[PATCH v3] score: PR2152: Use allocator mutex for objects
Sebastian Huber
Fri Mar 28 09:29:16 UTC 2014
Use allocator mutex for objects allocate/free. This prevents that the
thread dispatch latency depends on the workspace/heap fragmentation.
v3: Add more documentation to objectimpl.h with code examples. Use
_POSIX_Semaphore_Allocate_unprotected().
cpukit/libcsupport/src/resource_snapshot.c | 24 +---
cpukit/posix/include/rtems/posix/pthreadimpl.h | 21 +---
cpukit/posix/include/rtems/posix/semaphoreimpl.h | 13 +--
cpukit/posix/src/conddestroy.c | 8 +-
cpukit/posix/src/condinit.c | 6 +-
cpukit/posix/src/keycreate.c | 6 +-
cpukit/posix/src/keydelete.c | 4 +
cpukit/posix/src/mqueueclose.c | 4 +
cpukit/posix/src/mqueuecreatesupp.c | 12 +--
cpukit/posix/src/mqueueopen.c | 14 +--
cpukit/posix/src/mqueueunlink.c | 3 +
cpukit/posix/src/mutexdestroy.c | 10 +-
cpukit/posix/src/mutexinit.c | 9 +-
cpukit/posix/src/pbarrierdestroy.c | 7 +-
cpukit/posix/src/pbarrierinit.c | 12 +--
cpukit/posix/src/prwlockdestroy.c | 8 +-
cpukit/posix/src/prwlockinit.c | 9 +-
cpukit/posix/src/pspindestroy.c | 7 +-
cpukit/posix/src/pspininit.c | 7 +-
cpukit/posix/src/pthreadcreate.c | 13 +--
cpukit/posix/src/semaphorecreatesupp.c | 7 +-
cpukit/posix/src/semclose.c | 4 +
cpukit/posix/src/semdestroy.c | 4 +
cpukit/posix/src/seminit.c | 2 +
cpukit/posix/src/semopen.c | 11 +-
cpukit/posix/src/semunlink.c | 11 +-
cpukit/posix/src/timercreate.c | 8 +-
cpukit/posix/src/timerdelete.c | 7 +-
cpukit/rtems/Makefile.am | 1 -
cpukit/rtems/include/rtems/rtems/messageimpl.h | 16 +--
cpukit/rtems/include/rtems/rtems/tasksimpl.h | 13 +--
cpukit/rtems/src/barriercreate.c | 6 +-
cpukit/rtems/src/barrierdelete.c | 8 +-
cpukit/rtems/src/dpmemcreate.c | 8 +-
cpukit/rtems/src/dpmemdelete.c | 6 +-
cpukit/rtems/src/msgqallocate.c | 37 ------
cpukit/rtems/src/msgqcreate.c | 10 +-
cpukit/rtems/src/msgqdelete.c | 9 +-
cpukit/rtems/src/partcreate.c | 10 +-
cpukit/rtems/src/partdelete.c | 9 +-
cpukit/rtems/src/ratemoncreate.c | 8 +-
cpukit/rtems/src/ratemondelete.c | 6 +-
cpukit/rtems/src/regioncreate.c | 7 +-
cpukit/rtems/src/regiondelete.c | 5 +-
cpukit/rtems/src/regionextend.c | 3 +-
cpukit/rtems/src/regiongetsegment.c | 3 +-
cpukit/rtems/src/regionresizesegment.c | 3 +-
cpukit/rtems/src/semcreate.c | 12 +-
cpukit/rtems/src/semdelete.c | 11 ++-
cpukit/rtems/src/taskcreate.c | 13 +--
cpukit/rtems/src/timercreate.c | 6 +-
cpukit/rtems/src/timerdelete.c | 6 +-
cpukit/sapi/src/extensioncreate.c | 8 +-
cpukit/sapi/src/extensiondelete.c | 6 +-
cpukit/score/include/rtems/score/objectimpl.h | 147 ++++++++++++++++++++--
cpukit/score/include/rtems/score/threadimpl.h | 7 +-
cpukit/score/src/apimutex.c | 3 +-
cpukit/score/src/objectactivecount.c | 10 ++-
cpukit/score/src/objectallocate.c | 27 ++++-
cpukit/score/src/objectextendinformation.c | 49 ++++----
cpukit/score/src/objectfree.c | 5 +-
cpukit/score/src/objectshrinkinformation.c | 5 +-
testsuites/sptests/spobjgetnext/init.c | 2 +
63 files changed, 419 insertions(+), 317 deletions(-)
delete mode 100644 cpukit/rtems/src/msgqallocate.c
diff --git a/cpukit/libcsupport/src/resource_snapshot.c b/cpukit/libcsupport/src/resource_snapshot.c
index 8c66f0f..6f5038d 100644
--- a/cpukit/libcsupport/src/resource_snapshot.c
+++ b/cpukit/libcsupport/src/resource_snapshot.c
@@ -98,38 +98,28 @@ static int open_files(void)
return (int) rtems_libio_number_iops - free_count;
-static void free_all_delayed_blocks(void)
- #ifdef HEAP_PROTECTION
- _RTEMS_Lock_allocator();
- _Thread_Disable_dispatch();
- _Heap_Protection_free_all_delayed_blocks( RTEMS_Malloc_Heap );
- _Heap_Protection_free_all_delayed_blocks( &_Workspace_Area );
- _Thread_Enable_dispatch();
- _RTEMS_Unlock_allocator();
- #endif
void rtems_resource_snapshot_take(rtems_resource_snapshot *snapshot)
uint32_t *active = &snapshot->rtems_api.active_barriers;
size_t i;
- free_all_delayed_blocks();
+ _RTEMS_Lock_allocator();
_Thread_Kill_zombies();
- _Protected_heap_Get_information(RTEMS_Malloc_Heap, &snapshot->heap_info);
+ #ifdef HEAP_PROTECTION
+ _Heap_Protection_free_all_delayed_blocks(RTEMS_Malloc_Heap);
+ _Heap_Protection_free_all_delayed_blocks(&_Workspace_Area);
+ #endif
+ _Heap_Get_information(RTEMS_Malloc_Heap, &snapshot->heap_info);
_Heap_Get_information(&_Workspace_Area, &snapshot->workspace_info);
for (i = 0; i < RTEMS_ARRAY_SIZE(objects_info_table); ++i) {
active [i] = _Objects_Active_count(objects_info_table[i]);
+ _RTEMS_Unlock_allocator();
#ifndef RTEMS_POSIX_API
memset(&snapshot->posix_api, 0, sizeof(snapshot->posix_api));
diff --git a/cpukit/posix/include/rtems/posix/pthreadimpl.h b/cpukit/posix/include/rtems/posix/pthreadimpl.h
index 02d8bca..d4a04e1 100644
--- a/cpukit/posix/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/posix/include/rtems/posix/pthreadimpl.h
@@ -68,16 +68,6 @@ extern void (*_POSIX_Threads_Initialize_user_threads_p)(void);
void _POSIX_Threads_Manager_initialization(void);
- * @brief Allocate POSIX thread control block.
- * This function allocates a pthread control block from
- * the inactive chain of free pthread control blocks.
- * @return This method returns a newly allocated thread.
-RTEMS_INLINE_ROUTINE Thread_Control *_POSIX_Threads_Allocate( void );
* @brief Copy POSIX Thread attribute structure.
* This routine copies the attr2 thread attribute structure
@@ -211,15 +201,14 @@ int rtems_pthread_attribute_compare(
const pthread_attr_t *attr2
- * _POSIX_Threads_Allocate
+RTEMS_INLINE_ROUTINE Thread_Control *_POSIX_Threads_Allocate(void)
+ _Objects_Allocator_lock();
- return (Thread_Control *) _Objects_Allocate( &_POSIX_Threads_Information );
+ return (Thread_Control *)
+ _Objects_Allocate_unprotected( &_POSIX_Threads_Information );
diff --git a/cpukit/posix/include/rtems/posix/semaphoreimpl.h b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
index 7754ee9..df5e523 100644
--- a/cpukit/posix/include/rtems/posix/semaphoreimpl.h
+++ b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
@@ -48,20 +48,13 @@ extern const int
void _POSIX_Semaphore_Manager_initialization(void);
- * @brief POSIX Semaphore Allocate
- * This function allocates a semaphore control block from
- * the inactive chain of free semaphore control blocks.
-RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *_POSIX_Semaphore_Allocate( void )
+RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *
+ _POSIX_Semaphore_Allocate_unprotected( void )
return (POSIX_Semaphore_Control *)
- _Objects_Allocate( &_POSIX_Semaphore_Information );
+ _Objects_Allocate_unprotected( &_POSIX_Semaphore_Information );
* @brief POSIX Semaphore Free
diff --git a/cpukit/posix/src/conddestroy.c b/cpukit/posix/src/conddestroy.c
index 75bf4cd..cd437a9 100644
--- a/cpukit/posix/src/conddestroy.c
+++ b/cpukit/posix/src/conddestroy.c
@@ -38,6 +38,7 @@ int pthread_cond_destroy(
POSIX_Condition_variables_Control *the_cond;
Objects_Locations location;
the_cond = _POSIX_Condition_variables_Get( cond, &location );
switch ( location ) {
@@ -45,6 +46,7 @@ int pthread_cond_destroy(
if ( _Thread_queue_First( &the_cond->Wait_queue ) ) {
_Objects_Put( &the_cond->Object );
+ _Objects_Allocator_unlock();
return EBUSY;
@@ -52,9 +54,9 @@ int pthread_cond_destroy(
&_POSIX_Condition_variables_Information,
&the_cond->Object
- _POSIX_Condition_variables_Free( the_cond );
+ _POSIX_Condition_variables_Free( the_cond );
return 0;
#if defined(RTEMS_MULTIPROCESSING)
@@ -64,5 +66,7 @@ int pthread_cond_destroy(
break;
return EINVAL;
diff --git a/cpukit/posix/src/condinit.c b/cpukit/posix/src/condinit.c
index a69bc8c..81575f2 100644
--- a/cpukit/posix/src/condinit.c
+++ b/cpukit/posix/src/condinit.c
@@ -51,12 +51,10 @@ int pthread_cond_init(
if ( !the_attr->is_initialized )
return EINVAL;
the_cond = _POSIX_Condition_variables_Allocate();
if ( !the_cond ) {
return ENOMEM;
@@ -79,7 +77,7 @@ int pthread_cond_init(
*cond = the_cond->Object.id;
return 0;
diff --git a/cpukit/posix/src/keycreate.c b/cpukit/posix/src/keycreate.c
index a7f6c91..245ac9e 100644
--- a/cpukit/posix/src/keycreate.c
+++ b/cpukit/posix/src/keycreate.c
@@ -38,18 +38,16 @@ int pthread_key_create(
POSIX_Keys_Control *the_key;
the_key = _POSIX_Keys_Allocate();
if ( !the_key ) {
return EAGAIN;
the_key->destructor = destructor;
_Objects_Open_u32( &_POSIX_Keys_Information, &the_key->Object, 0 );
*key = the_key->Object.id;
return 0;
diff --git a/cpukit/posix/src/keydelete.c b/cpukit/posix/src/keydelete.c
index cd2b398..392558f 100644
--- a/cpukit/posix/src/keydelete.c
+++ b/cpukit/posix/src/keydelete.c
@@ -38,6 +38,7 @@ int pthread_key_delete(
the_key = _POSIX_Keys_Get( key, &location );
@@ -50,6 +51,7 @@ int pthread_key_delete(
_POSIX_Keys_Free( the_key );
_Objects_Put(&the_key->Object);
return 0;
@@ -59,5 +61,7 @@ int pthread_key_delete(
break;
return EINVAL;
diff --git a/cpukit/posix/src/mqueueclose.c b/cpukit/posix/src/mqueueclose.c
index 152fc7e..72a7cdc 100644
--- a/cpukit/posix/src/mqueueclose.c
+++ b/cpukit/posix/src/mqueueclose.c
@@ -57,6 +57,7 @@ int mq_close(
POSIX_Message_queue_Control_fd *the_mq_fd;
the_mq_fd = _POSIX_Message_queue_Get_fd( mqdes, &location );
if ( location == OBJECTS_LOCAL ) {
/* OBJECTS_LOCAL:
@@ -79,9 +80,12 @@ int mq_close(
_POSIX_Message_queue_Free_fd( the_mq_fd );
_Objects_Put( &the_mq_fd->Object );
return 0;
* OBJECTS_REMOTE:
* OBJECTS_ERROR:
diff --git a/cpukit/posix/src/mqueuecreatesupp.c b/cpukit/posix/src/mqueuecreatesupp.c
index 056d35d..3be64b4 100644
--- a/cpukit/posix/src/mqueuecreatesupp.c
+++ b/cpukit/posix/src/mqueuecreatesupp.c
@@ -62,8 +62,6 @@ int _POSIX_Message_queue_Create_support(
/* length of name has already been validated */
* There is no real basis for the default values. They will work
* but were not compared against any existing implementation for
@@ -75,12 +73,10 @@ int _POSIX_Message_queue_Create_support(
attr.mq_msgsize = 16;
} else {
if ( attr_ptr->mq_maxmsg <= 0 ){
rtems_set_errno_and_return_minus_one( EINVAL );
if ( attr_ptr->mq_msgsize <= 0 ){
@@ -89,7 +85,7 @@ int _POSIX_Message_queue_Create_support(
the_mq = _POSIX_Message_queue_Allocate();
if ( !the_mq ) {
rtems_set_errno_and_return_minus_one( ENFILE );
@@ -100,7 +96,7 @@ int _POSIX_Message_queue_Create_support(
name = _Workspace_String_duplicate( name_arg, name_len );
if ( !name ) {
_POSIX_Message_queue_Free( the_mq );
rtems_set_errno_and_return_minus_one( ENOMEM );
@@ -128,7 +124,7 @@ int _POSIX_Message_queue_Create_support(
_Workspace_Free(name);
rtems_set_errno_and_return_minus_one( ENOSPC );
@@ -140,6 +136,6 @@ int _POSIX_Message_queue_Create_support(
*message_queue = the_mq;
return 0;
diff --git a/cpukit/posix/src/mqueueopen.c b/cpukit/posix/src/mqueueopen.c
index b33fc95..43e4082 100644
--- a/cpukit/posix/src/mqueueopen.c
+++ b/cpukit/posix/src/mqueueopen.c
@@ -72,8 +72,6 @@ mqd_t mq_open(
size_t name_len;
if ( oflag & O_CREAT ) {
va_start(arg, oflag);
mode = va_arg( arg, mode_t );
@@ -83,7 +81,7 @@ mqd_t mq_open(
the_mq_fd = _POSIX_Message_queue_Allocate_fd();
if ( !the_mq_fd ) {
the_mq_fd->oflag = oflag;
@@ -103,7 +101,7 @@ mqd_t mq_open(
if ( !( status == ENOENT && (oflag & O_CREAT) ) ) {
rtems_set_errno_and_return_minus_one_cast( status, mqd_t );
@@ -113,7 +111,7 @@ mqd_t mq_open(
if ( (oflag & (O_CREAT | O_EXCL)) == (O_CREAT | O_EXCL) ) {
rtems_set_errno_and_return_minus_one_cast( EEXIST, mqd_t );
@@ -130,7 +128,7 @@ mqd_t mq_open(
NULL
return (mqd_t)the_mq_fd->Object.id;
@@ -152,7 +150,7 @@ mqd_t mq_open(
if ( status == -1 ) {
return (mqd_t) -1;
@@ -163,7 +161,7 @@ mqd_t mq_open(
NULL
return (mqd_t) the_mq_fd->Object.id;
diff --git a/cpukit/posix/src/mqueueunlink.c b/cpukit/posix/src/mqueueunlink.c
index 47a0f5a..92b1976 100644
--- a/cpukit/posix/src/mqueueunlink.c
+++ b/cpukit/posix/src/mqueueunlink.c
@@ -46,11 +46,13 @@ int mq_unlink(
Objects_Id the_mq_id;
size_t name_len;
status = _POSIX_Message_queue_Name_to_id( name, &the_mq_id, &name_len );
if ( status != 0 ) {
rtems_set_errno_and_return_minus_one( status );
@@ -64,5 +66,6 @@ int mq_unlink(
_POSIX_Message_queue_Delete( the_mq );
return 0;
diff --git a/cpukit/posix/src/mutexdestroy.c b/cpukit/posix/src/mutexdestroy.c
index 0fad9a9..fce78af 100644
--- a/cpukit/posix/src/mutexdestroy.c
+++ b/cpukit/posix/src/mutexdestroy.c
@@ -39,6 +39,7 @@ int pthread_mutex_destroy(
register POSIX_Mutex_Control *the_mutex;
the_mutex = _POSIX_Mutex_Get( mutex, &location );
@@ -50,15 +51,16 @@ int pthread_mutex_destroy(
if ( _CORE_mutex_Is_locked( &the_mutex->Mutex ) ) {
_Objects_Put( &the_mutex->Object );
return EBUSY;
_Objects_Close( &_POSIX_Mutex_Information, &the_mutex->Object );
_CORE_mutex_Flush( &the_mutex->Mutex, NULL, EINVAL );
- _POSIX_Mutex_Free( the_mutex );
+ _POSIX_Mutex_Free( the_mutex );
return 0;
@@ -68,5 +70,7 @@ int pthread_mutex_destroy(
break;
return EINVAL;
diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
index d41b4c7..73d3101 100644
--- a/cpukit/posix/src/mutexinit.c
+++ b/cpukit/posix/src/mutexinit.c
@@ -149,15 +149,10 @@ int pthread_mutex_init(
#endif
- * Enter a dispatching critical section and begin to do the real work.
