[PATCH] bsps/sparc: Add common gnat handler function prototype.
Daniel Cederman cederman at gaisler.com
Fri Mar 14 08:52:54 UTC 2014
So I should place gnatcommon.h in
c/src/lib/libbsp/sparc/shared/include/bsp instead?
On 2014-03-13 15:23, Joel Sherrill wrote:
> On 3/13/2014 9:14 AM, Daniel Cederman wrote:
>> Moved prototype for __gnat_install_handler and __gnat_install_handler_common to common header file.
>>   c/src/lib/libbsp/sparc/Makefile.am                 |    1 +
>>   c/src/lib/libbsp/sparc/erc32/Makefile.am           |    1 +
>>   c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c   |    2 +-
>>   c/src/lib/libbsp/sparc/erc32/preinstall.am         |    4 ++++
>>   c/src/lib/libbsp/sparc/leon2/Makefile.am           |    1 +
>>   c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c   |    2 +-
>>   c/src/lib/libbsp/sparc/leon2/preinstall.am         |    4 ++++
>>   c/src/lib/libbsp/sparc/leon3/Makefile.am           |    1 +
>>   c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c   |    2 +-
>>   c/src/lib/libbsp/sparc/leon3/preinstall.am         |    4 ++++
>>   c/src/lib/libbsp/sparc/shared/gnatcommon.c         |    1 +
>>   c/src/lib/libbsp/sparc/shared/include/gnatcommon.h |   19 +++++++++++++++++++
>>   12 files changed, 39 insertions(+), 3 deletions(-)
>>   create mode 100644 c/src/lib/libbsp/sparc/shared/include/gnatcommon.h
>> diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
>> index 3508d89..3d433fb 100644
>> --- a/c/src/lib/libbsp/sparc/Makefile.am
>> +++ b/c/src/lib/libbsp/sparc/Makefile.am
>> @@ -6,6 +6,7 @@ SUBDIRS = @RTEMS_BSP_FAMILY@
>>   EXTRA_DIST =
>>   EXTRA_DIST += shared/gnatcommon.c
>> +EXTRA_DIST += shared/include/gnatcommon.h
>>   EXTRA_DIST += shared/start/start.S
>>   # Interrupt
>> diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
>> index 677c44e..5f161e1 100644
>> --- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
>> +++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
>> @@ -39,6 +39,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
>>   libbsp_a_SOURCES += ../../sparc/shared/irq_asm.S
>>   # gnatsupp
>>   libbsp_a_SOURCES += gnatsupp/gnatsupp.c ../../sparc/shared/gnatcommon.c
>> +include_HEADERS += ../shared/include/gnatcommon.h
>>   # console
>>   libbsp_a_SOURCES += console/erc32_console.c ../../shared/console.c \
>>       ../../shared/console_select.c  ../../shared/console_control.c \
>> diff --git a/c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c b/c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c
>> index ebab714..74403cd 100644
>> --- a/c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c
>> +++ b/c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c
>> @@ -4,7 +4,7 @@
>>    * Jiri Gaisler, ESA/ESTEC, 17-02-1999.
>> -void __gnat_install_handler_common( int, int );
>> +#include "../../shared/include/gnatcommon.h"
> Since you installed this as <gnatcommon.h>, it should use <>
> not ".../.../"
> Also I think it should have been installed as <bsp/gnatcommon.h>
> Other than that, this patch is Ok.
>>   void
>>   __gnat_install_handler (void)
>> diff --git a/c/src/lib/libbsp/sparc/erc32/preinstall.am b/c/src/lib/libbsp/sparc/erc32/preinstall.am
>> index a235296..b3f4f22 100644
>> --- a/c/src/lib/libbsp/sparc/erc32/preinstall.am
>> +++ b/c/src/lib/libbsp/sparc/erc32/preinstall.am
>> @@ -73,6 +73,10 @@ $(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base $(PROJECT_LIB)/$(d
>>   	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.base
>>   PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.base
>> +$(PROJECT_INCLUDE)/gnatcommon.h: ../shared/include/gnatcommon.h $(PROJECT_INCLUDE)/$(dirstamp)
>> +	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/gnatcommon.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/gnatcommon.h
>>   $(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>   	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
>> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
>> index c08f159..50e61fb 100644
>> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
>> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
>> @@ -56,6 +56,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
>>   # gnatsupp
>>   # console
>>   libbsp_a_SOURCES += console/console.c console/debugputs.c
>>   # clock
>> diff --git a/c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c b/c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c
>> index b3a7c18..c0ee1e2 100644
>> --- a/c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c
>> +++ b/c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c
>> @@ -10,7 +10,7 @@
>> -void __gnat_install_handler_common (int t1, int t2);
>>    *  Avoid trap 0x18 which is used by the clock tick, and
>> diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
>> index 84aa2b4..2fe4f1c 100644
>> --- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
>> +++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
>> @@ -141,6 +141,10 @@ $(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base $(PROJECT_LIB)/$(d
>> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> index 3c87e18..7fbf5ba 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> @@ -45,6 +45,7 @@ libbsp_a_SOURCES += startup/cpucounter.c
>>   # gnatsupp
>>   # AMBA bus
>>   include_HEADERS += include/amba.h
>>   include_HEADERS += ../../sparc/shared/include/ambapp.h
>> diff --git a/c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c b/c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c
>> index 4b1056f..0e65ee7 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c
>> @@ -8,7 +8,7 @@
>> +#include <gnatcommon.h>
>> diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
>> index 0005edd..ed6e96d 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
>> +++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
>> @@ -85,6 +85,10 @@ $(PROJECT_LIB)/linkcmds.ngmp: startup/linkcmds.ngmp $(PROJECT_LIB)/$(dirstamp)
>>   	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.ngmp
>>   PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.ngmp
>>   $(PROJECT_INCLUDE)/amba.h: include/amba.h $(PROJECT_INCLUDE)/$(dirstamp)
>>   	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/amba.h
>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/amba.h
>> diff --git a/c/src/lib/libbsp/sparc/shared/gnatcommon.c b/c/src/lib/libbsp/sparc/shared/gnatcommon.c
>> index 4128982..32d9de9 100644
>> --- a/c/src/lib/libbsp/sparc/shared/gnatcommon.c
>> +++ b/c/src/lib/libbsp/sparc/shared/gnatcommon.c
>> @@ -11,6 +11,7 @@
>>   #include <rtems/bspIo.h>
>>   #include <signal.h>
>>   #include <stdlib.h>
>>    * Synchronous trap handler. Map the trap number of SIGFPE, SIGSEGV
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/gnatcommon.h b/c/src/lib/libbsp/sparc/shared/include/gnatcommon.h
>> new file mode 100644
>> index 0000000..1a04449
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/shared/include/gnatcommon.h
>> @@ -0,0 +1,19 @@
>> +#ifndef __GNATCOMMON_H
>> +#define __GNATCOMMON_H
>> + * Support for gnat/rtems interrupts and exception handling.
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif
>> +void __gnat_install_handler (void);
>> +void __gnat_install_handler_common (int t1, int t2);
>> +#ifdef __cplusplus
>> +#endif
>> +#endif
