems_rate_monotonic_period - local RTEMS_INVALID_ID" );
-  status = rtems_rate_monotonic_period( Period_id[ 1 ], RTEMS_PERIOD_STATUS );
-    status,
-    RTEMS_NOT_DEFINED,
-    "rtems_rate_monotonic_period status not defined"
-  puts(
-    "TA1 - rtems_rate_monotonic_period(RTEMS_PERIOD_STATUS) - RTEMS_NOT_DEFINED"
-  status = rtems_rate_monotonic_period( Period_id[ 1 ], 100 );
-  directive_failed( status, "rtems_rate_monotonic_period successful" );
-  puts( "TA1 - rtems_rate_monotonic_period - 100 ticks - RTEMS_SUCCESSFUL" );
-  directive_failed( status, "rtems_rate_monotonic_period status" );
-  puts(
-    "TA1 - rtems_rate_monotonic_period(RTEMS_PERIOD_STATUS) - RTEMS_SUCCESSFUL"
-  while ( FOREVER ) {
-     status = rtems_rate_monotonic_period(Period_id[ 1 ], RTEMS_PERIOD_STATUS);
-     if ( status == RTEMS_TIMEOUT ) break;
-     directive_failed(
-       status,
-       "rtems_rate_monotonic_period waiting for timeout"
-     rtems_task_wake_after( 1 );
-  puts(
-    "TA1 - rtems_rate_monotonic_period(RTEMS_PERIOD_STATUS) - RTEMS_TIMEOUT"
-   * Check get_statistics error cases.
-  status = rtems_rate_monotonic_get_statistics( Period_id[ 1 ], NULL );
-    status,
-    "rtems_rate_monotonic_get_statistics with NULL param"
-  puts( "TA1 - rtems_rate_monotonic_get_statistics - RTEMS_INVALID_ADDRESS" );
-   * Check get_status error cases.
-  status = rtems_rate_monotonic_get_status( Period_id[ 1 ], NULL );
-    status,
-    "rtems_rate_monotonic_get_status with NULL param"
-  puts( "TA1 - rtems_rate_monotonic_get_status - RTEMS_INVALID_ADDRESS" );
-  status = rtems_rate_monotonic_get_status( 100, &period_status );
-    status,
-    RTEMS_INVALID_ID,
-    "rtems_rate_monotonic_get_status with illegal id"
-  puts( "TA1 - rtems_rate_monotonic_get_status - RTEMS_INVALID_ID" );
-   * Check cancel error cases.
-  status = rtems_rate_monotonic_cancel( 100 );
-    status,
-    RTEMS_INVALID_ID,
-    "rtems_rate_monotonic_cancel with illegal id"
-  puts( "TA1 - rtems_rate_monotonic_cancel - RTEMS_INVALID_ID" );
-  status = rtems_rate_monotonic_cancel( rtems_build_id( 1, 1, 1, 256 ) );
-    status,
-    RTEMS_INVALID_ID,
-    "rtems_rate_monotonic_cancel will illegal id"
-  puts( "TA1 - rtems_rate_monotonic_cancel - local RTEMS_INVALID_ID" );
-  status = rtems_rate_monotonic_cancel( Period_id[ 1 ] );
-  directive_failed( status, "rtems_rate_monotonic_cancel" );
-  puts( "TA1 - rtems_rate_monotonic_cancel - RTEMS_SUCCESSFUL" );
-  status = rtems_rate_monotonic_period( Period_id[ 1 ], 5 );
-  directive_failed( status, "rtems_rate_monotonic_period restart" );
-  status = rtems_task_wake_after( rtems_clock_get_ticks_per_second() );
-  directive_failed( status, "rtems_task_wake_after" );
-    status,
-    RTEMS_TIMEOUT,
-    "rtems_rate_monotonic_period"
-  puts( "TA1 - rtems_rate_monotonic_period - 5 ticks - RTEMS_TIMEOUT" );
-  status = rtems_task_start( Task_id[ 4 ], Task_4, 0 );
-  directive_failed( status, "rtems_task_start of TA4" );
-  puts( "TA1 - yielding to TA4" );
-  status = rtems_task_wake_after( RTEMS_YIELD_PROCESSOR );
-   * Check delete error cases.
