[PATCH 08/11] bsps/leon3: Add interrupt delay profiling support
Sebastian Huber
Tue Mar 11 13:46:48 UTC 2014
c/src/lib/libbsp/sparc/leon3/clock/ckinit.c | 39 ++++++++++++++++++++++++++-
1 files changed, 38 insertions(+), 1 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
index d2aae23..136499e 100644
--- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
@@ -21,6 +21,7 @@
#include <bsp.h>
#include <bspopts.h>
#include <ambapp.h>
+#include <rtems/score/profiling.h>
#if SIMSPARC_FAST_IDLE==1
#define CLOCK_DRIVER_USE_FAST_IDLE 1
@@ -35,7 +36,43 @@ static int clkirq;
#define CLOCK_VECTOR LEON_TRAP_TYPE( clkirq )
-#define Clock_driver_support_at_tick()
+static void leon3_clock_profiling_interrupt_delay(void)
+#ifdef RTEMS_PROFILING
+ * We need a small state machine to ignore the first clock interrupt, since
+ * it contains the sequential system initialization time. Do the timestamp
+ * initialization on the fly.
+ static int state = 1;
+ volatile struct irqmp_timestamp_regs *irqmp_ts =
+ &LEON3_IrqCtrl_Regs->timestamp[0];
+ unsigned int s1_s2 = (1U << 25) | (1U << 26);
+ if (state == 0) {
+ unsigned int first = irqmp_ts->assertion;
+ unsigned int second = irqmp_ts->counter;
+ irqmp_ts->control |= s1_s2;
+ _Profiling_Update_max_interrupt_delay(_Per_CPU_Get(), second - first);
+ } else if (state == 1 && leon3_irqmp_has_timestamp(irqmp_ts)) {
+ unsigned int ks = 1U << 5;
+ state = 0;
+ irqmp_ts->control = ks | s1_s2 | (unsigned int) clkirq;
+ } else if (state == 1) {
+ state = 2;
+#endif
+#define Clock_driver_support_at_tick() \
+ do { \
+ leon3_clock_profiling_interrupt_delay(); \
+ } while (0)
#if defined(RTEMS_MULTIPROCESSING)
#define Adjust_clkirq_for_node() \
1.7.7
