[PATCH 8/9] sptask_err03: New test split from sp09 screen 3.
Jennifer Averett jennifer.averett at oarcorp.com
Thu Mar 27 15:30:05 UTC 2014
 testsuites/sptests/Makefile.am                   |   2 +-
 testsuites/sptests/configure.ac                  |   1 +
 testsuites/sptests/sp09/Makefile.am              |   2 +-
 testsuites/sptests/sp09/screen03.c               | 238 ---------------------
 testsuites/sptests/sp09/sp09.scn                 |  17 --
 testsuites/sptests/sp09/task1.c                  |   3 -
 testsuites/sptests/sptask_err03/Makefile.am      |  22 ++
 testsuites/sptests/sptask_err03/init.c           | 258 +++++++++++++++++++++++
 testsuites/sptests/sptask_err03/sptask_err03.doc |  25 +++
 testsuites/sptests/sptask_err03/sptask_err03.scn |  18 ++
 testsuites/sptests/sptask_err03/system.h         |  49 +++++
 11 files changed, 375 insertions(+), 260 deletions(-)
 delete mode 100644 testsuites/sptests/sp09/screen03.c
 create mode 100644 testsuites/sptests/sptask_err03/Makefile.am
 create mode 100644 testsuites/sptests/sptask_err03/init.c
 create mode 100644 testsuites/sptests/sptask_err03/sptask_err03.doc
 create mode 100644 testsuites/sptests/sptask_err03/sptask_err03.scn
 create mode 100644 testsuites/sptests/sptask_err03/system.h
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index d5e43ae..1a5e81d 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -31,7 +31,7 @@ SUBDIRS = \
     spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
     spregion_err01 sppartition_err01 spratemon_err01 spintr_err01 \
     spsignal_err01 spport_err01 spmsgq_err01 spmsgq_err02 spsem_err01 \
-    spsem_err02 sptask_err01 spevent_err03
+    spsem_err02 sptask_err01 spevent_err03 sptask_err03
 SUBDIRS += spprofiling01
 SUBDIRS += spcache01
 SUBDIRS += sptls03
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 545d1f8..a4f1bda 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -222,6 +222,7 @@ sptimespec01/Makefile
 spwatchdog/Makefile
 spwkspace/Makefile
 sptask_err01/Makefile
+sptask_err03/Makefile
 sptimer_err01/Makefile
 sptimer_err02/Makefile
 spcpuset01/Makefile
diff --git a/testsuites/sptests/sp09/Makefile.am b/testsuites/sptests/sp09/Makefile.am
index 2b4e16f..2c6f903 100644
--- a/testsuites/sptests/sp09/Makefile.am
+++ b/testsuites/sptests/sp09/Makefile.am
@@ -1,6 +1,6 @@
 rtems_tests_PROGRAMS = sp09
-sp09_SOURCES = init.c delay.c isr.c screen01.c screen02.c screen03.c \
+sp09_SOURCES = init.c delay.c isr.c screen01.c screen02.c \
     task1.c task2.c task3.c \
     system.h
diff --git a/testsuites/sptests/sp09/screen03.c b/testsuites/sptests/sp09/screen03.c
deleted file mode 100644
index 7debabc..0000000
--- a/testsuites/sptests/sp09/screen03.c
+++ /dev/null
@@ -1,238 +0,0 @@
-/*  Screen3
- *  This routine generates error screen 3 for test 9.