-  status = rtems_rate_monotonic_delete( 100 );
-    status,
-    RTEMS_INVALID_ID,
-    "rtems_rate_monotonic_delete with illegal id"
-  puts( "TA1 - rtems_rate_monotonic_delete - RTEMS_INVALID_ID" );
-  status = rtems_rate_monotonic_delete( rtems_build_id( 1, 1, 1, 256 ) );
-    status,
-    RTEMS_INVALID_ID,
-  puts( "TA1 - rtems_rate_monotonic_delete - local RTEMS_INVALID_ID" );
-  status = rtems_rate_monotonic_delete( Period_id[ 1 ] );
-  directive_failed( status, "rtems_rate_monotonic_delete" );
-  puts( "TA1 - rtems_rate_monotonic_delete - RTEMS_SUCCESSFUL" );
diff --git a/testsuites/sptests/sp09/sp09.scn b/testsuites/sptests/sp09/sp09.scn
index 9cd3545..5539b1f 100644
--- a/testsuites/sptests/sp09/sp09.scn
+++ b/testsuites/sptests/sp09/sp09.scn
@@ -65,7 +65,6 @@ TA1 - rtems_task_suspend - suspend TA2 - RTEMS_SUCCESSFUL
 TA1 - rtems_task_suspend - suspend TA2 - RTEMS_ALREADY_SUSPENDED
 TA1 - rtems_task_resume - TA2 resumed - RTEMS_SUCCESSFUL
-TA1 - rtems_task_create - 4 created - RTEMS_SUCCESSFUL
 TA1 - rtems_task_create - 5 created - RTEMS_SUCCESSFUL
 TA1 - rtems_task_create - 6 created - RTEMS_SUCCESSFUL
 TA1 - rtems_task_create - 7 created - RTEMS_SUCCESSFUL
@@ -192,30 +191,4 @@ TA1 - rtems_port_ident - RTEMS_INVALID_NAME
 TA1 - rtems_port_external_to_internal - RTEMS_INVALID_ADDRESS
 TA1 - rtems_port_internal_to_external - RTEMS_INVALID_ID
-<pause - screen 10>
-TA1 - rtems_rate_monotonic_create - RTEMS_INVALID_ADDRESS
-TA1 - rtems_rate_monotonic_create - RTEMS_INVALID_NAME
-TA1 - rtems_rate_monotonic_create - RTEMS_SUCCESSFUL
-TA1 - rtems_rate_monotonic_create - RTEMS_TOO_MANY
-TA1 - rtems_rate_monotonic_ident - RTEMS_INVALID_NAME
-TA1 - rtems_rate_monotonic_period - RTEMS_INVALID_ID
-TA1 - rtems_rate_monotonic_period - local RTEMS_INVALID_ID
-TA1 - rtems_rate_monotonic_period(RTEMS_PERIOD_STATUS) - RTEMS_NOT_DEFINED
-TA1 - rtems_rate_monotonic_period - 100 ticks - RTEMS_SUCCESSFUL
-TA1 - rtems_rate_monotonic_period(RTEMS_PERIOD_STATUS) - RTEMS_SUCCESSFUL
-TA1 - rtems_rate_monotonic_period(RTEMS_PERIOD_STATUS) - RTEMS_TIMEOUT
-TA1 - rtems_rate_monotonic_get_statistics - RTEMS_INVALID_ADDRESS
-TA1 - rtems_rate_monotonic_get_status - RTEMS_INVALID_ADDRESS
-TA1 - rtems_rate_monotonic_get_status - RTEMS_INVALID_ID
-TA1 - rtems_rate_monotonic_cancel - RTEMS_INVALID_ID
-TA1 - rtems_rate_monotonic_cancel - local RTEMS_INVALID_ID
-TA1 - rtems_rate_monotonic_cancel - RTEMS_SUCCESSFUL
-TA1 - rtems_rate_monotonic_period - 5 ticks - RTEMS_TIMEOUT
-TA1 - yielding to TA4
-TA4 - rtems_rate_monotonic_cancel - RTEMS_NOT_OWNER_OF_RESOURCE
-TA4 - rtems_rate_monotonic_period - RTEMS_NOT_OWNER_OF_RESOURCE
-TA4 - rtems_task_delete - delete self - RTEMS_SUCCESSFUL
-TA1 - rtems_rate_monotonic_delete - RTEMS_INVALID_ID
