[PATCH v2] score: PR788: Add INTERNAL_ERROR_RESOURCE_IN_USE
Sebastian Huber
Mon Mar 31 11:51:19 UTC 2014
Issue a fatal error in case a thread is deleted which still owns
resources (e.g. a binary semaphore with priority inheritance or ceiling
protocol). The resource count must be checked quite late since RTEMS
task variable destructors, POSIX key destructors, POSIX cleanup handler,
the Newlib thread termination extension or other thread termination
extensions may release resources. In this context it would be quite
difficult to return an error status to the caller.
An alternative would be to place threads with a non-zero resource count
not on the zombie chain. Thus we have a resource leak instead of a
fatal error. The terminator thread can see this error if we return an
RTEMS_RESOURCE_IN_USE status for the rtems_task_delete() for example.
cpukit/sapi/src/interrtext.c | 3 +-
cpukit/score/include/rtems/score/interr.h | 3 +-
cpukit/score/src/threadrestart.c | 8 +++++
testsuites/sptests/Makefile.am | 1 +
testsuites/sptests/configure.ac | 1 +
testsuites/sptests/spfatal28/Makefile.am | 19 +++++++++++++
testsuites/sptests/spfatal28/spfatal28.doc | 12 ++++++++
testsuites/sptests/spfatal28/spfatal28.scn | 3 ++
testsuites/sptests/spfatal28/testcase.h | 39 +++++++++++++++++++++++++++
testsuites/sptests/spinternalerror02/init.c | 2 +-
testsuites/sptests/spsem01/init.c | 6 ++--
testsuites/sptests/spsem01/spsem01.scn | 9 +++---
testsuites/sptests/spsem02/init.c | 6 ++--
testsuites/sptests/spsem02/spsem02.scn | 7 ++---
14 files changed, 101 insertions(+), 18 deletions(-)
create mode 100644 testsuites/sptests/spfatal28/Makefile.am
create mode 100644 testsuites/sptests/spfatal28/spfatal28.doc
create mode 100644 testsuites/sptests/spfatal28/spfatal28.scn
create mode 100644 testsuites/sptests/spfatal28/testcase.h
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index a18610c..e08414b 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -51,7 +51,8 @@ static const char *const internal_error_text[] = {
"INTERNAL_ERROR_GXX_KEY_ADD_FAILED",
"INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED",
"INTERNAL_ERROR_NO_MEMORY_FOR_HEAP",
- "INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR"
+ "INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR",
+ "INTERNAL_ERROR_RESOURCE_IN_USE"
const char *rtems_internal_error_text( rtems_fatal_code error )
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index 8c647f5..2100c13 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -147,7 +147,8 @@ typedef enum {
INTERNAL_ERROR_GXX_KEY_ADD_FAILED,
INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED,
INTERNAL_ERROR_NO_MEMORY_FOR_HEAP,
- INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
+ INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR,
+ INTERNAL_ERROR_RESOURCE_IN_USE
} Internal_errors_Core_list;
typedef uint32_t Internal_errors_t;
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 4b83ede..02371ac 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -47,6 +47,14 @@ static void _Thread_Make_zombie( Thread_Control *the_thread )
ISR_lock_Context lock_context;
Thread_Zombie_control *zombies = &_Thread_Zombies;
+ if ( the_thread->resource_count != 0 ) {
+ _Terminate(
+ INTERNAL_ERROR_CORE,
+ false,
_Thread_Set_state( the_thread, STATES_ZOMBIE );
_Thread_queue_Extract_with_proxy( the_thread );
_Watchdog_Remove( &the_thread->Timer );
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index d47f6f7..c344ce0 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -33,6 +33,7 @@ SUBDIRS = \
spsignal_err01 spport_err01 spmsgq_err01 spmsgq_err02 spsem_err01 \
spsem_err02 sptask_err01 spevent_err03 sptask_err03 sptask_err02 \
sptask_err04 spclock_err01
+SUBDIRS += spfatal28
SUBDIRS += spthreadlife01
SUBDIRS += spprofiling01
SUBDIRS += spcache01
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 4809bdc..3f2f952 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -36,6 +36,7 @@ AM_CONDITIONAL(HAS_CPUSET,test x"${ac_cv_header_sys_cpuset_h}" = x"yes")
# Explicitly list all Makefiles here
AC_CONFIG_FILES([Makefile
+spfatal28/Makefile
spthreadlife01/Makefile
spprofiling01/Makefile
spcache01/Makefile
diff --git a/testsuites/sptests/spfatal28/Makefile.am b/testsuites/sptests/spfatal28/Makefile.am
new file mode 100644
index 0000000..a20d936
--- /dev/null
+++ b/testsuites/sptests/spfatal28/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spfatal28
+spfatal28_SOURCES = ../spfatal_support/init.c ../spfatal_support/system.h testcase.h
+dist_rtems_tests_DATA = spfatal28.scn spfatal28.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spfatal28_OBJECTS)
+LINK_LIBS = $(spfatal28_LDLIBS)
+spfatal28$(EXEEXT): $(spfatal28_OBJECTS) $(spfatal28_DEPENDENCIES)
+ @rm -f spfatal28$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spfatal28/spfatal28.doc b/testsuites/sptests/spfatal28/spfatal28.doc
index 0000000..7514dd9
--- /dev/null
+++ b/testsuites/sptests/spfatal28/spfatal28.doc
@@ -0,0 +1,12 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spfatal28
+directives:
+ - rtems_task_delete()
+concepts:
+ - Ensure that deletion of a task with a semaphore in use leads to a fatal
+ error.