- *  Input parameters:  NONE
- *  Output parameters:  NONE
- *  COPYRIGHT (c) 1989-1999.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include "system.h"
-void Screen3()
-  rtems_name        task_name;
-  rtems_status_code status;
-  bool              skipUnsatisfied;
-  /* task create bad name */
-  task_name = 1;
-  status = rtems_task_create(
-    0,
-    1,
-    RTEMS_MINIMUM_STACK_SIZE,
-    RTEMS_DEFAULT_MODES,
-    RTEMS_DEFAULT_ATTRIBUTES,
-    &Junk_id
-  fatal_directive_status(
-    status,
-    RTEMS_INVALID_NAME,
-    "rtems_task_create with illegal name"
-  puts( "TA1 - rtems_task_create - RTEMS_INVALID_NAME" );
-  /* null ID */
-    Task_name[ 1 ],
-    4,
-    NULL
-    status,
-    RTEMS_INVALID_ADDRESS,
-    "rtems_task_create with NULL ID param"
-  puts( "TA1 - rtems_task_create - RTEMS_INVALID_ADDRESS" );
-   * If the bsp provides its own stack allocator, then
-   * skip the test that tries to allocate a stack that is too big.
-   * If on the m32c, we can't even ask for enough memory to trip this
-   * error.
-  skipUnsatisfied = false;
-  if (rtems_configuration_get_stack_allocate_hook())
-    skipUnsatisfied = true;
-  #if defined(__m32c__)
-  #endif
-  if ( skipUnsatisfied ) {
-    puts(
-      "TA1 - rtems_task_create - stack size - RTEMS_UNSATISFIED  -- SKIPPED"
-  } else {
-        task_name,
-        1,
-        rtems_configuration_get_work_space_size(),
-        &Junk_id
-        status,
-        RTEMS_UNSATISFIED,
-        "rtems_task_create with a stack size larger than the workspace"
-      puts( "TA1 - rtems_task_create - stack size - RTEMS_UNSATISFIED" );
-    Task_name[ 2 ],
-    4,
-    &Task_id[ 2 ]
-  directive_failed( status, "rtems_task_create of TA2" );
-  puts( "TA1 - rtems_task_create - TA2 created - RTEMS_SUCCESSFUL" );
-  status = rtems_task_suspend( Task_id[ 2 ] );
-  directive_failed( status, "rtems_task_suspend of TA2" );
-  puts( "TA1 - rtems_task_suspend - suspend TA2 - RTEMS_SUCCESSFUL" );
-    status,
-    RTEMS_ALREADY_SUSPENDED,
-    "rtems_task_suspend of suspended TA2"
-  puts( "TA1 - rtems_task_suspend - suspend TA2 - RTEMS_ALREADY_SUSPENDED" );
-  status = rtems_task_resume( Task_id[ 2 ] );
-  directive_failed( status, "rtems_task_resume of TA2" );
-  puts( "TA1 - rtems_task_resume - TA2 resumed - RTEMS_SUCCESSFUL" );
-    Task_name[ 3 ],
-    4,
-    &Task_id[ 3 ]
-  directive_failed( status, "rtems_task_create of TA3" );
-  puts( "TA1 - rtems_task_create - TA3 created - RTEMS_SUCCESSFUL" );
-    Task_name[ 5 ],
-    4,
-    &Task_id[ 5 ]
-  directive_failed( status, "rtems_task_create of TA5" );
-  puts( "TA1 - rtems_task_create - 5 created - RTEMS_SUCCESSFUL" );
-    Task_name[ 6 ],
-    4,
-    &Task_id[ 6 ]
-  directive_failed( status, "rtems_task_create of TA6" );
-  puts( "TA1 - rtems_task_create - 6 created - RTEMS_SUCCESSFUL" );
-    Task_name[ 7 ],
-    4,
-    &Task_id[ 7 ]
-  directive_failed( status, "rtems_task_create of TA7" );
-  puts( "TA1 - rtems_task_create - 7 created - RTEMS_SUCCESSFUL" );
-    Task_name[ 8 ],
-    4,
-    &Task_id[ 8 ]
-  directive_failed( status, "rtems_task_create of TA8" );
-  puts( "TA1 - rtems_task_create - 8 created - RTEMS_SUCCESSFUL" );
-    Task_name[ 9 ],
-    4,
-    &Task_id[ 9 ]
-  directive_failed( status, "rtems_task_create of TA9" );
-  puts( "TA1 - rtems_task_create - 9 created - RTEMS_SUCCESSFUL" );
-    Task_name[ 10 ],
-    4,
-    &Task_id[ 10 ]
-  directive_failed( status, "rtems_task_create of TA10" );
-  puts( "TA1 - rtems_task_create - 10 created - RTEMS_SUCCESSFUL" );
-    task_name,
-    4,
-    &Junk_id
-    status,
-    RTEMS_TOO_MANY,
-    "rtems_task_create for too many tasks"
-  puts( "TA1 - rtems_task_create - 11 - RTEMS_TOO_MANY" );
-   *  The check for an object being global is only made if
-   *  multiprocessing is enabled.
