[PATCH 02/11] sapi: Add profiling application level support
Sebastian Huber
Tue Mar 11 13:46:42 UTC 2014
cpukit/sapi/Makefile.am | 3 +
cpukit/sapi/include/rtems/profiling.h | 148 ++++++++++++++++++++
cpukit/sapi/preinstall.am | 4 +
cpukit/sapi/src/profilingiterate.c | 26 ++++
cpukit/sapi/src/profilingreportxml.c | 96 +++++++++++++
testsuites/sptests/Makefile.am | 1 +
testsuites/sptests/configure.ac | 1 +
testsuites/sptests/spprofiling01/Makefile.am | 19 +++
testsuites/sptests/spprofiling01/init.c | 63 +++++++++
testsuites/sptests/spprofiling01/spprofiling01.doc | 11 ++
testsuites/sptests/spprofiling01/spprofiling01.scn | 5 +
11 files changed, 377 insertions(+), 0 deletions(-)
create mode 100644 cpukit/sapi/include/rtems/profiling.h
create mode 100644 cpukit/sapi/src/profilingiterate.c
create mode 100644 cpukit/sapi/src/profilingreportxml.c
create mode 100644 testsuites/sptests/spprofiling01/Makefile.am
create mode 100644 testsuites/sptests/spprofiling01/init.c
create mode 100644 testsuites/sptests/spprofiling01/spprofiling01.doc
create mode 100644 testsuites/sptests/spprofiling01/spprofiling01.scn
diff --git a/cpukit/sapi/Makefile.am b/cpukit/sapi/Makefile.am
index 63eb605..19f7d87 100644
--- a/cpukit/sapi/Makefile.am
+++ b/cpukit/sapi/Makefile.am
@@ -14,6 +14,7 @@ include_rtems_HEADERS += include/rtems/init.h
include_rtems_HEADERS += include/rtems/io.h
include_rtems_HEADERS += include/rtems/mptables.h
include_rtems_HEADERS += include/rtems/cbs.h
+include_rtems_HEADERS += include/rtems/profiling.h
include_rtems_HEADERS += include/rtems/rbheap.h
include_rtems_HEADERS += include/rtems/rbtree.h
include_rtems_HEADERS += include/rtems/sptables.h
@@ -36,6 +37,8 @@ libsapi_a_SOURCES += src/chainsmp.c
libsapi_a_SOURCES += src/cpucounterconverter.c
libsapi_a_SOURCES += src/delayticks.c
libsapi_a_SOURCES += src/delaynano.c
+libsapi_a_SOURCES += src/profilingiterate.c
+libsapi_a_SOURCES += src/profilingreportxml.c
libsapi_a_CPPFLAGS = $(AM_CPPFLAGS)
include $(srcdir)/preinstall.am
diff --git a/cpukit/sapi/include/rtems/profiling.h b/cpukit/sapi/include/rtems/profiling.h
new file mode 100644
index 0000000..b2bdf10
--- /dev/null
+++ b/cpukit/sapi/include/rtems/profiling.h
@@ -0,0 +1,148 @@
+ * @file
+ * @ingroup Profiling
+ * @brief Profiling API
+ * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifndef _RTEMS_PROFILING_H
+#define _RTEMS_PROFILING_H
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @defgroup Profiling Profiling Support
+ * @brief The profiling support offers functions to report profiling
+ * information available in the system.
+ * Profiling support is by default disabled. It must be enabled via the
+ * configure command line with the <tt>--enable-profiling</tt> option. In this
+ * case the RTEMS_PROFILING pre-processor symbol is defined and profiling
+ * statistics will be gathered during system run-time. The profiling support
+ * increases the time of critical sections and has some memory overhead. The
+ * overhead should be acceptable for most applications. The aim of the
+ * profiling implementation is to be available even for production systems so
+ * that verification is simplified.
+ * Profiling information includes critical timing values such as the maximum
+ * time of disabled thread dispatching which is a measure for the thread
+ * dispatch latency. On SMP configurations statistics of all SMP locks in the
+ * system are available.
+ * Profiling information can be retrieved via rtems_profiling_iterate() and
+ * reported as an XML dump via rtems_profiling_report_xml(). These functions
+ * are always available, but actual profiling data is only available if enabled
+ * at build configuration time.