diff --git a/testsuites/sptests/spfatal28/spfatal28.scn b/testsuites/sptests/spfatal28/spfatal28.scn
index 0000000..6fcae10
--- /dev/null
+++ b/testsuites/sptests/spfatal28/spfatal28.scn
@@ -0,0 +1,3 @@
+*** BEGIN OF TEST SPFATAL 28 ***
+Fatal error (delete a task with a semaphore in use) hit
+*** END OF TEST SPFATAL 28 ***
diff --git a/testsuites/sptests/spfatal28/testcase.h b/testsuites/sptests/spfatal28/testcase.h
index 0000000..fc72100
--- /dev/null
+++ b/testsuites/sptests/spfatal28/testcase.h
@@ -0,0 +1,39 @@
+ * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+#define FATAL_ERROR_TEST_NAME "28"
+#define FATAL_ERROR_DESCRIPTION "delete a task with a semaphore in use"
+#define FATAL_ERROR_EXPECTED_SOURCE INTERNAL_ERROR_CORE
+#define FATAL_ERROR_EXPECTED_IS_INTERNAL FALSE
+#define FATAL_ERROR_EXPECTED_ERROR INTERNAL_ERROR_RESOURCE_IN_USE
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+void force_error()
+ rtems_status_code sc;
+ rtems_id id;
+ sc = rtems_semaphore_create(
+ rtems_build_name('S', 'E', 'M', 'A'),
+ 0,
+ RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY,
+ 0,
+ &id
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_task_delete(RTEMS_SELF);
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index 340a9e3..3302a2c 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -35,7 +35,7 @@ static void test_internal_error_text(void)
puts( text );
} while ( text != text_last );
- rtems_test_assert( error - 3 == INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR );
+ rtems_test_assert( error - 3 == INTERNAL_ERROR_RESOURCE_IN_USE );
static void test_fatal_source_text(void)
diff --git a/testsuites/sptests/spsem01/init.c b/testsuites/sptests/spsem01/init.c
index e950890..924f4c0 100644
--- a/testsuites/sptests/spsem01/init.c
+++ b/testsuites/sptests/spsem01/init.c
@@ -150,8 +150,8 @@ rtems_task Task02(rtems_task_argument ignored)
directive_failed( status, " rtems_semaphore_obtain S1");
printf("TA02: priority %d, holding S1\n", getprio());
- printf("TA02: exiting\n");
- status = rtems_task_delete( RTEMS_SELF);
- directive_failed( status, "rtems_task_delete TA02");
+ printf("TA02: suspending\n");
+ status = rtems_task_suspend( RTEMS_SELF);
+ directive_failed( status, "rtems_task_suspend TA02");
diff --git a/testsuites/sptests/spsem01/spsem01.scn b/testsuites/sptests/spsem01/spsem01.scn
index 8b0a59a..35e6b94 100644
--- a/testsuites/sptests/spsem01/spsem01.scn
+++ b/testsuites/sptests/spsem01/spsem01.scn
@@ -1,4 +1,4 @@
-*** TEST SEM01 ***
+*** BEGIN OF TEST SPSEM 1 ***
init: S0 created
init: S1 created
init: TA01 created with priority 36
@@ -7,10 +7,9 @@ TA01: started with priority 36
TA01: priority 36, holding S0
TA01: priority 36, holding S0, S1
TA02: started with priority 34
+TA01: priority 34, holding S0
TA02: priority 34, holding S1
-TA02: exiting
-TA01: priority 36, holding S0
+TA02: suspending
TA01: priority 36
TA01: exiting
-*** END OF SEM01 ***
+*** END OF TEST SPSEM 1 ***
diff --git a/testsuites/sptests/spsem02/init.c b/testsuites/sptests/spsem02/init.c
index c88e9ad..d5fb47b 100644
--- a/testsuites/sptests/spsem02/init.c
+++ b/testsuites/sptests/spsem02/init.c
@@ -168,9 +168,9 @@ rtems_task Task02(rtems_task_argument ignored)
/* Task03 starts with priority 32 */
diff --git a/testsuites/sptests/spsem02/spsem02.scn b/testsuites/sptests/spsem02/spsem02.scn
index 5b8d03d..ab8c7ce 100644
--- a/testsuites/sptests/spsem02/spsem02.scn
+++ b/testsuites/sptests/spsem02/spsem02.scn
@@ -1,4 +1,4 @@
-*** TEST SEM02 ***
+*** BEGIN OF TEST SPSEM 2 ***
init: S0 created
init: S1 created
@@ -15,8 +15,7 @@ TA03: priority 32, holding S0
TA03: priority 32
TA03: exiting
-TA02: exiting
+TA02: suspending
TA01: priority 36
TA01: exiting
-*** END OF SEM02 ***
+*** END OF TEST SPSEM 2 ***
1.7.7
