[PATCH 11/18] bsp/arm: Add SCU errata handling for L2C-310 cache
Ralf Kirchner
ralf.kirchner at embedded-brains.de
Fri Mar 7 13:59:15 UTC 2014
.../libbsp/arm/shared/include/arm-a9mpcore-regs.h | 5 +-
.../libbsp/arm/shared/include/arm-a9mpcore-start.h | 50 ++++++++++++++++----
2 Dateien geändert, 44 Zeilen hinzugefügt(+), 11 Zeilen entfernt(-)
diff --git a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h
index 28640d2..861d1ae 100644
--- a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h
+++ b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h
@@ -58,7 +58,10 @@ typedef struct {
#define A9MPCORE_SCU_INVSS_CPU3(ways) BSP_FLD32(val, 12, 15)
#define A9MPCORE_SCU_INVSS_CPU3_GET(reg) /* Write only register */
#define A9MPCORE_SCU_INVSS_CPU3_SET(reg, val) BSP_FLD32SET(reg, val, 12, 15)
- uint32_t reserved_10[12];
+ uint32_t reserved_09[8];
+ uint32_t diagn_ctrl;
+#define A9MPCORE_SCU_DIAGN_CTRL_MIGRATORY_BIT_DISABLE BSP_BIT32(0)
+ uint32_t reserved_10[3];
uint32_t fltstart;
uint32_t fltend;
uint32_t reserved_48[2];
diff --git a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
index ad4cf42..72e7100 100644
--- a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
+++ b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
@@ -30,6 +30,7 @@
#include <bsp.h>
#include <bsp/start.h>
#include <bsp/arm-a9mpcore-regs.h>
+#include <bsp/arm-errata.h>
#ifdef __cplusplus
extern "C" {
@@ -50,6 +51,20 @@ arm_cp15_set_auxiliary_control(uint32_t val);
BSP_START_TEXT_SECTION static inline void
arm_cp15_set_vector_base_address(void *base);
+#if ( defined(RTEMS_SMP) )
+ BSP_START_TEXT_SECTION static void inline
+ arm_a9mpcore_start_errata_764369_handler(
+ volatile a9mpcore_scu *scu
+ if( arm_errata_is_applicable_processor_errata_764369() ) {
+ scu->diagn_ctrl |= A9MPCORE_SCU_DIAGN_CTRL_MIGRATORY_BIT_DISABLE;
+#else /* #if ( defined(RTEMS_SMP) ) */
+ #define arm_a9mpcore_start_errata_764369_handler( scu )
+#endif /* #if ( defined(RTEMS_SMP) ) */
BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_set_vector_base(void)
@@ -70,32 +85,46 @@ BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_set_vector_base(void)
-BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_scu_invalidate(const uint32_t cpu_id, const uint32_t ways)
+BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_scu_enable( volatile a9mpcore_scu *scu )
+ arm_a9mpcore_start_errata_764369_handler( scu );
+ scu->ctrl |= A9MPCORE_SCU_CTRL_SCU_EN;
+BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_scu_invalidate(
+ const uint32_t cpu_id,
+ const uint32_t ways
- volatile a9mpcore_scu *scu = (volatile a9mpcore_scu *) BSP_ARM_A9MPCORE_SCU_BASE;
+ volatile a9mpcore_scu *scu =
+ (volatile a9mpcore_scu *) BSP_ARM_A9MPCORE_SCU_BASE;
scu->invss = ( ( ways & 0xF ) << ( ( cpu_id & 0x3 ) * 4 ) );
BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_hook_0(void)
-#ifdef RTEMS_SMP
uint32_t cpu_id;
- uint32_t actlr;
/* Enable Snoop Control Unit (SCU) */
- scu->ctrl |= A9MPCORE_SCU_CTRL_SCU_EN;
+ arm_a9mpcore_start_scu_enable( scu );
+#ifdef RTEMS_SMP
/* Enable cache coherency support for this processor */
- actlr = arm_cp15_get_auxiliary_control();
- actlr |= ARM_CORTEX_A9_ACTL_SMP;
- arm_cp15_set_auxiliary_control(actlr);
+ uint32_t actlr = arm_cp15_get_auxiliary_control();
+ actlr |= ARM_CORTEX_A9_ACTL_SMP;
+ arm_cp15_set_auxiliary_control(actlr);
+#endif
cpu_id = arm_cortex_a9_get_multiprocessor_cpu_id();
arm_a9mpcore_start_scu_invalidate(cpu_id, 0xF);
+#ifdef RTEMS_SMP
if (cpu_id != 0) {
arm_a9mpcore_start_set_vector_base();
@@ -114,7 +143,8 @@ BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_hook_0(void)
/* FIXME: Sharing the translation table between processors is brittle */
- arm_cp15_set_translation_table_base((uint32_t *) bsp_translation_table_base);
+ arm_cp15_set_translation_table_base(
+ (uint32_t *) bsp_translation_table_base);
ctrl |= ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M;
arm_cp15_set_control(ctrl);
1.7.10.4