-TA1 - rtems_rate_monotonic_delete - local RTEMS_INVALID_ID
-TA1 - rtems_rate_monotonic_delete - RTEMS_SUCCESSFUL
 *** END OF TEST 9 ***
diff --git a/testsuites/sptests/sp09/system.h b/testsuites/sptests/sp09/system.h
index 55b5099..2e1b4df 100644
--- a/testsuites/sptests/sp09/system.h
+++ b/testsuites/sptests/sp09/system.h
@@ -37,10 +37,6 @@ rtems_task Task_3(
   rtems_task_argument argument
-rtems_task Task_4(
-  rtems_task_argument argument
 rtems_isr Service_routine(
   rtems_vector_number ignored
@@ -67,14 +63,12 @@ void Screen8( void );
 void Screen9( void );
-void Screen10( void );
 /* configuration information */
 #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_MAXIMUM_TASKS              10
+#define CONFIGURE_MAXIMUM_TASKS               9
 #define CONFIGURE_MAXIMUM_TIMERS              1
 #define CONFIGURE_MAXIMUM_SEMAPHORES          2
 #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES      1
diff --git a/testsuites/sptests/sp09/task1.c b/testsuites/sptests/sp09/task1.c
index 30318b4..1e8bf6f 100644
--- a/testsuites/sptests/sp09/task1.c
+++ b/testsuites/sptests/sp09/task1.c
@@ -50,10 +50,7 @@ rtems_task Task_1(
   rtems_test_pause_and_screen_number( 9 );
   Screen9();
-  rtems_test_pause_and_screen_number( 10 );
-  Screen10();
   puts( "*** END OF TEST 9 ***" );
   rtems_test_exit( 0 );
diff --git a/testsuites/sptests/sp09/task4.c b/testsuites/sptests/sp09/task4.c
index 4e8df72..0000000
--- a/testsuites/sptests/sp09/task4.c
+++ /dev/null
@@ -1,51 +0,0 @@
-/*  Task_4
- *  This routine serves as a test task.  Its only purpose in life is to
- *  generate the error where a rate monotonic period is accessed by a
- *  task other than its creator.
- *    argument - task argument
- *  COPYRIGHT (c) 1989-1999.
-#endif
-rtems_task Task_4(
-    status,
-    RTEMS_NOT_OWNER_OF_RESOURCE,
-    "rtems_rate_monotonic_cancel not the owner"
-  puts( "TA4 - rtems_rate_monotonic_cancel - RTEMS_NOT_OWNER_OF_RESOURCE" );
-    status,
-    "rtems_rate_monotonic_period not the owner"
-  puts( "TA4 - rtems_rate_monotonic_period - RTEMS_NOT_OWNER_OF_RESOURCE" );
-  puts( "TA4 - rtems_task_delete - delete self - RTEMS_SUCCESSFUL" );
-  status = rtems_task_delete( RTEMS_SELF );
-  directive_failed( status, "rtems_task_delete of TA4" );
diff --git a/testsuites/sptests/spratemon_err01/Makefile.am b/testsuites/sptests/spratemon_err01/Makefile.am
new file mode 100644
index 0000000..e068243
--- /dev/null
+++ b/testsuites/sptests/spratemon_err01/Makefile.am
@@ -0,0 +1,23 @@
+rtems_tests_PROGRAMS = spratemon_err01
+spratemon_err01_SOURCES = init.c screen10.c \
+    task4.c system.h
+dist_rtems_tests_DATA = spratemon_err01.scn
+dist_rtems_tests_DATA += spratemon_err01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spratemon_err01_OBJECTS)