-#if defined(RTEMS_MULTIPROCESSING)
-    task_name,
-    4,
-    RTEMS_GLOBAL,
-    &Junk_id
-    status,
-    RTEMS_MP_NOT_CONFIGURED,
-    "rtems_task_create of global task in a single cpu system"
-#endif
-  puts( "TA1 - rtems_task_create - RTEMS_MP_NOT_CONFIGURED" );
diff --git a/testsuites/sptests/sp09/sp09.scn b/testsuites/sptests/sp09/sp09.scn
index fc35d23..001239d 100644
--- a/testsuites/sptests/sp09/sp09.scn
+++ b/testsuites/sptests/sp09/sp09.scn
@@ -56,21 +56,4 @@ TA1 - rtems_task_wake_when - 08:30:48   02/05/1961 - RTEMS_INVALID_CLOCK
 TA1 - rtems_task_wake_when - 25:30:48   02/05/1988 - RTEMS_INVALID_CLOCK
 TA1 - current time - 08:30:51   02/05/1988
 TA1 - rtems_task_wake_when - 08:30:51   01/05/1988 - RTEMS_INVALID_CLOCK
-<pause - screen 3>
-TA1 - rtems_task_create - RTEMS_INVALID_NAME
-TA1 - rtems_task_create - RTEMS_INVALID_ADDRESS
-TA1 - rtems_task_create - stack size - RTEMS_UNSATISFIED  -- SKIPPED
-TA1 - rtems_task_create - TA2 created - RTEMS_SUCCESSFUL
-TA1 - rtems_task_suspend - suspend TA2 - RTEMS_SUCCESSFUL
-TA1 - rtems_task_suspend - suspend TA2 - RTEMS_ALREADY_SUSPENDED
-TA1 - rtems_task_resume - TA2 resumed - RTEMS_SUCCESSFUL
-TA1 - rtems_task_create - TA3 created - RTEMS_SUCCESSFUL
-TA1 - rtems_task_create - 5 created - RTEMS_SUCCESSFUL
-TA1 - rtems_task_create - 6 created - RTEMS_SUCCESSFUL
-TA1 - rtems_task_create - 7 created - RTEMS_SUCCESSFUL
-TA1 - rtems_task_create - 8 created - RTEMS_SUCCESSFUL
-TA1 - rtems_task_create - 9 created - RTEMS_SUCCESSFUL
-TA1 - rtems_task_create - 10 created - RTEMS_SUCCESSFUL
-TA1 - rtems_task_create - 11 - RTEMS_TOO_MANY
-TA1 - rtems_task_create - RTEMS_MP_NOT_CONFIGURED
 *** END OF TEST 9 ***
diff --git a/testsuites/sptests/sp09/task1.c b/testsuites/sptests/sp09/task1.c
index 5b09822..27b55ef 100644
--- a/testsuites/sptests/sp09/task1.c
+++ b/testsuites/sptests/sp09/task1.c
@@ -29,9 +29,6 @@ rtems_task Task_1(
   rtems_test_pause_and_screen_number( 2 );
   Screen2();
-  rtems_test_pause_and_screen_number( 3 );
-  Screen3();
   puts( "*** END OF TEST 9 ***" );
   rtems_test_exit( 0 );
diff --git a/testsuites/sptests/sptask_err03/Makefile.am b/testsuites/sptests/sptask_err03/Makefile.am
new file mode 100644
index 0000000..9b70700
--- /dev/null