+ * @brief Type of profiling data.
+typedef enum {
+} rtems_profiling_type;
+ * @brief The profiling data header.
+typedef struct {
+ * @brief The profiling data type.
+ rtems_profiling_type type;
+} rtems_profiling_header;
+ * @brief Collection of profiling data.
+typedef union {
+ * @brief Header to specify the actual profiling data.
+ rtems_profiling_header header;
+} rtems_profiling_data;
+ * @brief Visitor function for the profiling iteration.
+ * @param[in, out] arg The visitor argument.
+ * @param[in] data The current profiling data.
+ * @see rtems_profiling_iterate().
+typedef void (*rtems_profiling_visitor)(
+ void *arg,
+ const rtems_profiling_data *data
+ * @brief Iterates through all profiling data of the system.
+ * @param[in] visitor The visitor.
+ * @param[in, out] visitor_arg The visitor argument.
+void rtems_profiling_iterate(
+ rtems_profiling_visitor visitor,
+ void *visitor_arg
+ * @brief Function for formatted output.
+ * @param[in, out] arg Some argument.
+ * @param[in] format The output format as specified by printf().
+ * @param[in] ... More parameters according to format.
+ * @returns As specified by printf().
+ * @see rtems_profiling_report_xml().
+typedef int (*rtems_profiling_printf)(void *arg, const char *format, ...);
+ * @brief Reports profiling data as XML.
+ * @param[in] name The name of the profiling report.
+ * @param[in] printf_func The formatted output function.
+ * @param[in, out] printf_arg The formatted output function argument.
+ * @param[in] indentation_level The current indentation level.
+ * @param[in] indentation The string used for indentation.
+int rtems_profiling_report_xml(
+ const char *name,
+ rtems_profiling_printf printf_func,
+ void *printf_arg,
+ uint32_t indentation_level,
+ const char *indentation
+#ifdef __cplusplus
+#endif /* _RTEMS_PROFILING_H */
diff --git a/cpukit/sapi/preinstall.am b/cpukit/sapi/preinstall.am
index 79eceef..d05ab25 100644
--- a/cpukit/sapi/preinstall.am
+++ b/cpukit/sapi/preinstall.am
@@ -72,6 +72,10 @@ $(PROJECT_INCLUDE)/rtems/cbs.h: include/rtems/cbs.h $(PROJECT_INCLUDE)/rtems/$(d
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/cbs.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/cbs.h
+$(PROJECT_INCLUDE)/rtems/profiling.h: include/rtems/profiling.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/profiling.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/profiling.h
$(PROJECT_INCLUDE)/rtems/rbheap.h: include/rtems/rbheap.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/rbheap.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/rbheap.h
diff --git a/cpukit/sapi/src/profilingiterate.c b/cpukit/sapi/src/profilingiterate.c
index 0000000..e528932
--- /dev/null
+++ b/cpukit/sapi/src/profilingiterate.c
@@ -0,0 +1,26 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#ifdef HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/profiling.h>
+ void *visitor_arg
diff --git a/cpukit/sapi/src/profilingreportxml.c b/cpukit/sapi/src/profilingreportxml.c
index 0000000..d3fe7f7
--- /dev/null
+++ b/cpukit/sapi/src/profilingreportxml.c
@@ -0,0 +1,96 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#endif
+#ifdef RTEMS_PROFILING
+typedef struct {
+ rtems_profiling_printf printf_func;
+ void *printf_arg;
+ uint32_t indentation_level;
+ const char *indentation;
+ int retval;
+} context;
+static void update_retval(context *ctx, int rv)
+ if (rv > 0 && ctx->retval >= 0) {
+ ctx->retval += rv;
+static void indent(context *ctx, uint32_t indentation_level)
+ uint32_t n = ctx->indentation_level + indentation_level;
+ uint32_t i;
+ for (i = 0; i < n; ++i) {
+ int rv = (*ctx->printf_func)(ctx->printf_arg, "%s", ctx->indentation);
+ update_retval(ctx, rv);
