[PATCH 5/7] bsps/sparc: Make local functions static and add missing prototypes.
Daniel Cederman cederman at gaisler.com
Thu Mar 13 14:19:33 UTC 2014
 c/src/lib/libbsp/sparc/leon2/pci/pci.c            |    4 ++--
 c/src/lib/libbsp/sparc/leon3/pci/pci.c            |    4 ++--
 c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c |   10 ++++++++++
 c/src/lib/libbsp/sparc/shared/can/occan_pci.c     |    2 ++
 c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c     |    6 ++++++
 c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c  |    5 +++++
 6 files changed, 27 insertions(+), 4 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon2/pci/pci.c b/c/src/lib/libbsp/sparc/leon2/pci/pci.c
index 2fdacd1..47284c5 100644
--- a/c/src/lib/libbsp/sparc/leon2/pci/pci.c
+++ b/c/src/lib/libbsp/sparc/leon2/pci/pci.c
@@ -231,7 +231,7 @@ rtems_pci_config_t BSP_pci_configuration = {
-void init_at697_pci(void) {
+static void init_at697_pci(void) {
     /* Reset */
     pcic->pciic = 0xffffffff;
@@ -418,7 +418,7 @@ static inline void swap_res(struct pci_res **p1, struct pci_res **p2) {
-void pci_allocate_resources(void) {
+static void pci_allocate_resources(void) {
     unsigned int slot, numfuncs, func, id, pos, size, tmp, i, swapped, addr, dev, fn;
     unsigned char header;
diff --git a/c/src/lib/libbsp/sparc/leon3/pci/pci.c b/c/src/lib/libbsp/sparc/leon3/pci/pci.c
index a110067..88b577e 100644
--- a/c/src/lib/libbsp/sparc/leon3/pci/pci.c
+++ b/c/src/lib/libbsp/sparc/leon3/pci/pci.c
@@ -223,7 +223,7 @@ rtems_pci_config_t BSP_pci_configuration = {
-int init_grpci(void) {
+static int init_grpci(void) {
     volatile unsigned int *page0 =  (unsigned volatile int *) PCI_MEM_START;
     uint32_t data;
@@ -333,7 +333,7 @@ static inline void swap_res(struct pci_res **p1, struct pci_res **p2) {
     unsigned int slot, numfuncs, func, pos, i, swapped, addr, dev, fn;
     uint32_t id, tmp, size;
diff --git a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
index 3be26b1..25364c9 100644
--- a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
+++ b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
@@ -1,3 +1,6 @@
+#include <ambapp.h>
+#include <b1553brm_pci.h>
 /* Select PCI driver */
 #define B1553BRM_NO_AMBA
 #define B1553BRM_PCI
@@ -73,6 +76,13 @@ void (*b1553brm_pci_int_reg)(void *handler, int irq, void *arg) = 0;
 static void b1553brmpci_interrupt_handler(int irq, void *arg);
+int b1553brmpci_register(
+ struct ambapp_bus *bus,
+ unsigned int clksel,
+ unsigned int clkdiv,
+ unsigned int brm_freq
 #include "b1553brm.c"
diff --git a/c/src/lib/libbsp/sparc/shared/can/occan_pci.c b/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
index a1fecc5..12273c9 100644
--- a/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
+++ b/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
@@ -3,6 +3,8 @@
 #define OCCAN_WORD_REGS
+#include <occan_pci.h>
 /* Set registered device name */
 #define OCCAN_DEVNAME "/dev/occanpci0"
 #define OCCAN_DEVNAME_NO(devstr,no) ((devstr)[13]='0'+(no))
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
index 2a9a8d6..ec3538b 100644
--- a/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
+++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
@@ -1,3 +1,7 @@
+#include <rtems/libio.h>
+#include <grspw_pci.h>
 #define GRSPW_PCI
@@ -70,6 +74,8 @@ static inline unsigned int hw_to_cpu(unsigned int addr) {
 #endif
 int grspwpci_interrupt_handler(int irq, void *arg);
+int grspwpci_register(struct ambapp_bus *bus);
 #include "grspw.c"
diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
index 63cac35..440f8da 100644
--- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
+++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
@@ -1,3 +1,6 @@
+#include <apbuart_pci.h>
 #undef DEBUG
@@ -21,6 +24,8 @@ void apbuartpci_interrupt_handler(int irq, void *arg);
 /* AMBA Bus is clocked using the PCI clock (33.3MHz) */
 #define SYS_FREQ_HZ 33333333
+int apbuartpci_register(struct ambapp_bus *bus);
 #include "apbuart.c"
 int apbuart_pci_register(struct ambapp_bus *bus)
1.7.9.5
