[PATCH 04/11] sapi: Add SMP lock profiling app. level data
Sebastian Huber
Tue Mar 11 13:46:44 UTC 2014
cpukit/sapi/include/rtems/profiling.h | 99 ++++++++++++++++++++++++++++++++-
cpukit/sapi/src/profilingreportxml.c | 78 ++++++++++++++++++++++++++
2 files changed, 176 insertions(+), 1 deletions(-)
diff --git a/cpukit/sapi/include/rtems/profiling.h b/cpukit/sapi/include/rtems/profiling.h
index 3bc5921..133d164 100644
--- a/cpukit/sapi/include/rtems/profiling.h
+++ b/cpukit/sapi/include/rtems/profiling.h
@@ -66,7 +66,14 @@ typedef enum {
* @see rtems_profiling_per_cpu.
- RTEMS_PROFILING_PER_CPU
+ RTEMS_PROFILING_PER_CPU,
+ * @brief Type of SMP lock profiling data.
+ * @see rtems_profiling_smp_lock.
+ RTEMS_PROFILING_SMP_LOCK
} rtems_profiling_type;
@@ -170,6 +177,91 @@ typedef struct {
} rtems_profiling_per_cpu;
+ * @brief Count of lock contention counters for SMP lock profiling.
+#define RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS 4
+ * @brief SMP lock profiling data.
+ * The lock acquire attempt instant is the point in time right after the
+ * interrupt disable action in the lock acquire sequence.
+ * The lock acquire instant is the point in time right after the lock
+ * acquisition. This is the begin of the critical section code execution.
+ * The lock acquire time is the time elapsed between the lock acquire attempt
+ * instant and the lock acquire instant.
+ * The lock release instant is the point in time right before the interrupt
+ * enable action in the lock release sequence.
+ * The lock section time is the time elapsed between the lock acquire instant
+ * and the lock release instant.
+typedef struct {
+ * @brief The profiling data header.
+ rtems_profiling_header header;
+ * @brief The lock name.
+ const char *name;
+ * @brief The maximum lock acquire time in nanoseconds.
+ uint32_t max_acquire_time;
+ * @brief The maximum lock section time in nanoseconds.
+ uint32_t max_section_time;
+ * @brief The count of lock uses.
+ * This value may overflow.
+ uint64_t usage_count;
+ * @brief Total lock acquire time in nanoseconds.
+ * The average lock acquire time is the total acquire time divided by the
+ * lock usage count. The ration of the total section and total acquire times
+ * gives a measure for the lock contention.
+ uint64_t total_acquire_time;
+ * @brief Total lock section time in nanoseconds.
+ * The average lock section time is the total section time divided by the
+ uint64_t total_section_time;
+ * @brief The counts of lock acquire operations by contention.
+ * The contention count for index N corresponds to a lock acquire attempt
+ * with an initial queue length of N. The last index corresponds to all
+ * lock acquire attempts with an initial queue length greater than or equal
+ * to RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS minus one.
+ * The values may overflow.
+ uint64_t contention_counts[RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS];
+} rtems_profiling_smp_lock;
* @brief Collection of profiling data.
typedef union {
@@ -182,6 +274,11 @@ typedef union {
* @brief Per-CPU profiling data if indicated by the header.
rtems_profiling_per_cpu per_cpu;
+ * @brief SMP lock profiling data if indicated by the header.
+ rtems_profiling_smp_lock smp_lock;
} rtems_profiling_data;
diff --git a/cpukit/sapi/src/profilingreportxml.c b/cpukit/sapi/src/profilingreportxml.c
index 409fe3d..8ca6971 100644
--- a/cpukit/sapi/src/profilingreportxml.c
+++ b/cpukit/sapi/src/profilingreportxml.c
@@ -130,6 +130,81 @@ static void report_per_cpu(context *ctx, const rtems_profiling_per_cpu *per_cpu)
update_retval(ctx, rv);
+static void report_smp_lock(context *ctx, const rtems_profiling_smp_lock *smp_lock)
+ rtems_profiling_printf printf_func = ctx->printf_func;
+ void *printf_arg = ctx->printf_arg;
+ int rv;
+ uint32_t i;
+ indent(ctx, 1);
+ rv = (*printf_func)(
+ printf_arg,
+ "<SMPLockProfilingReport name=\"%s\">\n",
+ smp_lock->name
+ update_retval(ctx, rv);
+ indent(ctx, 2);
+ printf_arg,
+ "<MaxAcquireTime unit=\"ns\">%" PRIu32 "</MaxAcquireTime>\n",
+ smp_lock->max_acquire_time
+ indent(ctx, 2);
+ printf_arg,
+ "<MaxSectionTime unit=\"ns\">%" PRIu32 "</MaxSectionTime>\n",
+ smp_lock->max_section_time
+ indent(ctx, 2);
+ printf_arg,
+ "<UsageCount>%" PRIu64 "</UsageCount>\n",
+ smp_lock->usage_count
+ indent(ctx, 2);
+ printf_arg,
+ "<TotalAcquireTime unit=\"ns\">%" PRIu64 "</TotalAcquireTime>\n",
+ smp_lock->total_acquire_time
+ indent(ctx, 2);
+ printf_arg,
+ "<TotalSectionTime unit=\"ns\">%" PRIu64 "</TotalSectionTime>\n",
+ smp_lock->total_section_time
+ for (i = 0; i < RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS; ++i) {
+ indent(ctx, 2);
+ printf_arg,
+ "<ContentionCount initialQueueLength=\"%" PRIu32 "\">%"
+ PRIu64 "</ContentionCount>\n",
+ i,
+ smp_lock->contention_counts[i]
+ indent(ctx, 1);
+ printf_arg,
+ "</SMPLockProfilingReport>\n"
static void report(void *arg, const rtems_profiling_data *data)
context *ctx = arg;
@@ -138,6 +213,9 @@ static void report(void *arg, const rtems_profiling_data *data)
case RTEMS_PROFILING_PER_CPU:
report_per_cpu(ctx, &data->per_cpu);
break;
+ case RTEMS_PROFILING_SMP_LOCK:
+ report_smp_lock(ctx, &data->smp_lock);
+ break;
1.7.7
