[PATCH 11/11] smptests/smpload01: New test
Sebastian Huber
Mon Mar 10 13:28:33 UTC 2014
testsuites/smptests/Makefile.am | 1 +
testsuites/smptests/configure.ac | 1 +
testsuites/smptests/smpload01/Makefile.am | 19 +++
testsuites/smptests/smpload01/init.c | 137 +++++++++++++++++++++++
testsuites/smptests/smpload01/smpload01.doc | 13 ++
testsuites/smptests/smpload01/smpload01.scn | 160 +++++++++++++++++++++++++++
6 files changed, 331 insertions(+), 0 deletions(-)
create mode 100644 testsuites/smptests/smpload01/Makefile.am
create mode 100644 testsuites/smptests/smpload01/init.c
create mode 100644 testsuites/smptests/smpload01/smpload01.doc
create mode 100644 testsuites/smptests/smpload01/smpload01.scn
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 1f4b0b3..c7fa028 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -1,6 +1,7 @@
ACLOCAL_AMFLAGS = -I ../aclocal
SUBDIRS =
+SUBDIRS += smpload01
if SMPTESTS
SUBDIRS += smp01
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index a2e99eb..0d08f0d 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -57,6 +57,7 @@ AM_CONDITIONAL(HAS_CPUSET,test x"${ac_cv_header_sys_cpuset_h}" = x"yes")
# Explicitly list all Makefiles here
AC_CONFIG_FILES([Makefile
+smpload01/Makefile
smp01/Makefile
smp02/Makefile
smp03/Makefile
diff --git a/testsuites/smptests/smpload01/Makefile.am b/testsuites/smptests/smpload01/Makefile.am
new file mode 100644
index 0000000..7e41337
--- /dev/null
+++ b/testsuites/smptests/smpload01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpload01
+smpload01_SOURCES = init.c
+dist_rtems_tests_DATA = smpload01.scn smpload01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smpload01_OBJECTS)
+LINK_LIBS = $(smpload01_LDLIBS)
+smpload01$(EXEEXT): $(smpload01_OBJECTS) $(smpload01_DEPENDENCIES)
+ @rm -f smpload01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpload01/init.c b/testsuites/smptests/smpload01/init.c
index 0000000..b33dd63
--- /dev/null
+++ b/testsuites/smptests/smpload01/init.c
@@ -0,0 +1,137 @@
+ * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include "tmacros.h"
+#include <rtems.h>
+#include <rtems/profiling.h>
+#define CPU_COUNT 32
+struct {
+ rtems_id sema_prio_inherit;
+ rtems_id sema_prio_ceiling;
+} test_context;
+static uint32_t simple_random(uint32_t v)
+ v *= 1664525;
+ v += 1013904223;
+ return v;
+static void worker_task(rtems_task_argument arg)
+ uint32_t v = arg;
+ while (true) {
+ rtems_status_code sc;
+ rtems_id id;
+ v = simple_random(v);
+ if ((v & 0x80000000) != 0) {
+ id = test_context.sema_prio_inherit;
+ } else {
+ id = test_context.sema_prio_ceiling;
+ sc = rtems_semaphore_obtain(id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_task_wake_after(1);
+ sc = rtems_semaphore_release(id);
+static void test(void)
+ uint32_t n = 3 * rtems_smp_get_processor_count();
+ uint32_t i;
+ rtems_id id;
+ sc = rtems_semaphore_create(
+ rtems_build_name('I', 'N', 'H', 'R'),
+ 1,
+ RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY,
+ 0,
+ &test_context.sema_prio_inherit
+ rtems_build_name('C', 'E', 'I', 'L'),
+ 1,
+ RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_PRIORITY_CEILING,
+ 2,
+ &test_context.sema_prio_ceiling
+ for (i = 0; i < n; ++i) {
+ sc = rtems_task_create(
+ rtems_build_name('W', 'O', 'R', 'K'),
+ 3 + i,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &id
+ sc = rtems_task_start(id, worker_task, i);
+ sc = rtems_task_wake_after(10 * rtems_clock_get_ticks_per_second());
+ rtems_profiling_report_xml("SMPLOAD 1", rtems_printf_plugin, NULL, 1, " ");
+static void Init(rtems_task_argument arg)
+ puts("\n\n*** TEST SMPLOAD 1 ***");
+ test();
+ puts("*** END OF TEST SMPLOAD 1 ***");
+ rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_MAXIMUM_TASKS (1 + 3 * CPU_COUNT)
+#define CONFIGURE_MAXIMUM_SEMAPHORES 2
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpload01/smpload01.doc b/testsuites/smptests/smpload01/smpload01.doc
index 0000000..9777502
--- /dev/null
+++ b/testsuites/smptests/smpload01/smpload01.doc
@@ -0,0 +1,13 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpload01
+directives:
+ - rtems_semaphore_obtain()
+ - rtems_semaphore_release()
+ - rtems_profiling_report_xml()
+concepts:
+ - Produce some system load to get profiling data samples.