+LINK_LIBS = $(spratemon_err01_LDLIBS)
+spratemon_err01$(EXEEXT): $(spratemon_err01_OBJECTS) $(spratemon_err01_DEPENDENCIES)
+	@rm -f spratemon_err01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spratemon_err01/init.c b/testsuites/sptests/spratemon_err01/init.c
index 0000000..0851784
--- /dev/null
+++ b/testsuites/sptests/spratemon_err01/init.c
@@ -0,0 +1,40 @@
+ *  COPYRIGHT (c) 2014.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include "system.h"
+rtems_task Init(
+  rtems_task_argument argument
+  rtems_status_code status;
+  puts( "\n\n*** TEST RATE MONOTONIC ERROR 01 ***" );
+  Task_name[ 4 ]       =  rtems_build_name( 'T', 'A', '4', ' ' );
+  Period_name[ 1 ]     =  rtems_build_name( 'T', 'M', '1', ' ' );
+  status = rtems_task_create(
+    Task_name[ 4 ],
+    1,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &Task_id[ 4 ]
+  directive_failed( status, "rtems_task_create of TA4" );
+  puts( "TA1 - rtems_task_create - 4 created - RTEMS_SUCCESSFUL" );
+  Screen10();
+  puts( "*** END TEST RATE MONOTONIC ERROR 01 ***" );
diff --git a/testsuites/sptests/spratemon_err01/screen10.c b/testsuites/sptests/spratemon_err01/screen10.c
index 0000000..d1c1850
--- /dev/null
+++ b/testsuites/sptests/spratemon_err01/screen10.c
@@ -0,0 +1,222 @@
+/*  Screen10
+ *  This routine generates error screen 10 for test 9.
+ *  Input parameters:  NONE
+ *  Output parameters:  NONE
+ *  COPYRIGHT (c) 1989-2009.
+#endif
+void Screen10()
+  rtems_rate_monotonic_period_status period_status;
+   * Check create error cases.
+  status = rtems_rate_monotonic_create( Period_name[ 1 ], NULL );
+  fatal_directive_status(
+    status,
+    RTEMS_INVALID_ADDRESS,
+    "rtems_rate_monotonic_create with NULL param"
+  puts( "TA1 - rtems_rate_monotonic_create - RTEMS_INVALID_ADDRESS" );
+  status = rtems_rate_monotonic_create( 0, &Junk_id );
+    status,
+    RTEMS_INVALID_NAME,
+    "rtems_rate_monotonic_create with illegal name"
+  puts( "TA1 - rtems_rate_monotonic_create - RTEMS_INVALID_NAME" );
+  status = rtems_rate_monotonic_create( Period_name[ 1 ], &Period_id[ 1 ] );
+  directive_failed( status, "rtems_rate_monotonic_create successful" );
+  puts( "TA1 - rtems_rate_monotonic_create - RTEMS_SUCCESSFUL" );
+  status = rtems_rate_monotonic_create( Period_name[ 1 ], &Junk_id );
+    status,
+    RTEMS_TOO_MANY,
+    "rtems_rate_monotonic_create of too many"
+  puts( "TA1 - rtems_rate_monotonic_create - RTEMS_TOO_MANY" );
+   * Check ident error cases.
+  status = rtems_rate_monotonic_ident( 0, &Junk_id );
+    status,
+    "rtems_rate_monotonic_ident with illegal name"
+  puts( "TA1 - rtems_rate_monotonic_ident - RTEMS_INVALID_NAME" );
+   * Check period error cases.
