[PATCH 3/3] libcsupport: Use POSIX keys for gxx-wrapper-key-functions.
Christian Mauderer
Christian.Mauderer at embedded-brains.de
Fri Mar 21 13:00:30 UTC 2014
Am 21.03.2014 13:30, schrieb Gedare Bloom:
> On Fri, Mar 21, 2014 at 5:26 AM, Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
>> With this patch C++ applications now eventually need additional POSIX-keys and
>> POSIX-key-value-pairs configured.
> I'm not sure where, but this fact should be somewhere in user documentation.
I've already thought about that but I haven't found a place where the
documentation would make sense.
I wanted to add it at least to the release notes as soon as the patch
has been applied.
>> cpukit/libcsupport/include/rtems/gxx_wrappers.h | 10 +--
>> cpukit/libcsupport/src/gxx_wrappers.c | 111 +++++++++++-------------
>> testsuites/libtests/gxx01/gxx01.scn | 8 +-
>> testsuites/libtests/gxx01/init.c | 29 ++++++-
>> testsuites/sptests/spfatal24/spfatal24.doc | 2 +-
>> testsuites/sptests/spfatal24/testcase.h | 6 +-
>> testsuites/sptests/sptls02/init.cc | 3 +
>> 7 files changed, 91 insertions(+), 78 deletions(-)
>> diff --git a/cpukit/libcsupport/include/rtems/gxx_wrappers.h b/cpukit/libcsupport/include/rtems/gxx_wrappers.h
>> index 801223e..0efb341 100644
>> --- a/cpukit/libcsupport/include/rtems/gxx_wrappers.h
>> +++ b/cpukit/libcsupport/include/rtems/gxx_wrappers.h
>> @@ -21,6 +21,8 @@
>> #ifndef __GCC_WRAPPERS_h
>> #define __GCC_WRAPPERS_h
>> +#include <pthread.h>
>> #ifdef __cplusplus
>> extern "C" {
>> #endif /* __cplusplus */
>> @@ -36,14 +38,8 @@ extern "C" {
>> * These typedefs should match with the ones defined in the file
>> * gcc/gthr-rtems.h in the gcc distribution.
>> - * FIXME: T.S, 2007/01/31: -> gcc/gthr-rtems.h still declares
>> - * void * __gthread_key_t;
>> -typedef struct __gthread_key_ {
>> - void *val; /* this is switched with the task */
>> - void (*dtor)(void*); /* this remains in place for all tasks */
>> -} __gthread_key, *__gthread_key_t;
>> +typedef void *__gthread_key_t;
>> typedef int __gthread_once_t;
>> typedef void *__gthread_mutex_t;
>> typedef void *__gthread_recursive_mutex_t;
>> diff --git a/cpukit/libcsupport/src/gxx_wrappers.c b/cpukit/libcsupport/src/gxx_wrappers.c
>> index 0b9cad6..963b712 100644
>> --- a/cpukit/libcsupport/src/gxx_wrappers.c
>> +++ b/cpukit/libcsupport/src/gxx_wrappers.c
>> @@ -31,6 +31,7 @@
>> #include <rtems/gxx_wrappers.h>
>> #include <rtems/score/onceimpl.h>
>> +#include <errno.h>
>> #include <stdlib.h>
>> #include <rtems.h>
>> @@ -49,82 +50,64 @@ int rtems_gxx_once(__gthread_once_t *once, void (*func) (void))
>> int rtems_gxx_key_create (__gthread_key_t *key, void (*dtor) (void *))
>> - rtems_status_code status;
>> - /* Ok, this can be a bit tricky. We are going to return a "key" as a
>> - * pointer to the buffer that will hold the value of the key itself.
>> - * We have to to this, because the others functions on this interface
>> - * deal with the value of the key, as used with the POSIX API.
