[PATCH 17/25] gen68360/include/bsp.h: Remove rtems_bsp_delay()
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Mar 20 18:29:13 UTC 2014
c/src/lib/libbsp/m68k/gen68360/include/bsp.h | 16 ----------------
1 files changed, 0 insertions(+), 16 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/gen68360/include/bsp.h b/c/src/lib/libbsp/m68k/gen68360/include/bsp.h
index ed05ade..093cd93 100644
--- a/c/src/lib/libbsp/m68k/gen68360/include/bsp.h
+++ b/c/src/lib/libbsp/m68k/gen68360/include/bsp.h
@@ -56,22 +56,6 @@ extern int rtems_scc1_driver_attach (struct rtems_bsdnet_ifconfig *config, int a
#define RTEMS_BSP_NETWORK_DRIVER_NAME "scc1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_scc1_driver_attach
- * Simple spin delay in microsecond units for device drivers.
- * This is very dependent on the clock speed of the target.
-#define rtems_bsp_delay( microseconds ) \
- { register uint32_t _delay=(microseconds); \
- register uint32_t _tmp=123; \
- __asm__ volatile( "0: \
- nbcd %0 ; \
- nbcd %0 ; \
- dbf %1,0b" \
- : "=d" (_tmp), "=d" (_delay) \
- : "0" (_tmp), "1" (_delay) ); \
extern rtems_isr_entry M68Kvec[]; /* vector table address */
/* functions */
1.7.1