the_mutex = _POSIX_Mutex_Allocate();
if ( !the_mutex ) {
return EAGAIN;
@@ -188,6 +183,6 @@ int pthread_mutex_init(
*mutex = the_mutex->Object.id;
return 0;
diff --git a/cpukit/posix/src/pbarrierdestroy.c b/cpukit/posix/src/pbarrierdestroy.c
index d2eb505..4b9a0fd 100644
--- a/cpukit/posix/src/pbarrierdestroy.c
+++ b/cpukit/posix/src/pbarrierdestroy.c
@@ -45,6 +45,7 @@ int pthread_barrier_destroy(
if ( !barrier )
return EINVAL;
the_barrier = _POSIX_Barrier_Get( barrier, &location );
@@ -55,10 +56,10 @@ int pthread_barrier_destroy(
_Objects_Close( &_POSIX_Barrier_Information, &the_barrier->Object );
+ _Objects_Put( &the_barrier->Object );
_POSIX_Barrier_Free( the_barrier );
- _Objects_Put( &the_barrier->Object );
return 0;
@@ -68,5 +69,7 @@ int pthread_barrier_destroy(
break;
return EINVAL;
diff --git a/cpukit/posix/src/pbarrierinit.c b/cpukit/posix/src/pbarrierinit.c
index f2dda78..9560856 100644
--- a/cpukit/posix/src/pbarrierinit.c
+++ b/cpukit/posix/src/pbarrierinit.c
@@ -92,15 +92,10 @@ int pthread_barrier_init(
the_attributes.discipline = CORE_BARRIER_AUTOMATIC_RELEASE;
the_attributes.maximum_count = count;
- * Enter dispatching critical section to allocate and initialize barrier
- _Thread_Disable_dispatch(); /* prevents deletion */
the_barrier = _POSIX_Barrier_Allocate();
if ( !the_barrier ) {
return EAGAIN;
@@ -112,10 +107,7 @@ int pthread_barrier_init(
0
- * Exit the critical section and return the user an operational barrier
*barrier = the_barrier->Object.id;
return 0;
diff --git a/cpukit/posix/src/prwlockdestroy.c b/cpukit/posix/src/prwlockdestroy.c
index 9054e92..d1261ca 100644
--- a/cpukit/posix/src/prwlockdestroy.c
+++ b/cpukit/posix/src/prwlockdestroy.c
@@ -44,6 +44,7 @@ int pthread_rwlock_destroy(
if ( !rwlock )
return EINVAL;
the_rwlock = _POSIX_RWLock_Get( rwlock, &location );
@@ -53,6 +54,7 @@ int pthread_rwlock_destroy(
if ( _Thread_queue_First( &the_rwlock->RWLock.Wait_queue ) != NULL ) {
_Objects_Put( &the_rwlock->Object );
return EBUSY;
@@ -61,10 +63,10 @@ int pthread_rwlock_destroy(
_Objects_Close( &_POSIX_RWLock_Information, &the_rwlock->Object );
+ _Objects_Put( &the_rwlock->Object );
_POSIX_RWLock_Free( the_rwlock );
- _Objects_Put( &the_rwlock->Object );
return 0;
@@ -74,5 +76,7 @@ int pthread_rwlock_destroy(
break;
return EINVAL;
diff --git a/cpukit/posix/src/prwlockinit.c b/cpukit/posix/src/prwlockinit.c
index 488b46b..94973f6 100644
--- a/cpukit/posix/src/prwlockinit.c
+++ b/cpukit/posix/src/prwlockinit.c
@@ -88,15 +88,10 @@ int pthread_rwlock_init(
_CORE_RWLock_Initialize_attributes( &the_attributes );
- * Enter dispatching critical section to allocate and initialize RWLock
the_rwlock = _POSIX_RWLock_Allocate();
if ( !the_rwlock ) {
return EAGAIN;
@@ -110,6 +105,6 @@ int pthread_rwlock_init(
*rwlock = the_rwlock->Object.id;
return 0;
diff --git a/cpukit/posix/src/pspindestroy.c b/cpukit/posix/src/pspindestroy.c
index 7795a33..ab45ad1 100644
--- a/cpukit/posix/src/pspindestroy.c
+++ b/cpukit/posix/src/pspindestroy.c
@@ -45,6 +45,7 @@ int pthread_spin_destroy(
if ( !spinlock )
return EINVAL;
the_spinlock = _POSIX_Spinlock_Get( spinlock, &location );
@@ -55,10 +56,10 @@ int pthread_spin_destroy(
_Objects_Close( &_POSIX_Spinlock_Information, &the_spinlock->Object );
+ _Objects_Put( &the_spinlock->Object );
_POSIX_Spinlock_Free( the_spinlock );
- _Objects_Put( &the_spinlock->Object );
return 0;
@@ -68,5 +69,7 @@ int pthread_spin_destroy(
break;
return EINVAL;
diff --git a/cpukit/posix/src/pspininit.c b/cpukit/posix/src/pspininit.c
index 6030ed0..02b07c8 100644
--- a/cpukit/posix/src/pspininit.c
+++ b/cpukit/posix/src/pspininit.c
@@ -49,7 +49,6 @@ int pthread_spin_init(
POSIX_Spinlock_Control *the_spinlock;
CORE_spinlock_Attributes attributes;
if ( !spinlock )
return EINVAL;
@@ -61,12 +60,10 @@ int pthread_spin_init(
return EINVAL;
the_spinlock = _POSIX_Spinlock_Allocate();
if ( !the_spinlock ) {
return EAGAIN;
@@ -78,6 +75,6 @@ int pthread_spin_init(
*spinlock = the_spinlock->Object.id;
return 0;
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index 5a6d929..8d03133 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -156,18 +156,13 @@ int pthread_create(
#endif
- * Lock the allocator mutex for protection
* Allocate the thread control block.