>> - /* Do not pull your hair, trust me this works. :-) */
>> - __gthread_key_t new_key = (__gthread_key_t) malloc( sizeof( *new_key ) );
>> - *key = new_key;
>> - new_key->val = NULL;
>> - new_key->dtor = dtor;
>> + int eno;
>> + pthread_key_t *pkey;
>> + pkey = malloc( sizeof( *pkey ) );
>> + *key = pkey;
>> + if ( pkey == NULL )
>> + return ENOMEM;
>> #ifdef DEBUG_GXX_WRAPPERS
>> printk(
>> - "gxx_wrappers: create key=%x, dtor=%x, new_key=%x\n", key, dtor, new_key
>> + "gxx_wrappers: create key=%x, dtor=%x, pkey=%x\n", key, dtor, pkey
>> #endif
>> - /* register with RTEMS the buffer that will hold the key values */
>> - status = rtems_task_variable_add( RTEMS_SELF, (void **)new_key, dtor );
>> - if ( status == RTEMS_SUCCESSFUL )
>> - return 0;
>> + eno = pthread_key_create(pkey, dtor);
>> + if ( eno != 0 ) {
>> + free( pkey );
>> + *key = NULL;
>> - free( new_key );
>> - return -1;
>> + return eno;
>> int rtems_gxx_key_delete (__gthread_key_t key)
>> + int eno = 0;
>> + pthread_key_t *pkey = key;
>> - printk( "gxx_wrappers: delete key=%x\n", key );
>> + printk( "gxx_wrappers: delete key=%x\n", pkey );
>> #endif
>> - status = rtems_task_variable_delete( RTEMS_SELF, (void **)key );
>> - if ( status == RTEMS_SUCCESSFUL ) {
>> - /* Hmm - hopefully all tasks using this key have gone away... */
>> - if ( key ) free( *(void **)key );
>> - return 0;
>> + if ( pkey == NULL ) {
>> + return EINVAL;
>> - key = NULL;
>> - return 0;
>> + eno = pthread_key_delete(*pkey);
>> + if ( eno == 0 ) {
>> + free( pkey );
>> + return eno;
>> void *rtems_gxx_getspecific(__gthread_key_t key)
>> - void *p= 0;
>> - status = rtems_task_variable_get( RTEMS_SELF, (void **)key, &p );
>> - /* We do not have to do this, but what the heck ! */
>> - p= key->val;
>> - } else {
>> - /* fisrt time, always set to zero, it is unknown the value that the others
>> - * threads are using at the moment of this call
>> - status = rtems_task_variable_add( RTEMS_SELF, (void **)key, key->dtor );
>> - if ( status != RTEMS_SUCCESSFUL ) {
>> - _Terminate(
>> - INTERNAL_ERROR_CORE,
>> - true,
>> - INTERNAL_ERROR_GXX_KEY_ADD_FAILED
>> - key->val = (void *)0;
>> + void *p = NULL;
>> + if ( pkey != NULL ) {
>> + p = pthread_getspecific( *pkey );
>> printk(
>> "gxx_wrappers: getspecific key=%x, ptr=%x, id=%x\n",
>> - key,
>> + pkey,
>> p,
>> rtems_task_self()
>> @@ -134,25 +117,33 @@ void *rtems_gxx_getspecific(__gthread_key_t key)
>> int rtems_gxx_setspecific(__gthread_key_t key, const void *ptr)
>> + int eno;
>> + return EINVAL;
>> + eno = pthread_setspecific( *pkey, ptr );
>> printk(
>> "gxx_wrappers: setspecific key=%x, ptr=%x, id=%x\n",
>> - key,
>> + pkey,
>> ptr,
>> rtems_task_self()
>> #endif
>> - /* now let's set the proper value */
>> - key->val = (void *)ptr;
>> - return 0;
>> + if ( eno != 0 ) {
>> + _Terminate(
>> + INTERNAL_ERROR_CORE,
>> + true,
>> + INTERNAL_ERROR_GXX_KEY_ADD_FAILED
>> - return -1;
>> + return 0;
>> diff --git a/testsuites/libtests/gxx01/gxx01.scn b/testsuites/libtests/gxx01/gxx01.scn
>> index cb9f6b5..f831881 100644
>> --- a/testsuites/libtests/gxx01/gxx01.scn
>> +++ b/testsuites/libtests/gxx01/gxx01.scn
>> @@ -22,10 +22,14 @@ Call once method the second time
>> rtems_gxx_key_create(&key, NULL) - OK
>> rtems_gxx_key_delete(key) - OK
>> rtems_gxx_key_create(&key, key_dtor) - OK
>> -rtems_gxx_setspecific() - OK
>> +rtems_gxx_getspecific(key) not set - OK
>> +rtems_gxx_setspecific(key, 0x1234) - OK
>> rtems_gxx_getspecific(key) already existing - OK
>> rtems_gxx_getspecific(key) non-existent - OK
>> -rtems_gxx_key_delete(key) - OK
>> +rtems_gxx_key_delete(key) - NOT OK
