[PATCH 04/17] bsp/arm: Add linker symbol bsp_processor_count
Sebastian Huber
Thu Mar 13 10:31:00 UTC 2014
On 2014-03-13 01:20, Chris Johns wrote:
> On 4/03/2014 8:47 pm, Ralf Kirchner wrote:
>> Hi Chris,
>> Yes using "enable SMP" sounds like a nice idea.
>> Actually beeing under time pressure I needed a solution which I could
>> get up and running quickly and easily. This is the major reason for the
>> linker command files solution.
>> I am sure the "enable SMP" solution also would be doable but it would
>> have cost me time I did not have.
> Is there plans to address this ?
> My concern is the effect this approach will have on continuous testing time and
> when that is active this approach may be rejected. For example complete
> testing, which we cannot do, would imply we test all combinations of options to
> configure. This is not feasible so we have to limit ourselves to a subset and
> in this case each BSP with and without --enable-smp would be required where a
> single BSP covers both. My point being I suspect the testing system's load and
> performance may have to be given a higher consideration over your time
> allocation and budgeting once it is running and we know the performance and
> loading.
This bsp_processor_count symbol definition is just there to provide a sanity
check. I you use the wrong linker command file, then you use some stack areas
multiple times at once and this is not healthy. Since the ARM uses a lot less
copy and paste compared to other architectures it is easy to change something
if someone has a better solution.
We provide two BSP names so that a user can install two BSP libraries.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