+  status = rtems_rate_monotonic_period( 100, 5 );
+    status,
+    RTEMS_INVALID_ID,
+    "rtems_rate_monotonic_period with illegal id"
+  puts( "TA1 - rtems_rate_monotonic_period - RTEMS_INVALID_ID" );
+  status = rtems_rate_monotonic_period( rtems_build_id( 1, 1, 1, 256 ), 5 );
+    status,
+    RTEMS_INVALID_ID,
+  puts( "TA1 - rtems_rate_monotonic_period - local RTEMS_INVALID_ID" );
+  status = rtems_rate_monotonic_period( Period_id[ 1 ], RTEMS_PERIOD_STATUS );
+    status,
+    RTEMS_NOT_DEFINED,
+    "rtems_rate_monotonic_period status not defined"
+  puts(
+    "TA1 - rtems_rate_monotonic_period(RTEMS_PERIOD_STATUS) - RTEMS_NOT_DEFINED"
+  status = rtems_rate_monotonic_period( Period_id[ 1 ], 100 );
+  directive_failed( status, "rtems_rate_monotonic_period successful" );
+  puts( "TA1 - rtems_rate_monotonic_period - 100 ticks - RTEMS_SUCCESSFUL" );
+  directive_failed( status, "rtems_rate_monotonic_period status" );
+  puts(
+    "TA1 - rtems_rate_monotonic_period(RTEMS_PERIOD_STATUS) - RTEMS_SUCCESSFUL"
+  while ( FOREVER ) {
+     status = rtems_rate_monotonic_period(Period_id[ 1 ], RTEMS_PERIOD_STATUS);
+     if ( status == RTEMS_TIMEOUT ) break;
+     directive_failed(
+       status,
+       "rtems_rate_monotonic_period waiting for timeout"
+     rtems_task_wake_after( 1 );
+  puts(
+    "TA1 - rtems_rate_monotonic_period(RTEMS_PERIOD_STATUS) - RTEMS_TIMEOUT"
+   * Check get_statistics error cases.
+  status = rtems_rate_monotonic_get_statistics( Period_id[ 1 ], NULL );
+    status,
+    "rtems_rate_monotonic_get_statistics with NULL param"
+  puts( "TA1 - rtems_rate_monotonic_get_statistics - RTEMS_INVALID_ADDRESS" );
+   * Check get_status error cases.
+  status = rtems_rate_monotonic_get_status( Period_id[ 1 ], NULL );
+    status,
+    "rtems_rate_monotonic_get_status with NULL param"
+  puts( "TA1 - rtems_rate_monotonic_get_status - RTEMS_INVALID_ADDRESS" );
+  status = rtems_rate_monotonic_get_status( 100, &period_status );
+    status,
+    RTEMS_INVALID_ID,
+    "rtems_rate_monotonic_get_status with illegal id"
+  puts( "TA1 - rtems_rate_monotonic_get_status - RTEMS_INVALID_ID" );
+   * Check cancel error cases.
+  status = rtems_rate_monotonic_cancel( 100 );
+    status,
+    RTEMS_INVALID_ID,
+    "rtems_rate_monotonic_cancel with illegal id"
+  puts( "TA1 - rtems_rate_monotonic_cancel - RTEMS_INVALID_ID" );
+  status = rtems_rate_monotonic_cancel( rtems_build_id( 1, 1, 1, 256 ) );
+    status,
+    RTEMS_INVALID_ID,
+    "rtems_rate_monotonic_cancel will illegal id"
+  puts( "TA1 - rtems_rate_monotonic_cancel - local RTEMS_INVALID_ID" );
+  status = rtems_rate_monotonic_cancel( Period_id[ 1 ] );
+  directive_failed( status, "rtems_rate_monotonic_cancel" );
+  puts( "TA1 - rtems_rate_monotonic_cancel - RTEMS_SUCCESSFUL" );
+  status = rtems_rate_monotonic_period( Period_id[ 1 ], 5 );
+  directive_failed( status, "rtems_rate_monotonic_period restart" );
+  status = rtems_task_wake_after( rtems_clock_get_ticks_per_second() );
+  directive_failed( status, "rtems_task_wake_after" );
+    status,
+    RTEMS_TIMEOUT,
+    "rtems_rate_monotonic_period"
+  puts( "TA1 - rtems_rate_monotonic_period - 5 ticks - RTEMS_TIMEOUT" );
+  status = rtems_task_start( Task_id[ 4 ], Task_4, 0 );
+  directive_failed( status, "rtems_task_start of TA4" );
+  puts( "TA1 - yielding to TA4" );
+  status = rtems_task_wake_after( RTEMS_YIELD_PROCESSOR );
+   * Check delete error cases.