* NOTE: Global threads are not currently supported.
the_thread = _POSIX_Threads_Allocate();
if ( !the_thread ) {
return EAGAIN;
@@ -190,7 +185,7 @@ int pthread_create(
if ( !status ) {
_POSIX_Threads_Free( the_thread );
return EAGAIN;
@@ -235,7 +230,7 @@ int pthread_create(
if ( !status ) {
return EINVAL;
#endif
@@ -254,6 +249,6 @@ int pthread_create(
*thread = the_thread->Object.id;
return 0;
diff --git a/cpukit/posix/src/semaphorecreatesupp.c b/cpukit/posix/src/semaphorecreatesupp.c
index 54b5b46..7751a58 100644
--- a/cpukit/posix/src/semaphorecreatesupp.c
+++ b/cpukit/posix/src/semaphorecreatesupp.c
@@ -56,11 +56,8 @@ int _POSIX_Semaphore_Create_support(
if (pshared != 0)
rtems_set_errno_and_return_minus_one( ENOSYS );
- the_semaphore = _POSIX_Semaphore_Allocate();
+ the_semaphore = _POSIX_Semaphore_Allocate_unprotected();
if ( !the_semaphore ) {
@@ -72,7 +69,6 @@ int _POSIX_Semaphore_Create_support(
if ( !name ) {
_POSIX_Semaphore_Free( the_semaphore );
} else {
@@ -120,6 +116,5 @@ int _POSIX_Semaphore_Create_support(
*the_sem = the_semaphore;
return 0;
diff --git a/cpukit/posix/src/semclose.c b/cpukit/posix/src/semclose.c
index 1c205bf..9dedc34 100644
--- a/cpukit/posix/src/semclose.c
+++ b/cpukit/posix/src/semclose.c
@@ -38,6 +38,7 @@ int sem_close(
POSIX_Semaphore_Control *the_semaphore;
the_semaphore = _POSIX_Semaphore_Get( sem, &location );
@@ -45,6 +46,7 @@ int sem_close(
the_semaphore->open_count -= 1;
_POSIX_Semaphore_Delete( the_semaphore );
_Objects_Put( &the_semaphore->Object );
return 0;
@@ -54,5 +56,7 @@ int sem_close(
break;
diff --git a/cpukit/posix/src/semdestroy.c b/cpukit/posix/src/semdestroy.c
index 8c3f079..1c695bb 100644
--- a/cpukit/posix/src/semdestroy.c
+++ b/cpukit/posix/src/semdestroy.c
@@ -38,6 +38,7 @@ int sem_destroy(
@@ -53,6 +54,7 @@ int sem_destroy(
return 0;
@@ -62,5 +64,7 @@ int sem_destroy(
break;
diff --git a/cpukit/posix/src/seminit.c b/cpukit/posix/src/seminit.c
index 466b2d0..a55a1c4 100644
--- a/cpukit/posix/src/seminit.c
+++ b/cpukit/posix/src/seminit.c
@@ -47,6 +47,7 @@ int sem_init(
if ( !sem )
status = _POSIX_Semaphore_Create_support(
NULL,
0,
@@ -54,6 +55,7 @@ int sem_init(
value,
&the_semaphore
if ( status != -1 )
*sem = the_semaphore->Object.id;
diff --git a/cpukit/posix/src/semopen.c b/cpukit/posix/src/semopen.c
index 20e2e92..0b98ca6 100644
--- a/cpukit/posix/src/semopen.c
+++ b/cpukit/posix/src/semopen.c
@@ -66,8 +66,6 @@ sem_t *sem_open(
size_t name_len;
@@ -75,6 +73,7 @@ sem_t *sem_open(
va_end(arg);
status = _POSIX_Semaphore_Name_to_id( name, &the_semaphore_id, &name_len );
@@ -92,7 +91,7 @@ sem_t *sem_open(
rtems_set_errno_and_return_minus_one_cast( status, sem_t * );
} else {
@@ -102,14 +101,14 @@ sem_t *sem_open(
rtems_set_errno_and_return_minus_one_cast( EEXIST, sem_t * );
the_semaphore = _POSIX_Semaphore_Get( (sem_t *) &the_semaphore_id, &location );
the_semaphore->open_count += 1;
goto return_id;
@@ -130,7 +129,7 @@ sem_t *sem_open(
* errno was set by Create_support, so don't set it again.
if ( status == -1 )
return SEM_FAILED;
diff --git a/cpukit/posix/src/semunlink.c b/cpukit/posix/src/semunlink.c
index 180facc..40d5660 100644
--- a/cpukit/posix/src/semunlink.c
+++ b/cpukit/posix/src/semunlink.c
@@ -35,11 +35,12 @@ int sem_unlink(
const char *name
- int status;
- POSIX_Semaphore_Control *the_semaphore;
- Objects_Id the_semaphore_id;
- size_t name_len;
+ int status;
+ POSIX_Semaphore_Control *the_semaphore;
+ Objects_Id the_semaphore_id;
+ size_t name_len;
@@ -58,5 +59,7 @@ int sem_unlink(
return 0;
diff --git a/cpukit/posix/src/timercreate.c b/cpukit/posix/src/timercreate.c
index f55e2db..6d822b3 100644
--- a/cpukit/posix/src/timercreate.c
+++ b/cpukit/posix/src/timercreate.c
@@ -66,21 +66,19 @@ int timer_create(
- _Thread_Disable_dispatch(); /* to prevent deletion */
* Allocate a timer
ptimer = _POSIX_Timer_Allocate();
if ( !ptimer ) {
- _Objects_Put( &ptimer->Object );
rtems_set_errno_and_return_minus_one( EAGAIN );
/* The data of the created timer are stored to use them later */
ptimer->state = POSIX_TIMER_STATE_CREATE_NEW;
- ptimer->thread_id = _Thread_Executing->Object.id;
+ ptimer->thread_id = _Thread_Get_executing()->Object.id;
if ( evp != NULL ) {
ptimer->inf.sigev_notify = evp->sigev_notify;
@@ -98,6 +96,6 @@ int timer_create(
_Objects_Open_u32(&_POSIX_Timer_Information, &ptimer->Object, 0);
*timerid = ptimer->Object.id;
return 0;
diff --git a/cpukit/posix/src/timerdelete.c b/cpukit/posix/src/timerdelete.c
index 5ebf8f8..71b25fa 100644
--- a/cpukit/posix/src/timerdelete.c
+++ b/cpukit/posix/src/timerdelete.c
@@ -47,6 +47,7 @@ int timer_delete(
POSIX_Timer_Control *ptimer;
ptimer = _POSIX_Timer_Get( timerid, &location );
@@ -54,8 +55,10 @@ int timer_delete(
_Objects_Close( &_POSIX_Timer_Information, &ptimer->Object );
ptimer->state = POSIX_TIMER_STATE_FREE;
(void) _Watchdog_Remove( &ptimer->Timer );
- _POSIX_Timer_Free( ptimer );
+ _POSIX_Timer_Free( ptimer );
return 0;
@@ -65,5 +68,7 @@ int timer_delete(
break;
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index f89a896..cf8ca3b 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -175,7 +175,6 @@ librtems_a_SOURCES += src/rtemstimerdata.c
## MESSAGE_QUEUE_C_FILES
librtems_a_SOURCES += src/msg.c
-librtems_a_SOURCES += src/msgqallocate.c
librtems_a_SOURCES += src/msgqbroadcast.c
librtems_a_SOURCES += src/msgqcreate.c
librtems_a_SOURCES += src/msgqdelete.c
diff --git a/cpukit/rtems/include/rtems/rtems/messageimpl.h b/cpukit/rtems/include/rtems/rtems/messageimpl.h
index da87fd1..714fb61 100644
--- a/cpukit/rtems/include/rtems/rtems/messageimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/messageimpl.h
@@ -90,16 +90,6 @@ rtems_status_code _Message_queue_Submit(
- * @brief Message Queue Allocate
- * This function allocates a message queue control block from
- * the inactive chain of free message queue control blocks.
- * @retval the_message_queue filled in if successful, NULL otherwise
-Message_queue_Control *_Message_queue_Allocate (void);
* @brief Message queue Translate Core Message Queue Return Code
* This function returns a RTEMS status code based on
@@ -162,6 +152,12 @@ RTEMS_INLINE_ROUTINE Message_queue_Control *_Message_queue_Get (
_Objects_Get( &_Message_queue_Information, id, location );
+RTEMS_INLINE_ROUTINE Message_queue_Control *_Message_queue_Allocate( void )
+ return (Message_queue_Control *)
+ _Objects_Allocate( &_Message_queue_Information );
#ifdef __cplusplus
diff --git a/cpukit/rtems/include/rtems/rtems/tasksimpl.h b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
index 2a99812..c86d591 100644
--- a/cpukit/rtems/include/rtems/rtems/tasksimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
@@ -77,17 +77,14 @@ void _RTEMS_Tasks_Invoke_task_variable_dtor(
rtems_task_variable_t *tvp
- * @brief Allocates a task control block.
