[PATCH 03/11] sapi: Add per-CPU profiling application level data
Gedare Bloom
gedare at rtems.org
Tue Mar 11 12:51:35 UTC 2014
On Tue, Mar 11, 2014 at 4:04 AM, Sebastian Huber
> On 2014-03-10 16:44, Gedare Bloom wrote:
>> On Mon, Mar 10, 2014 at 9:28 AM, Sebastian Huber
>>> cpukit/sapi/include/rtems/profiling.h | 83
>>> cpukit/sapi/src/profilingreportxml.c | 89
>>> testsuites/sptests/spprofiling01/spprofiling01.scn | 10 ++-
>>> 3 files changed, 181 insertions(+), 1 deletions(-)
>>> diff --git a/cpukit/sapi/include/rtems/profiling.h
>>> b/cpukit/sapi/include/rtems/profiling.h
>>> index ee56a03..ecb3ff7 100644
>>> --- a/cpukit/sapi/include/rtems/profiling.h
>>> +++ b/cpukit/sapi/include/rtems/profiling.h
>>> @@ -61,6 +61,12 @@ extern "C" {
>>> * @brief Type of profiling data.
>>> typedef enum {
>>> + * @brief Type of per-CPU profiling data.
>>> + * @see rtems_profiling_per_cpu.
>>> + RTEMS_PROFILING_PER_CPU
>>> } rtems_profiling_type;
>>> @@ -74,6 +80,78 @@ typedef struct {
>>> } rtems_profiling_header;
>>> + * @brief Per-CPU profiling data.
>>> +typedef struct {
>>> + * @brief The profiling data header.
>>> + rtems_profiling_header header;
>>> + * @brief The processor index of this profiling data.
>>> + uint32_t processor_index;
>>> + * @brief The maximum time of disabled thread dispatching in
>>> nanoseconds.
>>> + uint32_t max_thread_dispatch_disabled_time;
>> I suppose it is safe to assume the max is less than 4 seconds...
> Yes.
>>> + * @brief Count of times when the thread dispatch disable level
>>> changes from
>>> + * zero to one in thread context.
>>> + * This value may overflow.
>>> + uint64_t thread_dispatch_disabled_count;
>>> + * @brief Total time of disabled thread dispatching in nanoseconds.
>>> + * The average time of disabled thread dispatching is the total time
>>> of
>>> + * disabled thread dispatching divided by the thread dispatch disabled
>>> + * count.
>>> + uint64_t total_thread_dispatch_disabled_time;
>> Is there any option to check for such overflow conditions? It might be
>> good to state the conditions under which the overflow may occur. I
>> don't think overflow is likely for most systems...
> If you have an 1GHz CPU counter, then this can overflow in 58 years. Since
> the system shouldn't spend most of the time in critical sections this is
> much longer. This comment is just a warning.
>>> + * @brief The maximum interrupt delay in nanoseconds if supported by
>>> the
>>> + * hardware.
>>> + uint32_t max_interrupt_delay;
>> How does an application tell whether the HW supports this one or not?
>> What does this measure exactly? My guess would be the time from the
>> interrupt signal arriving to the jump to ISR, thus giving the maximum
>> worst-case interrupt response time.
> Ok, I try to clarify this. Your guess is right. What about:
> * @brief The maximum interrupt delay in nanoseconds if supported by the
> * hardware.
> * The interrupt delay is the time interval from the recognition of an
> * interrupt signal by the hardware up to the execution start of the
> * corresponding high-level handler. The interrupt delay is the main
> * contributor to the interrupt latency. To measure this time hardware
> * support is required. A time stamp unit must capture the interrupt
> signal
> * recognition time. If no hardware support is available, then this field
> * will have a constant value of zero.
Yes, this is much better.
>>> + * @brief The maximum time spent to process a single sequence of
>>> nested
>>> + * interrupts in nanoseconds.
>>> + * This is the time interval between the change of the interrupt nest
>>> level
>>> + * from zero to one and the change back from one to zero.
>>> + uint32_t max_interrupt_time;
>> Is this the measured worst-case execution time for ISRs ?
> * @brief The maximum time spent to process a single sequence of nested
> level
> * from zero to one and the change back from one to zero. It is the
> measured
> * worst-case execution time of interrupt service routines. Please note
> that
> * in case of nested interrupts this time includes the combined execution
> * time and not the maximum time of an individual interrupt service
> routine.
Thanks for clarifying.
>>> + * @brief Count of times when the interrupt nest level changes from
>>> zero to
>>> + * one.
>>> + uint64_t interrupt_count;
>> Can this value realistically overflow?
> No.
>>> + * @brief Total time of interrupt processing in nanoseconds.
>>> + * The average time of interrupt processing is the total time of
>>> interrupt
>>> + * processing divided by the interrupt count.
>>> + uint64_t total_interrupt_time;
>> Again, it might be good to state the conditions under which the
>> overflow may occur.
> Ok:
> * Theoretically all values in this structure can overflow, but the integer
> * types are chosen so that they cannot overflow in practice. On systems
> with
> * a 1GHz CPU counter, the 64-bit integers can overflow in about 58 years.
> * Since the system should not spend most of the time in critical sections
> the
> * actual system run-time is much longer. Several other counters in the
> system
> * will overflow before we get a problem in the profiling area.
Great,
Gedare
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
