[GSoC 2014] Paravirtualization Layer of RTEMS.
Philipp Eppelt
philipp.eppelt at mailbox.tu-dresden.de
Mon Mar 3 17:07:30 UTC 2014
Hi Youren,
can you please explain your proposed hypercall solution in more detail.
Lets assume RTEMS requests notification for an interrupt line, e.g IRQ
0. How is the request delivered from RTEMS to POK in your solution?
The big issue is the delivery of interrupts to the guest system (RTEMS):
How are you planning on solving this?
Did you have time to get to know my code in POK?
Did you have a look at the --enable-paravirt configuration option,
especially the usage in cpukit/score/cpu/i386/*. That's how I dealt with
privileged instructions.
Cheers,
Philipp
On 03/03/2014 02:55 PM, Youren Shen wrote:
> Hi, everyone,
> These days I’m running the hello world example on POK, reading the
> source code of POK and the patch to RTEMS, knowing the work has been
> done before me. After that, I draft my proposal. Could you review it?
> However, as the time gets tight , I can’t catch every detail. So if
> there are any mistakes, please comments it and let me know.
> Thank you very much.
> [1].https://docs.google.com/document/d/10ehcM1f2eKNwcNgv5stphGtsVAnYc_K7KLhxmjvE1k8/edit?usp=sharing
> Best Regards.
> Youren Shen.
> rtems-devel mailing list
> rtems-devel at rtems.org
