[PATCH 1/1] LEON3: UT699 and GR712 sleep-mode d-cache fix
Daniel Cederman cederman at gaisler.com
Mon Mar 31 09:48:28 UTC 2014
That is the same master I'm referring too. I must have picked the wrong
commit or similar when I created the patch. I apologize. Will make sure
that the patch can be applied before submitting next time.
On 2014-03-31 10:26, Sebastian Huber wrote:
> On 2014-03-31 10:17, Daniel Cederman wrote:
>> It was generated against the current master. What conflict did you get?
> With current master I mean the master branch here:
> http://git.rtems.org/rtems/
> You probably don't have this change in your branch:
> http://git.rtems.org/rtems/commit/?id=4fe6759e2ac3771699c64abe3392f4cf3a77fe20
>> On 2014-03-31 09:59, Sebastian Huber wrote:
>>> On 2014-03-31 09:32, Daniel Cederman wrote:
>>>> The one without the signed-off-by part, Daniel H asked me to remove it.
>>> The patch doesn't apply cleanly.  Please generate it against the current
>>> Git master.
