Patch for pthread get and set affinity
    Joel Sherrill
    Joel.Sherrill at OARcorp.com
    Wed Mar  5 14:58:29 UTC 2014
On Mar 5, 2014 8:33 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 2014-03-05 15:21, Joel Sherrill wrote:
> > We discussed this privately when you raised this to me. It should not be part
> > of the scheduler per thread data. lf you do then the data just disappears from
> > the API perspective when the scheduler doesn't support affinity. It will create
> > a new class of odd errors at the API level which no other implementation of
> > this type of API has. From an API perspective, it is the same as the preempt
> > and timeslicing flags.
> It is the responsibility of the scheduler set/get thread affinity operation to
> validate/return the affinity sets.  Storing this stuff in an arbitrary format
> in the Thread_Control structure makes no sense since the thread affinity
> support is entirely scheduler dependent.
> > It is disabled in non-smp configurations, so doesn't impact minimum footprint.
> > I seriously considered this and decided it was a bad idea. I don't know if I
> > have veto power :) but if I did, I would invoke it here.
> > We can revisit this when we have a scheduler with affinity. As it stands now,
> > there is absolutely no way to test any of this code if we move the affinity
> > data to the scheduler.
> You can test the code if you add the scheduler set/get affinity operations.
> The default implementation is trivial.  We have only global schedulers, so
> simply check that the affinity set is the set of all processors in the system.
>   For the get simply return the set of all processors.
I don't disagree with this statement but you are being short sighted for iterative development.
If we do this, then the tests can't set an arbitrary affinity and return it.  We can commit this set will full passing tests.
We will move the set when we touch the schedulers. We were very open and public and getting the APIs in and tested with data consistency and no scheduler changes as step one. Step two moves the information into the schedulers.
If we make this change, we will commit nearly all broken tests
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140305/9ce3523a/attachment-0001.html>
