[PATCH 09/11] bsps/powerpc: Add support for interrupt profiling
Sebastian Huber
Mon Mar 10 13:28:31 UTC 2014
.../bspsupport/ppc_exc_async_normal.S | 53 +++++++++++++++++++-
1 files changed, 51 insertions(+), 2 deletions(-)
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S
index 7014530..49efe05 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S
@@ -1,8 +1,8 @@
- * Copyright (c) 2011-2012 embedded brains GmbH. All rights reserved.
+ * Copyright (c) 2011-2014 embedded brains GmbH. All rights reserved.
* embedded brains GmbH
- * Obere Lagerstr. 30
+ * Dornierstr. 4
* 82178 Puchheim
* Germany
* <rtems at embedded-brains.de>
@@ -46,6 +46,22 @@
#define FRAME_OFFSET(reg) GPR2_OFFSET(reg)
+#ifdef RTEMS_PROFILING
+ * The PPC_EXC_MINIMAL_FRAME_SIZE is enough to store this additional register.
+#define ENTRY_INSTANT_REGISTER r15
+#define ENTRY_INSTANT_OFFSET(reg) GPR13_OFFSET(reg)
+.macro GET_TIME_BASE REG
+#ifdef ppc8540
+ mfspr \REG, TBRL
+#else /* ppc8540 */
+ mftb \REG
+#endif /* ppc8540 */
+.endm
+#endif /* RTEMS_PROFILING */
#ifdef PPC_EXC_CONFIG_USE_FIXED_HANDLER
.global bsp_interrupt_dispatch
#endif /* PPC_EXC_CONFIG_USE_FIXED_HANDLER */
@@ -70,6 +86,14 @@ ppc_exc_min_prolog_async_tmpl_normal:
ppc_exc_wrap_async_normal:
+ /* Save non-volatile ENTRY_INSTANT_REGISTER */
+ stw ENTRY_INSTANT_REGISTER, ENTRY_INSTANT_OFFSET(r1)
+ /* Get entry instant */
+ GET_TIME_BASE ENTRY_INSTANT_REGISTER
/* Save non-volatile FRAME_REGISTER */
stw FRAME_REGISTER, FRAME_OFFSET(r1)
@@ -192,13 +216,33 @@ ppc_exc_wrap_async_normal:
lwz FRAME_REGISTER, FRAME_OFFSET(r1)
/* Decrement ISR nest level and thread dispatch disable level */
+ subic. ISR_NEST_REGISTER, ISR_NEST_REGISTER, 1
+ subi DISPATCH_LEVEL_REGISTER, DISPATCH_LEVEL_REGISTER, 1
+ cmpwi cr2, DISPATCH_LEVEL_REGISTER, 0
+#else /* RTEMS_PROFILING */
subi ISR_NEST_REGISTER, ISR_NEST_REGISTER, 1
subic. DISPATCH_LEVEL_REGISTER, DISPATCH_LEVEL_REGISTER, 1
stw ISR_NEST_REGISTER, PER_CPU_ISR_NEST_LEVEL(SELF_CPU_REGISTER)
stw DISPATCH_LEVEL_REGISTER, PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL(SELF_CPU_REGISTER)
+ /* Store profiling data if necessary */
+ bne profiling_done
+ mr r3, SELF_CPU_REGISTER
+ mr r4, ENTRY_INSTANT_REGISTER
+ GET_TIME_BASE r5
+ bl _Profiling_Outer_most_interrupt_entry_and_exit
+profiling_done:
/* Call thread dispatcher if necessary */
+ bne cr2, thread_dispatching_done
bne thread_dispatching_done
bl _Thread_Dispatch
thread_dispatching_done:
@@ -246,6 +290,11 @@ thread_dispatching_done:
mtlr SCRATCH_5_REGISTER
PPC_GPR_LOAD SCRATCH_5_REGISTER, SCRATCH_5_OFFSET(r1)
+ /* Restore ENTRY_INSTANT_REGISTER */
+ lwz ENTRY_INSTANT_REGISTER, ENTRY_INSTANT_OFFSET(r1)
/* Pop stack */
addi r1, r1, PPC_EXC_MINIMAL_FRAME_SIZE
1.7.7
