[PATCH 1/7] bsps/sparc: Make local functions for amba plug&play static.
Gedare Bloom
gedare at rtems.org
Thu Mar 13 14:27:29 UTC 2014
OK
On Thu, Mar 13, 2014 at 10:19 AM, Daniel Cederman <cederman at gaisler.com> wrote:
> c/src/lib/libbsp/sparc/shared/amba/ambapp.c | 12 ++++++------
> c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c | 2 +-
> c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c | 1 +
> c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c | 2 +-
> c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c | 5 +----
> 5 files changed, 10 insertions(+), 12 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
> index 504a3e7..7b3ae4a 100644
> --- a/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
> @@ -21,7 +21,7 @@
> #define AMBA_APB_SLAVES 16
> /* Allocate one AMBA device */
> -struct ambapp_dev *ambapp_alloc_dev_struct(int dev_type)
> +static struct ambapp_dev *ambapp_alloc_dev_struct(int dev_type)
> int size = sizeof(struct ambapp_dev);
> struct ambapp_dev *dev;
> @@ -38,7 +38,7 @@ struct ambapp_dev *ambapp_alloc_dev_struct(int dev_type)
> return dev;
> -unsigned int
> +static unsigned int
> ambapp_addr_from (struct ambapp_mmap *mmaps, unsigned int address)
> /* no translation? */
> @@ -55,7 +55,7 @@ ambapp_addr_from (struct ambapp_mmap *mmaps, unsigned int address)
> return 1;
> -void ambapp_ahb_dev_init(
> +static void ambapp_ahb_dev_init(
> unsigned int ioarea,
> struct ambapp_pnp_ahb *ahb,
> @@ -102,7 +102,7 @@ void ambapp_ahb_dev_init(
> -void ambapp_apb_dev_init(
> +static void ambapp_apb_dev_init(
> unsigned int base,
> struct ambapp_pnp_apb *apb,
> @@ -123,7 +123,7 @@ void ambapp_apb_dev_init(
> apb_info->mask = ambapp_pnp_apb_mask(apb->iobar);
> -int ambapp_add_ahbbus(
> +static int ambapp_add_ahbbus(
> struct ambapp_bus *abus,
> unsigned int ioarea
> @@ -298,7 +298,7 @@ int ambapp_scan(
> /* Match search options againt device */
> -int ambapp_dev_match_options(struct ambapp_dev *dev, unsigned int options, int vendor, int device)
> +static int ambapp_dev_match_options(struct ambapp_dev *dev, unsigned int options, int vendor, int device)
> if ((((options & (OPTIONS_ALL_DEVS)) == OPTIONS_ALL_DEVS) || /* TYPE */
> ((options & OPTIONS_AHB_MSTS) && (dev->dev_type == DEV_AHB_MST)) ||
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c
> index 03c0f68..0d18fea 100644
> --- a/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c
> @@ -21,7 +21,7 @@
> * If a unsupported bridge is found the invalid frequncy of 0Hz is
> * returned.
> -unsigned int ambapp_freq_calc(
> +static unsigned int ambapp_freq_calc(
> int ahbidx,
> unsigned int freq_hz,
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c
> index 4a47366..c0a8d63 100644
> --- a/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c
> @@ -12,6 +12,7 @@
> * http://www.rtems.com/license/LICENSE.
> +#include <ambapp.h>
> #include <ambapp_ids.h>
> #include <string.h>
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
> index 15aebe5..5d8212c 100644
> --- a/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
> @@ -19,7 +19,7 @@ struct ambapp_dev_find_match_arg {
> /* AMBA PP find routines */
> -int ambapp_dev_find_match(struct ambapp_dev *dev, int index, void *arg)
> +static int ambapp_dev_find_match(struct ambapp_dev *dev, int index, void *arg)
> struct ambapp_dev_find_match_arg *p = arg;
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c
> index f73ec1d..e4e04fd 100644
> --- a/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c
> @@ -12,16 +12,13 @@
> #include <stdio.h>
> #include <ambapp.h>
> -extern char *ambapp_device_id2str(int vendor, int id);
> -extern char *ambapp_vendor_id2str(int vendor);
> struct ambapp_dev_print_arg {
> int show_depth;
> static char *unknown = "unknown";
> -int ambapp_dev_print(struct ambapp_dev *dev, int index, void *arg)
> +static int ambapp_dev_print(struct ambapp_dev *dev, int index, void *arg)
> char *dev_str, *ven_str, *type_str;
> struct ambapp_dev_print_arg *p = arg;
> 1.7.9.5
> rtems-devel mailing list
> rtems-devel at rtems.org