>> +rtems_gxx_setspecific(NULL, 0x1234) - NOT OK
>> +rtems_gxx_getspecific(NULL) - OK
>> +rtems_gxx_key_delete(NULL) - NOT OK
>> *** END OF TEST GXX 01 ***
>> diff --git a/testsuites/libtests/gxx01/init.c b/testsuites/libtests/gxx01/init.c
>> index cc704ef..5c7a3c1 100644
>> --- a/testsuites/libtests/gxx01/init.c
>> +++ b/testsuites/libtests/gxx01/init.c
>> @@ -11,6 +11,7 @@
>> #include "config.h"
>> #endif
>> +#include <errno.h>
>> #include <tmacros.h>
>> #include "test_support.h"
>> @@ -140,7 +141,11 @@ void test_key(void)
>> sc = rtems_gxx_key_create(&key, key_dtor);
>> rtems_test_assert( sc == 0 );
>> - puts( "rtems_gxx_setspecific() - OK" );
>> + puts( "rtems_gxx_getspecific(key) not set - OK" );
>> + p = rtems_gxx_getspecific(key);
>> + rtems_test_assert( p == NULL );
>> + puts( "rtems_gxx_setspecific(key, 0x1234) - OK" );
>> sc = rtems_gxx_setspecific(key, (void *)0x1234);
>> @@ -151,7 +156,8 @@ void test_key(void)
>> puts( "rtems_gxx_key_delete(key) - OK" );
>> sc = rtems_gxx_key_delete(key);
>> - rtems_test_assert( key_dtor_ran == true );
>> + /* pthread_key man-page: the dtor should _not_ be called */
>> + rtems_test_assert( key_dtor_ran != true );
>> key = calloc( 1, sizeof( *key ) );
>> rtems_test_assert( key != NULL );
>> @@ -160,9 +166,21 @@ void test_key(void)
>> p = rtems_gxx_getspecific( key );
>> - puts( "rtems_gxx_key_delete(key) - OK" );
>> + puts( "rtems_gxx_key_delete(key) - NOT OK" );
>> sc = rtems_gxx_key_delete( key );
>> - rtems_test_assert( sc == 0 );
>> + rtems_test_assert( sc != 0 );
>> + puts( "rtems_gxx_setspecific(NULL, 0x1234) - NOT OK" );
>> + sc = rtems_gxx_setspecific( NULL, (void *)0x1234 );
>> + rtems_test_assert( sc == EINVAL );
>> + puts( "rtems_gxx_getspecific(NULL) - OK" );
>> + p = rtems_gxx_getspecific( NULL );
>> + puts( "rtems_gxx_key_delete(NULL) - NOT OK" );
>> + sc = rtems_gxx_key_delete( NULL );
>> rtems_task Init(
>> @@ -197,6 +215,9 @@ rtems_task Init(
>> #define CONFIGURE_MAXIMUM_SEMAPHORES 2
>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> +#define CONFIGURE_MAXIMUM_POSIX_KEYS 1
>> +#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 1
>> #define CONFIGURE_INIT
>> #include <rtems/confdefs.h>
>> diff --git a/testsuites/sptests/spfatal24/spfatal24.doc b/testsuites/sptests/spfatal24/spfatal24.doc
>> index ad6eda5..0ff898d 100644
>> --- a/testsuites/sptests/spfatal24/spfatal24.doc
>> +++ b/testsuites/sptests/spfatal24/spfatal24.doc
>> @@ -12,7 +12,7 @@ test set name: spfatal24
>> directives:
>> - rtems_gxx_getspecific();
>> + rtems_gxx_setspecific();
>> concepts:
>> diff --git a/testsuites/sptests/spfatal24/testcase.h b/testsuites/sptests/spfatal24/testcase.h
>> index 6ac8906..226ccc9 100644
>> --- a/testsuites/sptests/spfatal24/testcase.h
>> +++ b/testsuites/sptests/spfatal24/testcase.h
>> @@ -18,9 +18,7 @@
>> void force_error()
>> - __gthread_key key;
>> + pthread_key_t key = -1;
>> - rtems_workspace_greedy_allocate( NULL, 0 );
>> - rtems_gxx_getspecific( &key );
>> + rtems_gxx_setspecific( &key, NULL );
>> diff --git a/testsuites/sptests/sptls02/init.cc b/testsuites/sptests/sptls02/init.cc
>> index d704190..2c9e283 100644
>> --- a/testsuites/sptests/sptls02/init.cc
>> +++ b/testsuites/sptests/sptls02/init.cc
>> @@ -251,6 +251,9 @@ extern "C" void Init(rtems_task_argument arg)
>> +#define CONFIGURE_MAXIMUM_POSIX_KEYS 2
>> +#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 2
>> 1.8.4.5
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
embedded brains GmbH
Christian Mauderer Dornierstr. 4
D-82178 Puchheim Germany
email: Christian.Mauderer at embedded-brains.de
Phone: +49-89-18 94 741-18
Fax: +49-89-18 94 741-08