diff --git a/testsuites/smptests/smpload01/smpload01.scn b/testsuites/smptests/smpload01/smpload01.scn
index 0000000..901ef48
--- /dev/null
+++ b/testsuites/smptests/smpload01/smpload01.scn
@@ -0,0 +1,160 @@
+*** TEST SMPLOAD 1 ***
+ <ProfilingReport name="SMPLOAD 1">
+ <PerCPUProfilingReport processorIndex="0">
+ <MaxThreadDispatchDisabledTime unit="ns">74045</MaxThreadDispatchDisabledTime>
+ <ThreadDispatchDisabledCount>4623</ThreadDispatchDisabledCount>
+ <TotalThreadDispatchDisabledTime unit="ns">150714575</TotalThreadDispatchDisabledTime>
+ <MaxInterruptTime unit="ns">148430</MaxInterruptTime>
+ <MaxInterruptDelay unit="ns">9340</MaxInterruptDelay>
+ <InterruptCount>1224</InterruptCount>
+ <TotalInterruptTime unit="ns">85229435</TotalInterruptTime>
+ </PerCPUProfilingReport>
+ <PerCPUProfilingReport processorIndex="1">
+ <MaxThreadDispatchDisabledTime unit="ns">125580</MaxThreadDispatchDisabledTime>
+ <ThreadDispatchDisabledCount>3617</ThreadDispatchDisabledCount>
+ <TotalThreadDispatchDisabledTime unit="ns">116537550</TotalThreadDispatchDisabledTime>
+ <MaxInterruptTime unit="ns">7005</MaxInterruptTime>
+ <MaxInterruptDelay unit="ns">0</MaxInterruptDelay>
+ <InterruptCount>890</InterruptCount>
+ <TotalInterruptTime unit="ns">3334960</TotalInterruptTime>
+ <PerCPUProfilingReport processorIndex="2">
+ <MaxThreadDispatchDisabledTime unit="ns">103430</MaxThreadDispatchDisabledTime>
+ <ThreadDispatchDisabledCount>3627</ThreadDispatchDisabledCount>
+ <TotalThreadDispatchDisabledTime unit="ns">118006025</TotalThreadDispatchDisabledTime>
+ <MaxInterruptTime unit="ns">7585</MaxInterruptTime>
+ <InterruptCount>958</InterruptCount>
+ <TotalInterruptTime unit="ns">3393735</TotalInterruptTime>
+ <PerCPUProfilingReport processorIndex="3">
+ <MaxThreadDispatchDisabledTime unit="ns">205635</MaxThreadDispatchDisabledTime>
+ <ThreadDispatchDisabledCount>3802</ThreadDispatchDisabledCount>
+ <TotalThreadDispatchDisabledTime unit="ns">117862825</TotalThreadDispatchDisabledTime>
+ <MaxInterruptTime unit="ns">10530</MaxInterruptTime>
+ <InterruptCount>875</InterruptCount>
+ <TotalInterruptTime unit="ns">3463700</TotalInterruptTime>
+ <SMPLockProfilingReport name="SMP lock stats">
+ <MaxSectionTime unit="ns">18200</MaxSectionTime>
+ <MaxAcquireTime unit="ns">7795</MaxAcquireTime>
+ <UsageCount>13</UsageCount>
+ <TotalSectionTime unit="ns">58680</TotalSectionTime>
+ <ContentionCount initialQueueLength="0">13</ContentionCount>
+ <ContentionCount initialQueueLength="1">0</ContentionCount>
+ <ContentionCount initialQueueLength="2">0</ContentionCount>
+ <ContentionCount initialQueueLength="3">0</ContentionCount>
+ </SMPLockProfilingReport>
+ <SMPLockProfilingReport name="LEON3 IrqCtrl">
+ <MaxSectionTime unit="ns">3770</MaxSectionTime>
+ <MaxAcquireTime unit="ns">2525</MaxAcquireTime>
+ <UsageCount>3</UsageCount>
+ <TotalSectionTime unit="ns">11275</TotalSectionTime>
+ <ContentionCount initialQueueLength="0">3</ContentionCount>
+ <SMPLockProfilingReport name="per-CPU state">
+ <MaxSectionTime unit="ns">16100</MaxSectionTime>
+ <MaxAcquireTime unit="ns">63635</MaxAcquireTime>
+ <UsageCount>12</UsageCount>
+ <TotalSectionTime unit="ns">77005</TotalSectionTime>
+ <ContentionCount initialQueueLength="0">7</ContentionCount>
