Enable POSIX Keys in All Configurations v2
Thu Mar 6 20:22:13 UTC 2014
On 3/6/2014 1:43 PM, Gedare Bloom wrote:
> Joel,
> Around line 547 of the patch it appears to be adding an unconditional
> define in confdefs.h for
> +#define CONFIGURE_CONFDEFS_DEBUG
> Please justify or remove. Otherwise, the patch looks good to me.
Bad one on my part.
> Do you have any idea what the effect of this patch is on the code,
> data, and workspace size?
No.  But a quick check shows 36896 code, 1040 data and 3234 BSS for
minimum.exe built at -O2 with POSIX disabled. I had no special
build options.
So nothing noticeable.
> Gedare
> On Thu, Mar 6, 2014 at 2:13 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> Hi
>> I think all comments have been addressed. Tests run in uniprocessor
>> configuration with POSIX enabled and disabled.
>> confdefs.h debug updated
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
