[PATCH 4/7-V2] smc91111: Move driver attach prototype to header file.
Daniel Cederman
cederman at gaisler.com
Mon Mar 17 07:41:54 UTC 2014
Also signal to compiler that the start variable in lan91cxx_recv is only used when debugging.
.../lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c | 5 -----
.../sparc/leon2/leon_smc91111/leon_smc91111.c | 5 -----
.../sparc/leon3/leon_smc91111/leon_smc91111.c | 3 ---
c/src/libchip/network/smc91111.c | 8 +++++---
c/src/libchip/network/smc91111exp.h | 3 +++
5 files changed, 8 insertions(+), 16 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c b/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c
index 026a56c..995bf0b 100644
--- a/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c
+++ b/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c
@@ -64,11 +64,6 @@ scmv91111_configuration_t mpc5554_scmv91111_configuration = {
(void *)0
-int _rtems_smc91111_driver_attach(
- struct rtems_bsdnet_ifconfig *config,
- scmv91111_configuration_t *scm_config
* Attach an SMC91111 driver to the system
diff --git a/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c
index ad74c9a..abf1efc 100644
--- a/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c
+++ b/c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c
@@ -40,11 +40,6 @@ scmv91111_configuration_t leon_scmv91111_configuration = {
1 /* autoneg */
diff --git a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
index 9b9961d..a57de8f 100644
--- a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
+++ b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
@@ -23,9 +23,6 @@ scmv91111_configuration_t leon_scmv91111_configuration = {
1 /* autoneg */
-int _rtems_smc91111_driver_attach (struct rtems_bsdnet_ifconfig *config,
- scmv91111_configuration_t * scm_config);
diff --git a/c/src/libchip/network/smc91111.c b/c/src/libchip/network/smc91111.c
index 2332688..aec0f56 100644
--- a/c/src/libchip/network/smc91111.c
+++ b/c/src/libchip/network/smc91111.c
@@ -82,7 +82,7 @@ static void lan91cxx_phy_configure(struct lan91cxx_priv_data *cpd);
#define max(l,r) ((l) > (r) ? (l) : (r))
/* \ ------------- Interrupt ------------- \ */
-void lan91cxx_interrupt_handler(void *arg)
+static void lan91cxx_interrupt_handler(void *arg)
struct lan91cxx_priv_data *cpd = arg;
unsigned short irq, event;
@@ -153,6 +153,9 @@ static void lan91cxx_recv(struct lan91cxx_priv_data *cpd, struct mbuf *m)
rxd_t *data = NULL, val;
#if DEBUG & 64
rxd_t lp = 0;
+#else
+ /* start is only read with debug enabled */
+ (void)start;
#endif
struct mbuf *n;
dbg_prefix = "<";
@@ -247,7 +250,6 @@ static void lan91cxx_recv(struct lan91cxx_priv_data *cpd, struct mbuf *m)
db64_printf(" \n");
#endif
val = get_data(cpd); /* Read control word (and potential data) unconditionally */
@@ -657,7 +659,7 @@ static void sendpacket(struct ifnet *ifp, struct mbuf *m)
dbg_prefix = "";
-void smc91111_txDaemon(void *arg)
+static void smc91111_txDaemon(void *arg)
struct ifnet *ifp = &cpd->arpcom.ac_if;
diff --git a/c/src/libchip/network/smc91111exp.h b/c/src/libchip/network/smc91111exp.h
index 11feaab..08e086d 100644
--- a/c/src/libchip/network/smc91111exp.h
+++ b/c/src/libchip/network/smc91111exp.h
@@ -18,6 +18,9 @@ typedef struct scmv91111_configuration {
#endif
} scmv91111_configuration_t;
+int _rtems_smc91111_driver_attach (struct rtems_bsdnet_ifconfig *config,
+ scmv91111_configuration_t * scm_config);
#endif /* _SMC_91111_EXP_H_ */
1.7.9.5
