Youren Shen
shenyouren at gmail.com
Fri Mar 21 08:55:29 UTC 2014
Hi,Philipp:
I think it's my responsibility to fix this bug. And it's a good opportunity
to know the change of RTEMS.
However, I can begin to do it only in weekend due to some course at
college. :-(
Best Regards.
Youren Shen.
On Fri, Mar 21, 2014 at 4:53 PM, Philipp Eppelt <
philipp.eppelt at mailbox.tu-dresden.de> wrote:
> Hi Youren,
> git apply $attached_patch$
> I have a meeting to attend to, so I don't have the time to test it right
> now; will do it later. I hope it works.
> Cheers,
> Philipp
> On 03/21/2014 09:30 AM, Philipp Eppelt wrote:
> > Hi Youren,
> > I just looked at a fresh RTEMS clone. I thought the patch eliminating
> > sensitive instructions from the x86 paravirt target was merged, but it
> > looks like it wasn't.
> > I am working on an up to date patch. The old one, doesn't work anymore.
> > Cheers,
> > Philipp
> > On 03/21/2014 03:27 AM, Youren Shen wrote:
> >> Hi,Gedare:
> >> Thank you for your suggestion.
> >> In the function bootcart() in the file
> >> c/src/lib/libbsp/shared/bootcard.c, there is a
> >> function rtems_interrupt_disable which will be compiled to be
> >> instruction "cli" in x86 platform. And the cli is also the reason why I
> >> failed to startup POK partitions [1].
> >> Now I consider there are two ways to solve the problem.One I called
> >> functional solution, The other I called instruction solution. That is
> >> say , we replace some functions with sensitive instructions or replace
> >> every instructions. The first approach seems to be easy to
> >> implementation, however maybe not easy to transplant to other platform.
> >> I'm more familiar with the second approach, but to implement the whole
> >> project will spent more time. And once we finish this project, we can
> >> easily implement paravirtualization to other platform. And if design
> >> properly, will also easily to transplant RTEMS to other hypervisor.
> >> Or we have to mix this two solutions, This needs more discussion and
> >> should be thoughtful and deliberate.
> >> By the way, I'm going to post a blog about the POK initiation and
> >> interrupt system this weekend.
> >> [1].
> http://listengine.tuxfamily.org/lists.tuxfamily.org/pok/2014/03/msg00003.html
> >> Best Regards.
> >> Youren Shen.
> >> On Thu, Mar 20, 2014 at 10:04 PM, Gedare Bloom <gedare at rtems.org
> >> <mailto:gedare at rtems.org>> wrote:
> >> Youren Shen,
> >> It looks like the problem you are having is that RTEMS "hello world"
> >> executes a sensitive instruction? There should not be any such
> >> instruction when you use the --enable-paravirt option, so you need
> to
> >> determine where this instruction gets executed. The best way to do
> >> this is to hook gdb up to an executing qemu. You can start qemu with
> >> some -S option to prevent the boot sequence from starting to give
> you
> >> some time to load gdb and connect it to qemu's gdbserver socket.
> once
> >> you have done this, you should be able to set some breakpoints in
> the
> >> pok/hello application to step through the program, or you might be
> >> able to catch exceptions before they get raised to pok. The other
> >> option should be that inside pok there should be some information
> >> about the source of the exception that you might investigate.
> >> Please keep us informed about your progress on this problem,
> >> Thanks,
> >> Gedare
> >> On Thu, Mar 20, 2014 at 9:16 AM, Youren Shen <shenyouren at gmail.com
> >> <mailto:shenyouren at gmail.com>> wrote:
> >> > Hi,Gedare
> >> > Maybe it's because my qemu version is low or POK has change the
> >> kernel, I
> >> > can't run the RTEMS Hello world on my computer anymore.
> >> > The problem has spent me a few days to find. More details see this
> >> mails.
> >> > [1].
> http://listengine.tuxfamily.org/lists.tuxfamily.org/pok/2014/03/msg00000.html
> >> > Best Regards.
> >> > Youren Shen.
> >> > On Thu, Mar 20, 2014 at 8:03 PM, Philipp Eppelt
> >> > <philipp.eppelt at mailbox.tu-dresden.de
> >> <mailto:philipp.eppelt at mailbox.tu-dresden.de>> wrote:
> >> >> On 03/16/2014 01:01 PM, Youren Shen wrote:
> >> >> > Hi, every one:
> >> >> > I have write a blog about how to build the RTEMS on POK.
> >> However, the
> >> >> > RTEMS can't run on POK now. Here is my blog[1].
> >> >> > [1].
> http://huaiyusched.github.io/rtems/2014/03/15/how-to-run-rtems-on-pok/
> >> >> > Best Regards.
> >> >> > Youren Shen.
> >> >> Hi Youren,
> >> >> great!
> >> >> A screenshot of RTEMS HelloWorld sample running on POK would be
> even
> >> >> better :).
> >> >> Cheers,
> >> >> Philipp
> >> > Best Regards.
> >> > Youren Shen.
> >> Best Regards.
> >> Youren Shen.
> > rtems-devel mailing list
> > rtems-devel at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140321/99b8b5eb/attachment-0001.html>