+++ b/testsuites/sptests/sptask_err03/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = sptask_err03
+sptask_err03_SOURCES = init.c system.h
+dist_rtems_tests_DATA = sptask_err03.scn
+dist_rtems_tests_DATA += sptask_err03.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(sptask_err03_OBJECTS)
+LINK_LIBS = $(sptask_err03_LDLIBS)
+sptask_err03$(EXEEXT): $(sptask_err03_OBJECTS) $(sptask_err03_DEPENDENCIES)
+	@rm -f sptask_err03$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/sptask_err03/init.c b/testsuites/sptests/sptask_err03/init.c
index 0000000..e6f7c49
--- /dev/null
+++ b/testsuites/sptests/sptask_err03/init.c
@@ -0,0 +1,258 @@
+ *  COPYRIGHT (c) 2014.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include "system.h"
+rtems_task Init(
+  rtems_task_argument argument
+  rtems_name        task_name;
+  rtems_status_code status;
+  bool              skipUnsatisfied;
+  puts( "\n\n*** TEST TASK ERROR 03 ***" );
+  Task_name[ 1 ]       =  rtems_build_name( 'T', 'A', '1', ' ' );
+  Task_name[ 2 ]       =  rtems_build_name( 'T', 'A', '2', ' ' );
+  Task_name[ 3 ]       =  rtems_build_name( 'T', 'A', '3', ' ' );
+  Task_name[ 4 ]       =  rtems_build_name( 'T', 'A', '4', ' ' );
+  Task_name[ 5 ]       =  rtems_build_name( 'T', 'A', '5', ' ' );
+  Task_name[ 6 ]       =  rtems_build_name( 'T', 'A', '6', ' ' );
+  Task_name[ 7 ]       =  rtems_build_name( 'T', 'A', '7', ' ' );
+  Task_name[ 8 ]       =  rtems_build_name( 'T', 'A', '8', ' ' );
+  Task_name[ 9 ]       =  rtems_build_name( 'T', 'A', '9', ' ' );
+  Task_name[ 10 ]      =  rtems_build_name( 'T', 'A', 'A', ' ' );
+  /* task create bad name */
+  task_name = 1;
+  status = rtems_task_create(
+    0,
+    1,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &Junk_id
+  fatal_directive_status(
+    status,
+    RTEMS_INVALID_NAME,
+    "rtems_task_create with illegal name"
+  puts( "TA1 - rtems_task_create - RTEMS_INVALID_NAME" );
+  /* null ID */
+    Task_name[ 1 ],
+    4,
+    NULL
+    status,
+    RTEMS_INVALID_ADDRESS,
+    "rtems_task_create with NULL ID param"
+  puts( "TA1 - rtems_task_create - RTEMS_INVALID_ADDRESS" );
+   * If the bsp provides its own stack allocator, then
+   * skip the test that tries to allocate a stack that is too big.
+   * If on the m32c, we can't even ask for enough memory to trip this
+   * error.
