psxtests/psxkey08 failure
Joel Sherrill
Joel.Sherrill at OARcorp.com
Mon Mar 10 14:50:03 UTC 2014
On Mar 10, 2014 9:32 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 2014-03-10 15:23, Joel Sherrill wrote:
> > On Mar 10, 2014 8:14 AM, Sebastian Huber <sebastian.huber at embedded-brains.de>
> > wrote:
> > > On 2014-03-10 14:04, Joel Sherrill wrote:
> > > > On Mar 10, 2014 7:57 AM, Sebastian Huber <sebastian.huber at embedded-brains.de>
> > > > wrote:
> > > > > Hello,
> > > > > this test fails now on SIS with debugging enabled:
> > > > > *** TEST KEY 08 ***
> > > > > Init - Semaphore 1 create - OK
> > > > > Init - Semaphore 2 create - OK
> > > > > Init - pthread Key create - OK
> > ../../../../../../../rtems/c/src/../../testsuites/psxtests/psxkey08/init.c: 93
> > > > > task_id_p
> > > > Grrr.. I will try to look at it today. Any obvious code conversion mistake?
> > > I fixed some obvious thread affinity bugs, but this one exceeded my time limit
> > > for today.
> > What configuration is this failing in? I tried with --enable-rtems-debug and
> > POSIX enabled and disabled. Both builds ran fine.
> > My tree doesn't have any patches newer than the one where I enabled keys in all
> > configurations.
> That is with --enable-rtems-debug --enable-smp?
Ok. Was testing with SMP disabled. Wonder what impact that could have.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140310/42ed912f/attachment-0001.html>
