[PATCH 07/10] relnotes/install.texi: Change rtems.com to rtems.org
Thu Mar 20 18:31:19 UTC 2014
 doc/relnotes/install.texi |    6 +++---
 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/doc/relnotes/install.texi b/doc/relnotes/install.texi
index 205f3d4..833a58c 100644
--- a/doc/relnotes/install.texi
+++ b/doc/relnotes/install.texi
@@ -1,5 +1,5 @@
 @c
- at c  COPYRIGHT (c) 1989-2011.
+ at c  COPYRIGHT (c) 1989-2014.
 @c  On-Line Applications Research Corporation (OAR).
 @c  All rights reserved.
@@ -35,8 +35,8 @@ Throughout the rest of this manual
 within the RTEMS distribution.  For persons using the ftp
 distribution found on the primary ftp site for RTEMS,
 <RTEMS_distribution> are found under this directory
- at uref{ftp://ftp.rtems.com/pub/rtems/}.  HTTP access to the
-ftp site is available via @uref{http://www.rtems.com/ftp/pub/rtems}.
+ at uref{ftp://ftp.rtems.org/pub/rtems/}.  HTTP access to the
+ftp site is available via @uref{http://www.rtems.org/ftp/pub/rtems}.
 The archive files for RTEMS Release @value{VERSION} are found
 under the directory <RTEMS_distribution>.  This directory
1.7.1