+  status = rtems_rate_monotonic_delete( 100 );
+    status,
+    RTEMS_INVALID_ID,
+    "rtems_rate_monotonic_delete with illegal id"
+  puts( "TA1 - rtems_rate_monotonic_delete - RTEMS_INVALID_ID" );
+  status = rtems_rate_monotonic_delete( rtems_build_id( 1, 1, 1, 256 ) );
+    status,
+    RTEMS_INVALID_ID,
+  puts( "TA1 - rtems_rate_monotonic_delete - local RTEMS_INVALID_ID" );
+  status = rtems_rate_monotonic_delete( Period_id[ 1 ] );
+  directive_failed( status, "rtems_rate_monotonic_delete" );
+  puts( "TA1 - rtems_rate_monotonic_delete - RTEMS_SUCCESSFUL" );
diff --git a/testsuites/sptests/spratemon_err01/spratemon_err01.doc b/testsuites/sptests/spratemon_err01/spratemon_err01.doc
index 0000000..bf1a43c
--- /dev/null
+++ b/testsuites/sptests/spratemon_err01/spratemon_err01.doc
@@ -0,0 +1,25 @@
+#  COPYRIGHT (c) 1989-2014.
+#  On-Line Applications Research Corporation (OAR).
+#  The license and distribution terms for this file may be
+#  found in the file LICENSE in this distribution or at
+#  http://www.rtems.com/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name:  spratemon_err01
+ directives:
+  rm_create, rm_period, rm_stats, rm_gstatus, rm_cancel, rm_delete
+concepts:
+  a.  Verifies all error codes returned by the executive in single
+      processor configurations.
+  b.  Verifies error conditions in the following kernel routines or macros:
+        _Ck_date_time, _Expired, _Q_submit, _Get_mnodes, _Get_node,
+        _Free_mem, _Get_mem, _Valid_block, _Set_tcb, _Set_resource,
+        _In_range, _On_boundary
diff --git a/testsuites/sptests/spratemon_err01/spratemon_err01.scn b/testsuites/sptests/spratemon_err01/spratemon_err01.scn
index 0000000..ca2cebd
--- /dev/null
+++ b/testsuites/sptests/spratemon_err01/spratemon_err01.scn
@@ -0,0 +1,28 @@
+*** TEST RATE MONOTONIC ERROR 01 ***
+TA1 - rtems_task_create - 4 created - RTEMS_SUCCESSFUL
+TA1 - rtems_rate_monotonic_create - RTEMS_INVALID_ADDRESS
+TA1 - rtems_rate_monotonic_create - RTEMS_INVALID_NAME
+TA1 - rtems_rate_monotonic_create - RTEMS_SUCCESSFUL
+TA1 - rtems_rate_monotonic_create - RTEMS_TOO_MANY
+TA1 - rtems_rate_monotonic_ident - RTEMS_INVALID_NAME
+TA1 - rtems_rate_monotonic_period - RTEMS_INVALID_ID
+TA1 - rtems_rate_monotonic_period - local RTEMS_INVALID_ID
+TA1 - rtems_rate_monotonic_period(RTEMS_PERIOD_STATUS) - RTEMS_NOT_DEFINED
+TA1 - rtems_rate_monotonic_period - 100 ticks - RTEMS_SUCCESSFUL
+TA1 - rtems_rate_monotonic_period(RTEMS_PERIOD_STATUS) - RTEMS_SUCCESSFUL
+TA1 - rtems_rate_monotonic_period(RTEMS_PERIOD_STATUS) - RTEMS_TIMEOUT
+TA1 - rtems_rate_monotonic_get_statistics - RTEMS_INVALID_ADDRESS
+TA1 - rtems_rate_monotonic_get_status - RTEMS_INVALID_ADDRESS
+TA1 - rtems_rate_monotonic_get_status - RTEMS_INVALID_ID
+TA1 - rtems_rate_monotonic_cancel - RTEMS_INVALID_ID
+TA1 - rtems_rate_monotonic_cancel - local RTEMS_INVALID_ID
+TA1 - rtems_rate_monotonic_cancel - RTEMS_SUCCESSFUL
+TA1 - rtems_rate_monotonic_period - 5 ticks - RTEMS_TIMEOUT
+TA1 - yielding to TA4
+TA4 - rtems_rate_monotonic_cancel - RTEMS_NOT_OWNER_OF_RESOURCE
+TA4 - rtems_rate_monotonic_period - RTEMS_NOT_OWNER_OF_RESOURCE
+TA4 - rtems_task_delete - delete self - RTEMS_SUCCESSFUL
+TA1 - rtems_rate_monotonic_delete - RTEMS_INVALID_ID
+TA1 - rtems_rate_monotonic_delete - local RTEMS_INVALID_ID
+TA1 - rtems_rate_monotonic_delete - RTEMS_SUCCESSFUL
+*** END TEST RATE MONOTONIC ERROR 01 ***
diff --git a/testsuites/sptests/spratemon_err01/system.h b/testsuites/sptests/spratemon_err01/system.h
index 0000000..52bb580
--- /dev/null
+++ b/testsuites/sptests/spratemon_err01/system.h
@@ -0,0 +1,75 @@
+ *  This include file contains information that is included in every
+ *  function in the test set.
