SuperCore Scheduler (GSOC 2014)
Sebastian Huber
Mon Mar 10 07:37:36 UTC 2014
On 2014-03-09 18:51, Andre Marques wrote:
> The problem is everything in the SMP task list seems to be already under way.
> Maybe it would be better for me to focus outside SMP for GSoC.
> For POSIX I could:
> - Continue rename() test case (including the issues I have postponed until now)
> and then make rename() POSIX conformant
> - Implement lio_listio() (the only function that seems unimplemented at
> http://www.rtems.org/wiki/index.php/POSIX_Asynchronous_IO)
> - Test POSIX FIFOS (http://www.rtems.org/wiki/index.php/POSIXFIFOs)
> - Solve some issues with newlib
> (http://www.rtems.org/wiki/index.php/POSIX_Methods_in_NewLib_RTEMS_improvements)
> What do you think?
Another topic might be the Newlib locking:
https://www.rtems.org/bugzilla/show_bug.cgi?id=1247
I added support for the openat() etc. functions in Newlib for RTEMS early this
year:
https://sourceware.org/ml/newlib/2014/msg00000.html
Implementing these functions is suitable for a GSoC project. These functions
can be used to simplify the FTP server and the rtems_tarfs_load() function for
example.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