- * This function allocates a task control block from
- * the inactive chain of free task control blocks.
-RTEMS_INLINE_ROUTINE Thread_Control *_RTEMS_tasks_Allocate( void )
+RTEMS_INLINE_ROUTINE Thread_Control *_RTEMS_tasks_Allocate(void)
- return (Thread_Control *) _Objects_Allocate( &_RTEMS_tasks_Information );
+ _Objects_Allocate_unprotected( &_RTEMS_tasks_Information );
diff --git a/cpukit/rtems/src/barriercreate.c b/cpukit/rtems/src/barriercreate.c
index e865774..12a917f 100644
--- a/cpukit/rtems/src/barriercreate.c
+++ b/cpukit/rtems/src/barriercreate.c
@@ -68,12 +68,10 @@ rtems_status_code rtems_barrier_create(
the_attributes.discipline = CORE_BARRIER_MANUAL_RELEASE;
the_attributes.maximum_count = maximum_waiters;
the_barrier = _Barrier_Allocate();
return RTEMS_TOO_MANY;
@@ -89,6 +87,6 @@ rtems_status_code rtems_barrier_create(
*id = the_barrier->Object.id;
return RTEMS_SUCCESSFUL;
diff --git a/cpukit/rtems/src/barrierdelete.c b/cpukit/rtems/src/barrierdelete.c
index 90fff5e..2ea1550 100644
--- a/cpukit/rtems/src/barrierdelete.c
+++ b/cpukit/rtems/src/barrierdelete.c
@@ -28,6 +28,7 @@ rtems_status_code rtems_barrier_delete(
Barrier_Control *the_barrier;
the_barrier = _Barrier_Get( id, &location );
@@ -39,10 +40,9 @@ rtems_status_code rtems_barrier_delete(
_Objects_Close( &_Barrier_Information, &the_barrier->Object );
- _Barrier_Free( the_barrier );
+ _Barrier_Free( the_barrier );
@@ -52,5 +52,7 @@ rtems_status_code rtems_barrier_delete(
break;
return RTEMS_INVALID_ID;
diff --git a/cpukit/rtems/src/dpmemcreate.c b/cpukit/rtems/src/dpmemcreate.c
index 9ad1588..206a199 100644
--- a/cpukit/rtems/src/dpmemcreate.c
+++ b/cpukit/rtems/src/dpmemcreate.c
@@ -33,7 +33,7 @@ rtems_status_code rtems_port_create(
rtems_id *id
- Dual_ported_memory_Control *the_port;
+ Dual_ported_memory_Control *the_port;
if ( !rtems_is_name_valid( name ) )
return RTEMS_INVALID_NAME;
@@ -45,12 +45,10 @@ rtems_status_code rtems_port_create(
!_Addresses_Is_aligned( external_start ) )
return RTEMS_INVALID_ADDRESS;
the_port = _Dual_ported_memory_Allocate();
if ( !the_port ) {
@@ -65,6 +63,6 @@ rtems_status_code rtems_port_create(
*id = the_port->Object.id;
diff --git a/cpukit/rtems/src/dpmemdelete.c b/cpukit/rtems/src/dpmemdelete.c
index d6b42ff..6f11a53 100644
--- a/cpukit/rtems/src/dpmemdelete.c
+++ b/cpukit/rtems/src/dpmemdelete.c
@@ -32,13 +32,15 @@ rtems_status_code rtems_port_delete(
the_port = _Dual_ported_memory_Get( id, &location );
case OBJECTS_LOCAL:
_Objects_Close( &_Dual_ported_memory_Information, &the_port->Object );
- _Dual_ported_memory_Free( the_port );
_Objects_Put( &the_port->Object );
+ _Dual_ported_memory_Free( the_port );
@@ -48,5 +50,7 @@ rtems_status_code rtems_port_delete(
break;
diff --git a/cpukit/rtems/src/msgqallocate.c b/cpukit/rtems/src/msgqallocate.c
deleted file mode 100644
index f5776f1..0000000
--- a/cpukit/rtems/src/msgqallocate.c
+++ /dev/null
@@ -1,37 +0,0 @@
- * @file
- * @ingroup ClassicMessageQueue
- * COPYRIGHT (c) 1989-1999.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/system.h>
-#include <rtems/score/chain.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/coremsgimpl.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/wkspace.h>
-#include <rtems/rtems/status.h>
-#include <rtems/rtems/attrimpl.h>
-#include <rtems/rtems/messageimpl.h>
-#include <rtems/rtems/options.h>
-#include <rtems/rtems/support.h>
-Message_queue_Control *_Message_queue_Allocate(void)
- return (Message_queue_Control *)
- _Objects_Allocate(&_Message_queue_Information);
diff --git a/cpukit/rtems/src/msgqcreate.c b/cpukit/rtems/src/msgqcreate.c
index 6f60773..b18f3b2 100644
--- a/cpukit/rtems/src/msgqcreate.c
+++ b/cpukit/rtems/src/msgqcreate.c
@@ -81,12 +81,10 @@ rtems_status_code rtems_message_queue_create(
#endif
#endif
- _Thread_Disable_dispatch(); /* protects object pointer */
the_message_queue = _Message_queue_Allocate();
if ( !the_message_queue ) {
@@ -95,7 +93,7 @@ rtems_status_code rtems_message_queue_create(
!( _Objects_MP_Allocate_and_open( &_Message_queue_Information,
name, the_message_queue->Object.id, false ) ) ) {
_Message_queue_Free( the_message_queue );
#endif
@@ -120,7 +118,7 @@ rtems_status_code rtems_message_queue_create(
#endif
return RTEMS_UNSATISFIED;
@@ -142,6 +140,6 @@ rtems_status_code rtems_message_queue_create(
#endif
diff --git a/cpukit/rtems/src/msgqdelete.c b/cpukit/rtems/src/msgqdelete.c
index d3c0767..e2df2b9 100644
--- a/cpukit/rtems/src/msgqdelete.c
+++ b/cpukit/rtems/src/msgqdelete.c
@@ -37,6 +37,7 @@ rtems_status_code rtems_message_queue_delete(
Message_queue_Control *the_message_queue;
the_message_queue = _Message_queue_Get( id, &location );
@@ -54,8 +55,6 @@ rtems_status_code rtems_message_queue_delete(
CORE_MESSAGE_QUEUE_STATUS_WAS_DELETED
- _Message_queue_Free( the_message_queue );
if ( _Attributes_Is_global( the_message_queue->attribute_set ) ) {
_Objects_MP_Close(
@@ -72,11 +71,13 @@ rtems_status_code rtems_message_queue_delete(
#endif
_Objects_Put( &the_message_queue->Object );
+ _Message_queue_Free( the_message_queue );
case OBJECTS_REMOTE:
- _Thread_Dispatch();
return RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
#endif
@@ -84,5 +85,7 @@ rtems_status_code rtems_message_queue_delete(
break;
diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
index 32758f8..e3544e7 100644
--- a/cpukit/rtems/src/partcreate.c
+++ b/cpukit/rtems/src/partcreate.c
@@ -53,7 +53,7 @@ rtems_status_code rtems_partition_create(
rtems_id *id
- Partition_Control *the_partition;
+ Partition_Control *the_partition;
@@ -77,12 +77,10 @@ rtems_status_code rtems_partition_create(
return RTEMS_MP_NOT_CONFIGURED;
#endif
the_partition = _Partition_Allocate();
if ( !the_partition ) {
@@ -91,7 +89,7 @@ rtems_status_code rtems_partition_create(
!( _Objects_MP_Allocate_and_open( &_Partition_Information, name,
the_partition->Object.id, false ) ) ) {
_Partition_Free( the_partition );
#endif
@@ -122,6 +120,6 @@ rtems_status_code rtems_partition_create(
#endif
diff --git a/cpukit/rtems/src/partdelete.c b/cpukit/rtems/src/partdelete.c
index cc10abc..032f73d 100644
--- a/cpukit/rtems/src/partdelete.c
+++ b/cpukit/rtems/src/partdelete.c
@@ -29,13 +29,13 @@ rtems_status_code rtems_partition_delete(
