Patch for pthread get and set affinity
Thu Mar 6 07:38:50 UTC 2014
On 2014-03-05 17:31, Gedare Bloom wrote:
> Joel,
> On Wed, Mar 5, 2014 at 10:38 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> On 3/5/2014 9:05 AM, Sebastian Huber wrote:
>>> On 2014-03-05 15:58, Joel Sherrill wrote:
>>>> On Mar 5, 2014 8:33 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>>>>   > On 2014-03-05 15:21, Joel Sherrill wrote:
>>>>   > > We discussed this privately when you raised this to me. It should not be part
>>>>   > > of the scheduler per thread data. lf you do then the data just disappears from
>>>>   > > the API perspective when the scheduler doesn't support affinity. It will
>>>> create
>>>>   > > a new class of odd errors at the API level which no other implementation of
>>>>   > > this type of API has. From an API perspective, it is the same as the preempt
>>>>   > > and timeslicing flags.
> Oops I forgot about our chat. I do think we need to revisit the issue
> in the future though, and probably add calls to the scheduler from the
> score affinity implementation.
>>>>   > It is the responsibility of the scheduler set/get thread affinity operation to
>>>>   > validate/return the affinity sets.  Storing this stuff in an arbitrary format
>>>>   > in the Thread_Control structure makes no sense since the thread affinity
>>>>   > support is entirely scheduler dependent.
>>>>   > > It is disabled in non-smp configurations, so doesn't impact minimum footprint.
>>>>   > > I seriously considered this and decided it was a bad idea. I don't know if I
>>>>   > > have veto power :) but if I did, I would invoke it here.
>>>>   > > We can revisit this when we have a scheduler with affinity. As it stands now,
>>>>   > > there is absolutely no way to test any of this code if we move the affinity
>>>>   > > data to the scheduler.
>>>>   > You can test the code if you add the scheduler set/get affinity operations.
>>>>   > The default implementation is trivial.  We have only global schedulers, so
>>>>   > simply check that the affinity set is the set of all processors in the system.
>>>>   >   For the get simply return the set of all processors.
>>>> I don't disagree with this statement but you are being short sighted for
>>>> iterative development.
>>>> If we do this, then the tests can't set an arbitrary affinity and return it.
>>>> We can commit this set will full passing tests.
>>>> We will move the set when we touch the schedulers. We were very open and public
>>>> and getting the APIs in and tested with data consistency and no scheduler
>>>> changes as step one. Step two moves the information into the schedulers.
>>>> If we make this change, we will commit nearly all broken tests
>>> Its fine if you move the information into the schedulers later.  This wasn't
>>> obvious from the current patch set.
>> Great! Thanks. I just started hacking on the scheduler part and it would
>> be better to commit what we have and make sure it works before doing
>> more.
>> Unless someone has someone has something else, Jennifer is going
>> to commit and verify that the resulting master matches her results.
> OK with me. I would like you to add a note to the SMP wiki page
> regarding this issue about affinity in the TCB vs the scheduler. It
> seems to me that any SMP scheduler must deal with the affinity API
> whether or not the scheduler supports thread affinity---the scheduler
> can return an error if an application tries to use affinity calls but
> the scheduler does not support affinity.
All thread affinity support must move to the scheduler in the long run (data
and operations).  I see no way to implement this scheduler agnostic.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
