C++ Exception Test Failure on Sparc SIS.
JunBeom Kim (Coressent) jbkim at coressentkorea.co.kr
Fri Mar 21 15:12:06 UTC 2014
Dear Gedare,
Thank you for your reply.
First of all, I set breakpoint in _Unwind_RaiseException. also, software
crash is occurred in _Unwind_RaiseException function certainly.
When I see location of address 0x02034A43, it's location is
classify_object_over_fdes.
As I check google search with "classify_object_over_fdes C++ exception", I
am guessing that there is a bug in binutils.
On referencing, I built sparc-rtems4.11-xxx toolchain according to
http://www.rtems.org/wiki/index.php/Building_Tools
If possible, please let me know your advice for next step.
Best Regards,
JunBeom
-----Original Message-----
From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of
Gedare Bloom
Sent: Friday, March 21, 2014 9:38 PM
To: JunBeom Kim (Coressent)
Cc: RTEMS Devel
Subject: Re: C++ Exception Test Failure on Sparc SIS.
On Fri, Mar 21, 2014 at 2:42 AM, JunBeom Kim (Coressent)
<jbkim at coressentkorea.co.kr> wrote:
> Dear Sir,
> After I built RTEMS kernel for Sparc SIS, I downloaded examples-v2.
> Also, I am testing cxx example.
> When I test cxx example on SIS, C++ exception(throw->catch) is not
working.
> Console message is below;
> SIS - SPARC instruction simulator 2.7.5,  copyright Jiri Gaisler 1995
> Bug-reports to jgais at wd.estec.esa.nl
> sis> load cxx_throw.exe
> sis> go
> resuming at 0x02000000
> Hey I'm in base class constructor number 1 for 0x2081318.
> Hey I'm in base class constructor number 2 for 0x2081320.
> Hey I'm in derived class constructor number 3 for 0x2081320.
> *** CONSTRUCTOR/DESTRUCTOR TEST ***
> Hey I'm in base class constructor number 4 for 0x208c724.
> Hey I'm in base class constructor number 5 for 0x208c71c.
> Hey I'm in base class constructor number 6 for 0x208c714.
> Hey I'm in base class constructor number 7 for 0x208c70c.
> Hey I'm in derived class constructor number 8 for 0x208c70c.
> Testing a C++ I/O stream
> before try block
> Unexpected trap ( 7) at address 0x02034A54
> memory address not aligned
> IU in error mode (257)
>    826787 02036f14  91d02000  Address 0x02036f14 is out of bounds.
> I want to know how to receive this problem.
Use sparc-rtems-4.11-objdump -d option to disassemble the executable binary,
then see what is the location of address 0x02034A54. Set a breakpoint in
debugger at that function, see what memory address is causing the alignment
fault. Determine where the memory address gets computed, and why there is an
alignment problem. The compiler should not cause an alignment problem unless
it gets the wrong flags or the code uses some tricks to coerce data types,
so perhaps the code where the fault happens has got a bad set of compiler
flags.
That's where I would start anyway. Good luck, Gedare
> Best Regards,
> JunBeom Kim
> rtems-devel mailing list
> rtems-devel at rtems.org