+static void report(void *arg, const rtems_profiling_data *data)
+ context *ctx = arg;
+#endif /* RTEMS_PROFILING */
+ const char *name,
+ void *printf_arg,
+ context ctx_instance = {
+ .printf_func = printf_func,
+ .printf_arg = printf_arg,
+ .indentation_level = indentation_level,
+ .indentation = indentation,
+ .retval = 0
+ context *ctx = &ctx_instance;
+ int rv;
+ indent(ctx, 0);
+ rv = (*printf_func)(printf_arg, "<ProfilingReport name=\"%s\">\n", name);
+ rtems_profiling_iterate(report, ctx);
+ indent(ctx, 0);
+ rv = (*printf_func)(printf_arg, "</ProfilingReport>\n");
+ return ctx->retval;
+#else /* RTEMS_PROFILING */
+ (void) name;
+ (void) printf_func;
+ (void) printf_arg;
+ (void) indentation_level;
+ (void) indentation;
+ return 0;
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 3aa1330..d57ae69 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -30,6 +30,7 @@ SUBDIRS = \
spsimplesched03 spnsext01 spedfsched01 spedfsched02 spedfsched03 \
spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
spregion_err01 sppartition_err01
+SUBDIRS += spprofiling01
SUBDIRS += spcache01
SUBDIRS += sptls03
SUBDIRS += spcpucounter01
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index fe9f816..5f98ba7 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -36,6 +36,7 @@ AM_CONDITIONAL(HAS_CPUSET,test x"${ac_cv_header_sys_cpuset_h}" = x"yes")
# Explicitly list all Makefiles here
AC_CONFIG_FILES([Makefile
+spprofiling01/Makefile
spcache01/Makefile
sptls03/Makefile
spcpucounter01/Makefile
diff --git a/testsuites/sptests/spprofiling01/Makefile.am b/testsuites/sptests/spprofiling01/Makefile.am
index 0000000..872e50a
--- /dev/null
+++ b/testsuites/sptests/spprofiling01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spprofiling01
+spprofiling01_SOURCES = init.c
+dist_rtems_tests_DATA = spprofiling01.scn spprofiling01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spprofiling01_OBJECTS)
+LINK_LIBS = $(spprofiling01_LDLIBS)
+spprofiling01$(EXEEXT): $(spprofiling01_OBJECTS) $(spprofiling01_DEPENDENCIES)
+ @rm -f spprofiling01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spprofiling01/init.c b/testsuites/sptests/spprofiling01/init.c
index 0000000..a1af66b
--- /dev/null
+++ b/testsuites/sptests/spprofiling01/init.c
@@ -0,0 +1,63 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#endif
+#include <rtems/bspIo.h>
+#include <rtems.h>
+#include <stdio.h>
+#include "tmacros.h"
+static void test(void)
+ rtems_status_code sc;
+ int rv;
+ sc = rtems_task_wake_after(3);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ rv = rtems_profiling_report_xml("X", rtems_printf_plugin, NULL, 1, " ");
+ printf("characters produced by rtems_profiling_report_xml(): %i\n", rv);
+static void Init(rtems_task_argument arg)
+ puts("\n\n*** TEST SPPROFILING 1 ***");
+ test();
+ puts("*** END OF TEST SPPROFILING 1 ***");
+ rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spprofiling01/spprofiling01.doc b/testsuites/sptests/spprofiling01/spprofiling01.doc
index 0000000..2614c64
--- /dev/null
+++ b/testsuites/sptests/spprofiling01/spprofiling01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spprofiling01
+directives:
+ - rtems_profiling_report_xml()
+concepts:
+ - Ensure that rtems_profiling_report_xml() yields the expected output.
diff --git a/testsuites/sptests/spprofiling01/spprofiling01.scn b/testsuites/sptests/spprofiling01/spprofiling01.scn
index 0000000..2c289db
--- /dev/null
+++ b/testsuites/sptests/spprofiling01/spprofiling01.scn
@@ -0,0 +1,5 @@
+*** TEST SPPROFILING 1 ***
+ <ProfilingReport name="X">
+ </ProfilingReport>
+characters produced by rtems_profiling_report_xml(): 50
+*** END OF TEST SPPROFILING 1 ***
1.7.7