+ *  COPYRIGHT (c) 1989-2014.
+#include <tmacros.h>
+/* functions */
+rtems_task Init(
+rtems_timer_service_routine Delayed_routine(
+  rtems_id  ignored_id,
+  void     *ignored_address
+rtems_task Task_4(
+void Screen10( void );
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS              10
+#define CONFIGURE_MAXIMUM_TIMERS              1
+#define CONFIGURE_MAXIMUM_SEMAPHORES          2
+#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES      1
+#define CONFIGURE_MAXIMUM_PERIODS             1
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS     0
+#define CONFIGURE_TICKS_PER_TIMESLICE       100
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_EXTRA_TASK_STACKS         (20 * RTEMS_MINIMUM_STACK_SIZE)
+#include <rtems/confdefs.h>
+/* global variables */
+TEST_EXTERN rtems_id   Task_id[ 11 ];       /* array of task ids */
+TEST_EXTERN rtems_name Task_name[ 11 ];     /* array of task names */
+TEST_EXTERN rtems_name Semaphore_name[ 4 ]; /* array of semaphore names */
+TEST_EXTERN rtems_id   Semaphore_id[ 4 ];   /* array of semaphore ids */
+TEST_EXTERN rtems_name Queue_name[ 3 ];     /* array of queue names */
+TEST_EXTERN rtems_id   Queue_id[ 3 ];       /* array of queue ids */
+TEST_EXTERN rtems_name Port_name[ 2 ];      /* array of port names */
+TEST_EXTERN rtems_id   Port_id[ 2 ];        /* array of port ids */
+TEST_EXTERN rtems_name Period_name[ 2 ];    /* array of period names */
+TEST_EXTERN rtems_id   Period_id[ 2 ];      /* array of period ids */
+TEST_EXTERN rtems_id   Junk_id;             /* id used to return errors */
+#define Internal_port_area (void *) 0x00001000
+#define External_port_area (void *) 0x00002000
+/* end of include file */
diff --git a/testsuites/sptests/spratemon_err01/task4.c b/testsuites/sptests/spratemon_err01/task4.c
index 0000000..73a52ea
--- /dev/null
+++ b/testsuites/sptests/spratemon_err01/task4.c
@@ -0,0 +1,51 @@
+/*  Task_4
+ *  This routine serves as a test task.  Its only purpose in life is to
+ *  generate the error where a rate monotonic period is accessed by a
+ *  task other than its creator.
+ *    argument - task argument
+ *  COPYRIGHT (c) 1989-1999.
+#endif
+rtems_task Task_4(
+    status,
+    RTEMS_NOT_OWNER_OF_RESOURCE,
+    "rtems_rate_monotonic_cancel not the owner"
+  puts( "TA4 - rtems_rate_monotonic_cancel - RTEMS_NOT_OWNER_OF_RESOURCE" );
+    status,
+    "rtems_rate_monotonic_period not the owner"
+  puts( "TA4 - rtems_rate_monotonic_period - RTEMS_NOT_OWNER_OF_RESOURCE" );
+  puts( "TA4 - rtems_task_delete - delete self - RTEMS_SUCCESSFUL" );
+  status = rtems_task_delete( RTEMS_SELF );
+  directive_failed( status, "rtems_task_delete of TA4" );
1.8.1.4
