[PATCH 5/7] bsps/sparc: Make local functions static and add missing prototypes.
Thu Mar 13 14:30:38 UTC 2014
Looks good to me.
On 3/13/2014 9:19 AM, Daniel Cederman wrote:
>  c/src/lib/libbsp/sparc/leon2/pci/pci.c            |    4 ++--
>  c/src/lib/libbsp/sparc/leon3/pci/pci.c            |    4 ++--
>  c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c |   10 ++++++++++
>  c/src/lib/libbsp/sparc/shared/can/occan_pci.c     |    2 ++
>  c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c     |    6 ++++++
>  c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c  |    5 +++++
>  6 files changed, 27 insertions(+), 4 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon2/pci/pci.c b/c/src/lib/libbsp/sparc/leon2/pci/pci.c
> index 2fdacd1..47284c5 100644
> --- a/c/src/lib/libbsp/sparc/leon2/pci/pci.c
> +++ b/c/src/lib/libbsp/sparc/leon2/pci/pci.c
> @@ -231,7 +231,7 @@ rtems_pci_config_t BSP_pci_configuration = {
> -void init_at697_pci(void) {
> +static void init_at697_pci(void) {
>      /* Reset */
>      pcic->pciic = 0xffffffff;
> @@ -418,7 +418,7 @@ static inline void swap_res(struct pci_res **p1, struct pci_res **p2) {
> -void pci_allocate_resources(void) {
> +static void pci_allocate_resources(void) {
>      unsigned int slot, numfuncs, func, id, pos, size, tmp, i, swapped, addr, dev, fn;
>      unsigned char header;
> diff --git a/c/src/lib/libbsp/sparc/leon3/pci/pci.c b/c/src/lib/libbsp/sparc/leon3/pci/pci.c
> index a110067..88b577e 100644
> --- a/c/src/lib/libbsp/sparc/leon3/pci/pci.c
> +++ b/c/src/lib/libbsp/sparc/leon3/pci/pci.c
> @@ -223,7 +223,7 @@ rtems_pci_config_t BSP_pci_configuration = {
> -int init_grpci(void) {
> +static int init_grpci(void) {
>      volatile unsigned int *page0 =  (unsigned volatile int *) PCI_MEM_START;
>      uint32_t data;
> @@ -333,7 +333,7 @@ static inline void swap_res(struct pci_res **p1, struct pci_res **p2) {
>      unsigned int slot, numfuncs, func, pos, i, swapped, addr, dev, fn;
>      uint32_t id, tmp, size;
> diff --git a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
> index 3be26b1..25364c9 100644
> --- a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
> +++ b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
> @@ -1,3 +1,6 @@
> +#include <ambapp.h>
> +#include <b1553brm_pci.h>
>  /* Select PCI driver */
>  #define B1553BRM_NO_AMBA
>  #define B1553BRM_PCI
> @@ -73,6 +76,13 @@ void (*b1553brm_pci_int_reg)(void *handler, int irq, void *arg) = 0;
>  static void b1553brmpci_interrupt_handler(int irq, void *arg);
> +int b1553brmpci_register(
> + struct ambapp_bus *bus,
> + unsigned int clksel,
> + unsigned int clkdiv,
> + unsigned int brm_freq
>  #include "b1553brm.c"
> diff --git a/c/src/lib/libbsp/sparc/shared/can/occan_pci.c b/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
> index a1fecc5..12273c9 100644
> --- a/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
> +++ b/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
> @@ -3,6 +3,8 @@
>  #define OCCAN_WORD_REGS
> +#include <occan_pci.h>
>  /* Set registered device name */
>  #define OCCAN_DEVNAME "/dev/occanpci0"
>  #define OCCAN_DEVNAME_NO(devstr,no) ((devstr)[13]='0'+(no))
> diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
> index 2a9a8d6..ec3538b 100644
> --- a/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
> +++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
> @@ -1,3 +1,7 @@
> +#include <rtems/libio.h>
> +#include <grspw_pci.h>
>  #define GRSPW_PCI
> @@ -70,6 +74,8 @@ static inline unsigned int hw_to_cpu(unsigned int addr) {
>  #endif
>  int grspwpci_interrupt_handler(int irq, void *arg);
> +int grspwpci_register(struct ambapp_bus *bus);
>  #include "grspw.c"
> diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
> index 63cac35..440f8da 100644
> --- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
> +++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
> @@ -1,3 +1,6 @@
> +#include <apbuart_pci.h>
>  #undef DEBUG
> @@ -21,6 +24,8 @@ void apbuartpci_interrupt_handler(int irq, void *arg);
>  /* AMBA Bus is clocked using the PCI clock (33.3MHz) */
>  #define SYS_FREQ_HZ 33333333
> +int apbuartpci_register(struct ambapp_bus *bus);
>  #include "apbuart.c"
>  int apbuart_pci_register(struct ambapp_bus *bus)
