Empty inline functions vs. empty CPP macros
Tue Mar 11 14:11:49 UTC 2014
Empty static inlines normally optimize away. So no worries there.
I always prefer static inlines over macros.
Do you have specific example? There are places this may work but
others that it cannot.
--joel
On 3/11/2014 8:01 AM, Gedare Bloom wrote:
> On Tue, Mar 11, 2014 at 4:47 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Hello,
>> I would like to add a new section to the RTEMS coding style.  How do we want
>> to deal with features available only in case certain pre-processor symbols
>> are defined?  For example
>> #define FEATURE_X
>> 1:
>> static inline feature_x_func(int a, double b, void *c)
>> #ifdef FEATURE_X
>>   /* Do something */
>> #else
>>   (void) a;
>>   (void) b;
>>   (void) c;
>> #endif
>> 2:
>> #ifdef FEATRUE_X
>>   /* Do something */
>> #else
>> #define feature_x_func(a, b, c) do { } while ( 0 )
>> #endif
>> 3:
>> #ifdef FEATRUE_X
>>   /* Do something */
>> #else
>> #define feature_x_func(a, b, c) \
>>   do { (void) *a); (void) (b); (void) (c); } while ( 0 )
>> #endif
>> I am in favor of variant 1. since it has the benefit that type checks are
>> also performed in case feature X is disabled.
> The advantage of checks is a good reason. I don't like option 3.
>> Is the optimization of an empty inline function really a problem for modern
>> compilers?
> If no one knows, it should not take long to write a simple program to check.
>> In 2. we could also use an (for basedefs.h)
>> #define RTEMS_EMTPY_MACRO do { } while ( 0 )
> This option is "cleaner-looking" which is my preference for code
> readability. However the technical advantage of having the same
> function call invocation and thus type checks with option #1 is a good
> reason for it. I'm on the fence at the moment. I would like to get
> resolution about the question of optimizing compilers first.
> If the code size is the same with the two approaches, then I'm fine
> with option 1.
> -Gedare
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
