[PATCH 5/7] bsps/sparc: Make local functions static and add missing prototypes.
Thu Mar 13 15:01:27 UTC 2014
On 3/13/2014 9:26 AM, Gedare Bloom wrote:
> On Thu, Mar 13, 2014 at 10:19 AM, Daniel Cederman <cederman at gaisler.com> wrote:
>>  c/src/lib/libbsp/sparc/leon2/pci/pci.c            |    4 ++--
>>  c/src/lib/libbsp/sparc/leon3/pci/pci.c            |    4 ++--
>>  c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c |   10 ++++++++++
>>  c/src/lib/libbsp/sparc/shared/can/occan_pci.c     |    2 ++
>>  c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c     |    6 ++++++
>>  c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c  |    5 +++++
>>  6 files changed, 27 insertions(+), 4 deletions(-)
>> diff --git a/c/src/lib/libbsp/sparc/leon2/pci/pci.c b/c/src/lib/libbsp/sparc/leon2/pci/pci.c
>> index 2fdacd1..47284c5 100644
>> --- a/c/src/lib/libbsp/sparc/leon2/pci/pci.c
>> +++ b/c/src/lib/libbsp/sparc/leon2/pci/pci.c
>> @@ -231,7 +231,7 @@ rtems_pci_config_t BSP_pci_configuration = {
>> -void init_at697_pci(void) {
>> +static void init_at697_pci(void) {
>>      /* Reset */
>>      pcic->pciic = 0xffffffff;
>> @@ -418,7 +418,7 @@ static inline void swap_res(struct pci_res **p1, struct pci_res **p2) {
>> -void pci_allocate_resources(void) {
>> +static void pci_allocate_resources(void) {
>>      unsigned int slot, numfuncs, func, id, pos, size, tmp, i, swapped, addr, dev, fn;
>>      unsigned char header;
>> diff --git a/c/src/lib/libbsp/sparc/leon3/pci/pci.c b/c/src/lib/libbsp/sparc/leon3/pci/pci.c
>> index a110067..88b577e 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/pci/pci.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/pci/pci.c
>> @@ -223,7 +223,7 @@ rtems_pci_config_t BSP_pci_configuration = {
>> -int init_grpci(void) {
>> +static int init_grpci(void) {
>>      volatile unsigned int *page0 =  (unsigned volatile int *) PCI_MEM_START;
>>      uint32_t data;
>> @@ -333,7 +333,7 @@ static inline void swap_res(struct pci_res **p1, struct pci_res **p2) {
>>      unsigned int slot, numfuncs, func, pos, i, swapped, addr, dev, fn;
>>      uint32_t id, tmp, size;
>> diff --git a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
>> index 3be26b1..25364c9 100644
>> --- a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
>> +++ b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
>> @@ -1,3 +1,6 @@
>> +#include <ambapp.h>
>> +#include <b1553brm_pci.h>
>>  /* Select PCI driver */
>>  #define B1553BRM_NO_AMBA
>>  #define B1553BRM_PCI
>> @@ -73,6 +76,13 @@ void (*b1553brm_pci_int_reg)(void *handler, int irq, void *arg) = 0;
>>  static void b1553brmpci_interrupt_handler(int irq, void *arg);
>> +int b1553brmpci_register(
>> + struct ambapp_bus *bus,
>> + unsigned int clksel,
>> + unsigned int clkdiv,
>> + unsigned int brm_freq
> Why is this .c file declaring (non-static) functions?
And why aren't the arguments indented?
>>  #include "b1553brm.c"
>> diff --git a/c/src/lib/libbsp/sparc/shared/can/occan_pci.c b/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
>> index a1fecc5..12273c9 100644
>> --- a/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
>> +++ b/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
>> @@ -3,6 +3,8 @@
>>  #define OCCAN_WORD_REGS
>> +#include <occan_pci.h>
>>  /* Set registered device name */
>>  #define OCCAN_DEVNAME "/dev/occanpci0"
>>  #define OCCAN_DEVNAME_NO(devstr,no) ((devstr)[13]='0'+(no))
>> diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
>> index 2a9a8d6..ec3538b 100644
>> --- a/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
>> +++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
>> @@ -1,3 +1,7 @@
>> +#include <rtems/libio.h>
>> +#include <grspw_pci.h>
>>  #define GRSPW_PCI
>> @@ -70,6 +74,8 @@ static inline unsigned int hw_to_cpu(unsigned int addr) {
>>  #endif
>>  int grspwpci_interrupt_handler(int irq, void *arg);
>> +int grspwpci_register(struct ambapp_bus *bus);
> Same here. These function prototypes should properly be moved to a
> header file e.g. grspw_pci.h?
Agreed. If they are private, they should be static. If they are public,
they should
be in a .h.
>>  #include "grspw.c"
>> diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
>> index 63cac35..440f8da 100644
>> --- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
>> +++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
>> @@ -1,3 +1,6 @@
>> +#include <apbuart_pci.h>
>>  #undef DEBUG
>> @@ -21,6 +24,8 @@ void apbuartpci_interrupt_handler(int irq, void *arg);
>>  /* AMBA Bus is clocked using the PCI clock (33.3MHz) */
>>  #define SYS_FREQ_HZ 33333333
>> +int apbuartpci_register(struct ambapp_bus *bus);
> And here too.
>>  #include "apbuart.c"
>>  int apbuart_pci_register(struct ambapp_bus *bus)
>> 1.7.9.5
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