the_partition = _Partition_Get( id, &location );
case OBJECTS_LOCAL:
if ( the_partition->number_of_used_blocks == 0 ) {
_Objects_Close( &_Partition_Information, &the_partition->Object );
- _Partition_Free( the_partition );
if ( _Attributes_Is_global( the_partition->attribute_set ) ) {
@@ -54,14 +54,17 @@ rtems_status_code rtems_partition_delete(
#endif
_Objects_Put( &the_partition->Object );
+ _Partition_Free( the_partition );
return RTEMS_RESOURCE_IN_USE;
#endif
@@ -69,5 +72,7 @@ rtems_status_code rtems_partition_delete(
break;
diff --git a/cpukit/rtems/src/ratemoncreate.c b/cpukit/rtems/src/ratemoncreate.c
index ce0e1de..1f597ec 100644
--- a/cpukit/rtems/src/ratemoncreate.c
+++ b/cpukit/rtems/src/ratemoncreate.c
@@ -55,16 +55,14 @@ rtems_status_code rtems_rate_monotonic_create(
if ( !id )
the_period = _Rate_monotonic_Allocate();
if ( !the_period ) {
- the_period->owner = _Thread_Executing;
+ the_period->owner = _Thread_Get_executing();
the_period->state = RATE_MONOTONIC_INACTIVE;
_Watchdog_Initialize( &the_period->Timer, NULL, 0, NULL );
@@ -78,6 +76,6 @@ rtems_status_code rtems_rate_monotonic_create(
*id = the_period->Object.id;
diff --git a/cpukit/rtems/src/ratemondelete.c b/cpukit/rtems/src/ratemondelete.c
index 0a9e6a49..36480be 100644
--- a/cpukit/rtems/src/ratemondelete.c
+++ b/cpukit/rtems/src/ratemondelete.c
@@ -30,6 +30,7 @@ rtems_status_code rtems_rate_monotonic_delete(
Rate_monotonic_Control *the_period;
the_period = _Rate_monotonic_Get( id, &location );
@@ -38,8 +39,9 @@ rtems_status_code rtems_rate_monotonic_delete(
_Objects_Close( &_Rate_monotonic_Information, &the_period->Object );
(void) _Watchdog_Remove( &the_period->Timer );
- _Rate_monotonic_Free( the_period );
_Objects_Put( &the_period->Object );
+ _Rate_monotonic_Free( the_period );
@@ -49,5 +51,7 @@ rtems_status_code rtems_rate_monotonic_delete(
break;
diff --git a/cpukit/rtems/src/regioncreate.c b/cpukit/rtems/src/regioncreate.c
index 3b4325e..6c623c8 100644
--- a/cpukit/rtems/src/regioncreate.c
+++ b/cpukit/rtems/src/regioncreate.c
@@ -66,9 +66,7 @@ rtems_status_code rtems_region_create(
if ( !id )
- _RTEMS_Lock_allocator(); /* to prevent deletion */
- the_region = _Region_Allocate();
+ the_region = _Region_Allocate();
if ( !the_region )
return_status = RTEMS_TOO_MANY;
@@ -111,6 +109,7 @@ rtems_status_code rtems_region_create(
return return_status;
diff --git a/cpukit/rtems/src/regiondelete.c b/cpukit/rtems/src/regiondelete.c
index 5144db0..5a2df7c 100644
--- a/cpukit/rtems/src/regiondelete.c
+++ b/cpukit/rtems/src/regiondelete.c
@@ -34,7 +34,7 @@ rtems_status_code rtems_region_delete(
rtems_status_code return_status;
Region_Control *the_region;
the_region = _Region_Get( id, &location );
@@ -61,6 +61,7 @@ rtems_status_code rtems_region_delete(
break;
diff --git a/cpukit/rtems/src/regionextend.c b/cpukit/rtems/src/regionextend.c
index 289377d..65b68cd 100644
--- a/cpukit/rtems/src/regionextend.c
+++ b/cpukit/rtems/src/regionextend.c
@@ -40,7 +40,7 @@ rtems_status_code rtems_region_extend(
if ( !starting_address )
+ _RTEMS_Lock_allocator(); /* to prevent deletion */
@@ -75,5 +75,6 @@ rtems_status_code rtems_region_extend(
diff --git a/cpukit/rtems/src/regiongetsegment.c b/cpukit/rtems/src/regiongetsegment.c
index 92b3a94..4bd2445 100644
--- a/cpukit/rtems/src/regiongetsegment.c
+++ b/cpukit/rtems/src/regiongetsegment.c
@@ -47,7 +47,7 @@ rtems_status_code rtems_region_get_segment(
- executing = _Thread_Executing;
+ executing = _Thread_Get_executing();
@@ -110,5 +110,6 @@ rtems_status_code rtems_region_get_segment(
diff --git a/cpukit/rtems/src/regionresizesegment.c b/cpukit/rtems/src/regionresizesegment.c
index ff45215..ee3499a 100644
--- a/cpukit/rtems/src/regionresizesegment.c
+++ b/cpukit/rtems/src/regionresizesegment.c
@@ -64,7 +64,8 @@ rtems_status_code rtems_region_resize_segment(
_Region_Debug_Walk( the_region, 8 );
if ( status == HEAP_RESIZE_SUCCESSFUL )
- _Region_Process_queue( the_region ); /* unlocks allocator */
+ /* unlocks allocator */
+ _Region_Process_queue( the_region );
else
diff --git a/cpukit/rtems/src/semcreate.c b/cpukit/rtems/src/semcreate.c
index bf9229e..5cd9568 100644
--- a/cpukit/rtems/src/semcreate.c
+++ b/cpukit/rtems/src/semcreate.c
@@ -100,12 +100,10 @@ rtems_status_code rtems_semaphore_create(
if ( !_Attributes_Is_counting_semaphore( attribute_set ) && ( count > 1 ) )
return RTEMS_INVALID_NUMBER;
the_semaphore = _Semaphore_Allocate();
@@ -114,7 +112,7 @@ rtems_status_code rtems_semaphore_create(
! ( _Objects_MP_Allocate_and_open( &_Semaphore_Information, name,
the_semaphore->Object.id, false ) ) ) {
#endif
@@ -179,14 +177,14 @@ rtems_status_code rtems_semaphore_create(
mutex_status = _CORE_mutex_Initialize(
&the_semaphore->Core_control.mutex,
- _Thread_Executing,
+ _Thread_Get_executing(),
&the_mutex_attr,
(count == 1) ? CORE_MUTEX_UNLOCKED : CORE_MUTEX_LOCKED
if ( mutex_status == CORE_MUTEX_STATUS_CEILING_VIOLATED ) {
return RTEMS_INVALID_PRIORITY;
@@ -212,6 +210,6 @@ rtems_status_code rtems_semaphore_create(
0 /* Not used */
#endif
diff --git a/cpukit/rtems/src/semdelete.c b/cpukit/rtems/src/semdelete.c
index ea82b77..6e7c5ea 100644
--- a/cpukit/rtems/src/semdelete.c
+++ b/cpukit/rtems/src/semdelete.c
@@ -44,6 +44,8 @@ rtems_status_code rtems_semaphore_delete(
the_semaphore = _Semaphore_Get( id, &location );
@@ -53,6 +55,7 @@ rtems_status_code rtems_semaphore_delete(
!_Attributes_Is_simple_binary_semaphore(
the_semaphore->attribute_set ) ) {
_CORE_mutex_Flush(
@@ -70,8 +73,6 @@ rtems_status_code rtems_semaphore_delete(
_Objects_Close( &_Semaphore_Information, &the_semaphore->Object );
- _Semaphore_Free( the_semaphore );
if ( _Attributes_Is_global( the_semaphore->attribute_set ) ) {
@@ -85,12 +86,15 @@ rtems_status_code rtems_semaphore_delete(
#endif
+ _Semaphore_Free( the_semaphore );
#endif
@@ -98,5 +102,6 @@ rtems_status_code rtems_semaphore_delete(
break;
diff --git a/cpukit/rtems/src/taskcreate.c b/cpukit/rtems/src/taskcreate.c
index ae4e188..35dd37c 100644
--- a/cpukit/rtems/src/taskcreate.c
+++ b/cpukit/rtems/src/taskcreate.c
@@ -105,11 +105,6 @@ rtems_status_code rtems_task_create(
* Allocate the thread control block and -- if the task is global --
* allocate a global object control block.