+  skipUnsatisfied = false;
+  if (rtems_configuration_get_stack_allocate_hook())
+    skipUnsatisfied = true;
+  #if defined(__m32c__)
+  #endif
+  if ( skipUnsatisfied ) {
+    puts(
+      "TA1 - rtems_task_create - stack size - RTEMS_UNSATISFIED  -- SKIPPED"
+  } else {
+        task_name,
+        1,
+        rtems_configuration_get_work_space_size(),
+        &Junk_id
+        status,
+        RTEMS_UNSATISFIED,
+        "rtems_task_create with a stack size larger than the workspace"
+      puts( "TA1 - rtems_task_create - stack size - RTEMS_UNSATISFIED" );
+    Task_name[ 1 ],
+    4,
+    RTEMS_MINIMUM_STACK_SIZE * 3,
+    &Task_id[ 1 ]
+  directive_failed( status, "rtems_task_create of TA1" );
+    Task_name[ 2 ],
+    4,
+    &Task_id[ 2 ]
+  directive_failed( status, "rtems_task_create of TA2" );
+  puts( "TA1 - rtems_task_create - TA2 created - RTEMS_SUCCESSFUL" );
+  status = rtems_task_suspend( Task_id[ 2 ] );
+  directive_failed( status, "rtems_task_suspend of TA2" );
+  puts( "TA1 - rtems_task_suspend - suspend TA2 - RTEMS_SUCCESSFUL" );
+    status,
+    RTEMS_ALREADY_SUSPENDED,
+    "rtems_task_suspend of suspended TA2"
+  puts( "TA1 - rtems_task_suspend - suspend TA2 - RTEMS_ALREADY_SUSPENDED" );
+  status = rtems_task_resume( Task_id[ 2 ] );
+  directive_failed( status, "rtems_task_resume of TA2" );
+  puts( "TA1 - rtems_task_resume - TA2 resumed - RTEMS_SUCCESSFUL" );
+    Task_name[ 3 ],
+    4,
+    &Task_id[ 3 ]
+  directive_failed( status, "rtems_task_create of TA3" );
+  puts( "TA1 - rtems_task_create - TA3 created - RTEMS_SUCCESSFUL" );
+    Task_name[ 5 ],
+    4,
+    &Task_id[ 5 ]
+  directive_failed( status, "rtems_task_create of TA5" );
+  puts( "TA1 - rtems_task_create - 5 created - RTEMS_SUCCESSFUL" );
+    Task_name[ 6 ],
+    4,
+    &Task_id[ 6 ]
+  directive_failed( status, "rtems_task_create of TA6" );
+  puts( "TA1 - rtems_task_create - 6 created - RTEMS_SUCCESSFUL" );
+    Task_name[ 7 ],
+    4,
+    &Task_id[ 7 ]
+  directive_failed( status, "rtems_task_create of TA7" );
+  puts( "TA1 - rtems_task_create - 7 created - RTEMS_SUCCESSFUL" );
+    Task_name[ 8 ],
+    4,
+    &Task_id[ 8 ]
+  directive_failed( status, "rtems_task_create of TA8" );
+  puts( "TA1 - rtems_task_create - 8 created - RTEMS_SUCCESSFUL" );
+    Task_name[ 9 ],
+    4,
+    &Task_id[ 9 ]
+  directive_failed( status, "rtems_task_create of TA9" );
+  puts( "TA1 - rtems_task_create - 9 created - RTEMS_SUCCESSFUL" );
+    Task_name[ 10 ],
+    4,
+    &Task_id[ 10 ]
+  directive_failed( status, "rtems_task_create of TA10" );
+  puts( "TA1 - rtems_task_create - 10 created - RTEMS_SUCCESSFUL" );
+    task_name,
+    4,
+    &Junk_id
+    status,
+    RTEMS_TOO_MANY,
+    "rtems_task_create for too many tasks"
+  puts( "TA1 - rtems_task_create - 11 - RTEMS_TOO_MANY" );
+   *  The check for an object being global is only made if
+   *  multiprocessing is enabled.
+#if defined(RTEMS_MULTIPROCESSING)
+    task_name,
+    4,
+    RTEMS_GLOBAL,
+    &Junk_id
+    status,
+    RTEMS_MP_NOT_CONFIGURED,
+    "rtems_task_create of global task in a single cpu system"
+#endif
+  puts( "TA1 - rtems_task_create - RTEMS_MP_NOT_CONFIGURED" );
+  puts( "*** END TEST TASK ERROR 03 ***" );
diff --git a/testsuites/sptests/sptask_err03/sptask_err03.doc b/testsuites/sptests/sptask_err03/sptask_err03.doc
index 0000000..aa6a0f1
--- /dev/null
+++ b/testsuites/sptests/sptask_err03/sptask_err03.doc
@@ -0,0 +1,25 @@
+#  COPYRIGHT (c) 1989-2014.