+ <ContentionCount initialQueueLength="1">4</ContentionCount>
+ <ContentionCount initialQueueLength="2">1</ContentionCount>
+ <SMPLockProfilingReport name="per-CPU">
+ <MaxSectionTime unit="ns">76675</MaxSectionTime>
+ <MaxAcquireTime unit="ns">19785</MaxAcquireTime>
+ <UsageCount>5807</UsageCount>
+ <TotalSectionTime unit="ns">79800345</TotalSectionTime>
+ <ContentionCount initialQueueLength="0">5310</ContentionCount>
+ <ContentionCount initialQueueLength="1">497</ContentionCount>
+ <MaxSectionTime unit="ns">136635</MaxSectionTime>
+ <MaxAcquireTime unit="ns">35115</MaxAcquireTime>
+ <UsageCount>5008</UsageCount>
+ <TotalSectionTime unit="ns">67661840</TotalSectionTime>
+ <ContentionCount initialQueueLength="0">4444</ContentionCount>
+ <ContentionCount initialQueueLength="1">564</ContentionCount>
+ <MaxSectionTime unit="ns">79230</MaxSectionTime>
+ <MaxAcquireTime unit="ns">18320</MaxAcquireTime>
+ <UsageCount>5674</UsageCount>
+ <TotalSectionTime unit="ns">76243665</TotalSectionTime>
+ <ContentionCount initialQueueLength="0">5168</ContentionCount>
+ <ContentionCount initialQueueLength="1">506</ContentionCount>
+ <MaxSectionTime unit="ns">89215</MaxSectionTime>
+ <MaxAcquireTime unit="ns">19530</MaxAcquireTime>
+ <UsageCount>4226</UsageCount>
+ <TotalSectionTime unit="ns">49347540</TotalSectionTime>
+ <ContentionCount initialQueueLength="0">3521</ContentionCount>
+ <ContentionCount initialQueueLength="1">705</ContentionCount>
+ <SMPLockProfilingReport name="Giant">
+ <MaxSectionTime unit="ns">233360</MaxSectionTime>
+ <MaxAcquireTime unit="ns">192160</MaxAcquireTime>
+ <UsageCount>9281</UsageCount>
+ <TotalSectionTime unit="ns">464815740</TotalSectionTime>
+ <ContentionCount initialQueueLength="0">2480</ContentionCount>
+ <ContentionCount initialQueueLength="1">3893</ContentionCount>
+ <ContentionCount initialQueueLength="2">2201</ContentionCount>
+ <ContentionCount initialQueueLength="3">707</ContentionCount>
+ <SMPLockProfilingReport name="chains">
+ <MaxSectionTime unit="ns">10750</MaxSectionTime>
+ <MaxAcquireTime unit="ns">4175</MaxAcquireTime>
+ <TotalSectionTime unit="ns">34130</TotalSectionTime>
+ <ContentionCount initialQueueLength="0">12</ContentionCount>
+ <SMPLockProfilingReport name="TOD">
+ <MaxSectionTime unit="ns">15985</MaxSectionTime>
+ <MaxAcquireTime unit="ns">7080</MaxAcquireTime>
+ <UsageCount>11335</UsageCount>
+ <TotalSectionTime unit="ns">37367415</TotalSectionTime>
+ <ContentionCount initialQueueLength="0">11270</ContentionCount>
+ <ContentionCount initialQueueLength="1">65</ContentionCount>
+ <SMPLockProfilingReport name="mount table entry">
+ <MaxSectionTime unit="ns">4780</MaxSectionTime>
+ <MaxAcquireTime unit="ns">2680</MaxAcquireTime>
+ <UsageCount>43</UsageCount>
+ <TotalSectionTime unit="ns">75125</TotalSectionTime>
+ <ContentionCount initialQueueLength="0">43</ContentionCount>
+ <SMPLockProfilingReport name="constructor">
+ <MaxSectionTime unit="ns">11910</MaxSectionTime>
+ <MaxAcquireTime unit="ns">9110</MaxAcquireTime>
+ <UsageCount>1</UsageCount>
+ <TotalSectionTime unit="ns">11910</TotalSectionTime>
+ <ContentionCount initialQueueLength="0">1</ContentionCount>
+ </ProfilingReport>
+*** END OF TEST SMPLOAD 1 ***
1.7.7