@@ -122,7 +117,7 @@ rtems_status_code rtems_task_create(
the_thread = _RTEMS_tasks_Allocate();
@@ -132,7 +127,7 @@ rtems_status_code rtems_task_create(
if ( _Objects_MP_Is_null_global_object( the_global_object ) ) {
_RTEMS_tasks_Free( the_thread );
@@ -164,7 +159,7 @@ rtems_status_code rtems_task_create(
_Objects_MP_Free_global_object( the_global_object );
#endif
@@ -195,6 +190,6 @@ rtems_status_code rtems_task_create(
#endif
diff --git a/cpukit/rtems/src/timercreate.c b/cpukit/rtems/src/timercreate.c
index 35cdfab..0b1c44b 100644
--- a/cpukit/rtems/src/timercreate.c
+++ b/cpukit/rtems/src/timercreate.c
@@ -38,12 +38,10 @@ rtems_status_code rtems_timer_create(
if ( !id )
the_timer = _Timer_Allocate();
if ( !the_timer ) {
@@ -57,6 +55,6 @@ rtems_status_code rtems_timer_create(
*id = the_timer->Object.id;
diff --git a/cpukit/rtems/src/timerdelete.c b/cpukit/rtems/src/timerdelete.c
index a3cf52a..19232c8 100644
--- a/cpukit/rtems/src/timerdelete.c
+++ b/cpukit/rtems/src/timerdelete.c
@@ -32,14 +32,16 @@ rtems_status_code rtems_timer_delete(
Timer_Control *the_timer;
the_timer = _Timer_Get( id, &location );
case OBJECTS_LOCAL:
_Objects_Close( &_Timer_Information, &the_timer->Object );
(void) _Watchdog_Remove( &the_timer->Ticker );
- _Timer_Free( the_timer );
_Objects_Put( &the_timer->Object );
+ _Timer_Free( the_timer );
@@ -49,5 +51,7 @@ rtems_status_code rtems_timer_delete(
break;
diff --git a/cpukit/sapi/src/extensioncreate.c b/cpukit/sapi/src/extensioncreate.c
index 1d7232f..8442096 100644
--- a/cpukit/sapi/src/extensioncreate.c
+++ b/cpukit/sapi/src/extensioncreate.c
@@ -39,16 +39,16 @@ rtems_status_code rtems_extension_create(
the_extension = _Extension_Allocate();
if ( !the_extension ) {
+ _Thread_Disable_dispatch();
_User_extensions_Add_set_with_table( &the_extension->Extension, extension_table );
+ _Thread_Enable_dispatch();
_Objects_Open(
&_Extension_Information,
@@ -57,6 +57,6 @@ rtems_status_code rtems_extension_create(
*id = the_extension->Object.id;
diff --git a/cpukit/sapi/src/extensiondelete.c b/cpukit/sapi/src/extensiondelete.c
index 0eaaffd..f851ea0 100644
--- a/cpukit/sapi/src/extensiondelete.c
+++ b/cpukit/sapi/src/extensiondelete.c
@@ -30,13 +30,15 @@ rtems_status_code rtems_extension_delete(
Extension_Control *the_extension;
the_extension = _Extension_Get( id, &location );
case OBJECTS_LOCAL:
_User_extensions_Remove_set( &the_extension->Extension );
_Objects_Close( &_Extension_Information, &the_extension->Object );
- _Extension_Free( the_extension );
_Objects_Put( &the_extension->Object );
+ _Extension_Free( the_extension );
@@ -46,5 +48,7 @@ rtems_status_code rtems_extension_delete(
break;
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index 119f11d..383f0a7 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -20,6 +20,7 @@
#define _RTEMS_SCORE_OBJECTIMPL_H
+#include <rtems/score/apimutex.h>
#include <rtems/score/isrlevel.h>
@@ -264,25 +265,120 @@ unsigned int _Objects_API_maximum_class(
- * @brief Allocate an object.
+ * @brief Allocates an object without locking the allocator mutex.
- * This function allocates an object control block from
- * the inactive chain of free object control blocks.
+ * This function can be called in two contexts
+ * - the executing thread is the owner of the object allocator mutex, or
+ * - in case the system state is not up, e.g. during sequential system
+ * initialization.
- * @param[in] information points to an object class information block.
+ * @param[in] information The object information block.
+ * @retval NULL No object available.
+ * @retval object The allocated object.
+ * @see _Objects_Allocate() and _Objects_Free().
-Objects_Control *_Objects_Allocate(
+Objects_Control *_Objects_Allocate_unprotected(
Objects_Information *information
- * @brief Free an object.
+ * @brief Allocates an object.
- * This function frees an object control block to the
- * inactive chain of free object control blocks.
+ * This function locks the object allocator mutex via
+ * _Objects_Allocator_lock(). The caller must later unlock the object
+ * allocator mutex via _Objects_Allocator_unlock(). The caller must unlock the
+ * mutex in any case, even if the allocation failed due to resource shortage.
- * @param[in] the_object points to the object to deallocate.
+ * A typical object allocation code looks like this:
+ * @code
+ * rtems_status_code some_create( rtems_id *id )
+ * rtems_status_code sc;
+ * Some_Control *some;
+ * // The object allocator mutex protects the executing thread from
+ * // asynchronous thread restart and deletion.
+ * some = (Some_Control *) _Objects_Allocate( &_Some_Information );
+ * if ( some != NULL ) {
+ * _Some_Initialize( some );
+ * sc = RTEMS_SUCCESSFUL;
+ * } else {
+ * sc = RTEMS_TOO_MANY;
+ * _Objects_Allocator_unlock();
+ * return sc;
+ * @endcode
+ * @see _Objects_Free().
+Objects_Control *_Objects_Allocate( Objects_Information *information );
+ * @brief Frees an object.
+ * Appends the object to the chain of inactive objects.
+ * @param[in] the_object The object to free.
+ * @see _Objects_Allocate().
+ * A typical object deletion code looks like this:
+ * @code
+ * rtems_status_code some_delete( rtems_id id )
+ * Objects_Locations location;
+ * _Objects_Allocator_lock();
+ * // This will disable thread dispatching, so this starts a thread dispatch
+ * // critical section.
+ * some = (Semaphore_Control *)
+ * _Objects_Get( &_Some_Information, id, &location );
+ * switch ( location ) {
+ * case OBJECTS_LOCAL:
+ * // After the object close an object get with this identifier will
+ * // fail.
+ * _Objects_Close( &_Some_Information, &some->Object );
+ * _Some_Delete( some );
+ * // This enables thread dispatching, so the thread dispatch critical
+ * // section ends here.
+ * _Objects_Put( &some->Object );
+ * // Thread dispatching is enabled. The object free is only protected
+ * // by the object allocator mutex.
+ * _Objects_Free( &_Some_Information, &some->Object );
+ * break;
+ * default:
+ * sc = RTEMS_INVALID_ID;
+ * break;
+ * return sc;
+ * @endcode
void _Objects_Free(
Objects_Information *information,
@@ -892,6 +988,37 @@ RTEMS_INLINE_ROUTINE void _Objects_Put_for_get_isr_disable(
#endif
+ * @brief Locks the object allocator mutex.
+ * While holding the allocator mutex the executing thread is protected from
+ * asynchronous thread restart and deletion.
+ * The usage of the object allocator mutex with the thread life protection
+ * makes it possible to allocate and free objects without thread dispatching
+ * disabled. The usage of a unified workspace and unlimited objects may lead
+ * to heap fragmentation. Thus the execution time of the _Objects_Allocate()
+ * function may increase during system run-time.
+ * @see _Objects_Allocator_unlock() and _Objects_Allocate().
+RTEMS_INLINE_ROUTINE void _Objects_Allocator_lock( void )
+ * @brief Unlocks the object allocator mutex.
+ * In case the mutex is fully unlocked, then this function restores the
+ * previous thread life protection state and thus may not return if the
+ * executing thread was restarted or deleted in the mean-time.