+#  On-Line Applications Research Corporation (OAR).
+#  The license and distribution terms for this file may be
+#  found in the file LICENSE in this distribution or at
+#  http://www.rtems.com/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name:  sptask_err03
+directives:
+  t_create, cf_gstackhook, cf_gworksize, t_resume, t_suspend,
+concepts:
+  a.  Verifies all error codes returned by the executive in single
+      processor configurations.
+  b.  Verifies error conditions in the following kernel routines or macros:
+        _Ck_date_time, _Expired, _Q_submit, _Get_mnodes, _Get_node,
+        _Free_mem, _Get_mem, _Valid_block, _Set_tcb, _Set_resource,
+        _In_range, _On_boundary
diff --git a/testsuites/sptests/sptask_err03/sptask_err03.scn b/testsuites/sptests/sptask_err03/sptask_err03.scn
index 0000000..2787baf
--- /dev/null
+++ b/testsuites/sptests/sptask_err03/sptask_err03.scn
@@ -0,0 +1,18 @@
+*** TEST TASK ERROR 03 ***
+TA1 - rtems_task_create - RTEMS_INVALID_NAME
+TA1 - rtems_task_create - RTEMS_INVALID_ADDRESS
+TA1 - rtems_task_create - stack size - RTEMS_UNSATISFIED  -- SKIPPED
+TA1 - rtems_task_create - TA2 created - RTEMS_SUCCESSFUL
+TA1 - rtems_task_suspend - suspend TA2 - RTEMS_SUCCESSFUL
+TA1 - rtems_task_suspend - suspend TA2 - RTEMS_ALREADY_SUSPENDED
+TA1 - rtems_task_resume - TA2 resumed - RTEMS_SUCCESSFUL
+TA1 - rtems_task_create - TA3 created - RTEMS_SUCCESSFUL
+TA1 - rtems_task_create - 5 created - RTEMS_SUCCESSFUL
+TA1 - rtems_task_create - 6 created - RTEMS_SUCCESSFUL
+TA1 - rtems_task_create - 7 created - RTEMS_SUCCESSFUL
+TA1 - rtems_task_create - 8 created - RTEMS_SUCCESSFUL
+TA1 - rtems_task_create - 9 created - RTEMS_SUCCESSFUL
+TA1 - rtems_task_create - 10 created - RTEMS_SUCCESSFUL
+TA1 - rtems_task_create - 11 - RTEMS_TOO_MANY
+TA1 - rtems_task_create - RTEMS_MP_NOT_CONFIGURED
+*** END TEST TASK ERROR 03 ***
diff --git a/testsuites/sptests/sptask_err03/system.h b/testsuites/sptests/sptask_err03/system.h
index 0000000..4c7e51a
--- /dev/null
+++ b/testsuites/sptests/sptask_err03/system.h
@@ -0,0 +1,49 @@
+ *  This include file contains information that is included in every
+ *  function in the test set.
+ *  COPYRIGHT (c) 1989-2014.
+#include <tmacros.h>
+/* functions */
+rtems_task Init(
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS              10
+#define CONFIGURE_MAXIMUM_TIMERS              1
+#define CONFIGURE_MAXIMUM_SEMAPHORES          2
+#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES      1
+#define CONFIGURE_MAXIMUM_PERIODS             1
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS     0
+#define CONFIGURE_TICKS_PER_TIMESLICE       100
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_EXTRA_TASK_STACKS         (20 * RTEMS_MINIMUM_STACK_SIZE)
+#include <rtems/confdefs.h>
+/* global variables */
+TEST_EXTERN rtems_id   Task_id[ 11 ];       /* array of task ids */
+TEST_EXTERN rtems_name Task_name[ 11 ];     /* array of task names */
+TEST_EXTERN rtems_id   Junk_id;             /* id used to return errors */
+/* end of include file */
1.8.1.4
