[PATCH 24/25] no_bsp/include/bsp.h: Remove rtems_bsp_delay()
Thu Mar 20 18:29:20 UTC 2014
 c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h |   13 +++----------
 1 files changed, 3 insertions(+), 10 deletions(-)
diff --git a/c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h b/c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h
index a172fca..1d9a587 100644
--- a/c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h
+++ b/c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h
@@ -3,7 +3,9 @@
  *  This include file contains all board IO definitions.
  *  XXX : put yours in here
  *  COPYRIGHT (c) 1989-1999.
  *  On-Line Applications Research Corporation (OAR).
@@ -26,15 +28,6 @@ extern "C" {
 #include <rtems/console.h>
 #include <rtems/clockdrv.h>
- *  Simple spin delay in microsecond units for device drivers.
- *  This is very dependent on the clock speed of the target.
-#define rtems_bsp_delay( microseconds ) \
 /* functions */
 rtems_isr_entry set_vector(                     /* returns old vector */
1.7.1