+RTEMS_INLINE_ROUTINE void _Objects_Allocator_unlock( void )
#ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index d0c7933..2ac8344 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -590,13 +590,10 @@ RTEMS_INLINE_ROUTINE uint32_t _Thread_Get_maximum_internal_threads(void)
return maximum_internal_threads;
- * This routine allocates an internal thread.
RTEMS_INLINE_ROUTINE Thread_Control *_Thread_Internal_allocate( void )
- return (Thread_Control *) _Objects_Allocate( &_Thread_Internal_information );
+ _Objects_Allocate_unprotected( &_Thread_Internal_information );
RTEMS_INLINE_ROUTINE void _Thread_Request_dispatch_if_executing(
diff --git a/cpukit/score/src/apimutex.c b/cpukit/score/src/apimutex.c
index 18ac2db8..7899934 100644
--- a/cpukit/score/src/apimutex.c
+++ b/cpukit/score/src/apimutex.c
@@ -58,7 +58,8 @@ void _API_Mutex_Allocate(
0
- mutex = (API_Mutex_Control *) _Objects_Allocate( &_API_Mutex_Information );
+ mutex = (API_Mutex_Control *)
+ _Objects_Allocate_unprotected( &_API_Mutex_Information );
_CORE_mutex_Initialize( &mutex->Mutex, NULL, &attr, CORE_MUTEX_UNLOCKED );
diff --git a/cpukit/score/src/objectactivecount.c b/cpukit/score/src/objectactivecount.c
index de34212..de3243a 100644
--- a/cpukit/score/src/objectactivecount.c
+++ b/cpukit/score/src/objectactivecount.c
@@ -17,14 +17,20 @@
#endif
+#include <rtems/score/assert.h>
Objects_Maximum _Objects_Active_count(
const Objects_Information *information
- size_t inactive = _Chain_Node_count_unprotected( &information->Inactive );
- size_t maximum = information->maximum;
+ size_t inactive;
+ size_t maximum;
+ _Assert( _Debug_Is_owner_of_allocator() );
+ inactive = _Chain_Node_count_unprotected( &information->Inactive );
+ maximum = information->maximum;
return (Objects_Maximum) ( maximum - inactive );
diff --git a/cpukit/score/src/objectallocate.c b/cpukit/score/src/objectallocate.c
index 842c49d..40a7cae 100644
--- a/cpukit/score/src/objectallocate.c
+++ b/cpukit/score/src/objectallocate.c
@@ -19,7 +19,9 @@
#endif
+#include <rtems/score/sysstate.h>
/* #define RTEMS_DEBUG_OBJECT_ALLOCATION */
@@ -27,12 +29,24 @@
#include <rtems/bspIo.h>
#endif
+static Objects_Control *_Objects_Get_inactive(
+ Objects_Information *information
+ return (Objects_Control *) _Chain_Get_unprotected( &information->Inactive );
Objects_Control *the_object;
+ _Assert(
+ _Debug_Is_owner_of_allocator()
+ || !_System_state_Is_up( _System_state_Get() )
* If the application is using the optional manager stubs and
* still attempts to create the object, the information block
@@ -46,7 +60,7 @@ Objects_Control *_Objects_Allocate(
* OK. The manager should be initialized and configured to have objects.
* With any luck, it is safe to attempt to allocate an object.
- the_object = (Objects_Control *) _Chain_Get( &information->Inactive );
+ the_object = _Objects_Get_inactive( information );
if ( information->auto_extend ) {
@@ -56,7 +70,7 @@ Objects_Control *_Objects_Allocate(
if ( !the_object ) {
_Objects_Extend_information( information );
if ( the_object ) {
@@ -83,3 +97,10 @@ Objects_Control *_Objects_Allocate(
return the_object;
+ return _Objects_Allocate_unprotected( information );
diff --git a/cpukit/score/src/objectextendinformation.c b/cpukit/score/src/objectextendinformation.c
index d11f927..b1fcec7 100644
--- a/cpukit/score/src/objectextendinformation.c
+++ b/cpukit/score/src/objectextendinformation.c
@@ -20,8 +20,10 @@
#include <rtems/score/address.h>
#include <string.h> /* for memcpy() */
@@ -42,10 +44,10 @@ void _Objects_Extend_information(
- Chain_Control Inactive;
uint32_t block_count;
uint32_t block;
uint32_t index_base;
+ uint32_t index_end;
uint32_t minimum_index;
uint32_t index;
uint32_t maximum;
@@ -53,6 +55,11 @@ void _Objects_Extend_information(
void *new_object_block;
bool do_extend;
+ _Assert(
* Search for a free block of indexes. If we do NOT need to allocate or
* extend the block table, then we will change do_extend.
@@ -76,6 +83,7 @@ void _Objects_Extend_information(
index_base += information->allocation_size;
+ index_end = index_base + information->allocation_size;
maximum = (uint32_t) information->maximum + information->allocation_size;
@@ -213,12 +221,11 @@ void _Objects_Extend_information(
object_blocks[block_count] = NULL;
inactive_per_block[block_count] = 0;
- for ( index=index_base ;
- index < ( information->allocation_size + index_base );
- index++ ) {
+ for ( index = index_base ; index < index_end ; ++index ) {
local_table[ index ] = NULL;
_ISR_Disable( level );
old_tables = information->object_blocks;
@@ -235,6 +242,7 @@ void _Objects_Extend_information(
_ISR_Enable( level );
_Workspace_Free( old_tables );
@@ -247,32 +255,21 @@ void _Objects_Extend_information(
information->object_blocks[ block ] = new_object_block;
- * Initialize objects .. add to a local chain first.
+ * Append to inactive chain.
- _Chain_Initialize(
- &Inactive,
- information->object_blocks[ block ],
- information->allocation_size,
- information->size
- * Move from the local chain, initialise, then append to the inactive chain
- index = index_base;
- while ((the_object = (Objects_Control *) _Chain_Get( &Inactive )) != NULL ) {
+ the_object = information->object_blocks[ block ];
the_object->id = _Objects_Build_id(
- information->the_api,
- information->the_class,
- _Objects_Local_node,
- index
+ information->the_api,
+ information->the_class,
+ _Objects_Local_node,
+ index
- _Chain_Append( &information->Inactive, &the_object->Node );
+ _Chain_Append_unprotected( &information->Inactive, &the_object->Node );
- index++;
+ the_object = (Objects_Control *)
+ ( (char *) the_object + information->size );
information->inactive_per_block[ block ] = information->allocation_size;
diff --git a/cpukit/score/src/objectfree.c b/cpukit/score/src/objectfree.c
index cc2fbac..f1c0ee4 100644
--- a/cpukit/score/src/objectfree.c
+++ b/cpukit/score/src/objectfree.c
@@ -19,6 +19,7 @@
#endif
void _Objects_Free(
@@ -28,7 +29,9 @@ void _Objects_Free(
uint32_t allocation_size = information->allocation_size;
uint32_t block;
diff --git a/cpukit/score/src/objectshrinkinformation.c b/cpukit/score/src/objectshrinkinformation.c
index 9731c21..2f64cd2 100644
--- a/cpukit/score/src/objectshrinkinformation.c
+++ b/cpukit/score/src/objectshrinkinformation.c
@@ -19,6 +19,7 @@
#endif
@@ -30,6 +31,8 @@ void _Objects_Shrink_information(
uint32_t block;
* Search the list to find block or chunk with all objects inactive.
@@ -55,7 +58,7 @@ void _Objects_Shrink_information(
node = _Chain_Next( node );
if ( index >= index_base && index < index_end ) {
- _Chain_Extract( &object->Node );
+ _Chain_Extract_unprotected( &object->Node );
diff --git a/testsuites/sptests/spobjgetnext/init.c b/testsuites/sptests/spobjgetnext/init.c
index 9682c34..2695190 100644
--- a/testsuites/sptests/spobjgetnext/init.c
+++ b/testsuites/sptests/spobjgetnext/init.c
@@ -108,7 +108,9 @@ rtems_task Init(
/* XXX try with a manager with no objects created */
puts( "Init - _Objects_Active_count" );
active_count = _Objects_Active_count( info );
rtems_test_assert( active_count == 1 );
TEST_END();
1.7.7
