[PATCH 15/25] gen68302/include/bsp.h: Remove rtems_bsp_delay()
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Mar 20 18:29:11 UTC 2014
c/src/lib/libbsp/m68k/gen68302/include/bsp.h | 23 +----------------------
1 files changed, 1 insertions(+), 22 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/gen68302/include/bsp.h b/c/src/lib/libbsp/m68k/gen68302/include/bsp.h
index c258e58..b0e2fe6 100644
--- a/c/src/lib/libbsp/m68k/gen68302/include/bsp.h
+++ b/c/src/lib/libbsp/m68k/gen68302/include/bsp.h
@@ -6,12 +6,7 @@
* @brief Global BSP definitions.
-/* bsp.h
- * This include file contains all board IO definitions.
- * XXX : put yours in here
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
@@ -43,22 +38,6 @@ extern "C" {
* @brief GEN68302 support.
- * Simple spin delay in microsecond units for device drivers.
- * This is very dependent on the clock speed of the target.
-#define rtems_bsp_delay( microseconds ) \
- { register uint32_t _delay=(microseconds); \
- register uint32_t _tmp=123; \
- __asm__ volatile( "0: \
- nbcd %0 ; \
- nbcd %0 ; \
- dbf %1,0b" \
- : "=d" (_tmp), "=d" (_delay) \
- : "0" (_tmp), "1" (_delay) ); \
/* Constants */
#define RAM_START 0
1.7.1
